[General] Exam EFM Simulator Online - EFM Examinations Actual Questions
89
General Exam EFM Simulator Online - EFM Examinations Actual Questions
Posted at 2/9/2026 13:20:17      View94 | Replies0        Print      Only Author   [Copy Link] 1#
Stop wasting time on meaningless things. There are a lot wonderful things waiting for you to do. You still have the opportunities to become successful and wealthy. The EFM study materials is a kind of intelligent learning assistant, which is capable of aiding you pass the EFM Exam easily. If you are preparing the exam, you will save a lot of troubles with the guidance of our EFM study materials. Our company is aimed at relieving your pressure from heavy study load. So we strongly advise you to have a try.
We all realize that how important an NCC C-EFM certification is, also understand the importance of having a good knowledge of it. Passing the EFM exam means you might get the chance of higher salary, greater social state and satisfying promotion chance. Once your professional ability is acknowledged by authority, you master the rapidly developing information technology. With so many advantages, why dont you choose our reliable EFM Actual Exam guide, for broader future and better life? Our EFM exam questions won't let you down.
NCC - EFM - Updated Exam Certified - Electronic Fetal Monitoring Simulator OnlineItcertmaster is a wonderful study platform that can transform your effective diligence in to your best rewards. By years of diligent work, our experts have collected the frequent-tested knowledge into our EFM exam materials for your reference. So our practice materials are triumph of their endeavor. By resorting to our EFM Exam Materials, we can absolutely reap more than you have imagined before. We have clear data collected from customers who chose our EFM practice materials, and the passing rate is 98-100 percent.
NCC Certified - Electronic Fetal Monitoring Sample Questions (Q69-Q74):NEW QUESTION # 69
This fetal heart rate pattern is classified as Category III based on:
  • A. Type of deceleration
  • B. Absent variability
  • C. Contraction pattern
Comprehensive and Detailed Explanation From Exact Extract-Based NCC C-EFM References:
This tracing shows recurrent late decelerations accompanied by absent variability.
Per NICHD/NCC, a tracing is Category III if ANY of the following are present:
* Absent variability AND recurrent late decelerations
* Absent variability AND recurrent variable decelerations
* Absent variability AND bradycardia
* Sinusoidal pattern
In this strip:
* Variability is absent
* Decelerations are recurrent and late
The determining feature for the classification is absent variability, which indicates significant risk for fetal acidemia.
The contraction pattern (option B) does not determine category.
The deceleration type alone (option C) does not determine Category III without absent variability.
Thus, the classification is Category III because of absent variability.
References:NCC C-EFM Candidate Guide; NICHD Three-Tier System; AWHONN Fetal Heart Monitoring Principles & Practices; Miller's Fetal Monitoring Pocket Guide; Menihan Electronic Fetal Monitoring.
NEW QUESTION # 70
Fetal respiratory acidosis is most likely to present with which of the following fetal heart rate decelerations?
  • A. Early
  • B. Late
  • C. Variable
NCC and AWHONN physiology teachings:
* Variable decelerations caused by cord compression lead to:
* Transient interruption of umbilical venous flow
* Impaired fetal gas exchange
* Acute rise in CO#
* Respiratory acidosis (early phase of hypoxemia)
This is well documented:
* Early decelerations # head compression # NOT associated with acidemia.
* Late decelerations # uteroplacental insufficiency # metabolic acidosis, not respiratory.
Thus:
* Variable decelerations # respiratory acidosis
* Late decelerations # metabolic acidosis
Correct answer: C. Variable
References:NCC Physiology Domain; AWHONN FHMPP; Menihan EFM; Simpson & Creehan; Creasy & Resnik.
NEW QUESTION # 71
Interventions to decrease uterine activity should take place:
  • A. When labor is in the second stage
  • B. After tachysystole has been occurring for at least 30 minutes
  • C. If tachysystole is seen for one or two 10-minute segments
Comprehensive and Detailed Explanation From NCC-Aligned Sources:
Tachysystole = >5 contractions in 10 minutes averaged over 30 minutes (NICHD).
However, NCC and AWHONN intervention guidelines state:
* If tachysystole appears in one or two consecutive 10-minute segments, especially with Category II or III patterns, intervention must begin immediately.
* Intervention includes:
* Stopping/reducing oxytocin
* Maternal repositioning
* IV bolus
* Tocolysis if needed
Why the wrong answers are wrong:
* A. Waiting 30 minutes delays necessary fetal resuscitation.
* C. Stage of labor does not determine when to intervene.
Correct answer: B. If tachysystole is seen for one or two 10-minute segments References:NCC C-EFM Candidate Guide; AWHONN FHMPP; Menihan.
NEW QUESTION # 72
The tracing shown is from a woman at 28-weeks gestation in the post-anesthesia care unit (PACU) after an appendectomy. She is alert and awake. Based on this fetal heart rate pattern, the most appropriate intervention is:
  • A. Administer terbutaline
  • B. Perform cesarean birth
  • C. Continued monitoring
The fetal heart rate tracing shows:
* Baseline around 140 bpm
* Minimal variability
* No accelerations
* No decelerations
* Regular uterine activity but not tachysystole
This pattern is Category II, but in the context of:
* 28-week gestation
* Immediate postoperative status after anesthesia
* Maternal alertness and stability
NCC and AWHONN emphasize that maternal sedation, post-anesthesia effects, medications, and physiologic stress commonly cause temporary minimal variability without acidemia, especially at preterm gestations where baseline variability is normally lower.
Key NCC principle:
Minimal variability in a stable mother without decelerations does NOT require emergent delivery.
Instead, the fetus should be observed as anesthesia effects wear off.
Why other answers are incorrect:
* A. Terbutaline - No tachysystole and no recurrent decels are present.
* C. Cesarean birth - No bradycardia, no late decels, no absent variability, and no Category III criteria.
Thus, appropriate management is B. Continued monitoring.
References:NCC C-EFM Candidate Guide; AWHONN FHMPP; Menihan EFM; Miller's Pocket Guide; NICHD Definitions; Creasy & Resnik.
NEW QUESTION # 73
A woman (G1P0) arrives in triage with a pain score of 4/10 at 39-weeks gestation. The fetal heart rate tracing shown is obtained. The best intervention is to:
  • A. Adjust tocotransducer and continue to monitor
  • B. Admit for induction
  • C. Discharge to home
This tracing demonstrates a normal, reassuring fetal heart pattern that is technically categorized as Category I, indicating normal fetal acid-base status. Before any decision regarding discharge or induction, NCC emphasizes correct assessment of the tracing quality, fetal status, and uterine activity.
Key Tracing Characteristics
* Baseline:Approximately 135-145 bpm, well within the normal range of 110-160 bpm.
* Variability:The strip shows moderate variability (6-25 bpm), the strongest indicator of adequate fetal oxygenation per NCC, AWHONN, and NICHD.
* Accelerations:Several accelerations are present-another reassuring feature of normal fetal well-being.
* Decelerations:No variable, late, or prolonged decelerations are present.
* Uterine Activity:The lower channel shows poor recording quality and inconsistent signal- suggesting the toco is not capturing contractions well, not that the patient is contracting excessively or not at all.
Correct interpretation per NCC:
NCC emphasizes distinguishing between physiologic assessment and technical artifact.
The fetal tracing is completely reassuring.
The only abnormality is the poor uterine activity signal, a common triage occurrence due to:
* Toco placement
* Maternal body habitus
* Positioning
* Low contraction intensity in early labor
Thus, the correct next step is to optimize equipment (reposition the toco, adjust belt, palpate contractions) and continue to monitor.
B). Admit for induction - NOT indicated
* There is no evidence of fetal compromise.
* No indication for induction is present (pain score 4/10, reassuring FHR, term pregnancy).
* NCC emphasizes avoiding unnecessary interventions.
C). Discharge to home - NOT yet appropriate
* You cannot safely discharge a patient with a poorly monitored contraction pattern.
* Adequate assessment requires confirming uterine activity-after fixing the toco.
Therefore, the appropriate action is:
A). Adjust tocotransducer and continue to monitor.
References:NCC C-EFM Candidate Guide (2025); NCC Content Outline; AWHONN Fetal Heart Monitoring Principles & Practices; NICHD Definitions; Miller's Fetal Monitoring Pocket Guide; Menihan Electronic Fetal Monitoring; Simpson & Creehan Perinatal Nursing; Creasy & Resnik Maternal-Fetal Medicine.
NEW QUESTION # 74
We promise to provide a high-quality simulation system with advanced EFM study materials. With the simulation function, our EFM training guide is easier to understand and have more vivid explanations to help you learn more knowledge. You can set time to test your study efficiency, so that you can accomplish your test within the given time when you are in the Real EFM Exam. You will be confident if you have more experience on the EFM exam questions!
EFM Examinations Actual Questions: https://www.itcertmaster.com/EFM.html
NCC Exam EFM Simulator Online In order to let you access to the latest information, we offer you free update for 365 days after purchasing, and the update version will be sent to your email automatically, An easy pass will be a little case by using EFM : Certified - Electronic Fetal Monitoring training dumps, NCC Exam EFM Simulator Online The content is provided in PDF format, NCC Exam EFM Simulator Online Purchase practice test software, PDF or discount bundle.
A raw file is truly like a digital negative, Coworking EFM Software Provider Essensys Goes Public Essensys, which is based in London and describes itself as providing The world s leading coworking software EFM Latest Exam Tips and technology to power your workspace business, went public this week on the London Stock Exchange.
Free PDF Quiz NCC - EFM CProfessional Exam Simulator OnlineIn order to let you access to the latest information, we offer Valid EFM Test Sims you free update for 365 days after purchasing, and the update version will be sent to your email automatically.
An easy pass will be a little case by using EFM : Certified - Electronic Fetal Monitoring training dumps, The content is provided in PDF format, Purchase practice test software, PDF or discount bundle.
So our Certified - Electronic Fetal Monitoring training materials are suitable Exam EFM Simulator Online for qualifications of society, and only we can lead you to bright future.
