[General] Pass Guaranteed Quiz 2026 ACP-120: Fantastic Jira Cloud Administrator Latest Dum
90
General Pass Guaranteed Quiz 2026 ACP-120: Fantastic Jira Cloud Administrator Latest Dum
Posted at 2/11/2026 01:10:13      View136 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 ATLASSIAN ACP-120 dumps are available on Google Drive shared by DumpsQuestion: https://drive.google.com/open?id=12476-mWE2bfa-wbPVMzyh2qPFkzZv6Wm
At present, ATLASSIAN certification exam is the most popular test. Have you obtained ATLASSIAN exam certificate? For example, have you taken ATLASSIAN ACP-120 certification examIf not, you should take action as soon as possible. The certificate is very important, so you must get ACP-120 certificate. Here I would like to tell you how to effectively prepare for ATLASSIAN ACP-120 exam and pass the test first time to get the certificate.
By practicing our ACP-120 exam braindumps, you will get the most coveted certificate smoothly. Before getting ready for your exam, having the ability to choose the best ACP-120 practice materials is the manifestation of wisdom. Our ACP-120 training engine can help you effectively pass the exam within a week. That is also proved that we are worldwide bestseller. Come and buy our ACP-120 study dumps, you will get unexpected surprise.
ATLASSIAN ACP-120 Exam Questions Are Designed By ExpertsFor candidates who are going to attend the exam, the pass rate is quite important. ACP-120 training materials of us are pass guaranteed, and if you cant pass the exam one time, we are money back guaranteed. Besides ACP-120 training materials are verified by skilled experts, therefore the quality and accuracy can be guaranteed, and you can use the ACP-120 Exam Dumps at ease. We also have online and offline chat service stuff, if any other questions, please contact us, we will give a reply to you as quickly as possible.
ATLASSIAN Jira Cloud Administrator Sample Questions (Q16-Q21):NEW QUESTION # 16
Many projects share the same permission scheme and workflow scheme.
The requirements in those projects are:
- Only Translators should be able to use the Translation workflow transition.
- The same team of Translators work across all the projects.
How should Translators be configured to meet these requirements?
  • A. As a group
  • B. As a User custom field
  • C. As a project role
  • D. As a Group custom field
  • E. As single users
Reference: https://confluence.atlassian.com ... ects-776636280.html
NEW QUESTION # 17
Your Jira cloud instance has hundreds of projects which are used only by the development team at your organization.
All projects share a single permission scheme New business requirements state:
* Customer support staff at your organization need to view all issues in all projects
* They also need to share filters with other users
* They should not be granted too much access
Identify the appropriate way to configure customer support staff in Jira (Choose one)
  • A. With the Trusted role
  • B. As a new project role
  • C. As a security level
  • D. With an approved domain
  • E. As a new group
Answer: E
NEW QUESTION # 18
Sundar's development projects are falling behind.
He wants to write a JQL query to find issues that meet all three of these criteria:
1. He is the project lead of the project or the project is DEV.
2. fixVersion had been set to 4.3 at some point but was later removed.
3. Issues were created in the first 15 days of this month.
The Exhibit shows the JQL query he created.
Which statement about Sundar's query is true?
  • A. The query will not return the right set of issues because line 2 only is wrong.
  • B. The query will not return the right set of issues because the parentheses are wrong.
  • C. The query will not return the right set of issues because lines 2 and 3 are wrong.
  • D. The query is valid, but it will not run without a Jira Marketplace app.
  • E. The query will return the right set of issues, but it is inefficient.
  • F. The query is well written and will return the right set of issues.
NEW QUESTION # 19
What is the impact of changing the name of a project?
  • A. Jira will need to be reindexed.
  • B. The project key will also change.
  • C. The old name can no longer be reused.
  • D. The URL for issues will change.
  • E. Issue filters may need to be updated.
Answer: E
Changing the name of a project in Jira Software Cloud affects how the project is displayed and referenced in certain contexts, but it does not have significant system-wide impacts like reindexing or changing URLs. The primary impact is thatissue filters may need to be updated(Option E), as filters often reference the project name.
* Explanation of the Correct Answer (Option E):
* In Jira, issue filters (created using JQL, Jira Query Language) can include the project name to scope the search (e.g., project = "Old Project Name"). If the project name changes, any filters that explicitly reference the old project name will no longer return the correct results and must be updated to use the new project name.
* Exact Extract from Documentation:
Change a project's name
To change the name of a project:
* Go toProject settings > Details.
* Update theNamefield and save changes.Impact: Changing the project name does not affect the project key, issue keys, or URLs. However, JQL queries, filters, or dashboards that reference the project by name (e.g., project = "Old Name") may need to be updated to reflect the new name.Note: Use the project key in JQL queries to avoid issues with name changes, as the key remains constant.(Source: Atlassian Support Documentation, "Manage project settings in Jira Cloud")
* Why This Fits: The documentation explicitly states that changing a project's name impacts JQL- based filters and dashboards that reference the project name, making Option E the correct choice.
* Why Other Options Are Incorrect:
* Jira will need to be reindexed (Option A):
* Changing a project name is a metadata update that does not affect the search index.
Reindexing is required for changes like modifying field configurations or schemes, but not for renaming a project.
* Extract from Documentation:
Reindexing is required when you make changes to field configurations, schemes, or indexing settings.
Changing a project's name or key does not trigger a reindex.
(Source: Atlassian Support Documentation, "Reindex Jira Cloud")
* The URL for issues will change (Option B):
* Issue URLs in Jira are based on the project key and issue key (e.g., https://<site>.atlassian.
net/browse/KEY-123), not the project name. Changing the project name does not affect URLs.
Issue URLs are constructed using the project key and issue key, which remain unchanged when the project name is updated.
(Source: Atlassian Support Documentation, "Manage projects in Jira Cloud")
* The old name can no longer be reused (Option C):
* There is no restriction in Jira preventing the reuse of a previous project name. Project names are not required to be unique, and the old name can be reused for another project or reverted if needed.
Project names can be reused across projects, as they are not required to be unique. The project key, however, must be unique.
(Source: Atlassian Support Documentation, "Create and configure projects")
* The project key will also change (Option D):
* The project key is a separate attribute from the project name and remains unchanged when the name is updated. Changing the project key is a distinct operation that requires admin permissions and affects issue keys and URLs.
The project key is a unique identifier for the project and does not change when you update theproject name.
To change the project key, use theChange project keyoption, which updates all issue keys and URLs.
(Source: Atlassian Support Documentation, "Edit a project key")
* Additional Notes:
* To minimize the impact of project name changes, it's recommended to use the project key in JQL queries (e.g., project = KEY) instead of the project name, as the key is immutable unless explicitly changed.
* Changing the project name requires project admin permissions and is done inProject settings > Details.
Atlassian Support Documentation:Manage project settings in Jira Cloud
Atlassian Support Documentation:Create and configure projects
Atlassian Support Documentation:Reindex Jira Cloud
Atlassian Support Documentation:Edit a project key
NEW QUESTION # 20
Gary complains that he is not getting any notifications when issues are updated.
According to the notification helper, he should receive notifications for all issues he is watching. His coworkers confirm they receive those notifications and they regularly update issues that he is watching.
Which update to Gary's personal settings must have occurred (Choose one)
  • A. The setting You're watching the issue was disabled
  • B. The setting Watch your issues was disabled
  • C. The setting Email notifications format was changed
  • D. The setting You make changes to the issue was disabled
NEW QUESTION # 21
Choosing our ACP-120 exam quiz will be a wise decision that you make, because this decision may have a great impact in your future development. Having the certificate may be something you have always dreamed of, because it can prove that you have certain strength. Our ACP-120 exam questions can provide you with services with pretty quality and help you obtain a certificate. Our ACP-120 Learning Materials are made after many years of practical efforts and their quality can withstand the test of practice. And you will obtain the ACP-120 certification just for our ACP-120 study guide.
ACP-120 Test Centres: https://www.dumpsquestion.com/ACP-120-exam-dumps-collection.html
ATLASSIAN ACP-120 Latest Dumps Ebook If you want to get a higher position in your company, you must do an excellent work, APP Version ACP-120 Test Centres - Jira Cloud Administrator, ATLASSIAN ACP-120 Latest Dumps Ebook One-year Free Update, ATLASSIAN ACP-120 Latest Dumps Ebook Choosing ValidBraindumps is choosing success, ATLASSIAN ACP-120 Latest Dumps Ebook Our after sales services are also considerate, ACP-120 exam materials do everything to save your time.
Bringing Employees into e-Business, Bring together distributed information ACP-120 from heterogeneous environments, If you want to get a higher position in your company, you must do an excellent work.
ACP-120 Exam Latest Dumps Ebook & High Pass-Rate ACP-120 Test Centres Pass SuccessAPP Version Jira Cloud Administrator, One-year Free Update, Choosing ACP-120 Test Centres ValidBraindumps is choosing success, Our after sales services are also considerate.
2026 Latest DumpsQuestion ACP-120 PDF Dumps and ACP-120 Exam Engine Free Share: https://drive.google.com/open?id=12476-mWE2bfa-wbPVMzyh2qPFkzZv6Wm
Posted at 2/19/2026 14:05:28        Only Author  2#
What a great source of motivation, thank you for sharing this article! Sharing the New study AZ-204 questions files test questions with you for freepromotions and salary boosts are within reach!
