[General] New Microsoft MB-820 Braindumps Questions, MB-820 Latest Braindumps Book
112
【General】 New Microsoft MB-820 Braindumps Questions, MB-820 Latest Braindumps Book
Posted at 2/12/2026 02:56:35      View:94 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ValidExam MB-820 dumps from Cloud Storage: https://drive.google.com/open?id=1MKytvXbwAeMUN77ZAS8brb7WDnX7-pbK
Practicing under these situations helps to kill Microsoft Dynamics 365 Business Central Developer (MB-820) exam anxiety. Questions in desktop-based mock exams are identical to the real ones. Our practice exams give you options to change their durations and questions' numbers to polish your skills. You can easily assess your readiness with the assistance of results produced by the practice exam.
Our MB-820 exam material boosts both the high passing rate which is about 98%-100% and the high hit rate to have few difficulties to pass the test. Our MB-820 exam simulation is compiled based on the resources from the authorized experts’ diligent working and the real exam and confer to the past years' exam papers thus they are very practical. The content of the questions and answers of MB-820 Exam Questions is refined and focuses on the most important information. To let the clients be familiar with the atmosphere and pace of the real MB-820 exam we provide the function of stimulating the exam.
MB-820 Latest Braindumps Book | MB-820 Free DumpsIf you have any problems installing and using MB-820 study engine, you can contact our staff immediately. You know, we have so many users. If you do not immediately receive a link from us, you can send us an email to urge us. We hope you can use our MB-820 Exam simulating as soon as possible! Our system is very smooth and you basically have no trouble. We hope you enjoy using our MB-820 study engine.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q25-Q30):NEW QUESTION # 25
A company plans to change a field on the Resource Card page in a Base Application.
You need to hide the field "Unit Price" from the Resource Card page.
Which code snippet should you use?
  • A.
  • B.
  • C.
  • D.
To hide the field "Unit Price" from the Resource Card page in Microsoft Dynamics 365 Business Central, you need to modify the visibility property of the field using the modify keyword, which allows you to change the properties of an existing field on a page.
modify("Unit Price") is the correct way to target an existing field on a page (like the Resource Card page).
The line Visible = false; makes the field invisible on the page.
Here's a breakdown of why each option is right or wrong:
Option A:
Uses addlast("Unit Price"), which is incorrect because you are not adding a new field; you're modifying an existing one. Also, Visible = false is correct for hiding a field, but the wrong method (addlast) is used.
Option B:
Uses modify("Unit Price") with Enabled = false;. This would disable the field (make it non-editable), not hide it. The field would still be visible, so this does not meet the requirement.
Option C:
Uses addlast("Unit Price"), which is incorrect, and Enabled = false;, which would disable the field, not hide it.
Option D:
modify("Unit Price") { Visible = false; } is the correct syntax for hiding the field on the page.
Correct Code Snippet:
Visible = false;
This hides the "Unit Price" field from the Resource Card page.
NEW QUESTION # 26
You are writing a procedure to block all inventory items with numbers that do not start with the letter S.
You need to complete the procedure.
How should you complete the code expressions? To answer, select the appropriate options in the answer area.
procedure BlockNonSItems()
var
Item: Record Item;
begin
// Reset the Item record to clear any previous filters.
Item.Reset();
// Set the filter to exclude items that start with 'S'.
Item.SetFilter("No.", '<>%1*', 'S');
// Find each item that matches the filter.
if Item.FindSet() then
repeat
// Set the Blocked field to true to block the item.
Item.Blocked := true;
// Save the changes to the Item record.
Item.Modify();
until Item.Next() = 0; // Continue until no more items are found.
end;
NEW QUESTION # 27
A company plans to deploy Business Central.
The company has the following deployment requirements:
* Use the company hardware architecture to run the deployment.
* Use sandbox environments to develop extensions.
* Allow tenants to connect to Shopify with the standard connector.
* Use Microsoft Power Automate to create a workflow that calls a business event.
You need to identify the deployment type for each requirement.
Which deployment types should you use? To answer, move the appropriate deployment types to the correct requirements. You may use each deployment type once, more than once, or not at all.
* Use the company hardware architecture to run the deployment: On-premises
* Use sandbox environments to develop extensions: Online
* Allow tenants to connect to Shopify with the standard connector: Online
* Use Microsoft Power Automate to create a workflow that calls a business event: Online When deploying Microsoft Dynamics 365 Business Central, there are two main deployment types to consider:
On-premises and Online.
* On-premises Deployment:
* The requirement to use the company's hardware architecture implies a need for an on-premises deployment. This is because on-premises deployment allows for the application to be installed and run directly from the company's in-house servers and computing infrastructure, giving full control over the environment and data.
* Online Deployment:
* The use of sandbox environments for developing extensions is a feature provided in the online version of Business Central. Sandbox environments are a part of the service offered in the cloud- based version, which allows developers to test and develop without affecting the live environment.
* Connection to Shopify with the standard connector implies an online deployment. The standard connector is typically a cloud-based service that allows Business Central to connect with other cloud platforms like Shopify, which is more seamlessly integrated with the online version.
* Lastly, the use of Microsoft Power Automate to create a workflow that calls a business event suggests an online deployment. Power Automate is a cloud-based service designed to create automated workflows between applications and services - which aligns with the services provided by the online version of Business Central.
Therefore, each requirement aligns with the deployment types as indicated above.
NEW QUESTION # 28
You need to create the codeunit to read the POS terminal APIs.
How should you complete the code segment? To answer, select the appropriate options in the answer area.
NOTE; Each correct selection is worth one point.
codeunit 52102 "POS API Management"
Access = Public;
Permissions = TableData "POS Information" = rwdx;
trigger OnRun()
begin
readAPI();
end;
procedure readAPI()
begin
// Your code here to read from the POS API
end;
NEW QUESTION # 29
You need to configure telemetry for the SaaS tenant and test whether the ingested signals are displayed.
The correct sequence of actions to configure telemetry for the SaaS tenant and test whether the ingested signals are displayed would be:
* Create an Azure Application Insights instance by using the Azure Portal in the Customer's subscription.
* Select the environment in the Admin Center and place the connection string in the Application Insights Connection String field.
* Select the Application Insights instance, select Logs and then inspect the Traces table.
To set up telemetry for a SaaS tenant using Azure Application Insights, you need to follow these steps:
* Create an Azure Application Insights instance: This is the first step where you create an instance in Azure that will collect the telemetry data. This should be done in the customer's Azure subscription because it's their data that you're monitoring.
* Configure the SaaS tenant to use the created Application Insights instance: This involves entering the correct connection string in the Business Central Admin Center so that telemetry data from the tenant is sent to the Application Insights instance.
* Verify that telemetry is being collected: After configuring, you would check if the telemetry is arriving as expected by inspecting the Traces table in the Azure Application Insights instance. The 'Traces' table holds the telemetry data, which you can query to verify that the correct signals are being ingested.
NEW QUESTION # 30
Many applicants do not fulfill their dream of becoming professionals because of using outdated exam preparation material. Failure in the Microsoft Dynamics 365 Business Central Developer exam leads them to anxiety. If this situation sounds familiar, do not waste time and get your hands on Microsoft MB-820 for exam preparation.
MB-820 Latest Braindumps Book: https://www.validexam.com/MB-820-latest-dumps.html
Microsoft New MB-820 Braindumps Questions Our company emphasizes the interaction with customers, If you have any questions about our MB-820 lead4pass dumps, please feel free to contact our support, May be you will meet some difficult or problems when you prepare for your MB-820 exam, you even want to give it up, Microsoft New MB-820 Braindumps Questions It is developed and maintained by our company's professional personnel and is dedicated to provide the first-tier service to the clients.
Automatically switches to summer time for display purposes only) zone New MB-820 Braindumps Questions |, The key is to document the permission in the notes we file with every call, Our company emphasizes the interaction with customers.
100% Pass Quiz Microsoft - MB-820 –Reliable New Braindumps QuestionsIf you have any questions about our MB-820 lead4pass dumps, please feel free to contact our support, May be you will meet some difficult or problems when you prepare for your MB-820 exam, you even want to give it up.
It is developed and maintained by our company's MB-820 professional personnel and is dedicated to provide the first-tier service to the clients, With the help of MB-820 exam practice questions, you can just spend 20-30 hours for the preparation.
DOWNLOAD the newest ValidExam MB-820 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1MKytvXbwAeMUN77ZAS8brb7WDnX7-pbK
