Dumps AP-202 Reviews - Valid AP-202 Exam Notes
Posted at 2/10/2026 05:56:04
View114
Replies0
When you decide to pass the AP-202 exam and get relate certification, you must want to find a reliable exam tool to prepare for exam. That is the reason why I want to recommend our AP-202 prep guide to you, because we believe this is what you have been looking for. Moreover we are committed to offer you with data protect act and guarantee you will not suffer from virus intrusion and information leakage after purchasing our AP-202 Guide Torrent. The last but not least we have professional groups providing guidance in terms of download and installment remotely.
The Salesforce AP-202 certification is a valuable credential and comes with certain benefits. You can use B2B Commerce for Developers Accredited Professional exam certificate to inspire managers or employers. For many professionals, the Salesforce AP-202 Certification Exam will not only validate your expertise but also gives you an edge in the job market or the corporate ladder.
Perfect Dumps AP-202 Reviews & Leading Offer in Qualification Exams & Fantastic Salesforce B2B Commerce for Developers Accredited ProfessionalThere are other countless advantages of the B2B Commerce for Developers Accredited Professional AP-202 exam that you can avail of after passing the B2B Commerce for Developers Accredited Professional exam. But keep in mind to pass the B2B Commerce for Developers Accredited Professional AP-202 exam is a difficult job. You have to put in some extra effort, time, and investment then you will be confident to perform well in the final B2B Commerce for Developers Accredited Professional exam. In this journey, you can get help from B2B Commerce for Developers Accredited Professional AP-202 Dumps that will assist you in B2B Commerce for Developers Accredited Professional exam preparation and prepare you to perform well in the final B2B Commerce for Developers Accredited Professional exam.
Salesforce B2B Commerce for Developers Accredited Professional Sample Questions (Q224-Q229):NEW QUESTION # 224
In which three ways should useful debugging information in Salesforce B2B Commerce implementation be garnered? (3 answers) A) Enabling the logging token via
- A. Placing a System.debug() statement anywhere in the class being debugged.
- B. Enabling debugging options for the current user and visually inspecting the Salesforce debug logs.
- C. Admin andsubsequently inspecting the logs via the browser console.
- D. Logging a case with Salesforce support to enable advanced debugging options.
- E. Logging into the community as a system administrator to identify any potential permissions or Visualforce exceptions.
Answer: B,C,E
Useful debugging information in Salesforce B2B Commerce implementation can be garnered in three ways:
Enabling the logging token via Admin and subsequently inspecting the logs via the browser console. This will enable logging messages and errors to the browser console, which can be viewed by opening the Developer Tools in the browser. The logging token can be enabled by setting the value of CO.logToken to true in CCAdmin.
Enabling debugging options for the current user and visually inspecting the Salesforce debug logs. This will enable logging messages and errors to the Salesforce debug logs, which can be viewed by opening the Debug Logs page in Salesforce Setup. The debugging options can be enabled by creating a Debug Level and a Trace Flag for the current user in Salesforce Setup.
Logging into the community as a system administrator to identify any potential permissions or Visualforce exceptions. This will allow viewing any errors or warnings that may occur on the community pages due to insufficient permissions or Visualforce issues. The system administrator can also access CCAdmin and other tools from within the community. Salesforce B2B Commerce and D2C Commerce Developer Guide,Logging, Debug Your Code
NEW QUESTION # 225
A developer needs to make a call to a long running web service which is critical to finalizing their checkout process. Which three items should the developer consider in their implementation?
- A. Requests to the service should be brokered to prevent limit exceptions
- B. A new CORS entry may need to be created in Setup
- C. A new Remote Site may need to be created in Setup
- D. An Apex method returning a Continuation will need to be created
- E. new Named Credential may need to be created in Setup
Answer: B,D,E
A developer needs to make a call to a long running web service which is critical to finalizing their checkout process. The developer should consider the following items in their implementation:
A new CORS entry may need to be created in Setup. CORS stands for Cross-Origin Resource Sharing, which is a mechanism that allows web browsers to make requests to servers on different domains. If the web service is hosted on a different domain than the B2B Commerce site, the developer may need to add a CORS entry in Setup to allow the browser to access the web service.This entry specifies the origin, path, and method of the request, as well as any headers or cookies that are allowed1.
A new Named Credential may need to be created in Setup. A Named Credential is a type of metadata that stores the URL and authentication settings of a web service. By using a Named Credential, the developer can avoid hardcoding the web service URL and credentials in their code, and instead reference the Named Credential by name.This makes the code more secure and easier to maintain2.
An Apex method returning a Continuation will need to be created. A Continuation is a special type of Apex object that allows the developer to make asynchronous calls to long running web services. By using a Continuation, the developer can avoid blocking the main thread and improve the user experience.A Continuation method must return a Continuation object, specify the web service URL and parameters, and register a callback method that handles the response3.
Option D and Option E are incorrect because they are not relevant to the scenario. Option D suggests that the developer should broker the requests to the web service, which means to use an intermediary service that manages the requests and responses. This may be useful for some scenarios, but it is not required for making a call to a long running web service. Option E suggests that the developer should create a new Remote Site in Setup, which is a way to whitelist the domains that can be accessed from Apex code.However, this is not necessary if the developer uses a Named Credential, which automatically handles the Remote Site setting2.Reference:
Set Up CORS
Named Credentials
Continuation Class
NEW QUESTION # 226
What is one requirement to keep in mind when including additional JavaScript 1h files in a Lightning Web Component?
- A. Only one of the files can be used with an import statement
- B. Only five of the files can be used with an import statement
- C. All the files must be imported to a singleton.js file and the singleton.js file can be used with an import statement
- D. The files must be ES6 modules and must have names that are unique within the component's folder.
When including additional JavaScript files in a Lightning Web Component, it is required that these files are ECMAScript 6 (ES6) modules and have unique names within the component's folder. This ensures proper module resolution and avoids namespace conflicts. Salesforce LWC documentation provides guidelines on organizing component resources, including JavaScript modules, to ensure they are correctly recognized and utilized within the LWC framework.
NEW QUESTION # 227
Which event is triggered within Salesforce B2B Commerce whenever a cart's statechanges?
- A. pageMessage
- B. cart
- C. cartChange
- D. cartState
The event that is triggered within Salesforce B2B Commerce whenever a cart's state changes is cartChange. This event is triggered by the updateCart method of the CCRZ.Cart class, which is responsible for updating the cart data and performing any actions that depend on the cart state, such as applying discounts, taxes, or shipping charges. The event can be used to notify all the components that are listening to it that the cart has changed and they should refresh their data accordingly. Salesforce B2B Commerce and D2C Commerce Developer Guide,Events,Cart Class
NEW QUESTION # 228
Which two statement are true for Mass Order (2 answers)
- A. The variation product is leveraged for SKUs.
- B. Mass Order is mobile ready with the ccrz templates.
- C. Mass Order pricing is done via a batch job.
- D. Mass order works with thedefault wishlists
Mass Order pricing is done via a batch job, which means that the prices are not calculated in real time, but rather at a scheduled time. Mass order works with the variation product, which is a product that has multiple SKUs with different attributes, such as size or color. Mass order does not work with the default wishlists, which are used to store products that the customer wants to buy later. Mass order is not mobile ready with the ccrz templates, which are the default templates for the storefront pages. Salesforce B2B Commerce Developer Guide: Mass Order,B2B Commerce Developer Guide: Variation Products
NEW QUESTION # 229
Customers always attach great importance to the quality of AP-202 exam torrent. We can guarantee that our study materials deserve your trustee. We have built good reputation in the market now. After about ten years development, we have owned a perfect quality control system. All AP-202 exam prep has been inspected strictly before we sell to our customers. The inspection process is very strict and careful. Any small mistake can be tested clearly. So you can completely believe our AP-202 Exam Guide. Whats more, all contents are designed carefully according to the exam outline. As you can see, the quality of our AP-202 exam torrent can stand up to the test. Your learning will be a pleasant process.
Valid AP-202 Exam Notes: https://www.easy4engine.com/AP-202-test-engine.html
About Easy4Engine Valid AP-202 Exam Notes Real Q&As Or Braindumps, The B2B Commerce for Developers Accredited Professional (AP-202) certification exam has been inspiring Salesforce professionals since its beginning, If you still cannot trust us, we have prepared the free trials of the AP-202 study materials for you to try, We hope that our new design of AP-202 test questions will make the user's learning more interesting and colorful, Salesforce Dumps AP-202 Reviews Once the validity of your product is over (90 days after the purchase), you can renew it with a 30% discount in your Member's Area.
Encouraging Comments and Discussion, We'd better find out AP-202 Exam Torrent if we really are ready before we put the product in front of a real user, About Easy4Engine Real Q&As Or Braindumps.
The B2B Commerce for Developers Accredited Professional (AP-202) certification exam has been inspiring Salesforce professionals since its beginning, If you still cannot trust us, we have prepared the free trials of the AP-202 study materials for you to try.
AP-202 Pass-Sure Torrent - AP-202 Actual Braindumps & AP-202 Test CramWe hope that our new design of AP-202 test questions will make the user's learning more interesting and colorful, Once the validity of your product is over (90 days AP-202 after the purchase), you can renew it with a 30% discount in your Member's Area.
- AP-202 Exam Cram Review 🧟 AP-202 Exam Cram Review 😆 Exam Vce AP-202 Free 🐠 Open ✔ [url]www.examcollectionpass.com ️✔️ enter ➥ AP-202 🡄 and obtain a free download 📋AP-202 Latest Exam Testking[/url]
- Trust Dumps AP-202 Reviews, Pass The B2B Commerce for Developers Accredited Professional 🏓 Search for AP-202 and download it for free immediately on ☀ [url]www.pdfvce.com ️☀️ ✡New AP-202 Practice Materials[/url]
- Free PDF 2026 Salesforce AP-202 Latest Dumps Reviews ➰ Go to website [url]www.testkingpass.com open and search for ➥ AP-202 🡄 to download for free 🕙Test AP-202 Dumps Free[/url]
- Fast, Hands-On AP-202 Exam-Preparation Questions 🚞 Immediately open [ [url]www.pdfvce.com ] and search for ➽ AP-202 🢪 to obtain a free download 🔥New AP-202 Practice Materials[/url]
- New AP-202 Practice Materials 🐾 New AP-202 Exam Prep 🍚 Latest AP-202 Dumps Ebook Ⓜ Go to website [url]www.prep4sures.top open and search for ➥ AP-202 🡄 to download for free 🥓Reliable AP-202 Exam Preparation[/url]
- Pass Guaranteed Quiz AP-202 - Authoritative Dumps B2B Commerce for Developers Accredited Professional Reviews 🥣 Immediately open ➽ [url]www.pdfvce.com 🢪 and search for ➠ AP-202 🠰 to obtain a free download 🏸New AP-202 Test Book[/url]
- 2026 Unparalleled Salesforce Dumps AP-202 Reviews 🔃 Search for ➽ AP-202 🢪 on ⮆ [url]www.prep4sures.top ⮄ immediately to obtain a free download 💟AP-202 Exam Cram Review[/url]
- Exam Vce AP-202 Free 🛤 New AP-202 Exam Prep 🦡 Reliable AP-202 Exam Preparation 🤾 Search for ➽ AP-202 🢪 on ▶ [url]www.pdfvce.com ◀ immediately to obtain a free download 🎐Training AP-202 Materials[/url]
- New AP-202 Practice Materials 🩲 Valid Test AP-202 Testking 🍀 New AP-202 Test Book 📎 Search on ⮆ [url]www.prepawaypdf.com ⮄ for ▛ AP-202 ▟ to obtain exam materials for free download 🏯New AP-202 Practice Materials[/url]
- New AP-202 Exam Prep 🦗 Exam AP-202 Bootcamp 🌍 Latest AP-202 Exam Topics 🥕 Download ➤ AP-202 ⮘ for free by simply searching on ✔ [url]www.pdfvce.com ️✔️ 🔮New AP-202 Practice Materials[/url]
- Fast, Hands-On AP-202 Exam-Preparation Questions 📗 Download ✔ AP-202 ️✔️ for free by simply searching on ☀ [url]www.vce4dumps.com ️☀️ 🔢Exam AP-202 Quick Prep[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, giphy.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, iobrain.in, Disposable vapes
