Instant 1z0-1057-25 Download - New 1z0-1057-25 Test Tutorial
Posted at 2/10/2026 16:08:41
View217
Replies0
DOWNLOAD the newest Prep4sureExam 1z0-1057-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1II6YQUTtqasjdWBBe5XbUU0s35cdPEsq
The biggest advantage of our 1z0-1057-25 study question to stand the test of time and the market is that our sincere and warm service. To help examinee to pass 1z0-1057-25 exam, we are establishing a perfect product and service system between us. We can supply right and satisfactory 1z0-1057-25 exam questions you will enjoy the corresponding product and service. We cant say we are the absolutely 100% good, but we are doing our best to service every customer. Only in this way can we keep our customers and be long-term cooperative partners. Looking forwarding to your 1z0-1057-25 Test Guide use try!
For the peace of your mind, you can also try a free demo of Oracle 1z0-1057-25 Dumps practice material. You will not find such affordable and latest material for Oracle certification exam anywhere else. Don't miss these incredible offers. Order real Oracle 1z0-1057-25 Exam Questions today and start preparation for the certification exam.
New 1z0-1057-25 Test Tutorial - Valid Braindumps 1z0-1057-25 EbookIt is certain that the pass rate of our 1z0-1057-25 study guide among our customers is the most essential criteria to check out whether our 1z0-1057-25 training materials are effective or not. The good news is that according to statistics, under the help of our 1z0-1057-25 learning dumps, the pass rate among our customers has reached as high as 98% to 100%. It is strongly proved that we are professonal in this career and our 1z0-1057-25 exam braindumps are very popular.
Oracle Project Management Cloud 2025 Implementation Professional Sample Questions (Q86-Q91):NEW QUESTION # 86
You want to export your project plan to Oracle Project Financial Management Cloud after initial scheduling is complete in Microsoft Projects. Identify three conditions that must be met for exporting milestone tasks. ( Choose three.)
- A. percent work complete values of 0 or 100 percent
- B. only one labor resource assignment with 0 effort
- C. lowest-level tasks set up with zero duration
- D. only one labor resource assignment with 100 effort
- E. lowest-level tasks set up with non-zero duration
Answer: A,B,C
Ref: https://docs.oracle.com/en/cloud ... pex/define-project- management-configuration.html#OAPEX1357147 Topic - Microsoft Project Prevalidation: Explained The following table describes Prevalidation rules for tasks and resource assignments.
Level
Rule
Lowest-level tasks
One labor and multiple expense resources are allowed for a lowest-level task. Remove other resources.
Summary tasks
Only one labor resource with zero allocation is allowed for a summary task. Remove all other resources.
Milestone tasks
No subtasks are allowed under milestone tasks. Milestones must be lowest-level tasks.
Milestone tasks
Milestone tasks must have zero duration.
Milestone tasks
Only one labor resource, with zero effort, is allowed for a milestone task. Remove all other resources.
When exporting milestone tasks, ensure that the tasks:
* Are lowest-levels task with zero duration, that is, the same start and finish dates.
* Have only one labor resource assignment with zero effort.
* Have percent work complete values of 0 or 100 percent. Any other values are set to zero before export.
NEW QUESTION # 87
Your customer has implemented Oracle Project Portfolio Management Cloud recently and they have hired new employees for their Professions Services business. These employees are set up in Oracle Human Capital Management Cloud, but the Project Administrators are unable to add them as resources in the Planning Resource Breakdown Structure.
What are three conditions for new employees to show up in the list? (Choose three.)
- A. All new employees created as persons must be assigned to a department.
- B. All new employees created as persons must have an active project role.
- C. All new employees created as persons must have an active supervisor.
- D. Current date is before the effective date of the resource, and you did not enable the "Include people with future-dated effective start dates" option during the search.
- E. All new employees created as persons must have an active assignment.
Answer: A,D,E
NEW QUESTION # 88
Your customer wants to automatically allocate unassigned asset lines and common costs across multiple assets based on the construction-in-process cost of each asset. Identify the asset allocation method that you must use as the default method while configuring project types to meet this requirement. (Choose the best answer.)
- A. Spread Evenly
- B. Actual Unit
- C. Estimated Cost
- D. Standard Unit Cost
- E. Current Cost
Answer: E
Ref: https://docs.oracle.com/en/cloud ... project-foundation- configuration-manage-project-types.html#OAPFM220111 Topic - Asset Cost Allocation Methods: Explained The asset cost allocation method determines how indirect or common costs incurred on a project are allocated to multiple assets.
You can specify an asset cost allocation method to enable Oracle Fusion Project Costing to automatically allocate unassigned asset lines and common costs across multiple assets. Unassigned asset lines typically occur when more than one asset is assigned to an asset grouping level.
Projects and project templates inherit a default asset cost allocation method from the associated project type.
You can override the default at the project level. If you use capital events to allocate costs, then you can also override the asset cost allocation method at the event level.
The following table describes the available asset cost allocation methods.
Method
Basis of Cost Allocation
Actual Units
Number of units defined for each asset
Current Cost
Construction-in-process (CIP) cost of each asset
Estimated Cost
Estimated cost of each asset
Standard Unit Cost
Combination of the standard unit cost and the number of units defined for each asset Spread Evenly Equal allocation of cost to each asset
NEW QUESTION # 89
Your customer complains that their project resources do not report their time promptly, which has resulted in incorrect reporting of project performance. What should you do to fix this problem? (Choose the best answer.)
- A. Enable track missing time at project template.
- B. Enable track missing time at project type.
- C. Enable track missing time at project unit.
- D. Enable track missing time at business unit.
To fix the problem of project resources not reporting their time promptly, you should enable track missing time at project unit. This option allows you to track and report on missing time entries for project resources based on their work assignments and schedules. You can also set up notifications and reminders to prompt resources to enter their time on a regular basis. Reference: https://docs.oracle.com/en/cloud/saas/project- portfolio-management/20c/oapfm/manage-project-time-and-labor.html#OAPFM2356011
NEW QUESTION # 90
Which three Cost Collection Flexfield core attributes can be derived during import if not explicitly entered in a transaction document? (Choose three.)
- A. Capitalizable Flag
- B. Work Type
- C. Expenditure Type
- D. Funding Source
- E. Billable Flag
Answer: A,C,E
The Cost Collection Flexfield is a descriptive flexfield that captures additional information about project costs. It has three core attributes that are required for every cost transaction: Billable Flag, Expenditure Type, and Capitalizable Flag. These attributes can be derived during import if not explicitly entered in a transaction document, based on various rules and sources such as expenditure type defaults, project type defaults, transaction source defaults, etc. Funding Source and Work Type are not core attributes of the Cost Collection Flexfield, but context-sensitive segments that can be optionally enabled for certain transaction sources or business units. These segments capture additional information about how the costs are funded or what type of work is performed. Reference: https://docs.oracle.com/en/cloud ... anagement/20c/oapfm
/manage-project-costs.html#OAPFM2356141
NEW QUESTION # 91
To be well-prepared, you require trust worthy and reliable Prep4sureExam practice material. You also require accurate Prep4sureExam study material to polish your capabilities and improve your chances of passing the 1z0-1057-25 certification exam. Prep4sureExam facilitates your study with updated Oracle 1z0-1057-25 Exam Dumps. This 1z0-1057-25 exam prep material has been prepared under the expert surveillance of 90,000 highly experienced Prep4sureExam professionals worldwide.
New 1z0-1057-25 Test Tutorial: https://www.prep4sureexam.com/1z0-1057-25-dumps-torrent.html
Oracle Instant 1z0-1057-25 Download You have no need to purchase another exam materials or books, Prep4sureExam New 1z0-1057-25 Test Tutorial - World's Leading Exam Preparation Materials, Oracle Instant 1z0-1057-25 Download All these versions closely follow the syllabus of the test without useless knowledges, Oracle Instant 1z0-1057-25 Download And the most indispensable part is our thoughtful aftersales services offered by our company, The 1z0-1057-25 prep guide provides user with not only a learning environment, but also create a learning atmosphere like home.
It is also the moment when the employer determines whether you are someone 1z0-1057-25 to take a chance on, Since the advent of Windows Sharepoint, Microsoft has tried to reduce the use of public folders within a company environment.
1z0-1057-25 Exam Braindumps Materials are the Most Excellent Path for You to pass 1z0-1057-25 Exam - Prep4sureExamYou have no need to purchase another exam materials or books, Prep4sureExam 1z0-1057-25 Reliable Test Voucher - World's Leading Exam Preparation Materials, All these versions closely follow the syllabus of the test without useless knowledges.
- 1z0-1057-25 Exam Price 🚰 1z0-1057-25 Exam Price 🛢 1z0-1057-25 Actualtest 🧎 Easily obtain free download of ▶ 1z0-1057-25 ◀ by searching on ▶ [url]www.prepawaypdf.com ◀ 🏡1z0-1057-25 Free Brain Dumps[/url]
- Get Special Discount on Oracle 1z0-1057-25 Exam Dumps 🦛 Search for ⏩ 1z0-1057-25 ⏪ on [url]www.pdfvce.com immediately to obtain a free download 🏅1z0-1057-25 Training Materials[/url]
- 1z0-1057-25 Training Courses 🚌 1z0-1057-25 Reliable Study Plan 🥇 1z0-1057-25 Exam Actual Questions 🕌 Search for 1z0-1057-25 and download exam materials for free through [url]www.practicevce.com ☁1z0-1057-25 Sample Exam[/url]
- Free Updates for 365 Days on Oracle 1z0-1057-25 Exam Questions 🐫 Easily obtain free download of ☀ 1z0-1057-25 ️☀️ by searching on ➠ [url]www.pdfvce.com 🠰 😶1z0-1057-25 Exam Details[/url]
- Pass Guaranteed Quiz 1z0-1057-25 - Reliable Instant Oracle Project Management Cloud 2025 Implementation Professional Download 🍩 Easily obtain ➽ 1z0-1057-25 🢪 for free download through [url]www.pdfdumps.com 🎣1z0-1057-25 Reliable Study Plan[/url]
- 1z0-1057-25 Reliable Exam Papers 🐎 1z0-1057-25 Exam Questions 🎤 1z0-1057-25 Lead2pass Review 💛 Download ➡ 1z0-1057-25 ️⬅️ for free by simply entering ▷ [url]www.pdfvce.com ◁ website 💟1z0-1057-25 Reliable Exam Papers[/url]
- 1z0-1057-25 Free Brain Dumps 😇 1z0-1057-25 Training Courses 🐥 Visual 1z0-1057-25 Cert Exam 📈 Search on ▶ [url]www.exam4labs.com ◀ for ⏩ 1z0-1057-25 ⏪ to obtain exam materials for free download 🔉1z0-1057-25 Reliable Study Plan[/url]
- Pass Guaranteed Quiz 1z0-1057-25 - Reliable Instant Oracle Project Management Cloud 2025 Implementation Professional Download 🚲 ✔ [url]www.pdfvce.com ️✔️ is best website to obtain 1z0-1057-25 for free download 🧵1z0-1057-25 Training Courses[/url]
- Pass Guaranteed 2026 Oracle Newest 1z0-1057-25: Instant Oracle Project Management Cloud 2025 Implementation Professional Download 🙊 The page for free download of ➤ 1z0-1057-25 ⮘ on ▶ [url]www.torrentvce.com ◀ will open immediately 🤡1z0-1057-25 Training Courses[/url]
- 1z0-1057-25 Sample Exam 👝 Visual 1z0-1057-25 Cert Exam 👤 1z0-1057-25 Exam Questions 🦲 Download 1z0-1057-25 for free by simply searching on ➠ [url]www.pdfvce.com 🠰 🎂1z0-1057-25 Exam Actual Questions[/url]
- 1z0-1057-25 Lead2pass Review 💘 1z0-1057-25 Exam Questions 😵 1z0-1057-25 Actualtest 👤 Search for 1z0-1057-25 and download it for free on [ [url]www.troytecdumps.com ] website 🥴1z0-1057-25 Certification Exam Dumps[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, anonup.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New 1z0-1057-25 dumps are available on Google Drive shared by Prep4sureExam: https://drive.google.com/open?id=1II6YQUTtqasjdWBBe5XbUU0s35cdPEsq
