Posted at 2/12/2026 01:07:08
此外,這些VCESoft CISSP考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1IIo1jwjQ_6RIu8HTGd4Ed6FSFuPJ7uaA
關於CISSP考試的問題,我們VCESoft擁有一個偉大的良好品質,將是最值得信賴的來源,從成千上萬的大量註冊部門的回饋,大量的深入分析,我們是在一個位置以確定哪些供應商將為你提供更新和相關CISSP練習題和優秀的高品質CISSP實踐的檢驗。我們VCESoft ISC的CISSP培訓資料不斷被更新和修改,擁有最高的ISC的CISSP培訓經驗,今天想獲得認證就使用我們VCESoft ISC的CISSP考試培訓資料吧,來吧,將VCESoft ISC的CISSP加入購物車吧,它會讓你看到你意想不到的效果。
競爭頗似打網球,與球藝勝過你的對手比賽,可以提高你的水準。你可以選擇參加最近很有人氣的 ISC 的 CISSP 認證考試。得到這個考試的認證資格,你可以得到很大的好處。如果你要參加 CISSP 認證考試,ISC 的 CISSP 考古題是你最好的準備工具。這個資料可以幫助你輕鬆地通過考試。這是一個評價很高的資料,有了它,你就不用再擔心你的考試了。
最新的CISSP認證考試的新考古題匯總ISC CISSP認證考試是目前IT人士報名參加的考試中很受歡迎的一個認證考試。通過了ISC CISSP認證考試不僅能使你工作和生活帶來提升,而且還能鞏固你在IT 領域的地位。但是事實情況是它通過率確很低。
最新的 ISC Certification CISSP 免費考試真題 (Q350-Q355):問題 #350
When preparing a business continuity plan, who of the following is responsible for identifying and prioritizing time-critical systems?
- A. Functional business units
- B. Executive management staff
- C. Senior business unit management
- D. BCP committee
答案:C
解題說明:
Explanation/Reference:
Senior management is ultimately responsible for all phases of the plan, and who should be most concerned about the protection of its assets. They must sign off on all policy issues, and they will be held liable for overall success or failure of a security solution.
Incorrect Answers:
A: If possible the BCP plan should by endorsed by the Executive management staff, but the Executive management staff is not responsible for identifying and prioritizing time-critical systems.
C: The BCP committee does not identify and prioritize systems. The BCP committee oversees, initiates, plans, approves, tests and audits the BCP. It also implements the BCP, coordinates activities, approve the BIA survey. The BCP committee also oversees the creation of continuity plans and reviews the results of quality assurance activities
D: Functional business units are a part of the BCP committee. Functional business units are not responsible for identifying and prioritizing time-critical system.
Stewart, James M., Ed Tittel, and Mike Chapple, CISSP: Certified Information Systems Security Professional Study Guide, 5th Edition, Sybex, Indianapolis, 2011, p. 55
問題 #351
What is surreptitious transfer of information from a higher classification compartment to a lower classification compartment without going through the formal communication channels?
- A. Data Transfer
- B. Security domain
- C. Covert Channel
- D. Object Reuse
答案:C
解題說明:
A covert channel is a way for an entity to receive information in an unauthorized manner. It is an information flow that is not controlled by a security mechanism. This type of information path was not developed for communication; thus, the system does not properly protect this path, because the developers never envisioned information being passed in this way. Receiving information in this manner clearly violates the system's security policy.
The channel to transfer this unauthorized data is the result of one of the following conditions:
Improper oversight in the development of the product
Improper implementation of access controls within the software
Existence of a shared resource between the two entities which are not properly controlled
Incorrect Answers:
A: Object reuse is where media is given to someone without first deleting any existing data. This is not what is described in the question.
C: The term security describes a logical structure (domain) where resources are working under the same security policy and managed by the same group. This is not what is described in the question.
D: Data transfer describes all types and methods of transferring data whether it is authorized or not. It does not describe the specific type of transfer in the question.
Harris, Shon, All In One CISSP Exam Guide, 6th Edition, McGraw-Hill, New York, 2013, p. 378
問題 #352
Which one of the following is an advantage of an effective release control strategy form a configuration control standpoint?
- A. Ensures that a trace for all deliverables is maintained and auditable
- B. Enforces backward compatibility between releases
- C. Allows for future enhancements to existing features
- D. Ensures that there is no loss of functionality between releases
答案:D
解題說明:
Section: Software Development Security
問題 #353
The Diffie-Hellman algorithm is used for:
- A. Non-repudiation
- B. Digital signature
- C. Key agreement
- D. Encryption
答案:C
解題說明:
The Diffie-Hellman algorithm is the first asymmetric key agreement algorithm, which was developed by Whitfield Diffie and Martin Hellman.
Incorrect Answers:
A, B: The Diffie-Hellman algorithm does not offer encryption or digital signature functionality.
D: Non-repudiation requires digital signature functionality, which the Diffie-Hellman algorithm does not offer.
Harris, Shon, All In One CISSP Exam Guide, 6th Edition, McGraw-Hill, 2013, pp. 812, 813, 830
問題 #354
Enterprise Access Management (EAM) provides access control
management services to Web-based enterprise systems. Which of the
following functions is NOT normally provided by extant EAM
approaches?
- A. Interoperability among EAM implementations
- B. Accommodation of a variety of authentication mechanisms
- C. Role-based access control
- D. Single sign-on
答案:A
解題說明:
In general, security credentials produced by one EAM solution are
not recognized by another implementation. Thus, reauthentication is
required when linking from one Web site to another related Web site
if the sites have different EAM implementations.
Answer "Single sign-on" (SSO) is approached in a number of ways. For example,
SSO can be implemented on Web applications in the same domain
residing on different servers by using nonpersistent, encrypted
cookies on the client interface. This is accomplished by providing a
cookie to each application that the user wishes to access. Another
solution is to build a secure credential for each user on a reverse
proxy that is situated in front of the Web server. The credential is,
then, presented at each instance of a user attempting to access
protected Web applications. For answer b, most EAM solutions
accommodate a variety of authentication technologies, including
tokens, ID/passwords and digital certificates. Similarly, for answer
c, EAM solutions support role-based access controls, albeit they may
be implemented in different fashions. Enterprise-level roles should
be defined in terms that are universally accepted across most ecommerce applications.
問題 #355
當我們第一次開始提供ISC的CISSP考試的問題及答案和考試模擬器,我們做夢也沒有想到,我們將做出的聲譽,我們現在要做的是我們難以置信的擔保形式,VCESoft的擔保,你會把你的ISC的CISSP考試用來嘗試我們ISC的CISSP培訓產品之一,這是正確的,合格率100%,我們能保證你的結果。
CISSP考試指南: https://www.vcesoft.com/CISSP-pdf.html
VCESoft:提供兩千多種國際IT認證考試題庫,幫您輕松通過CCNA, CCNP, MCTS, MCPD ,MCITP, ISC Certification, OCA, OCP, SCJP等認證考試… CISSP,非常不錯,覆蓋100%,已過,ISC 新版CISSP考古題 如果你回答“是”,那趕緊來參加考試吧,我們為您提供涵蓋真實測試的題目和答案的試題,ISC 新版CISSP考古題 我可以毫不猶豫的說這絕對是一份具有針對性的培訓資料,在此系列中的ISC CISSP考試指南資料庫專業管理員認證(CISSP考試指南),業界簡稱ISC CISSP考試指南證照,談到EXIN的ITIL-F考試,VCESoft CISSP考試指南 EXIN的ITIL-F的考試培訓資料一直領先於其他的網站,因為VCESoft CISSP考試指南有一支強大的IT精英團隊,他們時刻跟蹤著最新的 EXIN的ITIL-F的考試培訓資料,用他們專業的頭腦來專注於EXIN的ITIL-F的考試培訓資料。
林夕麒明白馬三這是好意提醒自己,在我看來,妳不過是壹個浪得虛名之輩而已,VCESoft:提供兩千多種國際IT認證考試題庫,幫您輕松通過CCNA, CCNP, MCTS, MCPD ,MCITP, ISC Certification, OCA, OCP, SCJP等認證考試… CISSP,非常不錯,覆蓋100%,已過。
真實的新版CISSP考古題 |高通過率的考試材料|一流的CISSP考試指南如果你回答“是”,那趕緊來參加考試吧,我們為您提供涵蓋真實測試的題目和答案的試題,CISSP信息資訊我可以毫不猶豫的說這絕對是一份具有針對性的培訓資料,在此系列中的ISC資料庫專業管理員認證(ISC Certification),業界簡稱ISC證照。
談到EXIN的ITIL-F考試,VCESoft EXIN的ITIL-F的考試培訓資料一直CISSP領先於其他的網站,因為VCESoft有一支強大的IT精英團隊,他們時刻跟蹤著最新的 EXIN的ITIL-F的考試培訓資料,用他們專業的頭腦來專注於EXIN的ITIL-F的考試培訓資料。
- 權威的新版CISSP考古題 |高通過率的考試材料|準確的CISSP考試指南 🦞 透過《 [url]www.newdumpspdf.com 》搜索▛ CISSP ▟免費下載考試資料CISSP考試內容[/url]
- CISSP學習指南 🛹 CISSP更新 🚡 CISSP PDF題庫 🏭 複製網址【 [url]www.newdumpspdf.com 】打開並搜索➥ CISSP 🡄免費下載CISSP PDF題庫[/url]
- 最新發布的新版CISSP考古題 - ISC CISSP考試指南:Certified Information Systems Security Professional (CISSP) 🤳 進入▶ [url]www.pdfexamdumps.com ◀搜尋“ CISSP ”免費下載CISSP考古題介紹[/url]
- 值得信賴的新版CISSP考古題和資格考試領導者和準確的CISSP考試指南 🪓 透過「 [url]www.newdumpspdf.com 」搜索➥ CISSP 🡄免費下載考試資料最新CISSP題庫資源[/url]
- 資格考試中的最佳新版CISSP考古題和領先供應商&最近更正的ISC Certified Information Systems Security Professional (CISSP) 🎠 在【 [url]www.newdumpspdf.com 】網站上免費搜索☀ CISSP ️☀️題庫CISSP信息資訊[/url]
- CISSP新版題庫上線 🏵 CISSP認證考試解析 🚗 CISSP認證考試 🟩 免費下載✔ CISSP ️✔️只需在「 [url]www.newdumpspdf.com 」上搜索CISSP學習指南[/url]
- 權威的新版CISSP考古題 |高通過率的考試材料|準確的CISSP考試指南 🏫 免費下載▶ CISSP ◀只需在▛ tw.fast2test.com ▟上搜索CISSP信息資訊
- CISSP更新 🤙 CISSP考古題介紹 🕊 CISSP考古題介紹 🕯 「 [url]www.newdumpspdf.com 」網站搜索▛ CISSP ▟並免費下載CISSP新版題庫上線[/url]
- 資格考試中的最佳新版CISSP考古題和領先供應商&最近更正的ISC Certified Information Systems Security Professional (CISSP) 🌁 到( tw.fast2test.com )搜尋▷ CISSP ◁以獲取免費下載考試資料CISSP新版題庫上線
- 更新的ISC 新版CISSP考古題是行業領先材料&有效的CISSP:Certified Information Systems Security Professional (CISSP) 📝 「 [url]www.newdumpspdf.com 」上的免費下載「 CISSP 」頁面立即打開最新CISSP題庫資訊[/url]
- 最新CISSP題庫資訊 🐊 CISSP更新 🤗 最新CISSP題庫資源 🕡 複製網址⮆ [url]www.newdumpspdf.com ⮄打開並搜索☀ CISSP ️☀️免費下載CISSP考題資訊[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, schoolido.lu, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, adrcentre.org, Disposable vapes
