[Hardware] 熱門的FCP_FSM_AN-7.2考試題庫&頂尖的Fortinet認證培訓 -有用的Fortinet FCP - FortiSIEM 7.2 Analyst
103
【Hardware】 熱門的FCP_FSM_AN-7.2考試題庫&頂尖的Fortinet認證培訓 -有用的Fortinet FCP - FortiSIEM 7.2 Analyst
Posted at 2/10/2026 02:08:21      View:113 | Replies:0        Print      Only Author   [Copy Link] 1#
從Google Drive中免費下載最新的PDFExamDumps FCP_FSM_AN-7.2 PDF版考試題庫:https://drive.google.com/open?id=1uh1HUeVZ78PYLNsLnX84_B4LJqS8HOeH
想要通過FCP_FSM_AN-7.2認證考試並不是僅僅依靠與考試相關的書籍就可以辦到的。與其盲目地學習考試要求的相關知識,不如做一些有價值的試題。一本高效率的考古題是大家準備考試時必不可少的工具。所以,快點購買PDFExamDumps的FCP_FSM_AN-7.2考古題吧。這是一本命中率很高的考古題,比其他任何學習方法都有效。这是可以保证你一次就成功的难得的资料。
Fortinet FCP_FSM_AN-7.2 考試大綱:
主題簡介
主題 1
  • Incidents, notifications, and remediation: This section of the exam measures the skills of Incident Responders and encompasses the entire incident management lifecycle. This includes the skills required to manage and prioritize security incidents, configure policies for alert notifications, and set up automated remediation actions to contain and resolve threats.
主題 2
  • Machine learning, UEBA, and ZTNA: This section of the exam measures the skills of Advanced Security Architects and covers the integration of modern security technologies. It involves performing configuration tasks for machine learning models, incorporating UEBA (User and Entity Behavior Analytics) data into rules and dashboards for enhanced threat detection, and understanding how to integrate ZTNA (Zero Trust Network Access) principles into security operations.
主題 3
  • Analytics: This section of the exam measures the skills of Security Analysts and covers the foundational techniques for building and refining queries. It focuses on creating searches from events, applying grouping and aggregation methods, and performing various lookup operations, including CMDB and nested queries to effectively analyze and correlate data.
主題 4
  • Rules and subpatterns: This section of the exam measures the skills of SOC Engineers and focuses on the construction and implementation of analytics rules. It involves identifying the different components that make up a rule, utilizing advanced features like subpatterns and aggregation, and practically configuring these rules within the FortiSIEM platform to detect security events.
選擇FCP_FSM_AN-7.2考試題庫,傳遞FCP - FortiSIEM 7.2 Analyst有效信息對於 Fortinet的FCP_FSM_AN-7.2考試認證每個考生都很迷茫。每個人都有自己不用的想法,不過總結的都是考試困難之類的,Fortinet的FCP_FSM_AN-7.2考試是比較難的一次考試認證,我相信大家都是耳目有染的,不過只要大家相信PDFExamDumps,這一切將不是問題,PDFExamDumps Fortinet的FCP_FSM_AN-7.2考試培訓資料是每個考生的必備品,它是我們PDFExamDumps為考生們量身訂做的,有了它絕對100%通過考試認證,如果你不相信,你進我們網站看一看你就知道,看了嚇一跳,每天購買率是最高的,你也別錯過,趕緊加入購物車吧。
最新的 Fortinet Certified Professional Security Operations FCP_FSM_AN-7.2 免費考試真題 (Q27-Q32):問題 #27
What is the Group: FortiSIEM Analysts value referring to?
  • A. CMDB user group
  • B. FortiSIEM organization group
  • C. Windows Active Directory user group
  • D. LDAP user group
答案:A
解題說明:
In FortiSIEM, the value Group: FortiSIEM Analysts under the User attribute refers to a CMDB user group. These groups are defined within FortiSIEM's CMDB and used to logically organize users for analytics, correlation rules, and reporting.
問題 #28
Which analytics search can be used to apply a user and entity behavior analytics (UEBA) tag to an event for a failed login by the user JSmith?
  • A. User = smith
  • B. User IS jsmith
  • C. Username NOT END WITH jsmith
  • D. Username CONTAIN smit
答案:B
解題說明:
The correct syntax to match an exact username in FortiSIEM analytics search is User IS jsmith. This ensures that the UEBA tag is applied only when the event is specifically tied to the user "jsmith", which is required for accurate behavioral analytics.
問題 #29
What can you use to send data to FortiSIEM for user and entity behavior analytics (UEBA)?
  • A. FortiSIEM agent
  • B. SSH
  • C. SNMP
  • D. FortiSIEM worker
答案:A
解題說明:
The FortiSIEM agent can be used to send detailed endpoint data such as user activity and process behavior to FortiSIEM, which is essential for performing User and Entity Behavior Analytics (UEBA).
問題 #30
Which running mode takes the most time to perform machine learning tasks?
  • A. Regression
  • B. Forecasting
  • C. Local auto
  • D. Local
答案:D
解題說明:
In Local mode, FortiSIEM performs machine learning tasks using the full dataset without optimization shortcuts, making it the most time-consuming mode compared to Local Auto, Forecasting, or Regression.
問題 #31
How does FortiSIEM update the incident table if a performance rule triggers repeatedly?
  • A. FortiSIEM generates a new incident based on the Rule Frequency value, and updates the First Seen and Last Seen timestamps.
  • B. FortiSIEM updates the Incident Count value and Last Seen timestamp.
  • C. FortiSIEM changes the incident status to Repeated, and updates the Last Seen timestamp.
  • D. FortiSIEM generates a new incident each time the rule triggers, and updates the First Seen and Last Seen timestamps.
答案:B
解題說明:
When a performance rule triggers repeatedly, FortiSIEM updates the existing incident by incrementing the Incident Count and refreshing the Last Seen timestamp. This avoids flooding the incident table with duplicates while still tracking repeated occurrences.
問題 #32
我們PDFExamDumps免費更新我們研究的培訓材料,這意味著你將隨時得到最新的更新的FCP_FSM_AN-7.2考試認證培訓資料,只要FCP_FSM_AN-7.2考試的目標有了變化,我們PDFExamDumps提供的學習材料也會跟著變化,我們PDFExamDumps知道每個考生的需求,我們將幫助你通過你的FCP_FSM_AN-7.2考試認證,以最優惠最實在的價格和最高超的品質來幫助每位考生,讓你們順利獲得認證。
FCP_FSM_AN-7.2考題資源: https://www.pdfexamdumps.com/FCP_FSM_AN-7.2_valid-braindumps.html
P.S. PDFExamDumps在Google Drive上分享了免費的、最新的FCP_FSM_AN-7.2考試題庫:https://drive.google.com/open?id=1uh1HUeVZ78PYLNsLnX84_B4LJqS8HOeH
