Pass Guaranteed 2026 Salesforce ED-Con-101: Salesforce Certified Education Cloud
Posted at 2/10/2026 21:21:08
View127
Replies0
ActualTestsIT Salesforce ED-Con-101 practice exam software went through real-world testing with feedback from more than 90,000 global professionals before reaching its latest form. The Salesforce ED-Con-101 Exam Dumps are similar to real exam questions. Our Salesforce ED-Con-101 practice test software is suitable for computer users with a Windows operating system.
We learned that a majority of the candidates for the exam are office workers or students who are occupied with a lot of things, and do not have plenty of time to prepare for the ED-Con-101 exam. So we have tried to improve the quality of our training materials for all our worth. Now, I am proud to tell you that our training materials are definitely the best choice for those who have been yearning for success but without enough time to put into it. There are only key points in our ED-Con-101 Training Materials. That is to say, you can pass the ED-Con-101 exam as well as getting the related certification only with the minimum of time and efforts under the guidance of our training materials.
ED-Con-101 Reliable Test Forum - Flexible ED-Con-101 Learning ModeWe have collected the frequent-tested knowledge into our ED-Con-101 practice materials for your reference according to our experts years of diligent work. So our ED-Con-101 exam braindumps are triumph of their endeavor. By resorting to our ED-Con-101 practice dumps, we can absolutely reap more than you have imagined before. No only that you will pass your ED-Con-101 Exam for sure, according you will get the certificate, but also you will get more chances to have better jobs and higher salaries.
Salesforce Certified Education Cloud Consultant Sample Questions (Q11-Q16):NEW QUESTION # 11
A large online university uses Salesforce with the Education Data Architecture (EDA) to manage its operations. Its Salesforce environment has a large volume of records and it takes a long time to search and generate list views.
Which feature should the consultant use to resolve the issue?
- A. MuleSoft Anypoint Platform
- B. Table-Driven Trigger Management
- C. Data Loader error logs
- D. Custom Index
The consultant should use a custom index to resolve the issue of taking a long time to search and generate list views for the large online university's Salesforce environment that has a large volume of records and uses EDA. A custom index is a feature that allows users to create an index on a field that is not indexed by default, such as a custom field, a long text area field, or a multi-select picklist field. A custom index can help improve the performance and speed of queries and list views that use the indexed field as a filter. The consultant should identify the fields that are frequently used in searches and list views, and request Salesforce Support to create a custom index on them. MuleSoft Anypoint Platform, Data Loader error logs, and Table-Driven Trigger Management are not features that can resolve the issue of taking a long time to search and generate list views for the large online university's Salesforce environment that has a large volume of records and uses EDA. Reference:
https://help.salesforce.com/s/ar ... ndex.htm&type=5
https://developer.salesforce.com ... ructure_indexes.htm
NEW QUESTION # 12
What is the correct order of operations to ensure customer success in an Education Cloud implementation?
- A. Conduct Discovery Workshops, Document Current State, Write Test Scripts Plans, Generate Solution Design, Build Solution & Test, Deploy
- B. Document Current State, Conduct: Discovery Workshops, Write Test Scripts & Plans, Build Solution & Test, Generate Solution Design, Deploy.
- C. Document Current State, Conduct Discovery Workshops, Generate Solution Design, Write Test Scripts & Plans, Build Solution & Test, Deploy.
- D. Conduct Discovery Workshops, Document Current State, Generate Solution Design, Write Test Scripts & Plans, Build Solution & Test, Deploy,
The correct order of operations to ensure customer success in an Education Cloud implementation is:
Conduct Discovery Workshops: This is the first step where the consultant gathers information and requirements from the customer and stakeholders through interviews, surveys, or observations.
Document Current State: This is the second step where the consultant analyzes and documents the current processes and systems that the customer uses and identifies gaps and opportunities for improvement.
Generate Solution Design: This is the third step where the consultant creates and presents a solution design document that outlines how Salesforce will meet the customer's requirements and expectations, and defines the scope, timeline, and budget of the project.
Write Test Scripts & Plans: This is the fourth step where the consultant writes test scripts and plans that describe how to test the functionality and usability of the solution in different scenarios and conditions, and defines the success criteria and exit criteria for testing.
Build Solution & Test: This is the fifth step where the consultant builds the solution in a sandbox environment using declarative or programmatic tools, and tests the solution using the test scripts and plans to ensure quality and accuracy.
Deploy: This is the sixth and final step where the consultant deploys the solution into the production environment using change sets or other deployment tools, and provides training and support to the customer and end users.
Documenting Current State, Conducting Discovery Workshops, Writing Test Scripts & Plans, Building Solution & Test, Generating Solution Design, or Deploying are not correct orders of operations to ensure customer success in an Education Cloud implementation. Reference:
https://www.salesforce.org/wp-co ... Cloud_COE_Guide.pdf
https://trailhead.salesforce.com ... t-management-basics
NEW QUESTION # 13
A consultant is working with a university that uses Salesforce and wants to install the Education Data Architecture (EDA) in that environment.
What does the consultant need to do after installing EDA to ensure it is set up correctly?
- A. Assign EDA access to a cloned System Admin profile.
- B. Create and assign roles to all users who have access to EDA.
- C. Make the EDA record types available to profiles.
- D. Assign EDA layouts to the Cases object.
After installing EDA, the consultant needs to make the EDA record types available to profiles that need to access them. This is because EDA comes with several custom record types for standard objects, such as Account, Contact, Course, and Program Enrollment. These record types enable different views and fields for different types of records, such as Household, Student, Faculty, Course Offering, and Program Enrollment. By default, these record types are not assigned to any profiles, so the consultant needs to manually assign them to the appropriate profiles based on the business requirements and user roles of the university. This will ensure that the users can see and use the EDA record types and fields correctly and efficiently. Reference: Education Data Architecture Basics, Assign Record Types to Profiles
NEW QUESTION # 14
A large university has a Career Service Center that provides career advice to current students and alumni. Staff provide advice ...... the phone, via email and face-to-face. Students and alumni are served on a first come, first served basis and are rarely assigned to a specific advisor.
What should the consultant recommend to meet the requirement?
- A. Success Teams
- B. Queue Management
- C. Assignment Rules
- D. Appointment Scheduling
Appointment Scheduling is a solution that the consultant can recommend to meet the requirement of providing career advice to current students and alumni via phone, email, or face-to-face. Appointment Scheduling is a feature that allows users to create and manage appointments with customers or clients from Salesforce. Appointment Scheduling can be used to offer different types of services, such as career advice, tutoring, or counseling. Appointment Scheduling also integrates with calendars, email notifications, and reports. Success Teams, Queue Management, and Assignment Rules are not solutions that can meet the requirement of providing career advice to current students and alumni via phone, email, or face-to-face. Reference:
https://help.salesforce.com/s/ar ... view.htm&type=5
https://trailhead.salesforce.com ... ointment-scheduling
NEW QUESTION # 15
The International Student Services department manages the needs of international and study-abroad students in Salesforce using the Education Data Architecture. The residence hall address information must be associated to the international student Contact and Account record.
What account model should the consultant select?
- A. Person Account
- B. Household Account
- C. Administrative Account
- D. Standard Account
Person Account is an account model that the consultant should select to meet the requirement of associating the residence hall address information to the international student Contact and Account record. Person Account is a feature that allows users to store information about individual people who are not associated with an Account, such as students or applicants. Person Account also allows users to store multiple addresses for a Contact or an Account using Address Management. The consultant should enable Person Accounts and use them to store information about international students and their residence hall addresses. Standard Account, Household Account, and Administrative Account are not account models that can meet the requirement of associating the residence hall address information to the international student Contact and Account record. Reference:
https://help.salesforce.com/s/ar ... vior.htm&type=5
https://powerofus.force.com/s/article/EDA-Addresses
NEW QUESTION # 16
It would be really helpful to purchase Salesforce Certified Education Cloud Consultant (ED-Con-101) exam dumps right away. If you buy this Salesforce Certification Exams product right now, we'll provide you with up to 1 year of free updates for Salesforce Certified Education Cloud Consultant (ED-Con-101) authentic questions. You can prepare using these no-cost updates in accordance with the most recent test content changes provided by the Salesforce Certified Education Cloud Consultant (ED-Con-101) exam dumps.
ED-Con-101 Reliable Test Forum: https://www.actualtestsit.com/Salesforce/ED-Con-101-exam-prep-dumps.html
Salesforce Latest ED-Con-101 Exam Pdf If you are still lingering, we'll show you the fact, Salesforce Latest ED-Con-101 Exam Pdf If you find any problems during use, you can give us feedback, Salesforce Latest ED-Con-101 Exam Pdf You can choose any format as per your practice needs, The passing rate of our ED-Con-101 exam guide is high, Salesforce Latest ED-Con-101 Exam Pdf After deliberate consideration, you can pick one kind of study materials from our websites and prepare the exam.
Keep it short, keep it simple, Declaration of Public Variables, ED-Con-101 If you are still lingering, we'll show you the fact, If you find any problems during use, you can give us feedback.
You can choose any format as per your practice needs, The passing rate of our ED-Con-101 exam guide is high, After deliberate consideration, you can pick one kind of study materials from our websites and prepare the exam.
2026 Latest ED-Con-101 Exam Pdf | Updated 100% Free ED-Con-101 Reliable Test Forum- ED-Con-101 Valid Test Practice 🌹 ED-Con-101 Study Dumps 🏆 ED-Con-101 Latest Test Simulations 🦢 Search on [ [url]www.practicevce.com ] for ED-Con-101 to obtain exam materials for free download 🥀
ractice ED-Con-101 Test Engine[/url] - Get Help From Top Notch Pdfvce ED-Con-101 Exam Practice Questions 🔉 Download ED-Con-101 for free by simply entering ▷ [url]www.pdfvce.com ◁ website 🦗ED-Con-101 Practice Guide[/url]
- ED-Con-101 Valid Test Blueprint 😜 ED-Con-101 Practice Guide 💱 ED-Con-101 Study Dumps 🤰 Search for ▛ ED-Con-101 ▟ and obtain a free download on { [url]www.troytecdumps.com } 😶Test ED-Con-101 Pass4sure[/url]
- Valid ED-Con-101 Test Vce 🔨 Latest ED-Con-101 Exam Materials 🦋 Latest ED-Con-101 Exam Materials 👪 Easily obtain free download of ▛ ED-Con-101 ▟ by searching on [url]www.pdfvce.com ⛰ED-Con-101 Practice Guide[/url]
- Trustable Latest ED-Con-101 Exam Pdf - Passing ED-Con-101 Exam is No More a Challenging Task 💉 Download ▶ ED-Con-101 ◀ for free by simply entering ➽ [url]www.pdfdumps.com 🢪 website 💞Study ED-Con-101 Test[/url]
- ED-Con-101 Latest Test Simulations 🌜 Best ED-Con-101 Preparation Materials 🕟 ED-Con-101 Valid Test Practice 💧 Copy URL [url]www.pdfvce.com open and search for ▶ ED-Con-101 ◀ to download for free 🍦ED-Con-101 Valid Test Practice[/url]
- ED-Con-101 Valid Test Practice 🔁 ED-Con-101 Mock Exams 💘 ED-Con-101 Exam Syllabus 🍝 Download ➥ ED-Con-101 🡄 for free by simply entering ⇛ [url]www.practicevce.com ⇚ website 🏃Test ED-Con-101 Pass4sure[/url]
- [url=https://dimensioneudire.it/?s=Free%20ED-Con-101%20Dumps%20%f0%9f%9f%a2%20ED-Con-101%20Valid%20Test%20Braindumps%20%f0%9f%aa%94%20Study%20ED-Con-101%20Test%20%f0%9f%a4%8d%20Open%20[%20www.pdfvce.com%20]%20enter%20%e2%87%9b%20ED-Con-101%20%e2%87%9a%20and%20obtain%20a%20free%20download%20%f0%9f%8f%9eED-Con-101%20Practice%20Guide]Free ED-Con-101 Dumps 🟢 ED-Con-101 Valid Test Braindumps 🪔 Study ED-Con-101 Test 🤍 Open [ www.pdfvce.com ] enter ⇛ ED-Con-101 ⇚ and obtain a free download 🏞ED-Con-101 Practice Guide[/url]
- Free ED-Con-101 Dumps 🖖 Valid ED-Con-101 Test Vce 🔘 ED-Con-101 Exam Syllabus 🟥 Open ✔ [url]www.troytecdumps.com ️✔️ enter ➤ ED-Con-101 ⮘ and obtain a free download 🦂Latest ED-Con-101 Exam Price[/url]
- ED-Con-101 Test Questions - ED-Con-101 Test Torrent - ED-Con-101 Latest Torrents 😩 Simply search for ▛ ED-Con-101 ▟ for free download on ▛ [url]www.pdfvce.com ▟ 🕌
ractice ED-Con-101 Test Engine[/url] - Latest ED-Con-101 Exam Price 🌑 Latest ED-Con-101 Exam Price 🏹 ED-Con-101 Valid Test Braindumps 🍫 Search for ED-Con-101 and download it for free immediately on ➥ [url]www.examcollectionpass.com 🡄 💻Valid ED-Con-101 Test Vce[/url]
