[General] NSE7_OTS-7.2 Reliable Exam Voucher, Training NSE7_OTS-7.2 Materials
96
【General】 NSE7_OTS-7.2 Reliable Exam Voucher, Training NSE7_OTS-7.2 Materials
Posted at 2/10/2026 08:31:37      View:91 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New NSE7_OTS-7.2 dumps are available on Google Drive shared by DumpsFree: https://drive.google.com/open?id=1IKALpv2fFdF0pxq6VC5X814N5kJkanlK
If you are busy with your work and study and have little time to prepare for your exam, then choose us, we can do the rest for you. NSE7_OTS-7.2 exam torrent is high-quality, and you just need to spend about 48 to 72 hours on study, you can pass you exam just one time. In addition, we are pass guarantee and money back guarantee for NSE7_OTS-7.2 Exam Braindumps, and therefore you don’t need to worry about that you will waste your money. We offer you free update for one year, and the update version for NSE7_OTS-7.2 exam materials will be sent to your email automatically.
Fortinet NSE7_OTS-7.2 certification is ideal for IT professionals, security professionals, and network engineers who work with OT environments and want to enhance their skills and knowledge in OT security. Fortinet NSE 7 - OT Security 7.2 certification is recognized globally and can help the candidates advance their careers and increase their earning potential. Fortinet NSE 7 - OT Security 7.2 certification also demonstrates the candidates' commitment to continuous learning and professional development in the field of network security.
To pass the Fortinet NSE7_OTS-7.2 Exam, candidates must demonstrate a deep understanding of OT security concepts, including risk assessment, threat management, and incident response. They must also be able to apply this knowledge to real-world scenarios, such as the detection and mitigation of cyber attacks on industrial control systems. Successful candidates will have the skills they need to design, implement, and manage effective OT security solutions for their organizations.
Training Fortinet NSE7_OTS-7.2 Materials - NSE7_OTS-7.2 Real Brain DumpsOur NSE7_OTS-7.2 practice materials comprise of a number of academic questions for your practice, which are interlinked and helpful for your exam. So their perfection is unquestionable. As a result, NSE7_OTS-7.2 real exam win worldwide praise and acceptance. Our NSE7_OTS-7.2 practice materials are determinant factors giving you assurance of smooth exam. The sooner you make up your mind, the more efficient you will win.
Fortinet NSE 7 - OT Security 7.2 Sample Questions (Q56-Q61):NEW QUESTION # 56
An OT administrator ran a report to identify device inventory in an OT network.
Based on the report results, which report was run?
  • A. A FortiSIEM CMDB report
  • B. A FortiSIEM analytics report
  • C. A FortiAnalyzer device report
  • D. A FortiSIEM incident report
NEW QUESTION # 57
Refer to the exhibit. Based on the topology designed by the OT architect, which two statements about implementing OT security are true? (Choose two.)
  • A. FortiGate-3 and FortiGate-4 devices must be in a transparent mode.
  • B. Firewall policies should be configured on FortiGate-3 and FortiGate-4 with industrial protocol sensors.
  • C. Micro-segmentation can be achieved only by replacing FortiGate-3 and FortiGate-4 with a pair of FortiSwitch devices.
  • D. IT and OT networks are separated by segmentation.
Segmentation separates the IT side from the OT zones in the diagram. FortiGate-3 and FortiGate-4 sit closest to PLC/RTU traffic, so their policies must use industrial protocol sensors to inspect and control those OT flows.
NEW QUESTION # 58
You are navigating through FortiSIEM in an OT network.
How do you view information presented in the exhibit and what does the FortiGate device security status tell you?
  • A. In the business service dashboard and there are one or more high-severity security incidents for the FortiGate device.
  • B. In the widget dashboard and there are one or more high-severity incidents for the FortiGate device.
  • C. In the summary dashboard and there are one or more high-severity security incidents for the FortiGate device.
  • D. In the PCI logging dashboard and there are one or more high-severity security incidents for the FortiGate device.
NEW QUESTION # 59
An operational technology rule is created and successfully activated to monitor the Modbus protocol on FortiSIEM. However, the rule does not trigger incidents despite Modbus traffic and application logs being received correctly by FortiSIEM.
Which statement correctly describes the issue on the rule configuration?
  • A. The attributes in the Group By section must match the ones in Fitters section.
  • B. The first condition on the SubPattern filter must use the OR logical operator.
  • C. The SubPattern is missing the filter to match the Modbus protocol.
  • D. The Aggregate attribute COUNT expression is incompatible with the filters.
NEW QUESTION # 60
An OT network security audit concluded that the application sensor requires changes to ensure the correct security action is committed against the overrides filters.
Which change must the OT network administrator make?
  • A. Set all application categories to apply default actions.
  • B. Set the priority of the C.BO.NA.1 signature override to 1.
  • C. Remove IEC.60870.5.104 Information.Transfer from the first filter override.
  • D. Change the security action of the industrial category to monitor.
According to the Fortinet NSE 7 - OT Security 6.4 exam guide1, the application sensor settings allow you to configure the security action for each application category andnetwork protocol override. The security action determines how the FortiGate unit handles traffic that matches the application category or network protocol override. The security action can be one of the following:
Allow: The FortiGate unit allows the traffic without any further inspection.
Monitor: The FortiGate unit allows the traffic and logs it for monitoring purposes.
Block: The FortiGate unit blocks the traffic and logs it as an attack.
The priority of the network protocol override determines the order in which the FortiGate unit applies the security action to the traffic. The lower the priority number, the higher the priority. For example, a priority of 1 is higher than a priority of 10.
In the exhibit, the application sensor has the following settings:
The industrial category has a security action of allow, which means that the FortiGate unit will not inspect or log any traffic that belongs to this category.
The IEC.60870.5.104 Information.Transfer network protocol override has a security action of block, which means that the FortiGate unit will block and log any traffic that matches this protocol.
The IEC.60870.5.104 Control.Functions network protocol override has a security action of monitor, which means that the FortiGate unit will allow and log any traffic that matches this protocol.
The IEC.60870.5.104 Start/Stop network protocol override has a security action of allow, which means that the FortiGate unit will not inspect or log any traffic that matches this protocol.
The IEC.60870.5.104 Transfer.C.BO.NA.1 network protocol override has a security action of block, which means that the FortiGate unit will block and log any traffic that matches this protocol.
The problem with these settings is that the IEC.60870.5.104 Transfer.C.BO.NA.1 network protocol override has a lower priority than the IEC.60870.5.104 Information.Transfer network protocol override. This means that if the traffic matches both protocols, the FortiGate unit will apply the security action of the higher priority override, which is block. However, the IEC.60870.5.104 Transfer.C.BO.NA.1 protocol is used to transfer binary outputs, which are essential for controlling OT devices. Therefore, blocking this protocol could have negative consequences for the OT network.
To fix this issue, the OT network administrator must set the priority of the IEC.60870.5.104 Transfer.C.BO.NA.1 network protocol override to 1, which is higher than the priority of the IEC.60870.5.104 Information.Transfer network protocol override. This way, the FortiGate unit will apply the security action of the lower priority override, which is allow, to the traffic that matches both protocols. This will ensure that the FortiGate unit does not block the traffic that is used to transfer binary outputs, while still blocking the traffic that is used to transfer information.
1: NSE 7 Network Security Architect - Fortinet
NEW QUESTION # 61
When you take Fortinet NSE7_OTS-7.2 practice exams again and again you get familiar with the Fortinet NSE 7 - OT Security 7.2 (NSE7_OTS-7.2) real test pressure and learn to handle it for better outcomes. Features of the web-based and desktop NSE7_OTS-7.2 Practice Exams are similar. The only difference is that the Fortinet NSE 7 - OT Security 7.2 (NSE7_OTS-7.2) web-based version works online.
Training NSE7_OTS-7.2 Materials: https://www.dumpsfree.com/NSE7_OTS-7.2-valid-exam.html
BTW, DOWNLOAD part of DumpsFree NSE7_OTS-7.2 dumps from Cloud Storage: https://drive.google.com/open?id=1IKALpv2fFdF0pxq6VC5X814N5kJkanlK
