[General] Online 350-701 Tests - 350-701 Valid Test Blueprint
108
General Online 350-701 Tests - 350-701 Valid Test Blueprint
Posted at 2/12/2026 12:10:21      View145 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsTests 350-701 PDF Dumps and 350-701 Exam Engine Free Share: https://drive.google.com/open?id=1r6PlHyc0G8qeYE3bdfaSbcbupa5YLD1O
For the challenging Cisco 350-701 exam, they make an effort to locate reputable and recent Cisco 350-701 practice questions. The high anxiety and demanding workload the candidate must face being qualified for the Cisco 350-701 Certification are more difficult than only passing the Cisco 350-701 exam.
Cisco 350-701 exam is a two-hour exam that consists of 90-110 questions. 350-701 exam is available in English and Japanese languages and can be taken in-person or online. It is a challenging exam that requires a deep understanding of Cisco security technologies and their application in real-world scenarios. 350-701 Exam assesses the candidate's knowledge in implementing and operating Cisco security solutions like Cisco Identity Services Engine (ISE), Cisco Advanced Malware Protection (AMP), and Cisco Firepower Next-Generation Firewall (NGFW).
Pass-Sure Online 350-701 Tests by DumpsTestsDumpsTests provides numerous extra features to help you succeed on the 350-701 exam, in addition to the Cisco 350-701 exam questions in PDF format and online practice test engine. These include 100% real questions and accurate answers, 1 year of free updates, a free demo of the Cisco 350-701 Exam Questions, a money-back guarantee in the event of failure, and a 20% discount. DumpsTests is the ideal alternative for your 350-701 test preparation because it combines all of these elements.
Cisco Implementing and Operating Cisco Security Core Technologies Sample Questions (Q223-Q228):NEW QUESTION # 223
Drag and drop the VPN functions from the left onto the description on the right.
NEW QUESTION # 224
What are the two types of managed Intercloud Fabric deployment models? (Choose two.)
  • A. Enterprise managed
  • B. Public managed
  • C. User managed
  • D. Service Provider managed
  • E. Hybrid managed
NEW QUESTION # 225
A network administrator is configuring SNMPv3 on a new router. The users have already been created; however, an additional configuration is needed to facilitate access to the SNMP views. What must the administrator do to accomplish this?
  • A. specify the UDP port used by SNMP
  • B. define the encryption algorithm to be used by SNMPv3
  • C. set the password to be used for SNMPv3 authentication
  • D. map SNMPv3 users to SNMP views
SNMPv3 is a security model that uses authentication and encryption to provide secure access to devices.
SNMPv3 requires the configuration of SNMP groups, users, and views. SNMP groups define the security model, security level, and access rights for a set of users. SNMP users are members of SNMP groups and have passwords for authentication and encryption. SNMP views define the subset of the MIB tree that a group of users can access. To facilitate access to the SNMP views, the network administrator must map the SNMPv3 users to the SNMP views using the snmp-server group command with the v3 and view keywords. This command assigns a view to a group of users and specifies the security model and level for that group. For example, the following command maps the SNMPv3 users in the group admin to the view all using the authPriv security level:
snmp-server group admin v3 authPriv read all write all
This command allows the users in the group admin to access all the MIB objects in the view all using authentication and encryption. The other options are not correct because they are not related to the SNMP views. Option B is incorrect because the password for SNMPv3 authentication is configured for each user using the snmp-server user command with the auth keyword. Option C is incorrect because the encryption algorithm for SNMPv3 is also configured for each user using the snmp-server user command with the priv keyword. Option D is incorrect because the UDP port used by SNMP is not configurable and is always 161 for queries and 162 for traps. References := Some possible references for this question are:
* SNMP Configuration Guide, Cisco IOS XE Release 3SE (Catalyst 3850 Switches) - SNMP Version 3
* Configuration Template for SNMPv3 - Cisco Community
* Configure ESXi for SNMP v3 - VMware Docs
* How to Configure SNMPv3 and How It Works - CBT Nuggets
NEW QUESTION # 226
An administrator is configuring a DHCP server to better secure their environment. They need to be able to ratelimit the traffic and ensure that legitimate requests are not dropped. How would this be accomplished?
  • A. Add entries in the DHCP snooping database
  • B. Enable ARP inspection for the required VLAN
  • C. Set the DHCP snooping bit to 1
  • D. Set a trusted interface for the DHCP server
ExplanationTo understand DHCP snooping we need to learn about DHCP spoofing attack first.
DHCP spoofing is a type of attack in that the attacker listens for DHCP Requests from clients and answers them with fake DHCP Response before the authorized DHCP Response comes to the clients. The fake DHCP Response often gives its IP address as the client default gateway -> all the traffic sent from the client will go through the attacker computer, the attacker becomes a "man-in-the-middle".The attacker can have some ways to make sure its fake DHCP Response arrives first. In fact, if the attacker is "closer" than the DHCP Server then he doesn't need to do anything. Or he can DoS the DHCP Server so that it can't send the DHCP Response.DHCP snooping can prevent DHCP spoofing attacks. DHCP snooping is a Cisco Catalyst feature thatdetermines which switch ports can respond to DHCP requests. Ports are identified as trusted and untrusted.
Only ports that connect to an authorized DHCP server are trusted, and allowed to send all types of DHCPmessages. All other ports on the switch are untrusted and can send only DHCP requests. If a DHCP responseis seen on an untrusted port, the port is shut down.
NEW QUESTION # 227
An administrator wants to ensure that all endpoints are compliant before users are allowed access on the corporate network. The endpoints must have the corporate antivirus application installed and be running the latest build of Windows 10.
What must the administrator implement to ensure that all devices are compliant before they are allowed on the network?
  • A. Cisco Identity Services Engine with PxGrid services enabled
  • B. Cisco Identity Services Engine and AnyConnect Posture module
  • C. Cisco Stealthwatch and Cisco Identity Services Engine integration
  • D. Cisco ASA firewall with Dynamic Access Policies configured
Cisco Identity Services Engine (ISE) and AnyConnect Posture module are the best solution to ensure that all endpoints are compliant before users are allowed access on the corporate network. ISE is a policy-based platform that provides secure network access, identity management, and endpoint compliance. AnyConnect Posture module is a component of the AnyConnect Secure Mobility Client that performs posture assessment and remediation on the endpoints. Together, they can enforce policies based on the endpoint's compliance status, such as the presence and update of the corporate antivirus application and the Windows 10 build version. The administrator can configure posture requirements, profiles, and policies on ISE, and deploy them to the endpoints through AnyConnect. The endpoints will then report their posture status to ISE, which will grant or deny network access accordingly, or redirect them to a remediation portal if needed. References :
NEW QUESTION # 228
In this competitive society, being good at something is able to take up a large advantage, especially in the IT industry. Gaining some IT authentication certificate is very useful. Cisco 350-701 is a certification exam to test the IT professional knowledge level and has a Pivotal position in the IT industry. While Cisco 350-701 exam is very difficult to pass, so in order to pass the Cisco certification 350-701 exam a lot of people spend a lot of time and effort to learn the related knowledge, but in the end most of them do not succeed. Therefore DumpsTests is to analyze the reasons for their failure. The conclusion is that they do not take a pertinent training course. Now DumpsTests experts have developed a pertinent training program for Cisco Certification 350-701 Exam, which can help you spend a small amount of time and money and 100% pass the exam at the same time.
350-701 Valid Test Blueprint: https://www.dumpstests.com/350-701-latest-test-dumps.html
Posted at 2/22/2026 08:45:44        Only Author  2#
I found this article very inspiring, thanks for sharing! The Valid D-PST-DY-23 exam question content is top-tier, and it's totally free.
Posted at 3/6/2026 03:13:15        Only Author  3#
What a remarkable piece of writing, thank you for sharing it. Sharpen your IT knowledge with free C_P2WFI_2023 latest test cram materials. Wishing you success!
