Realistic Real MB-820 Testing Environment¨CPass MB-820 First Attempt
92
Posted at 2/9/2026 09:43:07      View£º100 | Replies£º1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft MB-820 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1Xv4-epyweqJ-oCFvzBtus_1vVxEMnVov
You can use this MB-820 simulation software without an internet connection after installation. Tracking and reporting features of our Microsoft MB-820 practice exam software makes it easier for you to identify and overcome mistakes. Customization feature of this format allows you to change time limits and questions numbers of mock exams.
If you have your own job and have little time to prepare for the exam, you can choose us. MB-820 exam bootcamp of us is high quality, and you just need to spend about 48to 72 hours, you can pass the exam. In addition, MB-820 exam bootcamp contains most of knowledge points of the exam, and you can also improve you professional ability in the process of learning. We offer you free update for 365 days after you buy MB-820 Exam Dumps. The update version will be sent to your email automatically.
Hot Real MB-820 Testing Environment & Useful Tips to help you pass Microsoft MB-820PrepAwayTest offers updated and real Microsoft MB-820 Exam Dumps for Microsoft Dynamics 365 Business Central Developer (MB-820) test takers who want to prepare quickly for the MB-820 examination. These actual MB-820 exam questions have been compiled by a team of professionals after a thorough analysis of past papers and current content of the MB-820 test. If students prepare with these valid MB-820 questions, they will surely become capable of clearing the MB-820 examination within a few days.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q121-Q126):NEW QUESTION # 121
After you answer a question in this section, you will NOT be able to return to it. As a result these questions will not appear in the review screen.
A company plans to optimize its permission sets.
The company has the following permission sets:
You need to provide the following implementation for a third permission set:
* Create a new Permission Set C that is a composite of Permission Set A and Permission Set B.
* Assign Permission Set C to a user.
You need to ensure that the user has only read access to the Job table.
Solution: Set the Included Permission Sets property to Permission Set B and the Excluded PermissionSets property to Permission Set A.
Does the solution meet the goal?
  • A. Yes
  • B. No
NEW QUESTION # 122
You need to determine If you have unwanted incoming web service calls in your tenant during the last seven days.
Which two KQL queries should you use? Each correct answer presents a complete solution.
  • A.
  • B.
  • C.
  • D.
  • E.
Answer: A,E
The task is to identify unwanted incoming web service calls during the last seven days. To do this, we need to look at KQL (Kusto Query Language) queries that would filter out web service calls based on the timestamp (to ensure the calls are within the last seven days) and by certain characteristics that would indicate they are unwanted, such as the wrong type of protocol (SOAP in this case, as Contoso Ltd. plans to dismiss using it).
Looking at the options:
Option A: This query selects all traces where the timestamp is within the last 7 days and where the custom dimension has a value of 'RT0008', and where the category is either 'ODataV4', 'ODataV3', or 'Api'. This query would show all API calls except SOAP, so it does not directly answer the question about unwanted calls.
Option B: This query filters for traces with a timestamp within the last 7 days, where 'RT0008' is present, and specifically looks for the category 'SOAP'. This query is correct because it directly targets SOAP calls, which are the unwanted calls according to Contoso Ltd.'s plans.
Option C: Similar to option B, this query filters for traces within the last 7 days and looks for 'RT0008' but uses the equality operator for the category 'SOAP'. This would also correctly return the unwanted SOAP calls.
Option D: This query also filters for traces within the last 7 days, but it excludes the 'ODataV4' category, which doesn't necessarily target the unwanted SOAP calls.
Option E: This query selects traces where the timestamp is within the last 7 days and the custom dimension has 'RT0008'. However, it filters out categories 'ODataV4' and 'Api', which does not directly help in identifying the unwanted SOAP calls.
Therefore, the queries that should be used to determine if there are unwanted incoming web service calls (SOAP calls) in the tenant during the last seven days are Options B and C. These queries are specific to identifying SOAP protocol usage, which is what Contoso Ltd. considers unwanted.
NEW QUESTION # 123
You are developing a test application to test the posting process of a sales order. You must provide the following implementation:
* Specify the value of post options (dialog: Ship, Invoice, Ship & Invoice) as Invoice.
* Perform calculations and values checking.
You need to complete the development of the test codeunit.
Which methods should you use? To answer, move the appropriate methods to the correct implementation.
You may use each method once, more than once, or not at all. You may need to move the split bar between panes or scroll to view content.
Specify the value of the post options as Invoice:
* Test
Perform calculations and values checking:
* Handler
In the context of Microsoft Dynamics 365 Business Central testing, the 'Test' attribute is used to mark a method as a test method. This is where you would specify the action or the behavior you're testing - in this case, setting the post options as Invoice. It's within these test methods that you would simulate setting the posting option to "Invoice" programmatically.
For performing calculations and checking values, you would use 'Handler' methods to handle specific business events or conditions that occur within the system, such as before or after posting a document. These handlers can ensure that calculations are done correctly and that all validation checks pass before the document is posted.
The 'Normal' method would be a standard method that could be involved in the posting process, ensuring that all business logic is correctly applied and that the calculations and value checks are as expected.
In a test codeunit, you would typically have test methods that call these handler and normal methods to verify the business logic in various scenarios, such as posting with different options or checking the results of calculations under different conditions.
NEW QUESTION # 124
You need to write an Upgrade codeunit and use the DataTransfer object to handle the data upgrade.
Which solution should you use for each requirement? To answer, select the appropriate options in the answer area.
Upgrade codeunit trigger: OnValidateUpgradePerDatabase
* Since the question specifies that you are handling data upgrades, and you need to use validation before upgrading at the database level, the correct choice is OnValidateUpgradePerDatabase. This method ensures that the upgrade process is validated before applying to the entire database, making it more efficient when data affects multiple companies or structures.
DataTransfer method to use: CopyRows
* CopyRows is the appropriate method when you are handling large data transfers between tables, especially in an upgrade scenario where you are migrating or transferring data from one table to another. It copies entire rows of data and is optimal for bulk data operations during upgrades.
NEW QUESTION # 125
Solution: Set the IncludedPermissionSets property to Permission Set A and the Excluded PermissionSets property to Permission SetB.
  • A. Yes
  • B. No
NEW QUESTION # 126
PrepAwayTest will give you confidence to pass Microsoft MB-820 test. Our Exam Preparation Material provides you everything the candidates will need to get the MB-820 certification. Our Microsoft MB-820 will provide you with exam questions with verified answers that reflect the actual exam. These questions and answers will help you to do preparation for taking a certification examination. High quality and Value for the MB-820 Exam: 100% guarantee to Pass Your Microsoft MB-820 exam and get your certification.
Exam MB-820 Simulator Fee: https://www.prepawaytest.com/Microsoft/MB-820-practice-exam-dumps.html
The contents of MB-820 learning questions are carefully compiled by the experts according to the content of the MB-820 examination syllabus of the calendar year, MB-820 study guide files will help you get a certification easily, We have heard that someone devotes most of their spare time preparing for MB-820 exam certification, but the effects are seems not ideal, Microsoft Exam MB-820 Simulator Fee Exam MB-820 Simulator Fee - Microsoft Dynamics 365 Business Central Developer Printable PDF.
Before you decide to buy, you can download the free demo of MB-820 dumps pdf to learn about our products, Having trouble precisely aligning the source point?
The contents of MB-820 learning questions are carefully compiled by the experts according to the content of the MB-820 examination syllabus of the calendar year.
Real MB-820 Testing Environment - Unparalleled Exam Microsoft Dynamics 365 Business Central Developer Simulator FeeMB-820 study guide files will help you get a certification easily, We have heard that someone devotes most of their spare time preparing for MB-820 exam certification, but the effects are seems not ideal.
Microsoft Microsoft Dynamics 365 Business Central Developer Printable PDF, It means you can MB-820 take this mock test via any browser like MS Edge, Firefox, Chrome, Internet Explorer, and Safari.
BTW, DOWNLOAD part of PrepAwayTest MB-820 dumps from Cloud Storage: https://drive.google.com/open?id=1Xv4-epyweqJ-oCFvzBtus_1vVxEMnVov
Posted at 2/16/2026 20:35:45        Only Author  2#
I found the article to be incredibly beneficial to my understanding. Thanks to the CDCS latest visual cert exam test, I reached new career heights¡ªnow, I¡¯m offering it to you for free!
