[General] MuleSoft MCD-Level-1 Passing Score Feedback & MCD-Level-1 PDF Download
94
General MuleSoft MCD-Level-1 Passing Score Feedback & MCD-Level-1 PDF Download
Posted at 2/9/2026 09:06:28      View117 | Replies0        Print      Only Author   [Copy Link] 1#
It semms that it's a terrible experience for some candicates to prepare and take part in the MCD-Level-1 Exam, we will provide you the MCD-Level-1 training materials to help you pass it succesfully. The MCD-Level-1 training materials have the knowledgef points, it will help you to command the knowledge of the MuleSoft Certified Developer - Level 1 (Mule 4). The pass rate is above 98%, which can ensure you pass it. If you have the Desktop version, it stimulates the real environmet, you can konwn the exact situaton about the exam,and your nervous for it will be reduced.
Exam Target AudienceCandidates to apply for the MCD - Level 1 (Mule 4) test are aspiring developers wishing to build basic skills in technologies about Mule 4. Their skills should enable them to move from the platform to the studio for Anypoint and back.
Test DetailsThe MCD - Level 1 exam will be coming with 60 questions in the form of multiple-choices. This test will be in English and will endure for 2 hours. The minimum score needed to achieve a passing mark is 70% while the registration fee goes for $250. You are allowed to take such an exam up to five times, though you have to wait for 24 hours before making another attempt. Interestingly enough, this MuleSoft validation can also be purchased through Flexible Training Credits (FTC) priced at $250 per credit as well. So, if you go this route, you will need 1.00 FTC to get access to your test. You will have two years before you can renew your MCD - Level 1 (Mule 4) certification.
MuleSoft Certified Developer - Level 1 (Mule 4) Practice Vce - MCD-Level-1 Training Material & MuleSoft Certified Developer - Level 1 (Mule 4) Study GuideBased on high-quality products, our MCD-Level-1 guide torrent has high quality to guarantee your test pass rate, which can achieve 98% to 100%. MCD-Level-1 study tool is updated online by our experienced experts, and then sent to the user. So you dont need to pay extra attention on the updating of study materials. The data of our MCD-Level-1 exam torrent is forward-looking and can grasp hot topics to help users master the latest knowledge. If you fail the exam with MCD-Level-1 Guide Torrent, we promise to give you a full refund in the shortest possible time. Of course, if you are not reconciled and want to re-challenge yourself again, we will give you certain discount.
MuleSoft Certified Developer - Level 1 (Mule 4) Sample Questions (Q10-Q15):NEW QUESTION # 10
Refer to the exhibits. In the color flow , both the variable named color and payload are set to "red".
An HTTP POST request is then sent to the decideColor flow's HTTP Listener.
What is the payload value at the Logger component after the HTTP request completes?
  • A. Error message
  • B. red
  • C. blue
  • D. white
Correct answer is white.
Key thing to note here is that variables are not available to the called flow when it is invoked using HTTP request.
So the flow goes like below
1) Color variable is set to red
2) Payload is set to red
3) Child flow is called using HTTP request which means variables are not available in called flow (They would have been if flow reference activity would have been used)
4) Hence set payload activity will set payload to white as color variable is null
5) Payload returned in main flow is white.
6) So finally output of logger is white
NEW QUESTION # 11
What payload and quantity are togged at the end of the main flow?
  • A. [[1,2,3,4], 10]
  • B. [[order1, order2, order3, order4], 14]
  • C. [orderlorder2order3order4, 14]
  • D. [[1,2,3,4], 14]
NEW QUESTION # 12
Which out of below is not an asset?
  • A. Connector
  • B. Example
  • C. Exchange
  • D. Template
Exchange is the odd man out here. Rest all are type of asset
NEW QUESTION # 13
An organization is beginning to follow Mulesoft's recommended API led connectivity approach to use modern API to support the development and lifecycle of the integration solutions and to close the IT delivery gap.
What distinguishes between how modern API's are organized in a MuleSoft recommended API-led connectivity approach as compared to other common enterprise integration solutions?
  • A. The API interfaces are specified at a granularity intended for developers to consume specific aspect of integration processes
  • B. The APIO implementations are monitored with common tools, centralized monitoring and security systems
  • C. The API implementation are built with standards using common lifecycle and centralized configuration management tools
  • D. The API interfaces are specified as macroservices with one API representing all the business logic of an existing and proven end to end solution
Correct answer is The API interfaces are specified at a granularity intended for developers to consume specific aspect of integration processes
NEW QUESTION # 14
Refer to the exhibits. The Set Payload transformer in the addltem child flow uses DataWeave to create an order object.
What is the correct DataWeave code for the Set Payload transformer in the createOrder flow to use the addltem child flow to add a router call with the price of 100 to the order?
  • A. lookup( "addltern", { price: "100", item: "router", itemType: "cable" } )
  • B. addltem( { price: "100", item: "router", itemType: "cable" } )
  • C. lookup( "addltem", { payload: { price: "100", item: "router", itemType: "cable" } > )
  • D. addltem( { payload: { price: "100", item: "router", itemType: "cable" > } )
NEW QUESTION # 15
Our company has authoritative experts and experienced team in related industry. To give the customer the best service, all of our company's MCD-Level-1 learning materials are designed by experienced experts from various field, so our MCD-Level-1 Learning materials will help to better absorb the test sites. One of the great advantages of buying our product is that can help you master the core knowledge in the shortest time. At the same time, our MCD-Level-1 Learning Materials discard the most traditional rote memorization methods and impart the key points of the qualifying exam in a way that best suits the user's learning interests, this is the highest level of experience that our most authoritative think tank brings to our MCD-Level-1 learning materials users.
MCD-Level-1 PDF Download: https://www.dumpsvalid.com/MCD-Level-1-still-valid-exam.html
