NS0-185 Latest Dumps Sheet | NS0-185 Latest Braindumps Ebook
95
Posted at 2/10/2026 01:35:37      View94 | Replies0        Print      Only Author   [Copy Link] 1#
If you want to get a better job and relieve your employment pressure, it is essential for you to get the NS0-185 certification. However, due to the severe employment situation, more and more people have been crazy for passing the NS0-185 exam by taking examinations, the exam has also been more and more difficult to pass. Our NS0-185 test guide has become more and more popular in the world. Of course, if you decide to buy our NS0-185 latest question, we can make sure that it will be very easy for you to pass NS0-185 exam torrent that you can learn and practice it. Then you just need 20-30 hours to practice our study materials that you can attend your exam. It is really spend your little time and energy.
As we all know, it is difficult for you to prepare a NS0-185 exam by yourself. You will feel confused about some difficult knowledge. Now, you are fortunate enough to purchase our NS0-185 study questions. Our study materials are compiled by professional experts. They have researched the annual Real NS0-185 Exam for many years. So once you buy our study materials, you will save a lot of troubles.
NS0-185 Latest Braindumps Ebook & NS0-185 Latest Learning MaterialBraindumpQuiz has created a real NetApp Storage Installation Engineer, ONTAP Professional Exam, NS0-185 exam questions in three forms: Network Appliance NS0-185 pdf questions file is the first form. The second and third formats are Web-based and desktop Network Appliance NS0-185 practice test software. NS0-185 pdf dumps file will help you to immediately prepare well for the actual Network Appliance NetApp Storage Installation Engineer, ONTAP Professional Exam. You can download and open the Network Appliance PDF Questions file anywhere or at any time. NS0-185 Dumps will work on your laptop, tablet, smartphone, or any other device. You will get a list of actual Network Appliance NS0-185 test questions in Network Appliance NS0-185 pdf dumps file. Practicing with Web-based and desktop NS0-185 practice test software you will find your knowledge gap.
Network Appliance NetApp Storage Installation Engineer, ONTAP Professional Exam Sample Questions (Q12-Q17):NEW QUESTION # 12
You want to connect a DS224C shelf with 3.8 TB NetApp Storage Encryption (NSE) SSDs to an AFF A300 HA pair that already has two DS224C shelves with 3.8 TB SSDs without NSE in one stack.
In this scenario, how would you add the shelf?
  • A. Connect the shelf to an HA pair with NSE drives.
  • B. Add the shelf to the existing stack.
  • C. Create a new stack on the HA pair to add the shelf.
  • D. License NSE and add the shelf to this HA pair as a new stack.
NetApp installation rules prohibit mixingNSE and non-NSE drives within the same stack. While the AFF A300 supports both encrypted and non-encrypted drives, they must be physically separated into different stacks.
Licensing NSE alone does not allow mixing encrypted and unencrypted drives in the same stack. The correct approach is tocreate a new stackspecifically for the NSE drives.
Therefore, the correct answer isB.
NEW QUESTION # 13
You want to use the NetAppDocs tool to collect information on a newly configured ONTAP 9.8 cluster and generate a Word document with cluster details.
Which two data sources would you use to collect the necessary data? (Choose two.)
  • A. Active IQ Digital Advisor
  • B. Active IQ Unified Manager
  • C. AutoSupport packages
  • D. ONTAP Cluster
NEW QUESTION # 14
You are deploying a cluster with four AFF A300 nodes and Cisco 3232C switches. When you arrive at the customer's site, you notice that there are multiple breakout cables and four Cisco 3232C switches.
In this scenario, which statement is true?
  • A. Cisco best practices require four switches.
  • B. Your customer ordered a MetroCluster IP configuration.
  • C. A 4-node cluster requires four switches.
  • D. Two switches are required for cluster and two for management.
NEW QUESTION # 15
After completing an installation, the customer wants to know how they can manually open a new technical case with NetApp Global Support.
What are three ways to accomplish this task? (Choose three.)
  • A. Use AutoSupport.
  • B. Use the mobile app.
  • C. Use a telephone.
  • D. Use the NetApp Field Portal.
  • E. Use the support site.
Answer: B,C,E
The question asks formanualmethods a customer can use to open anew technical support casewith NetApp Global Support. In NetApp operational/support concepts, there are multiple engagement paths, but only some are "manual case creation" mechanisms.
A web-basedsupport siteworkflow is a standard manual case-creation path for customers. In NetApp support processes (including guidance in NetApp-managed support tooling for storage services), web ticketing/case creation is explicitly described as a supported way to open a case.
A second supported manual method is bytelephone("Call Us" / phone support), which is also described as a direct support option alongside web case creation. This matches optionD.
A third manual method commonly provided for customers is amobile applicationthat supports support engagement (including case workflows). In contrast,AutoSupportis primarily an automated telemetry
/notification mechanism; while AutoSupport can triggerautomatedcase creation under certain conditions, it is not a customer-driven "manual open a new case" method. ONTAP documentation even discusses suppressing or resuming AutoSupport case generation, reinforcing that AutoSupport case behavior is automated and policy-driven rather than a manual "open a case" action. Thus optionEdoes not meet the "manually open" requirement.
OptionB (NetApp Field Portal)is generally a field/partner/internal operational portal used by NetApp personnel and partners rather than a standard customer manual case creation channel. From an installation knowledge-transfer perspective, the customer-facing paths that satisfy the requirement are the support website and phone, and the mobile app where available for case workflows.
Therefore, the three correct choices areA, C, and D.
NEW QUESTION # 16
To ensure that your customer's cluster is robust and operational, you need to be familiar with configuration best practices.
Which three practice rules should you always follow? (Choose three.)
  • A. Remove failed disk drives once a year to maintain minimum interruption in controller stability.
  • B. All power supply units should be plugged into the same power grid.
  • C. Keep all nodes in the cluster on the same version of ONTAP.
  • D. Use LIFs with defined failover policies.
  • E. Do not use the root aggregate for storing data.
Answer: C,D,E
ONTAP SAN solution assessment requires adherence to proven configuration best practices to ensure availability, resiliency, and supportability.
First,all nodes must run the same ONTAP version. Mixed-version clusters are only permitted temporarily during upgrades. Running different versions long-term can cause compatibility issues and is not supported as a steady-state configuration.
Second,LIFs must have defined failover policies. Proper LIF failover ensures that network access is maintained during port, node, or network failures. This is a foundational availability principle in ONTAP networking design.
Third,the root aggregate must never be used for data storage. The root aggregate is reserved exclusively for system metadata and cluster operations. Storing user data on the root aggregate can compromise system stability and is explicitly prohibited in NetApp best practices.
Removing failed disks annually is incorrect; failed disks must be replaced immediately. Plugging all power supplies into the same power grid eliminates redundancy and violates high-availability design principles.
Therefore, the correct answers areA, B, and E.
NEW QUESTION # 17
New NetApp Storage Installation Engineer, ONTAP Professional Exam NS0-185 study guide and latest learning materials and practice materials have been provide for customers. BraindumpQuiz is a good platform that has been providing reliable, true, updated, and free NetApp Storage Installation Engineer, ONTAP Professional Exam NS0-185 Exam Questions. The NetApp Storage Installation Engineer, ONTAP Professional Exam NS0-185 exam fee is affordable, in order to success in your career, you need to pass NetApp Storage Installation Engineer, ONTAP Professional Exam exam.
NS0-185 Latest Braindumps Ebook: https://www.braindumpquiz.com/NS0-185-exam-material.html
Network Appliance NS0-185 Latest Dumps Sheet A: Many of the software of the same nature as that of $129.00 package available in the cyber market today, So no matter what kinds of NS0-185 Latest Braindumps Ebook - NetApp Storage Installation Engineer, ONTAP Professional Exam test torrent you may ask, our after sale service staffs will help you to solve your problems in the most professional way, Our efficient customers' support service is always keen to respond to your inquiries about exam NS0-185 paper, its pattern and changes in NCSIE ONTAP syllabus contents.
The example of division has been brought into line with the description of NS0-185 Latest Braindumps Ebook multiplication, This photograph will pose a few issues because of the stark contrasts in color and tonal range between the candle and the salad.
NS0-185 Latest Dumps Sheet - 100% High Hit Rate Questions PoolA: Many of the software of the same nature as NS0-185 Latest Learning Material that of $129.00 package available in the cyber market today, So no matter what kinds ofNetApp Storage Installation Engineer, ONTAP Professional Exam test torrent you may ask, our after NS0-185 sale service staffs will help you to solve your problems in the most professional way.
If you want to choose passing Network Appliance certification NS0-185 exam to make yourself have a more stable position in today's competitive IT area and the professional ability become more powerful, you must have a strong expertise.
As long as you encounter obstacles in the learning process on our NS0-185 training guide, send us an email and we will solve it for you at the first time.
