[General] 156-215.82 Exam Preview - Reliable 156-215.82 Exam Cost
94
【General】 156-215.82 Exam Preview - Reliable 156-215.82 Exam Cost
Posted at 2/9/2026 06:25:31      View:111 | Replies:0        Print      Only Author   [Copy Link] 1#
The desktop practice test format comes with all features of the web-based practice exam. Pass4sures has made all of the different formats so the exam applicants won't face any additional issues and prepare themselves with the real questions and crack CheckPoint 156-215.82 Certification test for the betterment of their futures. One can set the time and questions numbers of practice exams (desktop and web-based) according to their needs. Pass4sures is giving multiple mock exams to the customers so they can practice and make themselves perfect.
We have to admit that the processional certificates are very important for many people to show their capacity in the highly competitive environment. If you have the CheckPoint certification, it will be very easy for you to get a promotion. If you hope to get a job with opportunity of promotion, it will be the best choice chance for you to choose the 156-215.82 study question from our company. Because our study materials have the enough ability to help you improve yourself and make you more excellent than other people. The 156-215.82 learning dumps from our company have helped a lot of people get the certification and achieve their dreams. Now you also have the opportunity to contact with the Check Point Certified Security Administrator - R82 test guide from our company.
Reliable CheckPoint 156-215.82 Exam Cost | 156-215.82 Exam TestkingI know you must want to get a higher salary, but your strength must match your ambition! The opportunity is for those who are prepared! 156-215.82 exam questions can help you improve your strength! You will master the most practical knowledge in the shortest possible time. It is also very easy if you want to get the 156-215.82 certificate. As long as you buy our 156-215.82 study braindumps and practice step by step, you are bound to pass the exam.
CheckPoint Check Point Certified Security Administrator - R82 Sample Questions (Q237-Q242):NEW QUESTION # 237
A SAM rule Is implemented to provide what function or benefit?
  • A. Allow security audits.
  • B. Monitor sequence activity.
  • C. Handle traffic as defined in the policy.
  • D. Block suspicious activity.
A SAM (Suspicious Activity Monitoring) rule is implemented to provide the function or benefit of blocking suspicious activity. A SAM rule is a rule that defines an action to be taken by the firewall when it detects a suspicious activity, such as an attack, a scan, or a policy violation. The action can be blocking, dropping, rejecting, or logging the traffic that triggered the suspicious activity. A SAM rule can be created manually or automatically by other security features, such as IPS, Anti-Bot, or SmartEvent.[SAM Rules], [Suspicious Activity Rules]
NEW QUESTION # 238
Fill in the bank: In Office mode, a Security Gateway assigns a remote client to an IP address once___________.
  • A. the user connects
  • B. office mode is initiated
  • C. the user requests a connection
  • D. the user connects and authenticates
In Office mode, a Security Gateway assigns a remote client to an IP address once the user connects and authenticates. Office mode allows a remote client to get an IP address from the internal network of the organization.The IP address is assigned during the IKE negotiation, after the user has successfully authenticated with the Security Gateway3. The other options are not correct timings for assigning an IP address in Office mode. Office Mode
NEW QUESTION # 239
Which is NOT an encryption algorithm that can be used in an IPSEC Security Association (Phase 2)?
  • A. AES-CBC-256
  • B. AES-GCM-128
  • C. AES-GCM-256
The answer is B because AES-CBC-256 is not a supported encryption algorithm for IPsec Security Associations (Phase 2) in R81.The supported encryption algorithms are AES-GCM-128, AES-GCM-256, AES-CBC-128, 3DES, and NULL3Check Point R81 VPN Administration Guide
NEW QUESTION # 240
What is the best sync method in the ClusterXL deployment?
  • A. Use 2 clusters + 1st sync + 2nd sync
  • B. Use 1 cluster + 1st sync
  • C. Use 1 dedicated sync interface
  • D. Use 3 clusters + 1st sync + 2nd sync + 3rd sync
The best sync method in the ClusterXL deployment is to use one dedicated sync interface56. This method provides optimal performance and reliability for synchronization traffic.Using multiple sync interfaces is not recommended as it increases CPU load and does not provide 100% sync redundancy5. Using multiple clusters is not a sync method, but a cluster topology. Sync Redundancy in ClusterXL,Best Practice for HA sync interface
NEW QUESTION # 241
You have created a rule at the top of your Rule Base to permit Guest Wireless access to the Internet. However, when guest users attempt to reach the Internet, they are not seeing the splash page to accept your Terms of Service, and cannot access the Internet. How can you fix this?
  • A. On the Security Management Server object, check the box "Identity Logging"
  • B. On the firewall object, Legacy Authentication screen, check "Enable Identity Captive Portal"
  • C. In the Captive Portal screen of Global Properties, check "Enable Identity Captive Portal"
  • D. Right click Accept in the rule, select "More", and then check "Enable Identity Captive Portal"
Identity Captive Portal is a Check Point Identity Awareness web portal, to which users connect with their web browser to log in and authenticate, when using Browser-Based Authentication2.To enable Identity Captive Portal for a specific rule, you need to right click Accept in the rule, select "More", and then check "Enable Identity Captive Portal"3. Identity Awareness Administration Guide R80,Identity awareness with captive portal in Checkpoint R80
NEW QUESTION # 242
The 156-215.82 certification verifies that you are a skilled professional. Pass4sures product is designed by keeping all the rules and regulations in focus that CheckPoint publishes. Our main goal is that you can memorize the actual CheckPoint 156-215.82 Exam Question to complete the Check Point Certified Security Administrator - R82 (156-215.82) test in time with extraordinary grades.
Reliable 156-215.82 Exam Cost: https://www.pass4sures.top/CCSA/156-215.82-testking-braindumps.html
Exam simulation, If you have any concerns about our Reliable 156-215.82 Exam Cost - Check Point Certified Security Administrator - R82 exam prep, you can first try the free demo of our Reliable 156-215.82 Exam Cost - Check Point Certified Security Administrator - R82 exam questions, and then make a decision whether to choose our Reliable 156-215.82 Exam Cost - Check Point Certified Security Administrator - R82 braindumps2go vce as your training materials, Candidates who don't study from real dumps questions fail to clear the Reliable 156-215.82 Exam Cost - Check Point Certified Security Administrator - R82 examination in a short time.
By Navaid Shamsee, David Klebanov, Hesham Fayed, Ahmed Afrose, 156-215.82 Well Prep Ozden Karakok, Everything But the Kitchen Sync, Exam simulation, If you have any concerns about our Check Point Certified Security Administrator - R82 exam prep, you can first try the free demo of our Check Point Certified Security Administrator - R82 Exam 156-215.82 Questions, and then make a decision whether to choose our Check Point Certified Security Administrator - R82 braindumps2go vce as your training materials.
2026 156-215.82: Accurate Check Point Certified Security Administrator - R82 Exam PreviewCandidates who don't study from real dumps questions fail to clear the Check Point Certified Security Administrator - R82 examination in a short time, Many examinees may find PDF version or VCE version for 156-215.82 study material.
We provide CheckPoint 156-215.82 exam product in three different formats to accommodate diverse learning styles and help candidates prepare successfully for the 156-215.82 exam.
