[General] 3 Formats of Microsoft AZ-204 Dumps that Suit your Study Style
107
【General】 3 Formats of Microsoft AZ-204 Dumps that Suit your Study Style
Posted at 2/12/2026 14:01:15      View:118 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Free4Torrent AZ-204 dumps now are free: https://drive.google.com/open?id=1wMNW4PCVeB0BgiAkC60SsIiRmCJXcMDk
You don't need to worry about network problems either. You only need to use AZ-204 exam questions for the first time in a network environment, after which you can be free from network restrictions. I know that many people like to write their own notes. The PDF version of AZ-204 training guide is for you. The PDF version of our AZ-204 study materials can be printed and you can carry it with you. If you have any of your own ideas, you can write it above. This can help you learn better.
Microsoft AZ-204 certification exam is designed for developers who want to demonstrate their expertise in developing solutions for Microsoft Azure. AZ-204 exam measures the candidate's knowledge of Azure services and tools that are required to develop, test, and deploy cloud-based applications. AZ-204 Exam covers various topics such as Azure compute, storage, security, integration, and monitoring.
Latest AZ-204 Pass4sure Pdf & AZ-204 Free Demo & AZ-204 Study GuideUnfortunately, many candidates do not pass the AZ-204 exam because they rely on outdated Microsoft AZ-204 exam preparation material. Failure leads to anxiety and money loss. You can avoid this situation with Free4Torrent that provides you with the most reliable and actual Microsoft AZ-204 with their real answers for AZ-204 exam preparation.
The AZ-204 exam measures the candidate's ability to develop and deploy Azure cloud-based solutions. AZ-204 exam covers several topics, including Azure compute, storage, security, and integration with other services. AZ-204 Exam also covers Azure App Service, Azure Functions, Azure Cosmos DB, Azure Storage, and Azure Event Grid, among others.
Microsoft Developing Solutions for Microsoft Azure Sample Questions (Q94-Q99):NEW QUESTION # 94
You are debugging an application that is running on Azure Kubernetes cluster named cluster1. The cluster uses Azure Monitor for containers to monitor the cluster.
The application has sticky sessions enabled on the ingress controller.
Some customers report a large number of errors in the application over the last 24 hours.
You need to determine on which virtual machines (VMs) the errors are occurring.
How should you complete the Azure Monitor query? To answer, select the appropriate options in the answer area.
Box 1: ago(1d)
Box 2: distinct containerID
Box 3: where ContainerID in (ContainerIDs)
Box 4: summarize Count by Computer
Summarize: aggregate groups of rows
Use summarize to identify groups of records, according to one or more columns, and apply aggregations to them. The most common use of summarize is count, which returns the number of results in each group.
https://docs.microsoft.com/en-us ... get-started-queries
https://docs.microsoft.com/en-us ... /query-optimization
NEW QUESTION # 95
You develop a solution that uses an Azure SQL Database to store user information for a mobile app.
The app stores sensitive information about users.
You need to hide sensitive information from developers that query the data for the mobile app.
Which three items must you identify when configuring dynamic data masking? Each correct answer presents a part of the solution.
  • A. Index
  • B. Table
  • C. Trigger
  • D. Column
  • E. Schema
Answer: B,D,E
In the Dynamic Data Masking configuration page, you may see some database columns that the recommendations engine has flagged for masking. In order to accept the recommendations, just click Add Mask for one or more columns and a mask is created based on the default type for this column. You can change the masking function by clicking on the masking rule and editing the masking field format to a different format of your choice.
https://docs.microsoft.com/en-us ... -get-started-portal
NEW QUESTION # 96
You are developing several microservices to deploy to a Azure Service cluster. The microservices manage data stored in Azure Cosmos DB and Azure Blob storage. The data is secured by using customer-managed keys stored in Aue Key Vault.
You must automate key rotation for all Key Vault keys and allow for manual key rotation. Keys must rotate every three months. Notifications Of expiring keys must be sent before key expiry.
You need to configure key rotation and enable key expiry notifications.
Which two actions should you perform? Each correct answer presents part Of solution.
  • A. Create and assign an Azure Key Vault access
  • B. Create configure a key rotation policy during key creation
  • C. Create and configure a new Azure Event Grid instance.
  • D. Configure Azure Key Vault
https://learn.microsoft.com/en-u ... figure-key-rotation
NEW QUESTION # 97
You are developing an application. You have an Azure user account that has access to two subscriptions.
You need to retrieve a storage account key secret from Azure Key Vault.
In which order should you arrange the PowerShell commands to develop the solution? To answer, move all commands from the list of commands to the answer area and arrange them in the correct order.
Step 1: Get-AzSubscription
If you have multiple subscriptions, you might have to specify the one that was used to create your key vault.
Enter the following to see the subscriptions for your account:
Get-AzSubscription
Step 2: Set-AzContext -SubscriptionId
To specify the subscription that's associated with the key vault you'll be logging, enter:
Set-AzContext -SubscriptionId <subscriptionID>
Step 3: Get-AzStorageAccountKey
You must get that storage account key.
Step 4: $secretvalue = ConvertTo-SecureString <storageAccountKey> -AsPlainText -Force Set-AzKeyVaultSecret -VaultName <vaultName> -Name <secretName> -SecretValue $secretvalue After retrieving your secret (in this case, your storage account key), you must convert that key to a secure string, and then create a secret with that value in your key vault.
Step 5: Get-AzKeyVaultSecret
Next, get the URI for the secret you created. You'll need this URI in a later step to call the key vault and retrieve your secret. Run the following PowerShell command and make note of the ID value, which is the secret's URI:
Get-AzKeyVaultSecret -VaultName <vaultName>
https://docs.microsoft.com/bs-la ... tion-log-monitoring
NEW QUESTION # 98
You are building a traffic monitoring system that monitors traffic along six highways. The system produces time series analysis-based reports for each highway. Data from traffic sensors are stored in Azure Event Hub.
Traffic data is consumed by four departments. Each department has an Azure Web App that displays the time-series-based reports and contains a WebJob that processes the incoming data from Event Hub. All Web Apps run on App Service Plans with three instances.
Data throughout must be maximized. Latency must be minimized.
You need to implement the Azure Event Hub.
Which settings should you use? To answer, select the appropriate options in the answer area.
Box 1: 6
The number of partitions is specified at creation and must be between 2 and 32.
There are 6 highways.
Box 2: Highway
https://docs.microsoft.com/en-us ... event-hubs-features
NEW QUESTION # 99
Free AZ-204 Pdf Guide: https://www.free4torrent.com/AZ-204-braindumps-torrent.html
BONUS!!! Download part of Free4Torrent AZ-204 dumps for free: https://drive.google.com/open?id=1wMNW4PCVeB0BgiAkC60SsIiRmCJXcMDk
