[General] Exam 300-420 Prep - 300-420 Exam Questions Fee
95
【General】 Exam 300-420 Prep - 300-420 Exam Questions Fee
Posted at 2/11/2026 00:34:55      View:109 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TestsDumps 300-420 dumps from Cloud Storage: https://drive.google.com/open?id=1VDv8ZpSewukoO_Sq2wfPxjPuHuilktqN
TestsDumps customizable practice exams (desktop and web-based) help students know and overcome their mistakes. The customizable Cisco 300-420 practice test means that the users can set the Designing Cisco Enterprise Networks (300-420) Dumps and time according to their needs so that they can feel the real-based 300-420 exam scenario and learn to handle the pressure.
Cisco 300-420 exam covers a wide range of topics, including advanced routing and switching technologies, network virtualization, network automation, and network security. 300-420 exam is designed to test the candidate's knowledge and skills in designing and implementing complex enterprise network solutions that meet the needs of modern businesses.
Cisco ENSDL 300-420 Practice Test Questions, Cisco ENSDL 300-420 Exam Practice Test QuestionsPassing the Cisco 300-420: Designing Cisco Enterprise Networks exam together with the core test, known as Cisco 350-401: Implementing Cisco Enterprise Network Core Technologies, is the major requirement for earning the CCNP Enterprise certification. Acing this exam also grants you another certificate that is Cisco Certified Specialist – Enterprise Design.
Quiz Trustable Cisco - 300-420 - Exam Designing Cisco Enterprise Networks PrepThe passing rate of our 300-420 training quiz is 99% and the hit rate is also high. Our professional expert team seizes the focus of the exam and chooses the most important questions and answers which has simplified the important 300-420 information and follow the latest trend to make the client learn easily and efficiently. We update the 300-420 Study Materials frequently to let the client practice more. We provide the function to stimulate the 300-420 exam and the timing function of our 300-420 study materials to adjust your speed to answer the questions. You will pass the 300-420 exam easily.
Cisco 300-420 Exam is an essential certification for network professionals who are responsible for designing and implementing enterprise networks. 300-420 exam is a part of the Cisco Certified Design Professional (CCDP) certification, which is a globally recognized certification for network designers. The CCDP certification validates the skills required to design and implement complex network solutions in an enterprise environment.
Cisco Designing Cisco Enterprise Networks Sample Questions (Q131-Q136):NEW QUESTION # 131
An engineer must design a WAN solution so that ISP-1 is always preferred over ISP-2. The path via ISP-2 is considered as a backup and must be used only when the path to ISP-1 is down. Which solution must the engineer choose?
  • A. R1:
    - Routes advertised to ISP-1: 0x AS-path prepend
    - Routes received from ISP-1: HIGH local-preference
    - Routes advertised to R2: community NO-EXPORT
    - Routes received from R2: no action
    R2:
    - Routes advertised to ISP-2: 5x AS-path prepend
    - Routes received from ISP-2: LOW local-preference
    - Routes advertised to R1: no action
    - Routes received from R1: no action
  • B. R1:
    - Routes received from ISP-1: LOW local-preference
    - Routes advertised to R2: community NO-ADVERTISE
    R2:
    - Routes received from ISP-2: HIGH local-preference
    - Routes received from R1: community NO-ADVERTISE
  • C. R1:
    - Routes advertised to ISP-1: 5x AS-path prepend
    R2:
    - Routes advertised to ISP-2: 0x AS-path prepend
    - Routes advertised to R1: community NO-EXPORT
  • D. R1:
    - Routes advertised to R2: no action
    - Routes received from R2: community NO-EXPORT
    R2:
    - Routes advertised to ISP-2:5x AS-path prepend
    - Routes advertised to R1: community NO-ADVERTISE
NEW QUESTION # 132
Exhibit:
Refer to the exhibit. An engineer is designing a Layer 2 campus network. The design must support fast convergence and leverage as much bandwidth as possible between layers. Distribution switches do support VSS; unfortunately, not all routing protocols are available for use due to license limitations. Which solution must the engineer choose?
  • A. RSTP
  • B. EtherChannel
  • C. ECMP
  • D. MEC
NEW QUESTION # 133
An engineer uses Postman and YANG to configure a router with:
* OSPF process ID 200
* network 172.16.10.128/26 enabled for Area 0
Which get-config reply verifies that the model set was designed correctly?
  • A. Graphical user interface, text, letter, email Description automatically generated
  • B. Text, letter Description automatically generated
  • C. Text, letter Description automatically generated
  • D. Text, letter Description automatically generated
NEW QUESTION # 134
Which component is part of the Cisco SD-Access overlay architecture?
  • A. spine node
  • B. Cisco DNA Center
  • C. leaf node
  • D. border node
Border Node is part of the overlay.
https://www.cisco.com/c/en/us/td ... s/cisco-sda-design- guide.html#OverlayNetwork
NEW QUESTION # 135
Refer to the exhibit. AS65533 and AS65530 are announcing a partial Internet routing table as well as their IP subnets. An architect must create a design that ensures AS64512 become a transit AS. Which filtering solution must the architect choose?
  • A. Maximum-prefix
  • B. No-advertise
  • C. Next-hop
NEW QUESTION # 136
300-420 Exam Questions Fee: https://www.testsdumps.com/300-420_real-exam-dumps.html
DOWNLOAD the newest TestsDumps 300-420 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1VDv8ZpSewukoO_Sq2wfPxjPuHuilktqN
