Reliable Microsoft AZ-120 Test Practice | New AZ-120 Exam Testking
Posted at 2/11/2026 16:43:46
What's more, part of that Actual4Exams AZ-120 dumps now are free: https://drive.google.com/open?id=1VswVzkvz_3DFRTuguAMp-LcpWi-CdmmX
The experts of our company are checking whether our AZ-120 test quiz is updated or not every day. We can guarantee that our AZ-120 exam torrent will keep pace with the digitized world by the updating system. We will try our best to help our customers get the latest information about study materials. If you are willing to buy our AZ-120 Exam Torrent, there is no doubt that you can have the right to enjoy the updating system. Once our AZ-120 exam dumps are updated, you will receive the newest information of our AZ-120 test quiz in time. So quickly buy our AZ-120 exam prep now!
To prepare for the Microsoft AZ-120 Certification Exam, candidates should have a strong understanding of SAP applications and Azure cloud services. Microsoft recommends that candidates have at least two years of experience working with SAP workloads and one year of experience working with Azure. Additionally, candidates should have experience with networking, storage, and security concepts, as well as familiarity with Azure Resource Manager templates and PowerShell scripting.
New Microsoft AZ-120 Exam Testking - Exam AZ-120 TrainingOur AZ-120 learning quiz can be downloaded for free trial before purchase, which allows you to understand our sample questions and software usage. It will also enable you to make a decision based on your own needs. And we have organized a group of professionals to revise our AZ-120 Preparation materials, according to the examination status and trend changes. The simple and easy-to-understand language of AZ-120 exam questins frees any learner from studying difficulties.
Microsoft AZ-120 exam is designed for professionals who are responsible for planning and administering Microsoft Azure for SAP workloads. AZ-120 exam tests candidates' knowledge and skills in various areas, including deployment, migration, security, and monitoring of SAP workloads on Azure. AZ-120 Exam is intended for individuals who have a strong understanding of SAP applications and infrastructure, as well as experience with Azure technologies and services.
Microsoft Planning and Administering Microsoft Azure for SAP Workloads Sample Questions (Q276-Q281):NEW QUESTION # 276
You need to deploy an SAP production landscape on Azure. The solution must be supported by the SAP production landscape and must minimize costs.
Which Azure virtual machine series should you use for each SAP workload? To answer, drag the appropriate series to the correct workloads. Each series may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 277
A company named Contoso, Ltd. has users across the globe. Contoso is evaluating whether to migrate SAP to Azure.
The SAP environment runs on SUSE Linux Enterprise Server (SLES) servers and SAP HANA databases. The Suite on HANA database is 4 TB.
You need to recommend a migration solution to migrate SAP application servers and the SAP HANA databases. The solution must minimize downtime.
Which migration solutions should you recommend? To answer, select the appropriate options in the answer area.
Box 1: Azure Site Recovery
Microsoft Azure Site Recovery (ASR) now supports SUSE Linux Enterprise Server 11 SP3/SP4 and SUSE Linux Enterprise Server 12 SP1/SP2/SP3. This is great for customers that are planning to migrate systems to Microsoft Azure or customers who need to have a business continuity strategy for their Azure deployments.
Azure Site Recovery enables SUSE customers to migrate their non-Azure virtual machines or physical servers to Microsoft Azure virtual machines.
Box 2: SAP Hana System replication
https://www.suse.com/c/asr_supports_suse/
https://www.netapp.com/us/media/tr-4746.pdf
NEW QUESTION # 278
You have an Azure Availability Set that is configured as shown in the following exhibit.
Box 1: the same fault domain
Fault domains define the group of virtual machines that share a common power source and network switch. If a storage fault domain fails due to hardware or software failure, only the VM instance with disks on the storage fault domain fails.
Box 2: managed disks
Managed disks provide better reliability for Availability Sets by ensuring that the disks of VMs in an Availability Set are sufficiently isolated from each other to avoid single points of failure. It does this by automatically placing the disks in different storage fault domains (storage clusters) and aligning them with the VM fault domain.
https://docs.microsoft.com/en-us ... manage-availability
NEW QUESTION # 279
You have an Azure subscription.
You plan to deploy a QA landscape to SAP on Azure by using Azure Center for SAP solutions.
You need to use the Azure command-line interface (CLI) to deploy the landscape.
How should you complete the command? To answer, select the appropriate options in the answer area.
NEW QUESTION # 280
You have an on-premises SAP landscape and an Azure subscription that contains a virtual network named VNET1. VNET1 has the following settings.
You plan to migrate the landscape to Azure.
You need to configure VNET1 to support the SAP landscape.
Use the drop-down menus to select the answer choice that completes each statement based on the information presented in the settings.
Graphical user interface, text, application, table Description automatically generated
Box 1: add a virtual network gateway
Box 2: use remote gateways
Each virtual network, regardless of whether peered with another virtual network, can still have its own gateway to connect to an on-premises network. When you peer virtual networks, you can also configure the gateway in the peered virtual network as a transit point to an on-premises network. In this case, the virtual network that uses a remote gateway cannot have its own gateway. A virtual network can have only one gateway that can be either a local or remote gateway (in the peered virtual network).
https://docs.microsoft.com/en-us ... rk-peering-overview
NEW QUESTION # 281
New AZ-120 Exam Testking: https://www.actual4exams.com/AZ-120-valid-dump.html
- Valid AZ-120 Test Guide 🥕 Valid AZ-120 Exam Online 🚏 Certification AZ-120 Cost 💲 Search on ▶ [url]www.prepawaypdf.com ◀ for 【 AZ-120 】 to obtain exam materials for free download 🟥AZ-120 Passing Score Feedback[/url]
- AZ-120 Dumps Guide 🏧 Valid AZ-120 Exam Question 🍀 AZ-120 New Braindumps Ebook ⛰ Easily obtain ⮆ AZ-120 ⮄ for free download through “ [url]www.pdfvce.com ” 🍊Certification AZ-120 Cost[/url]
- Pass Guaranteed 2026 Microsoft AZ-120: Useful Reliable Planning and Administering Microsoft Azure for SAP Workloads Test Practice 🌗 Download ⇛ AZ-120 ⇚ for free by simply entering ➠ [url]www.troytecdumps.com 🠰 website 🆑Valid AZ-120 Test Guide[/url]
- Free PDF Reliable AZ-120 Test Practice – The Best New Exam Testking for AZ-120 - Authoritative Exam AZ-120 Training 🌀 Search for 「 AZ-120 」 and download exam materials for free through 【 [url]www.pdfvce.com 】 🔎
ass AZ-120 Test[/url] - Planning and Administering Microsoft Azure for SAP Workloads easy pass guide - AZ-120 training pdf - Planning and Administering Microsoft Azure for SAP Workloads torrent vce 🔈 Immediately open ( [url]www.dumpsquestion.com ) and search for ➠ AZ-120 🠰 to obtain a free download 👙Valid AZ-120 Exam Online[/url]
- AZ-120 Practice Test Online 🐤 Certification AZ-120 Cost 🙎 Useful AZ-120 Dumps 👲 ☀ [url]www.pdfvce.com ️☀️ is best website to obtain 【 AZ-120 】 for free download ⛰Valid AZ-120 Exam Voucher[/url]
- Planning and Administering Microsoft Azure for SAP Workloads easy pass guide - AZ-120 training pdf - Planning and Administering Microsoft Azure for SAP Workloads torrent vce ⚒ Open ➠ [url]www.testkingpass.com 🠰 and search for ( AZ-120 ) to download exam materials for free 🤾Valid AZ-120 Test Guide[/url]
- 100% Pass Quiz 2026 Authoritative Microsoft AZ-120: Reliable Planning and Administering Microsoft Azure for SAP Workloads Test Practice 🤐 ➠ [url]www.pdfvce.com 🠰 is best website to obtain ➥ AZ-120 🡄 for free download 🍙AZ-120 Valid Test Papers[/url]
- Free PDF Reliable AZ-120 Test Practice – The Best New Exam Testking for AZ-120 - Authoritative Exam AZ-120 Training 🧰 Go to website ▛ [url]www.validtorrent.com ▟ open and search for 《 AZ-120 》 to download for free 🏺Certification AZ-120 Cost[/url]
- AZ-120 Valid Test Papers 😁 Valid AZ-120 Exam Voucher 🥕 Useful AZ-120 Dumps 🧇 Download ▷ AZ-120 ◁ for free by simply searching on ⏩ [url]www.pdfvce.com ⏪ 🍱AZ-120 Practice Test Online[/url]
- 100% Pass Quiz 2026 Authoritative Microsoft AZ-120: Reliable Planning and Administering Microsoft Azure for SAP Workloads Test Practice 🐗 Search for ▶ AZ-120 ◀ and easily obtain a free download on ⇛ [url]www.torrentvce.com ⇚ 🦚Reliable AZ-120 Exam Answers[/url]
- www.stes.tyc.edu.tw, wanderlog.com, www.stes.tyc.edu.tw, ppkd.humplus.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, devfolio.co, www.stes.tyc.edu.tw, onlyfans.com, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New AZ-120 dumps are available on Google Drive shared by Actual4Exams: https://drive.google.com/open?id=1VswVzkvz_3DFRTuguAMp-LcpWi-CdmmX
