ROC-RK3568-PC SE won't boot, can't be flashed, and fails tests
21
Posted at 7/18/2025 21:14:08      View1344 | Replies0        Print      Only Author   [Copy Link] 1#
Hello!
My ROC-RK3568-PC SE board is not booting. It is impossible to flash update.img. I am able to flash the miniloader, but nothing else works after that (listing storage, erasing, running a test, etc.).
Here are a few screenshots:
Here is the boot log:
  1. DDR fdeec6f4fc typ 23/09/25-19:41:25,fwver: v1.19
  2. In
  3. LP4/4x derate en, other dram:1x trefi
  4. ddrconfig:7
  5. LPDDR4X, 324MHz
  6. BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
  7. tdqss: cs0 dqs0: -48ps, dqs1: -144ps, dqs2: -96ps, dqs3: -192ps,
  8. tdqss: cs1 dqs0: -48ps, dqs1: -144ps, dqs2: -72ps, dqs3: -192ps,
  9. change to: 324MHz
  10. clk skew:0x64
  11. change to: 528MHz
  12. clk skew:0x58
  13. change to: 780MHz
  14. clk skew:0x58
  15. change to: 1560MHz(final freq)
  16. PHY drv:clk:36,ca:36,DQ:29,odt:60
  17. vrefinner:16%, vrefout:22%
  18. dram drv:40,odt:80
  19. vref_ca:00000071
  20. clk skew:0x35
  21. cs 0:
  22. the read training result:
  23. DQS0:0x33, DQS1:0x31, DQS2:0x37, DQS3:0x2a,
  24. min  :0x12 0x14 0x14 0x12  0x2  0x6  0x9  0x1 , 0xb  0xa  0x2  0x2  0xc  0x7  0x8  0x5 ,
  25.       0x19 0x17 0x10 0x10  0x7  0x2  0x4  0x5 , 0xb  0x9  0x7  0x2  0xf  0xb  0x7  0xa ,
  26. mid  :0x2c 0x2d 0x2d 0x2b 0x1c 0x20 0x22 0x1b ,0x26 0x25 0x1c 0x1c 0x27 0x21 0x23 0x1f ,
  27.       0x32 0x32 0x2a 0x29 0x21 0x1c 0x1d 0x20 ,0x23 0x20 0x1e 0x18 0x25 0x22 0x1e 0x20 ,
  28. max  :0x47 0x46 0x47 0x44 0x37 0x3b 0x3c 0x36 ,0x41 0x41 0x36 0x36 0x43 0x3b 0x3e 0x39 ,
  29.       0x4b 0x4d 0x44 0x43 0x3c 0x36 0x37 0x3b ,0x3b 0x38 0x36 0x2f 0x3b 0x3a 0x35 0x37 ,
  30. range:0x35 0x32 0x33 0x32 0x35 0x35 0x33 0x35 ,0x36 0x37 0x34 0x34 0x37 0x34 0x36 0x34 ,
  31.       0x32 0x36 0x34 0x33 0x35 0x34 0x33 0x36 ,0x30 0x2f 0x2f 0x2d 0x2c 0x2f 0x2e 0x2d ,
  32. the write training result:
  33. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  34. min  :0x69 0x6d 0x6c 0x6b 0x5b 0x5d 0x5f 0x5e 0x5d ,0x50 0x4e 0x42 0x46 0x51 0x4d 0x4f 0x4d 0x48 ,
  35.       0x63 0x63 0x58 0x5a 0x50 0x4e 0x4e 0x51 0x53 ,0x4a 0x47 0x3f 0x3e 0x4b 0x4d 0x46 0x4e 0x3f ,
  36. mid  :0x83 0x88 0x86 0x85 0x76 0x79 0x7a 0x79 0x77 ,0x6c 0x6a 0x5e 0x62 0x6d 0x69 0x6b 0x6a 0x65 ,
  37.       0x7e 0x7d 0x73 0x76 0x6d 0x6a 0x6b 0x6e 0x6f ,0x66 0x63 0x5c 0x5a 0x69 0x6a 0x63 0x6a 0x5b ,
  38. max  :0x9e 0xa3 0xa0 0xa0 0x92 0x96 0x96 0x95 0x92 ,0x89 0x87 0x7b 0x7e 0x8a 0x86 0x88 0x87 0x82 ,
  39.       0x99 0x98 0x8f 0x92 0x8b 0x87 0x88 0x8b 0x8c ,0x83 0x80 0x7a 0x76 0x87 0x87 0x80 0x86 0x78 ,
  40. range:0x35 0x36 0x34 0x35 0x37 0x39 0x37 0x37 0x35 ,0x39 0x39 0x39 0x38 0x39 0x39 0x39 0x3a 0x3a ,
  41.       0x36 0x35 0x37 0x38 0x3b 0x39 0x3a 0x3a 0x39 ,0x39 0x39 0x3b 0x38 0x3c 0x3a 0x3a 0x38 0x39 ,
  42. cs 1:
  43. the read training result:
  44. DQS0:0x30, DQS1:0x31, DQS2:0x38, DQS3:0x2f,
  45. min  :0x10 0x13 0x13 0x11  0x2  0x5  0x9  0x1 , 0xa  0xb  0x2  0x2  0xe  0x9  0x9  0x4 ,
  46.       0x17 0x16  0xe  0xe  0x5  0x1  0x2  0x4 , 0xd  0x9  0x7  0x1  0xe  0xb  0xa  0xb ,
  47. mid  :0x2a 0x2b 0x2c 0x29 0x1a 0x1e 0x21 0x1a ,0x25 0x25 0x1b 0x1c 0x28 0x22 0x24 0x1e ,
  48.       0x31 0x31 0x29 0x28 0x20 0x1c 0x1d 0x1f ,0x27 0x23 0x21 0x1a 0x27 0x26 0x22 0x23 ,
  49. max  :0x44 0x43 0x45 0x41 0x33 0x38 0x39 0x33 ,0x40 0x40 0x34 0x36 0x42 0x3b 0x3f 0x38 ,
  50.       0x4c 0x4d 0x44 0x43 0x3c 0x38 0x38 0x3b ,0x41 0x3d 0x3b 0x33 0x41 0x41 0x3b 0x3c ,
  51. range:0x34 0x30 0x32 0x30 0x31 0x33 0x30 0x32 ,0x36 0x35 0x32 0x34 0x34 0x32 0x36 0x34 ,
  52.       0x35 0x37 0x36 0x35 0x37 0x37 0x36 0x37 ,0x34 0x34 0x34 0x32 0x33 0x36 0x31 0x31 ,
  53. the write training result:
  54. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  55. min  :0x6a 0x6e 0x6d 0x6d 0x5a 0x5e 0x64 0x63 0x5e ,0x50 0x4e 0x45 0x47 0x51 0x4e 0x4f 0x4d 0x48 ,
  56.       0x68 0x68 0x5c 0x5f 0x54 0x51 0x53 0x57 0x57 ,0x4c 0x48 0x43 0x3d 0x4d 0x4c 0x47 0x4e 0x43 ,
  57. mid  :0x85 0x89 0x88 0x87 0x76 0x7a 0x7e 0x7c 0x78 ,0x6c 0x6b 0x60 0x62 0x6e 0x6b 0x6c 0x69 0x65 ,
  58.       0x83 0x84 0x77 0x7b 0x71 0x6d 0x6f 0x73 0x73 ,0x67 0x64 0x5e 0x5a 0x69 0x69 0x62 0x6a 0x5d ,
  59. max  :0xa1 0xa4 0xa3 0xa2 0x92 0x96 0x98 0x96 0x93 ,0x89 0x88 0x7c 0x7e 0x8b 0x88 0x89 0x86 0x83 ,
  60.       0x9f 0xa0 0x93 0x98 0x8f 0x8a 0x8c 0x8f 0x8f ,0x83 0x80 0x79 0x78 0x86 0x86 0x7e 0x86 0x78 ,
  61. range:0x37 0x36 0x36 0x35 0x38 0x38 0x34 0x33 0x35 ,0x39 0x3a 0x37 0x37 0x3a 0x3a 0x3a 0x39 0x3b ,
  62.       0x37 0x38 0x37 0x39 0x3b 0x39 0x39 0x38 0x38 ,0x37 0x38 0x36 0x3b 0x39 0x3a 0x37 0x38 0x35 ,
  63. DDR fdeec6f4fc typ 23/09/25-19:41:25,fwver: v1.19
  64. In
  65. LP4/4x derate en, other dram:1x trefi
  66. ddrconfig:7
  67. LPDDR4X, 324MHz
  68. BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
  69. tdqss: cs0 dqs0: -48ps, dqs1: -144ps, dqs2: -96ps, dqs3: -192ps,
  70. tdqss: cs1 dqs0: -48ps, dqs1: -144ps, dqs2: -72ps, dqs3: -192ps,
  71. change to: 324MHz
  72. clk skew:0x64
  73. change to: 528MHz
  74. clk skew:0x58
  75. change to: 780MHz
  76. clk skew:0x58
  77. change to: 1560MHz(final freq)
  78. PHY drv:clk:36,ca:36,DQ:29,odt:60
  79. vrefinner:16%, vrefout:22%
  80. dram drv:40,odt:80
  81. vref_ca:00000071
  82. clk skew:0x35
  83. cs 0:
  84. the read training result:
  85. DQS0:0x33, DQS1:0x31, DQS2:0x37, DQS3:0x2a,
  86. min  :0x12 0x14 0x14 0x12  0x2  0x5  0x9  0x2 , 0xb  0xa  0x2  0x2  0xc  0x6  0x8  0x5 ,
  87.       0x19 0x17 0x10 0x10  0x7  0x2  0x4  0x5 , 0xc  0xa  0x7  0x2  0xf  0xb  0x7  0xa ,
  88. mid  :0x2c 0x2d 0x2d 0x2b 0x1c 0x20 0x22 0x1c ,0x26 0x25 0x1c 0x1c 0x27 0x20 0x23 0x1f ,
  89.       0x32 0x32 0x2a 0x29 0x21 0x1c 0x1d 0x1f ,0x23 0x21 0x1e 0x18 0x25 0x22 0x1e 0x20 ,
  90. max  :0x47 0x46 0x47 0x44 0x37 0x3b 0x3c 0x36 ,0x41 0x41 0x36 0x37 0x43 0x3b 0x3e 0x39 ,
  91.       0x4b 0x4d 0x44 0x43 0x3c 0x36 0x37 0x3a ,0x3b 0x38 0x36 0x2f 0x3b 0x3a 0x35 0x37 ,
  92. range:0x35 0x32 0x33 0x32 0x35 0x36 0x33 0x34 ,0x36 0x37 0x34 0x35 0x37 0x35 0x36 0x34 ,
  93.       0x32 0x36 0x34 0x33 0x35 0x34 0x33 0x35 ,0x2f 0x2e 0x2f 0x2d 0x2c 0x2f 0x2e 0x2d ,
  94. the write training result:
  95. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  96. min  :0x6a 0x6c 0x6c 0x6b 0x5b 0x5d 0x62 0x5e 0x5d ,0x50 0x4e 0x42 0x45 0x51 0x4d 0x4f 0x4d 0x48 ,
  97.       0x63 0x63 0x58 0x5a 0x50 0x4e 0x4e 0x51 0x53 ,0x4a 0x47 0x3f 0x3d 0x4c 0x4d 0x46 0x4e 0x3f ,
  98. mid  :0x84 0x87 0x85 0x85 0x76 0x79 0x7c 0x79 0x77 ,0x6c 0x6a 0x5e 0x61 0x6d 0x6a 0x6b 0x6a 0x65 ,
  99.       0x7e 0x7d 0x73 0x76 0x6e 0x6a 0x6b 0x6e 0x6f ,0x66 0x63 0x5c 0x59 0x69 0x6a 0x63 0x6a 0x5b ,
  100. max  :0x9e 0xa3 0x9e 0xa0 0x92 0x96 0x96 0x95 0x92 ,0x89 0x86 0x7b 0x7e 0x8a 0x87 0x88 0x87 0x82 ,
  101.       0x99 0x98 0x8f 0x92 0x8c 0x87 0x88 0x8b 0x8c ,0x83 0x80 0x7a 0x76 0x87 0x87 0x80 0x86 0x78 ,
  102. range:0x34 0x37 0x32 0x35 0x37 0x39 0x34 0x37 0x35 ,0x39 0x38 0x39 0x39 0x39 0x3a 0x39 0x3a 0x3a ,
  103.       0x36 0x35 0x37 0x38 0x3c 0x39 0x3a 0x3a 0x39 ,0x39 0x39 0x3b 0x39 0x3b 0x3a 0x3a 0x38 0x39 ,
  104. cs 1:
  105. the read training result:
  106. DQS0:0x30, DQS1:0x30, DQS2:0x38, DQS3:0x2f,
  107. min  :0x11 0x13 0x13 0x11  0x2  0x5  0x9  0x2 , 0x9  0xa  0x1  0x2  0xc  0x7  0x8  0x4 ,
  108.       0x17 0x16  0xf  0xe  0x5  0x0  0x3  0x4 , 0xd  0x9  0x7  0x2  0xe  0xb  0xa  0xa ,
  109. mid  :0x2a 0x2b 0x2b 0x29 0x1a 0x1e 0x21 0x1a ,0x24 0x24 0x1a 0x1b 0x26 0x20 0x23 0x1d ,
  110.       0x31 0x31 0x29 0x28 0x20 0x1c 0x1d 0x1f ,0x27 0x23 0x21 0x1a 0x27 0x25 0x22 0x23 ,
  111. max  :0x44 0x43 0x44 0x41 0x33 0x38 0x39 0x33 ,0x3f 0x3f 0x33 0x34 0x41 0x3a 0x3f 0x37 ,
  112.       0x4b 0x4d 0x44 0x43 0x3c 0x38 0x38 0x3b ,0x41 0x3d 0x3b 0x33 0x41 0x40 0x3b 0x3c ,
  113. range:0x33 0x30 0x31 0x30 0x31 0x33 0x30 0x31 ,0x36 0x35 0x32 0x32 0x35 0x33 0x37 0x33 ,
  114.       0x34 0x37 0x35 0x35 0x37 0x38 0x35 0x37 ,0x34 0x34 0x34 0x31 0x33 0x35 0x31 0x32 ,
  115. the write training result:
  116. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  117. min  :0x6a 0x6e 0x6d 0x6c 0x5a 0x5e 0x64 0x63 0x5e ,0x50 0x4e 0x45 0x47 0x51 0x4e 0x4f 0x4d 0x48 ,
  118.       0x68 0x68 0x5d 0x5f 0x54 0x51 0x53 0x57 0x57 ,0x4b 0x48 0x43 0x3e 0x4d 0x4c 0x47 0x4e 0x42 ,
  119. mid  :0x85 0x89 0x88 0x87 0x76 0x7a 0x7e 0x7c 0x78 ,0x6c 0x6b 0x60 0x62 0x6d 0x6b 0x6c 0x69 0x65 ,
  120.       0x83 0x84 0x78 0x7b 0x71 0x6d 0x6f 0x73 0x73 ,0x67 0x64 0x5e 0x5b 0x69 0x69 0x63 0x6a 0x5d ,
  121. max  :0xa1 0xa4 0xa3 0xa3 0x92 0x96 0x98 0x96 0x93 ,0x89 0x88 0x7c 0x7e 0x8a 0x88 0x89 0x86 0x83 ,
  122.       0x9f 0xa0 0x93 0x98 0x8f 0x8a 0x8c 0x8f 0x8f ,0x83 0x80 0x79 0x78 0x86 0x86 0x80 0x86 0x78 ,
  123. range:0x37 0x36 0x36 0x37 0x38 0x38 0x34 0x33 0x35 ,0x39 0x3a 0x37 0x37 0x39 0x3a 0x3a 0x39 0x3b ,
  124.       0x37 0x38 0x36 0x39 0x3b 0x39 0x39 0x38 0x38 ,0x38 0x38 0x36 0x3a 0x39 0x3a 0x39 0x38 0x36 ,
  125. DDR fdeec6f4fc typ 23/09/25-19:41:25,fwver: v1.19
  126. In
  127. LP4/4x derate en, other dram:1x trefi
  128. ddrconfig:7
  129. LPDDR4X, 324MHz
  130. BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
  131. tdqss: cs0 dqs0: -48ps, dqs1: -144ps, dqs2: -96ps, dqs3: -192ps,
  132. tdqss: cs1 dqs0: -48ps, dqs1: -144ps, dqs2: -72ps, dqs3: -192ps,
  133. change to: 324MHz
  134. clk skew:0x64
  135. change to: 528MHz
  136. clk skew:0x58
  137. change to: 780MHz
  138. clk skew:0x58
  139. change to: 1560MHz(final freq)
  140. PHY drv:clk:36,ca:36,DQ:29,odt:60
  141. vrefinner:16%, vrefout:22%
  142. dram drv:40,odt:80
  143. vref_ca:00000071
  144. clk skew:0x35
  145. cs 0:
  146. the read training result:
  147. DQS0:0x33, DQS1:0x31, DQS2:0x36, DQS3:0x2a,
  148. min  :0x11 0x14 0x14 0x12  0x3  0x6  0x9  0x1 , 0xb  0xa  0x2  0x2  0xd  0x7  0x8  0x5 ,
  149.       0x17 0x17  0xf 0x10  0x7  0x1  0x4  0x4 , 0xc  0xa  0x7  0x2  0xf  0xb  0x8  0xa ,
  150. mid  :0x2c 0x2d 0x2d 0x2b 0x1d 0x20 0x22 0x1b ,0x26 0x25 0x1c 0x1c 0x27 0x21 0x23 0x1f ,
  151.       0x30 0x31 0x29 0x29 0x21 0x1b 0x1c 0x1e ,0x23 0x21 0x1e 0x18 0x25 0x22 0x1e 0x20 ,
  152. max  :0x47 0x46 0x47 0x44 0x37 0x3b 0x3c 0x36 ,0x41 0x41 0x36 0x37 0x42 0x3b 0x3e 0x39 ,
  153.       0x4a 0x4c 0x43 0x42 0x3b 0x35 0x35 0x39 ,0x3b 0x38 0x36 0x2f 0x3b 0x3a 0x35 0x37 ,
  154. range:0x36 0x32 0x33 0x32 0x34 0x35 0x33 0x35 ,0x36 0x37 0x34 0x35 0x35 0x34 0x36 0x34 ,
  155.       0x33 0x35 0x34 0x32 0x34 0x34 0x31 0x35 ,0x2f 0x2e 0x2f 0x2d 0x2c 0x2f 0x2d 0x2d ,
  156. the write training result:
  157. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  158. min  :0x69 0x6c 0x6c 0x6b 0x5b 0x5d 0x62 0x5e 0x5d ,0x50 0x4d 0x42 0x45 0x51 0x4d 0x4f 0x4d 0x48 ,
  159.       0x63 0x62 0x58 0x5a 0x50 0x4e 0x4e 0x51 0x53 ,0x4a 0x46 0x3f 0x3d 0x4c 0x4d 0x47 0x4e 0x3f ,
  160. mid  :0x83 0x87 0x86 0x84 0x76 0x79 0x7c 0x79 0x77 ,0x6c 0x69 0x5e 0x61 0x6d 0x6a 0x6b 0x6a 0x64 ,
  161.       0x7e 0x7d 0x73 0x76 0x6e 0x6a 0x6b 0x6e 0x70 ,0x66 0x63 0x5c 0x59 0x69 0x6a 0x63 0x6a 0x5b ,
  162. max  :0x9e 0xa3 0xa0 0x9e 0x92 0x95 0x96 0x95 0x92 ,0x89 0x86 0x7b 0x7e 0x8a 0x87 0x88 0x87 0x81 ,
  163.       0x99 0x99 0x8f 0x92 0x8c 0x87 0x88 0x8b 0x8d ,0x83 0x80 0x7a 0x76 0x87 0x87 0x80 0x86 0x78 ,
  164. range:0x35 0x37 0x34 0x33 0x37 0x38 0x34 0x37 0x35 ,0x39 0x39 0x39 0x39 0x39 0x3a 0x39 0x3a 0x39 ,
  165.       0x36 0x37 0x37 0x38 0x3c 0x39 0x3a 0x3a 0x3a ,0x39 0x3a 0x3b 0x39 0x3b 0x3a 0x39 0x38 0x39 ,
  166. cs 1:
  167. the read training result:
  168. DQS0:0x30, DQS1:0x30, DQS2:0x39, DQS3:0x2f,
  169. min  :0x10 0x13 0x13 0x11  0x2  0x5  0x9  0x2 , 0x9  0xa  0x1  0x1  0xb  0x7  0x7  0x2 ,
  170.       0x18 0x17 0x10  0xf  0x7  0x2  0x4  0x4 , 0xd  0x9  0x7  0x1  0xe  0xb  0xa  0xa ,
  171. mid  :0x2a 0x2b 0x2b 0x29 0x1a 0x1e 0x21 0x1a ,0x24 0x24 0x1a 0x1a 0x26 0x20 0x22 0x1d ,
  172.       0x32 0x33 0x2b 0x2a 0x22 0x1e 0x1f 0x20 ,0x27 0x23 0x21 0x1a 0x27 0x26 0x22 0x23 ,
  173. max  :0x44 0x43 0x44 0x41 0x33 0x38 0x39 0x33 ,0x3f 0x3f 0x33 0x34 0x41 0x3a 0x3e 0x38 ,
  174.       0x4d 0x4f 0x46 0x45 0x3e 0x3a 0x3a 0x3c ,0x41 0x3d 0x3b 0x33 0x41 0x41 0x3b 0x3c ,
  175. range:0x34 0x30 0x31 0x30 0x31 0x33 0x30 0x31 ,0x36 0x35 0x32 0x33 0x36 0x33 0x37 0x36 ,
  176.       0x35 0x38 0x36 0x36 0x37 0x38 0x36 0x38 ,0x34 0x34 0x34 0x32 0x33 0x36 0x31 0x32 ,
  177. the write training result:
  178. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  179. min  :0x6a 0x6e 0x6d 0x6c 0x5a 0x5d 0x64 0x63 0x5e ,0x50 0x4e 0x45 0x47 0x51 0x4e 0x4f 0x4e 0x48 ,
  180.       0x68 0x68 0x5d 0x5f 0x54 0x51 0x53 0x57 0x57 ,0x4b 0x48 0x43 0x3e 0x4d 0x4c 0x47 0x4e 0x43 ,
  181. mid  :0x85 0x89 0x88 0x87 0x76 0x79 0x7e 0x7c 0x78 ,0x6c 0x6a 0x60 0x62 0x6d 0x6b 0x6c 0x6a 0x65 ,
  182.       0x83 0x84 0x78 0x7b 0x71 0x6d 0x6f 0x73 0x73 ,0x67 0x63 0x5e 0x5b 0x69 0x69 0x62 0x6a 0x5d ,
  183. max  :0xa1 0xa4 0xa3 0xa3 0x92 0x96 0x98 0x96 0x93 ,0x89 0x87 0x7c 0x7e 0x8a 0x88 0x89 0x86 0x83 ,
  184.       0x9f 0xa0 0x93 0x98 0x8f 0x8a 0x8c 0x8f 0x8f ,0x83 0x7e 0x79 0x78 0x86 0x86 0x7e 0x86 0x78 ,
  185. range:0x37 0x36 0x36 0x37 0x38 0x39 0x34 0x33 0x35 ,0x39 0x39 0x37 0x37 0x39 0x3a 0x3a 0x38 0x3b ,
  186.       0x37 0x38 0x36 0x39 0x3b 0x39 0x39 0x38 0x38 ,0x38 0x36 0x36 0x3a 0x39 0x3a 0x37 0x38 0x35 ,
  187. CA Training result:
  188. cs:0 min  :0x5c 0x4e 0x4e 0x3d 0x50 0x3a 0x4f ,0x5c 0x48 0x4b 0x37 0x4d 0x3d 0x53 ,
  189. cs:0 mid  :0x94 0x92 0x84 0x82 0x84 0x80 0x7b ,0x92 0x8d 0x82 0x7e 0x81 0x82 0x7c ,
  190. cs:0 max  :0xcc 0xd6 0xbb 0xc8 0xb9 0xc6 0xa8 ,0xc8 0xd2 0xb9 0xc6 0xb6 0xc7 0xa5 ,
  191. cs:0 range:0x70 0x88 0x6d 0x8b 0x69 0x8c 0x59 ,0x6c 0x8a 0x6e 0x8f 0x69 0x8a 0x52 ,
  192. cs:1 min  :0x57 0x53 0x4b 0x42 0x4a 0x3f 0x4e ,0x59 0x4c 0x48 0x3c 0x4a 0x40 0x4e ,
  193. cs:1 mid  :0x93 0x90 0x85 0x82 0x84 0x7e 0x7a ,0x93 0x8c 0x82 0x7e 0x83 0x80 0x7a ,
  194. cs:1 max  :0xcf 0xcd 0xbf 0xc2 0xbf 0xbd 0xa7 ,0xcd 0xcd 0xbd 0xc1 0xbc 0xc1 0xa7 ,
  195. cs:1 range:0x78 0x7a 0x74 0x80 0x75 0x7e 0x59 ,0x74 0x81 0x75 0x85 0x72 0x81 0x59 ,
  196. out
  197. U-Boot SPL board init
  198. U-Boot SPL 2017.09-ge4e124926e-230922 #lxh (Sep 25 2023 - 11:07:45), fwver: v1.13
  199. unknown raw ID 0 0 0
  200. unrecognized JEDEC id bytes: 00, 00, 00
  201. Trying to boot from MMC2
  202. Card did not respond to voltage select!
  203. mmc_init: -95, time 9
  204. spl: mmc init failed with error: -95
  205. Trying to boot from MMC1
  206. No bootable slots found, use lastboot.
  207. Trying fit image at 0x4000 sector
  208. Not fit magic
  209. Trying fit image at 0x5000 sector
  210. Not fit magic
  211. A/B: no bootable slot
  212. Trying fit image at 0x4000 sector
  213. Not fit magic
  214. Trying fit image at 0x5000 sector
  215. Not fit magic
  216. A/B: no bootable slot
  217. SPL: failed to boot from all boot devices
  218. ### ERROR ### Please RESET the board ###
  219. # Reset the board to bootrom #
  220. DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21
  221. In
  222. LP4/4x derate en, other dram:1x trefi
  223. SRX
  224. ddrconfig:7
  225. LPDDR4X, 324MHz
  226. BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
  227. tdqss: cs0 dqs0: -48ps, dqs1: -144ps, dqs2: -96ps, dqs3: -192ps,
  228. tdqss: cs1 dqs0: -48ps, dqs1: -144ps, dqs2: -72ps, dqs3: -192ps,
  229. change to: 324MHz
  230. PHY drv:clk:36,ca:36,DQ:29,odt:0
  231. vrefinner:24%, vrefout:41%
  232. dram drv:40,odt:0
  233. clk skew:0x64
  234. rx vref: 32.4%
  235. tx vref: 48.0%
  236. change to: 528MHz
  237. PHY drv:clk:36,ca:36,DQ:29,odt:0
  238. vrefinner:24%, vrefout:41%
  239. dram drv:40,odt:0
  240. clk skew:0x58
  241. rx vref: 30.4%
  242. tx vref: 44.0%
  243. change to: 780MHz
  244. PHY drv:clk:36,ca:36,DQ:29,odt:60
  245. vrefinner:16%, vrefout:41%
  246. dram drv:40,odt:0
  247. clk skew:0x58
  248. rx vref: 16.6%
  249. tx vref: 52.0%
  250. change to: 1560MHz(final freq)
  251. PHY drv:clk:36,ca:36,DQ:29,odt:60
  252. vrefinner:16%, vrefout:22%
  253. dram drv:40,odt:80
  254. vref_ca:00000071
  255. clk skew:0x35
  256. rx vref: 16.6%
  257. tx vref: 21.8%
  258. cs 0:
  259. the read training result:
  260. DQS0:0x30, DQS1:0x32, DQS2:0x38, DQS3:0x2e,
  261. min  :0x10 0x10 0x10 0x10  0x2  0x4  0x7  0x2 , 0xb  0xb  0x1  0x4  0xd  0x9  0x8  0x5 ,
  262.       0x17 0x15  0xe  0xf  0x5  0x2  0x1  0x5 , 0xd  0x8  0x6  0x2  0xf  0xb  0x8  0xb ,
  263. mid  :0x2a 0x29 0x2a 0x29 0x1a 0x1d 0x1f 0x1c ,0x26 0x26 0x1b 0x1d 0x27 0x22 0x23 0x20 ,
  264.       0x31 0x31 0x29 0x29 0x20 0x1c 0x1b 0x20 ,0x27 0x22 0x20 0x1b 0x28 0x26 0x21 0x25 ,
  265. max  :0x44 0x43 0x44 0x43 0x33 0x37 0x38 0x36 ,0x41 0x41 0x36 0x37 0x42 0x3c 0x3e 0x3b ,
  266.       0x4c 0x4d 0x44 0x44 0x3c 0x37 0x36 0x3b ,0x42 0x3d 0x3b 0x34 0x41 0x41 0x3b 0x3f ,
  267. range:0x34 0x33 0x34 0x33 0x31 0x33 0x31 0x34 ,0x36 0x36 0x35 0x33 0x35 0x33 0x36 0x36 ,
  268.       0x35 0x38 0x36 0x35 0x37 0x35 0x35 0x36 ,0x35 0x35 0x35 0x32 0x32 0x36 0x33 0x34 ,
  269. the write training result:
  270. DQS0:0x2c, DQS1:0x19, DQS2:0x27, DQS3:0xf,
  271. DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21
  272. In
  273. LP4/4x derate en, other dram:1x trefi
  274. ddrconfig:7
  275. LPDDR4X, 324MHz
  276. BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
  277. tdqss: cs0 dqs0: -48ps, dqs1: -144ps, dqs2: -96ps, dqs3: -192ps,
  278. tdqss: cs1 dqs0: -48ps, dqs1: -144ps, dqs2: -72ps, dqs3: -192ps,
  279. change to: 324MHz
  280. PHY drv:clk:36,ca:36,DQ:29,odt:0
  281. vrefinner:24%, vrefout:41%
  282. dram drv:40,odt:0
  283. clk skew:0x64
  284. rx vref: 32.4%
  285. tx vref: 50.0%
  286. change to: 528MHz
  287. PHY drv:clk:36,ca:36,DQ:29,odt:0
  288. vrefinner:24%, vrefout:41%
  289. dram drv:40,odt:0
  290. clk skew:0x58
  291. rx vref: 34.4%
  292. tx vref: 44.0%
  293. change to: 780MHz
  294. PHY drv:clk:36,ca:36,DQ:29,odt:60
  295. vrefinner:16%, vrefout:41%
  296. dram drv:40,odt:0
  297. clk skew:0x58
  298. rx vref: 16.6%
  299. tx vref: 52.0%
  300. change to: 1560MHz(final freq)
  301. PHY drv:clk:36,ca:36,DQ:29,odt:60
  302. vrefinner:16%, vrefout:22%
  303. dram drv:40,odt:80
  304. vref_ca:00000071
  305. clk skew:0x35
  306. rx vref: 16.6%
  307. tx vref: 21.8%
  308. cs 0:
  309. the read training result:
  310. DQS0:0x30, DQS1:0x32, DQS2:0x39, DQS3:0x2e,
  311. min  :0x10 0x10 0x10  0xf  0x2  0x4  0x7  0x2 , 0xb  0xb  0x2  0x4  0xc  0x9  0x8  0x6 ,
  312.       0x17 0x17  0xf 0x10  0x7  0x3  0x2  0x7 , 0xd  0x8  0x7  0x2  0xf  0xb  0x7  0xb ,
  313. mid  :0x2a 0x29 0x2a 0x29 0x1a 0x1d 0x1f 0x1c ,0x26 0x26 0x1c 0x1d 0x27 0x22 0x23 0x20 ,
  314.       0x32 0x32 0x2a 0x2a 0x22 0x1d 0x1c 0x21 ,0x27 0x22 0x21 0x1b 0x28 0x26 0x21 0x25 ,
  315. max  :0x44 0x43 0x44 0x43 0x33 0x37 0x38 0x36 ,0x41 0x41 0x36 0x37 0x42 0x3c 0x3e 0x3b ,
  316.       0x4e 0x4e 0x45 0x45 0x3d 0x38 0x37 0x3c ,0x42 0x3d 0x3b 0x34 0x41 0x41 0x3b 0x3f ,
  317. range:0x34 0x33 0x34 0x34 0x31 0x33 0x31 0x34 ,0x36 0x36 0x34 0x33 0x36 0x33 0x36 0x35 ,
  318.       0x37 0x37 0x36 0x35 0x36 0x35 0x35 0x35 ,0x35 0x35 0x34 0x32 0x32 0x36 0x34 0x34 ,
  319. the write training result:
  320. DQS0:0x2c, DQS1:0x19, DQS2:0x27, DQS3:0xf,
  321. min  :0x6b 0x6f 0x6d 0x6c 0x5b 0x5d 0x63 0x62 0x5f ,0x50 0x4e 0x47 0x47 0x51 0x4d 0x4f 0x4d 0x4a ,
  322.       0x67 0x68 0x5d 0x5f 0x55 0x51 0x54 0x59 0x59 ,0x48 0x45 0x3f 0x3c 0x48 0x4a 0x44 0x4a 0x44 ,
  323. mid  :0x86 0x89 0x88 0x86 0x76 0x78 0x7d 0x7c 0x79 ,0x6d 0x6b 0x60 0x61 0x6d 0x69 0x6b 0x69 0x65 ,
  324.       0x82 0x83 0x78 0x7a 0x71 0x6b 0x6e 0x74 0x74 ,0x64 0x61 0x5c 0x59 0x65 0x67 0x61 0x67 0x5e ,
  325. max  :0xa1 0xa3 0xa3 0xa1 0x92 0x94 0x98 0x96 0x93 ,0x8a 0x89 0x7a 0x7b 0x8a 0x86 0x87 0x86 0x80 ,
  326.       0x9e 0x9f 0x94 0x95 0x8e 0x86 0x89 0x8f 0x8f ,0x81 0x7e 0x7a 0x76 0x83 0x84 0x7e 0x84 0x78 ,
  327. range:0x36 0x34 0x36 0x35 0x37 0x37 0x35 0x34 0x34 ,0x3a 0x3b 0x33 0x34 0x39 0x39 0x38 0x39 0x36 ,
  328.       0x37 0x37 0x37 0x36 0x39 0x35 0x35 0x36 0x36 ,0x39 0x39 0x3b 0x3a 0x3b 0x3a 0x3a 0x3a 0x34 ,
  329. cs 1:
  330. the read training result:
  331. DQS0:0x30, DQS1:0x32, DQS2:0x39, DQS3:0x2e,
  332. min  :0x10 0x10 0x10  0xf  0x2  0x4  0x7  0x2 , 0xb  0xb  0x2  0x4  0xc  0x9  0x8  0x6 ,
  333.       0x17 0x17  0xf 0x10  0x7  0x3  0x2  0x7 , 0xd  0x8  0x7  0x2  0xf  0xb  0x7  0xb ,
  334. mid  :0x2a 0x29 0x2a 0x29 0x1a 0x1d 0x1f 0x1c ,0x26 0x26 0x1c 0x1d 0x27 0x22 0x23 0x20 ,
  335.       0x32 0x32 0x2a 0x2a 0x22 0x1d 0x1c 0x21 ,0x27 0x22 0x21 0x1b 0x28 0x26 0x21 0x25 ,
  336. max  :0x44 0x43 0x44 0x43 0x33 0x37 0x38 0x36 ,0x41 0x41 0x36 0x37 0x42 0x3c 0x3e 0x3b ,
  337.       0x4e 0x4e 0x45 0x45 0x3d 0x38 0x37 0x3c ,0x42 0x3d 0x3b 0x34 0x41 0x41 0x3b 0x3f ,
  338. range:0x34 0x33 0x34 0x34 0x31 0x33 0x31 0x34 ,0x36 0x36 0x34 0x33 0x36 0x33 0x36 0x35 ,
  339.       0x37 0x37 0x36 0x35 0x36 0x35 0x35 0x35 ,0x35 0x35 0x34 0x32 0x32 0x36 0x34 0x34 ,
  340. the write training result:
  341. DQS0:0x2c, DQS1:0x19, DQS2:0x27, DQS3:0xf,
  342. min  :0x6b 0x6f 0x6d 0x6c 0x5b 0x5d 0x63 0x62 0x5f ,0x50 0x4e 0x47 0x47 0x51 0x4d 0x4f 0x4d 0x4a ,
  343.       0x67 0x68 0x5d 0x5f 0x55 0x51 0x54 0x59 0x59 ,0x48 0x45 0x3f 0x3c 0x48 0x4a 0x44 0x4a 0x44 ,
  344. mid  :0x86 0x89 0x88 0x86 0x76 0x78 0x7d 0x7c 0x79 ,0x6d 0x6b 0x60 0x61 0x6d 0x69 0x6b 0x69 0x65 ,
  345.       0x82 0x83 0x78 0x7a 0x71 0x6b 0x6e 0x74 0x74 ,0x64 0x61 0x5c 0x59 0x65 0x67 0x61 0x67 0x5e ,
  346. max  :0xa1 0xa3 0xa3 0xa1 0x92 0x94 0x98 0x96 0x93 ,0x8a 0x89 0x7a 0x7b 0x8a 0x86 0x87 0x86 0x80 ,
  347.       0x9e 0x9f 0x94 0x95 0x8e 0x86 0x89 0x8f 0x8f ,0x81 0x7e 0x7a 0x76 0x83 0x84 0x7e 0x84 0x78 ,
  348. range:0x36 0x34 0x36 0x35 0x37 0x37 0x35 0x34 0x34 ,0x3a 0x3b 0x33 0x34 0x39 0x39 0x38 0x39 0x36 ,
  349.       0x37 0x37 0x37 0x36 0x39 0x35 0x35 0x36 0x36 ,0x39 0x39 0x3b 0x3a 0x3b 0x3a 0x3a 0x3a 0x34 ,
  350. CA Training result:
  351. cs:0 min  :0x5c 0x4e 0x4e 0x3e 0x50 0x3a 0x4e ,0x5c 0x48 0x4b 0x37 0x4d 0x3d 0x53 ,
  352. cs:0 mid  :0x94 0x92 0x84 0x83 0x84 0x80 0x7b ,0x92 0x8d 0x82 0x7e 0x81 0x82 0x7c ,
  353. cs:0 max  :0xcc 0xd6 0xbb 0xc8 0xb9 0xc6 0xa8 ,0xc8 0xd2 0xb9 0xc6 0xb6 0xc7 0xa5 ,
  354. cs:0 range:0x70 0x88 0x6d 0x8a 0x69 0x8c 0x5a ,0x6c 0x8a 0x6e 0x8f 0x69 0x8a 0x52 ,
  355. cs:1 min  :0x57 0x53 0x4a 0x42 0x4a 0x3f 0x4e ,0x59 0x4c 0x48 0x3c 0x49 0x40 0x4e ,
  356. cs:1 mid  :0x93 0x90 0x84 0x82 0x84 0x7e 0x7a ,0x93 0x8c 0x82 0x7e 0x83 0x80 0x7a ,
  357. cs:1 max  :0xcf 0xcd 0xbf 0xc2 0xbf 0xbd 0xa7 ,0xcd 0xcd 0xbd 0xc1 0xbd 0xc1 0xa7 ,
  358. cs:1 range:0x78 0x7a 0x75 0x80 0x75 0x7e 0x59 ,0x74 0x81 0x75 0x85 0x74 0x81 0x59 ,
  359. out
  360. Boot1 Release Time: Apr 14 2023 10:04:54, version: 1.17
  361. support nand flash type: slc
  362. ...nandc_flash_init enter...
  363. No.1 FLASH ID:ff ff ff ff ff ff
  364. sfc nor id: 20 41 18
  365. read_lines: 2
  366. UsbBoot ...5531
  367. powerOn 7424
  368. DDR fdeec6f4fc typ 23/09/25-19:41:25,fwver: v1.19
  369. In
  370. LP4/4x derate en, other dram:1x trefi
  371. ddrconfig:7
  372. LPDDR4X, 324MHz
  373. BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
  374. tdqss: cs0 dqs0: -48ps, dqs1: -144ps, dqs2: -96ps, dqs3: -192ps,
  375. tdqss: cs1 dqs0: -48ps, dqs1: -144ps, dqs2: -72ps, dqs3: -192ps,
  376. change to: 324MHz
  377. clk skew:0x64
  378. change to: 528MHz
  379. clk skew:0x58
  380. change to: 780MHz
  381. clk skew:0x58
  382. change to: 1560MHz(final freq)
  383. PHY drv:clk:36,ca:36,DQ:29,odt:60
  384. vrefinner:16%, vrefout:22%
  385. dram drv:40,odt:80
  386. vref_ca:00000071
  387. clk skew:0x35
  388. cs 0:
  389. the read training result:
  390. DQS0:0x33, DQS1:0x31, DQS2:0x37, DQS3:0x2a,
  391. min  :0x12 0x14 0x14 0x12  0x2  0x5  0x9  0x1 , 0xb  0xa  0x2  0x2  0xc  0x7  0x9  0x5 ,
  392.       0x19 0x17 0x10 0x10  0x7  0x2  0x4  0x5 , 0xb  0xa  0x7  0x2  0xf  0xb  0x8  0xa ,
  393. mid  :0x2c 0x2d 0x2d 0x2b 0x1c 0x20 0x22 0x1b ,0x26 0x25 0x1c 0x1c 0x27 0x21 0x23 0x1f ,
  394.       0x32 0x32 0x2a 0x29 0x21 0x1c 0x1d 0x20 ,0x23 0x21 0x1e 0x18 0x25 0x22 0x1e 0x20 ,
  395. max  :0x47 0x46 0x47 0x44 0x37 0x3b 0x3c 0x36 ,0x41 0x41 0x36 0x36 0x43 0x3b 0x3e 0x39 ,
  396.       0x4b 0x4d 0x44 0x43 0x3c 0x36 0x37 0x3b ,0x3b 0x38 0x36 0x2f 0x3b 0x3a 0x35 0x37 ,
  397. range:0x35 0x32 0x33 0x32 0x35 0x36 0x33 0x35 ,0x36 0x37 0x34 0x34 0x37 0x34 0x35 0x34 ,
  398.       0x32 0x36 0x34 0x33 0x35 0x34 0x33 0x36 ,0x30 0x2e 0x2f 0x2d 0x2c 0x2f 0x2d 0x2d ,
  399. the write training result:
  400. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  401. min  :0x69 0x6c 0x6c 0x6b 0x5a 0x5d 0x5f 0x5f 0x5d ,0x50 0x4e 0x42 0x45 0x51 0x4c 0x4f 0x4d 0x48 ,
  402.       0x63 0x62 0x58 0x5a 0x50 0x4e 0x4e 0x51 0x53 ,0x4a 0x47 0x3f 0x3d 0x4c 0x4d 0x47 0x4e 0x3f ,
  403. mid  :0x83 0x87 0x86 0x85 0x76 0x79 0x7a 0x7a 0x77 ,0x6c 0x6a 0x5e 0x61 0x6d 0x69 0x6b 0x6a 0x65 ,
  404.       0x7e 0x7d 0x73 0x76 0x6e 0x6a 0x6b 0x6e 0x70 ,0x66 0x63 0x5c 0x59 0x69 0x6a 0x62 0x6a 0x5b ,
  405. max  :0x9e 0xa3 0xa0 0xa0 0x92 0x96 0x96 0x95 0x92 ,0x89 0x87 0x7b 0x7e 0x8a 0x87 0x88 0x87 0x82 ,
  406.       0x99 0x98 0x8f 0x92 0x8c 0x87 0x88 0x8b 0x8d ,0x83 0x80 0x7a 0x76 0x87 0x87 0x7e 0x86 0x78 ,
  407. range:0x35 0x37 0x34 0x35 0x38 0x39 0x37 0x36 0x35 ,0x39 0x39 0x39 0x39 0x39 0x3b 0x39 0x3a 0x3a ,
  408.       0x36 0x36 0x37 0x38 0x3c 0x39 0x3a 0x3a 0x3a ,0x39 0x39 0x3b 0x39 0x3b 0x3a 0x37 0x38 0x39 ,
  409. cs 1:
  410. the read training result:
  411. DQS0:0x30, DQS1:0x31, DQS2:0x39, DQS3:0x2f,
  412. min  :0x10 0x13 0x13 0x11  0x2  0x5  0x8  0x2 , 0xa  0xb  0x2  0x2  0xe  0x9  0x9  0x4 ,
  413.       0x19 0x17 0x10  0xf  0x7  0x2  0x4  0x5 , 0xd  0x9  0x7  0x2  0xe  0xb  0xa  0xa ,
  414. mid  :0x2a 0x2b 0x2b 0x29 0x1a 0x1e 0x20 0x1a ,0x25 0x25 0x1b 0x1c 0x28 0x22 0x24 0x1e ,
  415.       0x32 0x33 0x2b 0x2a 0x22 0x1d 0x1e 0x20 ,0x27 0x23 0x21 0x1a 0x27 0x26 0x22 0x23 ,
  416. DDR fdeec6f4fc typ 23/09/25-19:41:25,fwver: v1.19
  417. In
  418. LP4/4x derate en, other dram:1x trefi
  419. ddrconfig:7
  420. LPDDR4X, 324MHz
  421. BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
  422. tdqss: cs0 dqs0: -48ps, dqs1: -144ps, dqs2: -96ps, dqs3: -192ps,
  423. tdqss: cs1 dqs0: -48ps, dqs1: -144ps, dqs2: -72ps, dqs3: -192ps,
  424. change to: 324MHz
  425. clk skew:0x64
  426. change to: 528MHz
  427. clk skew:0x58
  428. change to: 780MHz
  429. clk skew:0x58
  430. change to: 1560MHz(final freq)
  431. PHY drv:clk:36,ca:36,DQ:29,odt:60
  432. vrefinner:16%, vrefout:22%
  433. dram drv:40,odt:80
  434. vref_ca:00000071
  435. clk skew:0x35
  436. cs 0:
  437. the read training result:
  438. DQS0:0x33, DQS1:0x31, DQS2:0x36, DQS3:0x2a,
  439. min  :0x12 0x14 0x14 0x12  0x2  0x5  0x9  0x1 , 0xb  0xa  0x2  0x2  0xd  0x7  0x8  0x5 ,
  440.       0x17 0x17 0x10 0x10  0x7  0x0  0x4  0x4 , 0xb  0x9  0x7  0x2  0xf  0xb  0x7  0xa ,
  441. mid  :0x2c 0x2d 0x2d 0x2b 0x1c 0x20 0x22 0x1b ,0x26 0x25 0x1c 0x1c 0x27 0x21 0x23 0x1f ,
  442.       0x30 0x31 0x29 0x29 0x21 0x1a 0x1c 0x1e ,0x23 0x20 0x1e 0x18 0x25 0x22 0x1e 0x20 ,
  443. max  :0x47 0x46 0x47 0x44 0x37 0x3b 0x3b 0x36 ,0x41 0x41 0x36 0x37 0x42 0x3b 0x3e 0x39 ,
  444.       0x4a 0x4c 0x43 0x42 0x3b 0x35 0x35 0x39 ,0x3b 0x38 0x36 0x2f 0x3b 0x3a 0x35 0x37 ,
  445. range:0x35 0x32 0x33 0x32 0x35 0x36 0x32 0x35 ,0x36 0x37 0x34 0x35 0x35 0x34 0x36 0x34 ,
  446.       0x33 0x35 0x33 0x32 0x34 0x35 0x31 0x35 ,0x30 0x2f 0x2f 0x2d 0x2c 0x2f 0x2e 0x2d ,
  447. the write training result:
  448. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  449. min  :0x69 0x6c 0x6c 0x6b 0x5b 0x5d 0x62 0x5e 0x5d ,0x50 0x4e 0x42 0x45 0x51 0x4c 0x4e 0x4d 0x48 ,
  450.       0x63 0x62 0x58 0x5a 0x50 0x4e 0x4e 0x51 0x53 ,0x4a 0x46 0x3f 0x3d 0x4c 0x4d 0x46 0x4e 0x42 ,
  451. mid  :0x83 0x87 0x86 0x84 0x76 0x79 0x7c 0x7a 0x77 ,0x6c 0x6a 0x5e 0x61 0x6d 0x69 0x6b 0x6a 0x65 ,
  452.       0x7e 0x7d 0x73 0x76 0x6d 0x6a 0x6b 0x6e 0x70 ,0x66 0x63 0x5c 0x59 0x69 0x6a 0x63 0x6a 0x5d ,
  453. max  :0x9e 0xa3 0xa0 0x9e 0x92 0x96 0x96 0x96 0x92 ,0x89 0x86 0x7b 0x7e 0x8a 0x87 0x88 0x87 0x82 ,
  454.       0x99 0x98 0x8f 0x92 0x8b 0x87 0x88 0x8b 0x8d ,0x83 0x80 0x7a 0x76 0x87 0x87 0x80 0x86 0x78 ,
  455. range:0x35 0x37 0x34 0x33 0x37 0x39 0x34 0x38 0x35 ,0x39 0x38 0x39 0x39 0x39 0x3b 0x3a 0x3a 0x3a ,
  456.       0x36 0x36 0x37 0x38 0x3b 0x39 0x3a 0x3a 0x3a ,0x39 0x3a 0x3b 0x39 0x3b 0x3a 0x3a 0x38 0x36 ,
  457. cs 1:
  458. the read training result:
  459. DQS0:0x30, DQS1:0x31, DQS2:0x39, DQS3:0x2f,
  460. min  :0x10 0x13 0x13 0x10  0x2  0x6  0x8  0x2 , 0xb  0xb  0x2  0x2  0xe  0x9  0x9  0x5 ,
  461.       0x18 0x17 0x10 0x10  0x7  0x2  0x4  0x4 , 0xd  0x9  0x7  0x2  0xe  0xb  0xa  0xa ,
  462. mid  :0x2a 0x2b 0x2c 0x28 0x1a 0x1f 0x20 0x1a ,0x25 0x25 0x1b 0x1c 0x28 0x22 0x24 0x1e ,
  463.       0x32 0x33 0x2b 0x2a 0x22 0x1e 0x1e 0x20 ,0x27 0x23 0x21 0x1a 0x27 0x26 0x22 0x23 ,
  464. max  :0x44 0x43 0x45 0x41 0x33 0x38 0x39 0x33 ,0x40 0x40 0x34 0x36 0x42 0x3b 0x3f 0x38 ,
  465.       0x4d 0x4f 0x46 0x45 0x3d 0x3a 0x39 0x3c ,0x41 0x3d 0x3b 0x33 0x40 0x41 0x3b 0x3c ,
  466. range:0x34 0x30 0x32 0x31 0x31 0x32 0x31 0x31 ,0x35 0x35 0x32 0x34 0x34 0x32 0x36 0x33 ,
  467.       0x35 0x38 0x36 0x35 0x36 0x38 0x35 0x38 ,0x34 0x34 0x34 0x31 0x32 0x36 0x31 0x32 ,
  468. the write training result:
  469. DQS0:0x2c, DQS1:0x19, DQS2:0x22, DQS3:0xf,
  470. min  :0x6a 0x6e 0x6d 0x6d 0x5a 0x5e 0x64 0x63 0x5e ,0x51 0x4e 0x45 0x47 0x51 0x4e 0x4f 0x4e 0x48 ,
  471.       0x68 0x68 0x5d 0x5f 0x54 0x51 0x53 0x57 0x57 ,0x4c 0x48 0x42 0x3e 0x4d 0x4c 0x47 0x4e 0x43 ,
  472. mid  :0x85 0x89 0x88 0x87 0x76 0x7a 0x7e 0x7c 0x78 ,0x6d 0x6b 0x60 0x62 0x6d 0x6b 0x6c 0x6a 0x65 ,
  473.       0x83 0x84 0x78 0x7b 0x71 0x6d 0x6f 0x73 0x73 ,0x67 0x64 0x5d 0x5b 0x69 0x69 0x62 0x6a 0x5d ,
  474. max  :0xa1 0xa4 0xa3 0xa2 0x92 0x96 0x98 0x96 0x93 ,0x89 0x88 0x7c 0x7e 0x8a 0x88 0x89 0x87 0x83 ,
  475.       0x9f 0xa0 0x93 0x98 0x8f 0x8a 0x8c 0x8f 0x8f ,0x83 0x80 0x79 0x78 0x86 0x86 0x7e 0x86 0x78 ,
  476. range:0x37 0x36 0x36 0x35 0x38 0x38 0x34 0x33 0x35 ,0x38 0x3a 0x37 0x37 0x39 0x3a 0x3a 0x39 0x3b ,
  477.       0x37 0x38 0x36 0x39 0x3b 0x39 0x39 0x38 0x38 ,0x37 0x38 0x37 0x3a 0x39 0x3a 0x37 0x38 0x35 ,
  478. CA Training result:
  479. cs:0 min  :0x5a 0x4e 0x4d 0x3d 0x4e 0x39 0x4e ,0x5a 0x49 0x4a 0x37 0x4b 0x3c 0x51 ,
  480. cs:0 mid  :0x92 0x91 0x83 0x82 0x83 0x7f 0x7a ,0x91 0x8c 0x81 0x7d 0x80 0x80 0x7a ,
  481. cs:0 max  :0xca 0xd5 0xb9 0xc7 0xb8 0xc5 0xa6 ,0xc8 0xd0 0xb8 0xc3 0xb5 0xc5 0xa4 ,
  482. cs:0 range:0x70 0x87 0x6c 0x8a 0x6a 0x8c 0x58 ,0x6e 0x87 0x6e 0x8c 0x6a 0x89 0x53 ,
  483. cs:1 min  :0x56 0x53 0x49 0x43 0x48 0x3f 0x4e ,0x57 0x4c 0x4a 0x3d 0x4a 0x3f 0x50 ,
  484. cs:1 mid  :0x92 0x91 0x84 0x81 0x83 0x7d 0x7a ,0x92 0x8c 0x84 0x7f 0x84 0x80 0x7b ,
  485. cs:1 max  :0xcf 0xcf 0xc0 0xc0 0xbe 0xbc 0xa6 ,0xcd 0xcd 0xbe 0xc1 0xbe 0xc1 0xa7 ,
  486. cs:1 range:0x79 0x7c 0x77 0x7d 0x76 0x7d 0x58 ,0x76 0x81 0x74 0x84 0x74 0x82 0x57 ,
  487. out
  488. U-Boot SPL board init
  489. U-Boot SPL 2017.09-ge4e124926e-230922 #lxh (Sep 25 2023 - 11:07:45), fwver: v1.13
  490. unknown raw ID 0 0 0
  491. unrecognized JEDEC id bytes: 00, 00, 00
  492. Trying to boot from MMC2
  493. Card did not respond to voltage select!
  494. mmc_init: -95, time 9
  495. spl: mmc init failed with error: -95
  496. Trying to boot from MMC1
  497. No bootable slots found, use lastboot.
  498. Trying fit image at 0x4000 sector
  499. Not fit magic
  500. Trying fit image at 0x5000 sector
  501. Not fit magic
  502. A/B: no bootable slot
  503. Trying fit image at 0x4000 sector
  504. Not fit magic
  505. Trying fit image at 0x5000 sector
  506. Not fit magic
  507. A/B: no bootable slot
  508. SPL: failed to boot from all boot devices
  509. ### ERROR ### Please RESET the board ###
  510. # Reset the board to bootrom #
Copy the code
Is the device physically damaged, or is there anything else that can be done?
3_attempt to list storage.png (151.64 KB, Down times: 577)
2_attempt to flash miniloader.png (93.21 KB, Down times: 466)
1_attempt to erase flash.png (64.2 KB, Down times: 455)
