[General] Exam HPE7-A06 Questions | HPE7-A06 Exam Topics
103
General Exam HPE7-A06 Questions | HPE7-A06 Exam Topics
Posted at 2/10/2026 01:55:23      View121 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE7-A06 dumps are available on Google Drive shared by PassTorrent: https://drive.google.com/open?id=19UkVehXur1BveVdNvxKtF-m59tDv64eA
Generally speaking, passing the exam is what the candidates wish. Our HPE7-A06 exam braindumps can help you pass the exam just one time. And in this way, your effort and time spend on the practicing will be rewarded. HPE7-A06 training materials offer you free update for one year, so that you can know the latest information for the exam timely. In addition, HPE7-A06 Exam Dumps cover most of the knowledge point for the exam, and you can pass the exam as well as improve your ability in the process of learning. Online and offline chat service is available for HPE7-A06 learning materials, if you have any questions for HPE7-A06 exam dumps, you can have a chat with us.
The price for HPE7-A06 study materials is reasonable, no matter you are a student at school or an employee in the company, you can afford it. In addition, HPE7-A06 exam dumps are compiled by skilled experts, and therefore the quality can be guaranteed. You can receive the download link and password for HPE7-A06 Exam Dumps within ten minutes after payment. If you dont receive, you can contact us, and we will solve that for you. We are pass guarantee and money back guarantee, and if you fail to pass the exam, we will return your money.
HP HPE7-A06 Exam Topics & HPE7-A06 Reliable Exam AnswersYou can learn HPE7-A06 quiz torrent skills and theory at your own pace, and you are not necessary to waste your time on some useless books or materials and you will save more time and energy that you can complete other thing. We also provide every candidate who wants to get certification with free Demo to check our materials. It is time for you to realize the importance of our HPE7-A06 Test Prep, which can help you solve these annoyance and obtain a HPE7-A06 certificate in a more efficient and productive way.
HPE Campus Access Switching Expert Written Exam Sample Questions (Q65-Q70):NEW QUESTION # 65
Review the diagram and existing configuration of RouterA above. Which configuration changes are necessary to permit load balancing between RouterA and RouterB? (Selecttwo) Exhibit.
  • A.
  • B.
  • C.
  • D.
  • E.
Analyze Topology and Existing Configuration:
* RouterA (AS 64500) peers with RouterB (AS 64512) using eBGP.
* Peering is configured between loopback interfaces (RouterA Lo0 10.3.0.3 to RouterB Lo0 10.255.0.12).
* Two parallel physical links connect the routers (10.255.102.0/30 and 10.255.102.4/30).
* RouterA has two static routes pointing to RouterB's loopback (10.255.0.12/32), one via each physical link's next hop (10.255.102.1 and 10.255.102.5). This provides reachability to the BGP peer address over both paths.
* RouterA's BGP config activates the neighbor 10.255.0.12 for IPv4 unicast but is missing key commands for stable loopback peering and load balancing.
Goalermit load balancing for traffic exchanged via BGP between RouterA and RouterB. This requires BGP ECMP (Equal Cost Multi-Path).
Requirements for eBGP ECMP over Loopbacks:
* Stable Peeringeering must use loopback addresses. This requires:
* update-source loopback <id>: To source BGP TCP packets from the loopback IP.
* ebgp-multihop <ttl>: Because loopbacks are not directly connected (TTL > 1 needed).
* ECMP Enabled:BGP must be configured to allow multiple paths in the routing table. This requires:
* maximum-paths <n> (or maximum-paths ebgp <n>): To allow more than the default 1 path.
* Equal Paths:BGP must see multiple paths to thesameprefix learnedfrom RouterBthat are considered equal based on BGP path selection attributes (Weight, Local_Pref, AS_Path, Origin, MED, etc.). Since routes are learned from the same neighbor IP (RouterB's loopback), these attributes will likely be identical for routes learned via this peering. RouterA already has equal static routestothe BGP next hop (10.255.0.12).
NEW QUESTION # 66
A network administrator is implementing a new VoIP solution. They want the AOS-CX switches to advertise the correct DSCP priority for the physical IP phones.
Which switch features are needed to implement this solution? (Choose two.)
  • A. LLDP dot3 mfs
  • B. Voice VLAN
  • C. Priority-Flow Control (PFC)
  • D. LLDP med DSCP
  • E. LLDP med network-policy
Answer: B,E
To ensure IP phones receive the correct QoS settings, the switch must use Voice VLAN to separate VoIP traffic and apply appropriate QoS policies. Additionally, LLDP-MED network-policy is required to advertise voice-related parameters (such as VLAN ID, priority, and DSCP values) to the IP phones so they can mark traffic correctly.
NEW QUESTION # 67
A gateway cluster needs to be connected to the VSX-enabled switches where MC-LAG is configured. What is a possible constraint?
  • A. The command lacp fallback is missing on the interface lag level.
  • B. lacp mode active needs to be configured on the gateways when using "static-activate" mode.
  • C. LACP is not supported during the initial provisioning and needs to be turned off.
  • D. LLDP needs to be enabled to detect LACP-configured interfaces.
When connecting a gateway cluster to VSX-enabled switches with MC-LAG, LACP cannot be used during the initial provisioning phase (ZTP/OTP). You must use static port-channeling (no LACP) for the first setup. Once provisioning is complete, you can re-enable LACP. This is a documented constraint for initial gateway provisioning with Aruba gateways.
NEW QUESTION # 68
R1 has not learned OSPF routes from a directly connected neighboring router. Based on the exhibit's show command output, which statement describes a misconfiguration that would cause the router's neighbor state to remain stuck at 2-WAY/DROther?
  • A. The other router's directly connected interface is not attached to the default VRF.
  • B. There is a hello timer mismatch.
  • C. Both router's OSPF priority are set to 0.
  • D. There is an L2 interface MTU mismatch.
Both routers show OSPF priority 0, so neither can be elected DR/BDR on this broadcast segment. Without a DR/BDR, adjacencies remain at 2-WAY/DROther and routes aren't exchanged.
NEW QUESTION # 69
The administrator pf a large company noticed that there are some problems with UCC sessions on a wired network. Some employees complain about dropped calls and poor quality. The administrator wants to monitor jitter on AOS-CX switches with IP SLA, but notices results spiking to 100%.
What should the administrator check first to correct monitoring to run as desired?
  • A. source IP and source port combination
  • B. number of NAE agents
  • C. CoPP settings
  • D. memory and processor usage
IP SLA jitter measurements rely on unique source IP and source port combinations. If the same combination is reused, the results can show spikes or incorrect 100% loss. The first step is to verify and adjust the source IP and port settings to ensure proper packet tracking and accurate jitter monitoring.
NEW QUESTION # 70
Our HPE7-A06 practice materials will help you pass the HPE7-A06 exam with ease. The industry experts hired by HPE7-A06 study materials explain all the difficult-to-understand professional vocabularies by examples, diagrams, etc. All the languages used in HPE7-A06 real test were very simple and easy to understand. With our HPE7-A06 Study Materials, you don't have to worry about that you don't understand the content of professional books. You also don't need to spend expensive tuition to go to tutoring class. HPE7-A06 test engine can help you solve all the problems in your study.
HPE7-A06 Exam Topics: https://www.passtorrent.com/HPE7-A06-latest-torrent.html
HP Exam HPE7-A06 Questions The policy of our website, Dear, please prepare well with our HPE7-A06 Exam Topics - HPE Campus Access Switching Expert Written Exam dumps pdf, and you will pass at first attempt, If you are still a student, our HPE7-A06 certification will prepare you for a promising future, Industry experts hired by HPE7-A06 exam guide helps you to formulate a perfect learning system, and to predict the direction of the exam, and make your learning easy and efficient, The HP HPE7-A06 certification exam enables you to increase job opportunities, promotes professional development, and higher salary potential, and helps you to gain a competitive edge in your job search.
Each repeating element, such as `phone`, leads to an additional table in the relational HPE7-A06 target schema, What's interesting is that the idea of a tipping point and influentials is very appealing to marketers because it gives them scale.
Free PDF 2026 Latest HPE7-A06: Exam HPE Campus Access Switching Expert Written Exam QuestionsThe policy of our website, Dear, please prepare well with our HPE Campus Access Switching Expert Written Exam dumps pdf, and you will pass at first attempt, If you are still a student, our HPE7-A06 Certification will prepare you for a promising future.
Industry experts hired by HPE7-A06 exam guide helps you to formulate a perfect learning system, and to predict the direction of the exam, and make your learning easy and efficient.
BTW, DOWNLOAD part of PassTorrent HPE7-A06 dumps from Cloud Storage: https://drive.google.com/open?id=19UkVehXur1BveVdNvxKtF-m59tDv64eA
