[General] Confluent CCAAK Valid Torrent & CCAAK Reliable Exam Syllabus
94
【General】 Confluent CCAAK Valid Torrent & CCAAK Reliable Exam Syllabus
Posted at 2/9/2026 08:38:37      View:117 | Replies:2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TestBraindump CCAAK dumps for free: https://drive.google.com/open?id=1DC80__KweazCvUsN96Y_DJ69bZskSPSI
Our product’s passing rate is 99% which means that you almost can pass the test with no doubts. The reasons why our CCAAK study materials’ passing rate is so high are varied. Firstly, our test bank includes two forms and they are the PDF test questions which are selected by the senior lecturer, published authors and professional experts and the practice test software which can test your mastery degree of our CCAAK Study Materials at any time. The two forms cover the syllabus of the entire test. Our questions and answers include all the questions which may appear in the exam and all the approaches to answer the questions. So we provide the strong backing to help clients to help them pass the test.
To give you an idea before the TestBraindump exam questions purchase, we are offering a free Confluent CCAAK exam questions demo facility. This demo download facility is available for all three TestBraindump exam question formats. Moreover, we also offer up to 1 year of CCAAK Free Exam Questions updates. If you think the CCAAK exam questions can help you in CCAAK exam preparation then take your buying decision and start preparation. Best of luck!!!
CCAAK Reliable Exam Syllabus - New CCAAK Test CramThe TestBraindump aids students in passing the test on their first try by giving them the real questions in three formats, 24/7 support team assistance, free demo, up to 1 year of free updates, and the satisfaction guarantee. As a result of its persistent efforts in providing candidates with actual CCAAK Exam Questions, TestBraindump has become one of the best platforms to prepare for the Confluent CCAAK exam successfully. One must prepare with TestBraindump exam questions if one wishes to pass the CCAAK exam on their first attempt.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q26-Q31):NEW QUESTION # 26
Kafka Connect is running on a two node cluster in distributed mode. The connector is a source connector that pulls data from Postgres tables (users/payment/orders), writes to topics with two partitions, and with replication factor two. The development team notices that the data is lagging behind.
What should be done to reduce the data lag*?
The Connector definition is listed below:
"name": "confluent-postgresql-source",
"connector class": "PostgresSource",
"topic.prefix": "postgresql_",
& nbsp;& nbsp;& nbsp;...
"db.name": "postgres",
"table.whitelist": "users.payment.orders",
"timestamp.column.name": "created_at",
"output.data format": "JSON",
"db.timezone": "UTC",
"tasks.max": "1"
  • A. Increase the number of Connect Nodes.
  • B. Increase the number of partitions.
  • C. Increase the number of Connect Tasks (tasks max value).
  • D. Increase the replication factor and increase the number of Connect Tasks.
The connector is currently configured with "tasks.max": "1", which means only one task is handling all tables (users, payment, orders). This can create a bottleneck and lead to lag. Increasing tasks.max allows Kafka Connect to parallelize work across multiple tasks, which can pull data from different tables concurrently and reduce lag.
NEW QUESTION # 27
Which secure communication is supported between the REST proxy and REST clients?
  • A. Kerberos
  • B. TLS (HTTPS)
  • C. MD5
  • D. SCRAM
NEW QUESTION # 28
Your Kafka cluster has four brokers. The topic t1 on the cluster has two partitions, and it has a replication factor of three. You create a Consumer Group with four consumers, which subscribes to t1.
In the scenario above, how many Controllers are in the Kafka cluster?
  • A. two
  • B. three
  • C. Four
  • D. One
In a Kafka cluster, only one broker acts as the Controller at any given time. The Controller is responsible for managing cluster metadata, such as partition leadership and broker status. Even if the cluster has multiple brokers (in this case, four), only one is elected as the Controller, and others serve as regular brokers. If the current Controller fails, another broker is automatically elected to take its place.
NEW QUESTION # 29
An employee in the reporting department needs assistance because their data feed is slowing down. You start by quickly checking the consumer lag for the clients on the data stream.
Which command will allow you to quickly check for lag on the consumers?
  • A. bin/kafka-reassign-partitions.sh
  • B. bin/kafka-consumer-group-throughput.sh
  • C. bin/kafka-consumer-lag.sh
  • D. bin/kafka-consumer-groups.sh
The kafka-consumer-groups.sh script is used to inspect consumer group details, including consumer lag, which indicates how far behind a consumer is from the latest data in the partition.
The typical usage is bin/kafka-consumer-groups.sh --bootstrap-server <broker> --describe --group <group_id>
NEW QUESTION # 30
You want to increase Producer throughput for the messages it sends to your Kafka cluster by tuning the batch size ('batch size') and the time the Producer waits before sending a batch ('linger.ms').
According to best practices, what should you do?
  • A. Decrease 'batch.size' and increase 'linger.ms'
  • B. Increase 'batch.size' and increase 'linger.ms'
  • C. Increase 'batch.size' and decrease 'linger.ms'
  • D. Decrease 'batch.size' and decrease 'linger.ms'
Increasing batch.size allows the producer to accumulate more messages into a single batch, improving compression and reducing the number of requests sent to the broker.
Increasing linger.ms gives the producer more time to fill up batches before sending them, which improves batching efficiency and throughput.
This combination is a best practice for maximizing throughput, especially when message volume is high or consistent latency is not a strict requirement.
NEW QUESTION # 31
The above formats of TestBraindump are made to help customers prepare as per their unique styles and crack the Confluent Certified Administrator for Apache Kafka (CCAAK) exam certification on the very first attempt. Our Confluent Certified Administrator for Apache Kafka (CCAAK) questions product is getting updated regularly as per the original Confluent Certified Administrator for Apache Kafka (CCAAK) practice test’s content. So that customers can prepare according to the latest Confluent Certified Administrator for Apache Kafka (CCAAK) exam content and pass it with ease.
CCAAK Reliable Exam Syllabus: https://www.testbraindump.com/CCAAK-exam-prep.html
At TestBraindump, we are committed to providing our clients with the actual and latest Confluent CCAAK exam questions, Confluent CCAAK Valid Torrent Questions And Answers Features:, The our TestBraindump Confluent CCAAK exam training materials, the verified exam, these questions and answers reflect the professional and practical experience of TestBraindump, Confluent CCAAK Valid Torrent it can help you to pass the IT exam.
Your guide will be Chief Methodologist Dean Leffingwell, the creator of CCAAK the framework, In this training course, expert author Jeff Sengstack introduces you to using the video and animation features in Photoshop.
Pass Guaranteed High-quality Confluent - CCAAK Valid TorrentAt TestBraindump, we are committed to providing our clients with the actual and latest Confluent CCAAK Exam Questions, Questions And Answers Features:, The our TestBraindump Confluent CCAAK exam training materials, the verified exam, these questions and answers reflect the professional and practical experience of TestBraindump.
it can help you to pass the IT exam, We offer you a wide range of study CCAAK Valid Torrent guides, braindumps and practice exams on the career-oriented IT certifications and help you pass exams without facing any difficulty.
DOWNLOAD the newest TestBraindump CCAAK PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1DC80__KweazCvUsN96Y_DJ69bZskSPSI
Posted at 2/10/2026 04:51:44        Only Author  2#
Liking it because this content is awesome. The Exam C_C4H56_2411 objectives pdf exam questions are free for everyone. Best of luck in your studies!
Posted at 2/13/2026 00:49:55        Only Author  3#
Thank you for sharing this incredible article, it’s truly breathtaking! 1z0-1054-25 valid study questions files provides helpful, in-depth content, offered free for your academic needs.
