[General] Providing You Latest AZ-400 Well Prep with 100% Passing Guarantee
109
【General】 Providing You Latest AZ-400 Well Prep with 100% Passing Guarantee
Posted at 2/9/2026 16:28:08      View:137 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New AZ-400 dumps are available on Google Drive shared by UpdateDumps: https://drive.google.com/open?id=1Eh8eAmqj7czQ1bYI-MOpIf1utb3uaoRk
We believe that if you trust our AZ-400 exam simulator and we will help you obtain AZ-400 certification easily. After purchasing, you can receive our AZ-400 training material and download within 10 minutes. Besides, we provide one year free updates of our AZ-400 learning guide for you and money back guaranteed policy so that we are sure that it will give you free-shopping experience. Now choose our AZ-400 practic braindump, you will not regret.
Microsoft AZ-400: Skills measuredTo ensure your success in the Microsoft AZ-400 Exam, you must develop competence in the skill areas that will be evaluated during the delivery of the test. According to Microsoft, it measures different skills that include the following:
  • Develop an instrumentation strategy;
  • Manage source control;
  • Facilitate collaboration and communication;
You can find the details of these skills and the associated percentage on the certification exam webpage.
Exam AZ-400 Preview & New Exam AZ-400 BraindumpsYou will be cast in light of career acceptance and put individual ability to display. When you apply for a job you could have more opportunities than others. What is more, there is no interminable cover charge for our AZ-400 practice engine priced with reasonable prices for your information. Considering about all benefits mentioned above, you must have huge interest to our AZ-400 Study Materials. You should take the look at our AZ-400 simulating questions right now.
Microsoft Azure DevOps Solutions AZ-400 DumpsMicrosoft Azure DevOps Solutions AZ-400 Dumps will include below mentioned topics with Exam focused percentage
  • Implement Continuous Integration 10-15%
  • Implement DevOps Development Processes 20-25%
  • Design a DevOps Strategy 20-25%
  • Implement Dependency Management 5-10%
  • Implement Application Infrastructure 15-20%
To prepare for the Microsoft AZ-400 Exam, candidates should have a solid understanding of software development practices and be proficient in using Microsoft technologies, including Azure, Visual Studio, and PowerShell. Candidates should also have experience working with agile methodologies and be familiar with DevOps practices and principles.
Microsoft Designing and Implementing Microsoft DevOps Solutions Sample Questions (Q446-Q451):NEW QUESTION # 446
You need to configure a cloud service to store the secrets required by the mobile applications to call the share.
What should you include in the solution? To answer, select the appropriate options m the answer ater, NOTE: Each correct selection is worth one point.
References: https://docs.microsoft.com/en-us ... ize-with-shared-key
NEW QUESTION # 447
You have a web app that connects to an Azure SQL Database named db1.
You need to configure db1 to send Query Store runtime statistics to Azure Log Analytics.
To complete this task, sign in to the Microsoft Azure portal.
See explanation below
To enable streaming of diagnostic telemetry for a single or a pooled database, follow these steps:
1. Go to Azure SQL database resource.
2. Select Diagnostics settings.
3. Select Turn on diagnostics if no previous settings exist, or select Edit setting to edit a previous setting. You can create up to three parallel connections to stream diagnostic telemetry.
4. Select Add diagnostic setting to configure parallel streaming of diagnostics data to multiple resources.
Graphical user interface, text, application, email Description automatically generated
5. Enter a setting name for your own reference.
6. Select a destination resource for the streaming diagnostics data: Archive to storage account, Stream to an event hub, or Send to Log Analytics.
7. For the standard, event-based monitoring experience, select the following check boxes for database diagnostics log telemetry: QueryStoreRuntimeStatistics Graphical user interface, application Description automatically generated
8. For an advanced, one-minute-based monitoring experience, select the check box for Basic metrics.
9. Select Save.
https://docs.microsoft.com/en-us ... ing-streaming-expor
NEW QUESTION # 448
You have an Azure web app named Webapp1.
You need to use an Azure Monitor query to create a report that details the top 10 pages of Webapp1 that failed.
How should youcomplete the query? To answer, select the appropriate options in the answer area.
NOTE:Each correct selection is worth one point.
Box 1: requests
Failed requests (requests/failed):
The count of tracked server requests that were marked as failed.
Kusto code:
requests
| where success == 'False'
Box 2: success == false
https://docs.microsoft.com/en-us ... pp-insights-metrics
NEW QUESTION # 449
You have therepositories shown in the following table.
You need to migrate the contents of the GitHub repository to the Azure Repos repository. The solution must ensure that the Azure Repos repository only contains branches and history from the GitHub repository.
Which three commands should you run in sequence? To answer, move the appropriate commands from the list of commands to the answer area and arrange them in the correct order.
NEW QUESTION # 450
You have a project in Azure DevOps.
You need to configure a dashboard. The solution must include the following metrics:
* Bottlenecks in the software development process
* A burndown chart for the work in a single iteration
* How long it takes to close a work item after the item was started
Which type of widget should you use for each metric? To answer, drag the appropriate widget types to the correct metrics. Each widget type may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 451
Exam AZ-400 Preview: https://www.updatedumps.com/Microsoft/AZ-400-updated-exam-dumps.html
What's more, part of that UpdateDumps AZ-400 dumps now are free: https://drive.google.com/open?id=1Eh8eAmqj7czQ1bYI-MOpIf1utb3uaoRk
