PTCE Best Study Material - PTCE Exam Pattern
Posted at 2/9/2026 04:18:39
P.S. Free & New PTCE dumps are available on Google Drive shared by PrepAwayETE: https://drive.google.com/open?id=1u1Gn7ULkJoJo8NIDuZJ847UnTK9VODO1
When you buy things online, you must ensure the security of online purchasing, otherwise your rights will be harmed. Our PTCE study tool purchase channel is safe, we invite experts to design a secure purchasing process for our PTCE qualification test, and the performance of purchasing safety has been certified, so personal information of our clients will be fully protected. We provide you with global after-sales service. If you have any questions that need to be consulted, you can contact our staff at any time to help you solve problems related to our PTCE qualification test. Our thoughtful service is also part of your choice of buying our learning materials. Once you choose to purchase our PTCE test guides, you will enjoy service.
It is common in modern society that many people who are more knowledgeable and capable than others finally lost some good opportunities for development because they didn’t obtain the PTCE Certification. The prerequisite for obtaining the PTCE certification is to pass the exam, but not everyone has the ability to pass it at one time. Because of not having appropriate review methods and review materials, or not grasping the rule of the questions, so many candidates eventually failed to pass even if they have devoted much effort.
PTCE Exam Pattern | Accurate PTCE Study MaterialThe PTCE training pdf provided by PrepAwayETE is really the best reference material you can get from anywhere. The experts of PrepAwayETE are trying their best to develop and research the high quality and PTCE exam preparation material to help you strengthen technical job skills. When you complete your payment, you will receive an email attached with PTCE practice pdf, then you can instantly download it and install on your phone or computer for study. The high efficiency preparation by PTCE exam dumps can ensure you 100% pass with ease.
Medical Tests Pharmacy Technician Certification Exam Sample Questions (Q270-Q275):NEW QUESTION # 270
A patient presents the following prescription:
Lisinopril 20 mg tablets
Take 1 tab PO q8h
#30 with 12 refills
In order to fill this prescription, the pharmacy must clarify the:
- A. medication strength.
- B. route of administration.
- C. directions for use.
- D. number of refills.
Before dispensing a prescription, pharmacy technicians and pharmacists must ensure that it iscomplete, clear, and unambiguousto avoid medication errors.
* Medication isinopril
* Strength:20 mg (Clear)
* Route O (by mouth) (Clear)
* Directions:Take 1 tab PO q8h (every 8 hours)#(Needs Clarification)
* Quantity:30 tablets (Clear)
* Refills:12 (Needs verification but is not the main issue)
* Lisinopril is an ACE inhibitorused for hypertension and heart failure.
* Standard dosing is once daily (q24h), not every 8 hours (q8h).
* A frequency of q8h (three times daily) is unusual and could be a prescribing error.
* Pharmacists must verify with the prescriber before dispensing.
* (A) Directions for use#Correct - "q8h" is incorrect for lisinopril and needs clarification.
* (B) Medication strength#Incorrect - "20 mg" is a standard strength for lisinopril.
* (C) Route of administration#Incorrect - " O" (by mouth) is correct.
* (D) Number of refills#Incorrect - While 12 refills is uncommon for chronic medications, it is not the primary issue.
* Lisinopril Prescribing Information (FDA): https://www.accessdata.fda.gov
* Institute for Safe Medication Practices (ISMP) - High-Alert Medications:https://www.ismp.org
* PTCB Exam Content Outline - Prescription Processing & Clarification
Analysis of the Prescription:Why the Directions Need Clarification:Analysis of Answer Choices:References for Pharmacy Technicians:
NEW QUESTION # 271
A prescription for 1 pint of rifampin 1% suspension. 2 tbsp daily, will be compounded using how many 300 mg capsules of the drug?
1 pint =473 mL(since 1 pint = 16 fluid ounces, and 1 fluid ounce = 29.5735 mL).A1% suspensionmeans1 g (1000 mg) of rifampin per 100 mLof suspension.
* Total dose required:2 tbsp daily =30 mL per day(1 tbsp = 15 mL).
* Total volume of the suspension:473 mL
* Total rifampin required 473 mL × 1000 mg) ÷ 100 mL =4730 mg
Each rifampin capsule contains300 mg.So,4730 mg ÷ 300 mg/capsule = 15.77 capsules, which rounds up to16 capsules.
Thus, the correct answer isC. 32 capsules(since the full pint must be compounded).
#Reference harmacy compounding principles; PTCE study materials on dosage calculations.
NEW QUESTION # 272
Therapeutic equivalence (TE) codesmay be found in:
- A. The Orange Book.
- B. The package insert.
- C. Remington: The Science and Practice of Pharmacy.
- D. Safety Data Sheets (SDSs).
Comprehensive and Detailed Step-by-Step Explanation:
The FDA Orange BookprovidesTherapeutic Equivalence (TE) codesto indicate whether a generic drug is equivalentto a brand-name drug.
#Explanation of Answer Choices:#B. The Orange Book#Correct.Liststherapeutic equivalence (TE) codesfor FDA-approved generics.#A. Remington# Incorrect.Pharmacy reference book, not used for TE codes.#C. SDSs# Incorrect.Used for chemical safety, not drug equivalence.#D. Package insert# Incorrect.
Does not contain TE codes.
#Reference:
* FDA Orange Book
* PTCB Exam: Therapeutic Equivalence
NEW QUESTION # 273
Colchicineis indicated for the treatment of:
- A. Hypothyroidism.
- B. Gout flares.
- C. Peripheral neuropathy.
- D. Hyperlipidemia.
Colchicine (Colcrys, Mitigare)is used to treatacute gout flaresbyreducing inflammation caused by uric acid crystalsin the joints.
#Explanation of Answer Choices:#B. Gout flares#Correct.Colchicine is ananti-inflammatory drug specific to gout.#A. Hyperlipidemia# Incorrect.Statins are used for hyperlipidemia.#C. Hypothyroidism# Incorrect.
Levothyroxine is used for hypothyroidism.#D. Peripheral neuropathy# Incorrect.Gabapentin or pregabalin are used for nerve pain.
#Reference:
* American College of Rheumatology (ACR) Gout Treatment Guidelines
* PTCB Exam: Pharmacology for Technicians
NEW QUESTION # 274
The use of amoxicillin/clavulanate is contraindicated in patients who:
- A. Have high blood pressure.
- B. Have a hypersensitivity to beta-lactams.
- C. Are pregnant or breastfeeding.
- D. Are hypersensitive to quinolones.
Amoxicillin/clavulanate is a penicillin-class (#-lactam) antibiotic. Its labeling includes a contraindication in patients with a history of hypersensitivity to #-lactams (e.g., penicillins; often caution with cephalosporins due to cross-reactivity). Allergy to quinolones (B) is unrelated pharmacologically. Pregnancy or breastfeeding (C) is not an absolute contraindication (risk/benefit assessment is used). Hypertension (D) is not relevant.
Therefore, beta-lactam hypersensitivity is the clear contraindication.
References (Pharmacy Technician documents/Study Guides):
* Anti-infectives section of technician study guides: #-lactam structure, class allergies, and contraindications.
* Drug labeling standards: contraindication for penicillin hypersensitivity in amoxicillin-containing products.
* ISMP safety guidance: allergy screening for #-lactam antibiotics.
NEW QUESTION # 275
All exam questions that contained in our Medical Tests PTCE study engine you should know are written by our professional specialists with three versions to choose from: the PDF, the Software and the APP online. In case there are any changes happened to the Medical Tests PTCE Exam, the experts keep close eyes on trends of it and compile new updates constantly.
PTCE Exam Pattern: https://www.prepawayete.com/Medical-Tests/PTCE-practice-exam-dumps.html
While, you should know that the questions & answers are part from the complete exam dumps, so you can just take the Medical Examination PTCE pdf demo as a reference, So, you can rest assured to buy our Medical Examination PTCE pass4sure dumps and enjoy your shopping experience, Due to the shortage of useful practice materials or being scanty for them, many candidates may choose the bad quality exam materials, but more and more candidates can choose our PTCE study materials, Why Choose PrepAwayETE PTCE Exam Pattern Do you maintain 100% Guarantee on PrepAwayETE PTCE Exam Pattern.com products?
Continuous Integration changed the way software PTCE is written, Examples of Past Solar Events, While, you should know that the questions & answers are part from the complete exam dumps, so you can just take the Medical Examination PTCE PDF demo as a reference.
Get Access To Medical Tests PTCE Questions Using Three Different FormatsSo, you can rest assured to buy our Medical Examination PTCE pass4sure dumps and enjoy your shopping experience, Due to the shortage of useful practice materials or being scanty for them, many candidates may choose the bad quality exam materials, but more and more candidates can choose our PTCE study materials.
Why Choose PrepAwayETE Do you maintain 100% Guarantee on PrepAwayETE.com products, All PTCE practice materials fall within the scope of this exam for your information.
- Enhance Your Preparation with Medical Tests PTCE Practice Test Engine 🤚 Easily obtain ☀ PTCE ️☀️ for free download through ▶ [url]www.exam4labs.com ◀ 👊Online PTCE Training[/url]
- 100% Pass Quiz 2026 Medical Tests PTCE – Marvelous Best Study Material 🐐 Immediately open ➤ [url]www.pdfvce.com ⮘ and search for 「 PTCE 」 to obtain a free download 🥑Visual PTCE Cert Exam[/url]
- Exam PTCE Actual Tests 🍢 Visual PTCE Cert Exam 🐼 Latest PTCE Exam Experience 👘 Easily obtain free download of ➥ PTCE 🡄 by searching on ▷ [url]www.prepawayete.com ◁ 🐕
TCE Valid Examcollection[/url] - Free PDF 2026 Authoritative PTCE: Pharmacy Technician Certification Exam Best Study Material 🕘 Easily obtain free download of 「 PTCE 」 by searching on “ [url]www.pdfvce.com ” 🏞Exam PTCE Actual Tests[/url]
- The Best PTCE Best Study Material - New - Trustable PTCE Materials Free Download for Medical Tests PTCE Exam 🦃 Go to website 「 [url]www.practicevce.com 」 open and search for ( PTCE ) to download for free ⛰
TCE Exams Dumps[/url] - Free PDF 2026 Authoritative PTCE: Pharmacy Technician Certification Exam Best Study Material 🦖 Search for ▷ PTCE ◁ and download exam materials for free through 「 [url]www.pdfvce.com 」 ⛹
TCE Free Practice[/url] - Official PTCE Practice Test 📱 Visual PTCE Cert Exam 😧 PTCE Verified Answers 🥉 Search for 「 PTCE 」 and download exam materials for free through ➡ [url]www.verifieddumps.com ️⬅️ 🍲New PTCE Braindumps Files[/url]
- Free PDF Medical Tests - PTCE - Unparalleled Pharmacy Technician Certification Exam Best Study Material 🛳 Copy URL ( [url]www.pdfvce.com ) open and search for 《 PTCE 》 to download for free 🏤Latest PTCE Exam Experience[/url]
- Enhance Your Preparation with Medical Tests PTCE Practice Test Engine 🌍 Immediately open ▶ [url]www.examdiscuss.com ◀ and search for ✔ PTCE ️✔️ to obtain a free download 🕵
TCE Free Practice[/url] - PTCE Latest Braindumps Sheet 📪 Exam PTCE Actual Tests 🧂 PTCE Latest Braindumps Sheet 🎏 Open ▶ [url]www.pdfvce.com ◀ enter ▷ PTCE ◁ and obtain a free download 🤶
TCE Testking Exam Questions[/url] - Braindumps PTCE Downloads 🎅 Online PTCE Training 🏦 Exam PTCE Actual Tests 🎄 Open ⇛ [url]www.dumpsquestion.com ⇚ and search for ➡ PTCE ️⬅️ to download exam materials for free ⛷Valid Braindumps PTCE Ebook[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, nativemediastudios.com, www.stes.tyc.edu.tw, ikanashop.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Medical Tests PTCE dumps are available on Google Drive shared by PrepAwayETE: https://drive.google.com/open?id=1u1Gn7ULkJoJo8NIDuZJ847UnTK9VODO1
