[Hardware] 100% Pass Quiz 2026 Microsoft Authoritative AI-102 Valid Test Blueprint
96
【Hardware】 100% Pass Quiz 2026 Microsoft Authoritative AI-102 Valid Test Blueprint
Posted at 2/10/2026 08:35:58      View:110 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ITCertMagic AI-102 dumps from Cloud Storage: https://drive.google.com/open?id=1XYKmyN4cpVanTaqfumkYGbJj6wjt7hKV
If you want to get a higher position in your company, you must do an excellent work. Then your ability is the key to stand out. Perhaps our AI-102 study guide can help you get the desirable position. At present, many office workers are willing to choose our AI-102 Actual Exam to improve their ability. With the help of our AI-102 exam questions, not only they have strenghten their work competence and efficiency, but also they gained the certification which is widely accepted by the bigger enterprise.
To prepare for the Microsoft AI-102 Certification Exam, candidates should have a good understanding of AI concepts and experience working with Microsoft Azure. They should also be familiar with the Azure AI services and know how to use them to build AI solutions. Microsoft offers a variety of training resources, including self-paced online courses, classroom training, and hands-on labs, to help candidates prepare for the exam. Additionally, candidates can take practice exams and participate in study groups to gain a better understanding of the exam format and content.
Professional AI-102 Valid Test Blueprint, Exam AI-102 CollectionOverall obtaining AI-102 certificate can be a valuable investment in your professional career. As it can help you to stand out in a competitive market, more career opportunities, and advancement of your career. To gain all these advantages you just need to enroll in the Microsoft AI-102 Certification Exam and put all your efforts to pass this challenging AI-102 exam with flying colors.
Microsoft Designing and Implementing a Microsoft Azure AI Solution Sample Questions (Q361-Q366):NEW QUESTION # 361
Drag and Drop Question
You have an Azure subscription that contains an Azure OpenAI resource named AI1.
You need to analyze an image to obtain a text description.
Which four actions should you perform in sequence from Azure OpenAI Studio? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
1. Create a new deployment and select a DALL-E model. (DALL-E models are designed to work with image generation and analysis, which is necessary to obtain a text description from an image.)
2. In the System message field, enter 'You are an AI assistant that describes images.' (Setting up the system message clarifies the task for the model, specifying its role in the interaction.)
3. Open Chat playground and select the deployed model. (The playground allows you to interact with the deployed model.)
4. In the Chat session pane, enter a text prompt of 'Describe this image,' and upload an image by using the attachment button. (This step enables interaction with the model by providing the image and the instruction to describe it.)
NEW QUESTION # 362
You have an Azure subscription that contains an Azure OpenA1 resource named AH.
You plan to build an app named App1 that will write press releases by using AM.
You need to deploy an Azure OpenA1 model for Appl. The solution must minimize development effort.
Which three actions should you perform in sequence in Azure OpenAI Studio? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
1 - Create a deployment that uses the GPT-35 Turbo model.
2 - Apply the Marketing Writing Assistant system message template.
3 - Deploy the solution to a new web app.
NEW QUESTION # 363
You have 100 chatbots that each has its own Language Understanding model.
Frequently, you must add the same phrases to each model.
You need to programmatically update the Language Understanding models to include the new phrases.
How should you complete the code? To answer, drag the appropriate values to the correct targets. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
https://docs.microsoft.com/en-us ... -libraries-rest-api
NEW QUESTION # 364
You are developing the shopping on-the-go project.
You are configuring access to the QnA Maker resources.
Which role should you assign to AllUsers and LeadershipTeam? To answer, select the appropriate options in the answer area.
Box 1: QnA Maker Editor
Scenario: Provide all employees with the ability to edit Q&As.
The QnA Maker Editor (read/write) has the following permissions:
Create KB API
Update KB API
Replace KB API
Replace Alterations
"Train API" [in
new service model v5]
Box 2: Contributor
Scenario: Only senior managers must be able to publish updates.
Contributor permission: All except ability to add new members to roles
https://docs.microsoft.com/en-us ... ased-access-control
NEW QUESTION # 365
You are building a model that will be used in an iOS app.
You have images of cats and dogs. Each image contains either a cat or a dog.
You need to use the Custom Vision service to detect whether the images is of a cat or a dog.
How should you configure the project in the Custom Vision portal? To answer, select the appropriate options in the answer area.
Box 1: Classification
Box 2: Multiclass
A multiclass classification project is for classifying images into a set of tags, or target labels. An image can be assigned to one tag only.
Box 3: General
General: Optimized for a broad range of image classification tasks. If none of the other specific domains are appropriate, or if you're unsure of which domain to choose, select one of the General domains.
https://cran.r-project.org/web/p ... s/customvision.html
NEW QUESTION # 366
AI-102 exam certification is an international recognition, which is equivalent to a passport to enter a higher position. The AI-102 exam materials and test software provided by our ITCertMagic are developed by experienced IT experts, which have been updated again and again. Now you just take dozens of Euro to have such Reliable AI-102 Test Materials. Once you get the certification you may have a higher position and salary.
Exam AI-102 Collection: https://www.itcertmagic.com/Microsoft/real-AI-102-exam-prep-dumps.html
2026 Latest ITCertMagic AI-102 PDF Dumps and AI-102 Exam Engine Free Share: https://drive.google.com/open?id=1XYKmyN4cpVanTaqfumkYGbJj6wjt7hKV
