[Hardware] Free Updates To Microsoft AZ-204 Exam Dumps For 1 year
126
【Hardware】 Free Updates To Microsoft AZ-204 Exam Dumps For 1 year
Posted at 2/9/2026 05:18:33      View:86 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4SureQuiz AZ-204 PDF Dumps and AZ-204 Exam Engine Free Share: https://drive.google.com/open?id=1iL9pQJeCjGuiPW6NHvDPIGNMrxaNRYyO
The modern Microsoft world is changing its dynamics at a fast pace. To stay and compete in this challenging market, you have to learn and enhance your in-demand skills. Fortunately, with the Developing Solutions for Microsoft Azure (AZ-204) certification exam you can do this job nicely and quickly. To do this you just need to enroll in the Microsoft AZ-204 Certification Exam and put all your efforts to pass the Developing Solutions for Microsoft Azure (AZ-204) certification exam.
We all know that AZ-204 study materials can help us solve learning problems. But if it is too complex, not only can’t we get good results, but also the burden of students' learning process will increase largely. Unlike those complex and esoteric materials, our AZ-204 Study Materials are not only of high quality, but also easy to learn. Our study materials do not have the trouble that users can't read or learn because we try our best to present those complex and difficult test sites in a simple way.
Reliable AZ-204 Test Camp & AZ-204 Cost Effective DumpsAs is known to us, our company is professional brand established for compiling the AZ-204 exam materials for all candidates. The AZ-204 guide files from our company are designed by a lot of experts and professors of our company in the field. We can promise that the AZ-204 certification braindumps of our company have the absolute authority in the study materials market. We believe that the study materials designed by our company will be the most suitable choice for you. You can totally depend on the AZ-204 Guide files of our company when you are preparing for the exam.
Microsoft Developing Solutions for Microsoft Azure Sample Questions (Q317-Q322):NEW QUESTION # 317
You develop a gateway solution for a public facing news API.
The news API back end is implemented as a RESTful sen/ice and hosted in an Azure App Service instance.
You need to configure back-end authentication for the API Management service instance.
Which target and gateway credential type should you use? To answer, drag the appropriate values to the correct parameters. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Box 1: Azure Resource
Box 2: Client cert
API Management allows to secure access to the back-end service of an API using client certificates.
https://docs.microsoft.com/en-us ... agement-rest-api-ba
NEW QUESTION # 318
You develop Azure solutions.
You must grant a virtual machine (VM) access to specific resource groups in Azure Resource Manager.
You need to obtain an Azure Resource Manager access token.
Solution: Run the Invoke-RestMethod cmdlet to make a request to the local managed identity for Azure resources endpoint.
Does the solution meet the goal?
  • A. No
  • B. Yes
Get an access token using the VM's system-assigned managed identity and use it to call Azure Resource Manager You will need to use PowerShell in this portion.
* In the portal, navigate to Virtual Machines and go to your Windows virtual machine and in the Overview, click Connect.
* Enter in your Username and Password for which you added when you created the Windows VM.
* Now that you have created a Remote Desktop Connection with the virtual machine, open PowerShell in the remote session.
* Using the Invoke-WebRequest cmdlet, make a request to the local managed identity for Azure resources endpoint to get an access token for Azure Resource Manager.
Example:
$response = Invoke-WebRequest -Uri '
http://169.254.169.254/metadata/ ... -version=2018-02-01
&resource=https://management.azure.com/' -Method GET -Headers @{Metadata="true"} Reference:
https://docs.microsoft.com/en-us ... tutorial-windows-vm
NEW QUESTION # 319
Your company is migrating applications to Azure. The IT department must allow internal developers to communicate with Microsoft support.
The service agents of the IT department must only have view resources and create support ticket permissions to all subscriptions. A new custom role must be created by reusing a default role definition and changing the permissions.
You need to create the custom role.
To answer, select the appropriate options in the answer area.
Box 1: Set-AzureRmRoleDefinition Input-File C:SupportRole.json
The Set-AzureRmRoleDefinition cmdlet updates an existing custom role in Azure Role-Based Access Control.
Provide the updated role definition as an input to the command as a JSON file or a PSRoleDefinition object.
The role definition for the updated custom role MUST contain the Id and all other required properties of the role even if they are not updated: DisplayName, Description, Actions, AssignableScope Box 2: "*/read*."* Microsoft.Support/*" Microsoft.Support/* Create and manage support tickets
"Microsoft.Support" role definition azure
NEW QUESTION # 320
You have an Azure Function app named App1 written in C# and an Application Insights workspace named Workspaces App1 is implemented with Application Insights enabled and is configured to send its telemetry to Workspaces You observe that App1 telemetry collection regularly exceeds monthly quotas of Workspacel.
You need to ensure that the telemetry volume remains within the monthly quotas of Workspacel.
NEW QUESTION # 321
A company is developing a Java web app. The web app code is hosted in a GitHub repository located at
https://github.com/Contoso/webapp.
The web app must be evaluated before it is moved to production. You must deploy the initial code release to a deployment slot named staging.
You need to create the web app and deploy the code.
How should you complete the commands? To answer, select the appropriate options in the answer area.
Box 1: group
# Create a resource group.
az group create --location westeurope --name myResourceGroup
Box 2: appservice plan
# Create an App Service plan in STANDARD tier (minimum required by deployment slots).
az appservice plan create --name $webappname --resource-group myResourceGroup --sku S1 Box 3: webapp
# Create a web app.
az webapp create --name $webappname --resource-group myResourceGroup
--plan $webappname
Box 4: webapp deployment slot
#Create a deployment slot with the name "staging".
az webapp deployment slot create --name $webappname --resource-group myResourceGroup
--slot staging
Box 5: webapp deployment source
# Deploy sample code to "staging" slot from GitHub.
az webapp deployment source config --name $webappname --resource-group myResourceGroup
--slot staging --repo-url $gitrepo --branch master --manual-integration References:
https://docs.microsoft.com/en-us ... staging-environment
NEW QUESTION # 322
Please don’t worry about the purchase process because it’s really simple for you. The first step is to select the AZ-204 test guide, choose your favorite version, the contents of different versionof our AZ-204 exam questions are the same, but different in their ways of using. We have three different versions for you to choose: PDF, Soft and APP versions. The second step: fill in with your email and make sure it is correct, because we send our AZ-204 learn tool to you through the email. Later, if there is an update, our system will automatically send you the latest AZ-204 version.
Reliable AZ-204 Test Camp: https://www.pass4surequiz.com/AZ-204-exam-quiz.html
Our Microsoft experts have curated an amazing AZ-204 exam guide for passing the AZ-204 exam, It will create many career opportunities and benefits for you by AZ-204 pass exam files, If IT workers can pass exams and obtain certifications, AZ-204 exam dumps will be worth to purchasing, right, You will have enough time to practice our AZ-204 real questions because there are correct answers and detailed explanations in our learning materials.
Learn about new add-on features for Dynamics, including MarketingPilot, NetBreeze, and Yammer, Determining File Format Requirements, Our Microsoft experts have curated an amazing AZ-204 Exam Guide for passing the AZ-204 exam.
Updated AZ-204 - Developing Solutions for Microsoft Azure Flexible Testing EngineIt will create many career opportunities and benefits for you by AZ-204 pass exam files, If IT workers can pass exams and obtain certifications, AZ-204 exam dumps will be worth to purchasing, right?
You will have enough time to practice our AZ-204 real questions because there are correct answers and detailed explanations in our learning materials, Pass4SureQuiz can save you from facing these issues with its real Microsoft AZ-204 exam questions.
P.S. Free & New AZ-204 dumps are available on Google Drive shared by Pass4SureQuiz: https://drive.google.com/open?id=1iL9pQJeCjGuiPW6NHvDPIGNMrxaNRYyO
Posted at 2/24/2026 11:41:30        Only Author  2#
Just had to hit like—this content is so good. The Trusted UiPath-AAAv1 exam resource test questions are the key to career success—now shared for free!
