[General] Latest F5CAB1 Exam Guide, F5CAB1 Reliable Exam Prep
102
【General】 Latest F5CAB1 Exam Guide, F5CAB1 Reliable Exam Prep
Posted at 2/10/2026 13:24:09      View:211 | Replies:1        Print      Only Author   [Copy Link] 1#
Don't be trapped by one exam and give up the whole F5 certification. If you have no confidence in passing exam, Dumpleader releases the latest and valid F5CAB1 guide torrent files which is useful for you to get through your exam certainly. The earlier you pass exams and get certification with our F5CAB1 Latest Braindumps, the earlier you get further promotion and better benefits. Sometimes opportunity knocks but once. Timing is everything.
F5 F5CAB1 Exam Syllabus Topics:
  • BIG IP Administration Data Plane Configuration: This section of the exam measures skills of System Administrators and covers configuring BIG IP objects that control data plane behavior. It focuses on setting up virtual servers, pools, nodes, monitors, and profiles so that applications are delivered reliably and efficiently according to design requirements.
  • BIG IP Administration Install Initial Configuration and Upgrade: This section of the exam measures skills of System Administrators and covers the lifecycle tasks for deploying and maintaining a BIG IP system. It includes installing the platform, performing initial setup, applying licenses, configuring basic networking, and planning and executing software upgrades and hotfixes.
  • BIG IP Administration Support and Troubleshooting: This section of the exam measures skills of Network Administrators and covers identifying and resolving common issues that affect BIG IP operation. It focuses on using logs, statistics, diagnostic tools, and basic troubleshooting methods to restore normal traffic flow and maintain stable application delivery.
  • BIG IP Administration Control Plane Administration: This section of the exam measures skills of System Administrators and covers managing the control plane where BIG IP is configured and administered. It includes working with user accounts, roles, device settings, configuration management, and using the graphical interface and command line for daily administrative tasks.
Topic 5
  • BIG IP Administration Data Plane Concepts: This section of the exam measures skills of Network Administrators and covers how BIG IP handles application traffic on the data plane. It includes understanding flow of traffic, key data path components, basic concepts of load balancing, and how security and performance features affect user traffic.
Updated Latest F5CAB1 Exam Guide and Practical F5CAB1 Reliable Exam Prep & Correct BIG-IP Administration Install, Initial Configuration, and Upgrade Latest Test CampWe offer you free update for 365 days after you purchase F5CAB1 study materials from us, so that you don’t need to spend extra money for the update version. And the update version for F5CAB1 study materials will be sent to your email address automatically. You just need to check your mail when you need the update version. Besides F5CAB1 Study Materials are edited by professional experts, they are quite familiar with the dynamics of the exam center. Therefore if you choose F5CAB1 study materials of us, we will help you pass the exam and get the certificate successfully.
F5 BIG-IP Administration Install, Initial Configuration, and Upgrade Sample Questions (Q26-Q31):NEW QUESTION # 26
The BIG-IP Administrator received a ticket that an authorized user is attempting to connect to the Configuration Utility from a jump host and is being denied.
The HTTPD allow list is configured as:
sys httpd {
allow { 172.28.31.0/255.255.255.0 172.28.65.0/255.255.255.0 }
The jump host IP is172.28.32.22.
What command should the BIG-IP Administrator use to allow HTTPD access for this jump host?
  • A. modify /sys httpd allow replace-all-with { 172.28.32.22 }
  • B. modify /sys httpd allow delete { 172.28.31.0/255.255.255.0 172.28.65.0/255.255.255.0 }
  • C. modify /sys httpd allow add { 172.28.32.22 }
The HTTPD allow list controls which IP addresses or subnets may access the Configuration Utility (TMUI) on the BIG-IP system. The Administrator already has two subnets allowed and needs to add asingle host IPto the existing list.
* The object/sys httpd allowsupports actions such asadd,delete, andreplace-all-with.
* Because the goal is toaddone more entry without removing the existing permitted subnets, the correct command is:
This appends the new host to the existing list while preserving the previously configured networks.
* Option A (replace-all-with)wouldoverwritethe entire allow list, removing existing permitted subnets- unacceptable.
* Option B (delete)wouldremovethe existing networks and not add the required host.
Therefore, the correct administrative action is toaddthe jump host's IP.
NEW QUESTION # 27
An administrator is in the process of reactivating the license using the interface displayed in the exhibit.
What is the address of the license server to which the BIG-IP device must be able to establish an outbound connection in order to use theAutomatic Activation Method?
  • A. license.f5.com
  • B. callhome.f5.com
  • C. ask.f5.com
  • D. activate.f5.com
When you chooseAutomaticas the activation method in the License , Re-activate screen, the BIG-IP device itself contacts F5'slicense activation serviceover the Internet.
For successful automatic activation:
* The BIG-IP must have outbound network connectivity (typically via the management interface).
* DNS resolution and routing must allow it to reach theF5 license activation host(the one shown in option D).
* The device sends its dossier and registration key to that service and receives an updated license file in return, which is then installed automatically.
The other hostnames in the options are not used by BIG-IP for license activation, so they cannot be correct in the context ofAutomatic Activation.
NEW QUESTION # 28
The device is currently onv15.1.2.1.
The BIG-IP Administrator needs to boot the device back tov13.1.0.6to gather data for troubleshooting.
The system shows:
Sys::Software Status
Volume Product Version Build Active Status Allowed
HD1.1 BIG-IP 15.1.2.1 0.0.10 yes complete yes
HD1.2 BIG-IP 13.1.0.6 0.0.3 no complete yes
Which is the correct command-line sequence to boot the device to version13.1.0.6?
  • A. switchboot -I HD1.2, then reboot
  • B. switchboot -b HD1.2, then reboot
  • C. Use tmsh to select a new boot volume, tmsh reboot HD1.2
  • D. Use tmsh to select a new boot volume, tmsh switchboot HD1.2
To change the boot volume on a BIG-IP system from one installed TMOS version to another, the correct CLI tool is:
switchboot
The correct syntax uses the-bflag:
switchboot -b <volume>
This command marks the specified boot location as the one to be used on the next reboot.
Thus, to boot intoHD1.2which contains13.1.0.6, the sequence is:
* Mark HD1.2 as the next boot location:
* switchboot -b HD1.2
* Reboot the system:
* reboot
This is the standard and officially supported method for selecting a different installed volume.
A). "tmsh reboot HD1.2"
* There is no such tmsh syntax.
* Boot volume cannot be selected by adding a parameter to reboot.
C). switchboot -I HD1.2
* The -I flag is invalid. Only -b is used.
D). "tmsh switchboot HD1.2"
* switchboot isnota tmsh command; it is a system-level shell utility.
Therefore,Option Bis the correct and valid command sequence.
NEW QUESTION # 29
What traffic will be permitted to reach the BIG-IP?
  • A. Telnet
  • B. FTP
  • C. SSH
The exhibit shows the configuration of aSelf IPwith:
* Port Lockdown: Allow Custom
* ACustom Listthat includes the following TCP ports:
* 443
* 22
Meaning of these ports:
* TCP 443# HTTPS (TMUI - web-based management)
* TCP 22# SSH (command-line remote access)
No other TCP, UDP, or protocol entries are listed; therefore, only these two services are allowed to reach the BIG-IP via this Self IP.
Evaluating the answer choices:
Option
Service
Port
Allowed?
FTP
TCP 21
Not listed
#Not allowed
SSH
TCP 22
Listed
#Allowed
Telnet
TCP 23
Not listed
#Not allowed
Thus,SSHis the only traffic permitted through this Self IP configuration.
NEW QUESTION # 30
A BIG-IP Administrator is using Secure Copy Protocol (SCP) to transfer a TMOS image to the BIG-IP system in preparation for an upgrade.
To what directory should the file be transferred?
  • A. /local/images/
  • B. /shared/images/
  • C. /var/images/
BIG-IP systems require all ISO images (base TMOS images and HotFix images) to be stored in a specific directory used for software installation:
/shared/images/
This directory:
* Is theonly supported locationfrom which the BIG-IP software installation system validates and installs ISO files
* Is accessible by both the GUI and TMSH installers
* Has adequate storage space allocated specifically for images
* Is part of the shared partition that persists across reboots
When transferring images via SCP, the administrator must copy them directly into/shared/images/so that:
* The GUI (System # Software Management # Available Images) can detect the image
* TMSH install software image commands can reference it
Other directories such as/local/images/or/var/images/are not valid storage paths for software images.
NEW QUESTION # 31
To prepare for F5CAB1 exam, you do not need read a pile of reference books or take more time to join in related training courses, what you need to do is to make use of our Dumpleader exam software, and you can pass the exam with ease. Our exam dumps can not only help you reduce your pressure from F5CAB1 Exam Preparation, but also eliminate your worry about money waste. We guarantee to give you a full refund of the cost you purchased our dump if you fail F5CAB1 exam for the first time after you purchased and used our exam dumps. So please be rest assured the purchase of our dumps.
F5CAB1 Reliable Exam Prep: https://www.dumpleader.com/F5CAB1_exam.html
Posted at 4/20/2026 13:57:54        Only Author  2#
The article is full of inspiration, thank you for sharing it! Test Arch-303 result provides fantastic content for free.
