1z0-071 Valid Exam Syllabus, 1z0-071 Reliable Mock Test
Posted at 2/12/2026 14:35:41
View116
Replies0
P.S. Free 2026 Oracle 1z0-071 dumps are available on Google Drive shared by VCETorrent: https://drive.google.com/open?id=1LcQ9cHmdSDNrdX0SgSPodg5duU-PUFLN
At VCETorrent, we understand your needs when it comes to passing the Oracle Database SQL (1z0-071) Certification exam. If you prefer studying at home for the 1z0-071 Exam, we have got you covered. VCETorrent offers 1z0-071 exam questions in PDF format, which can be easily downloaded and accessed on all your devices. Moreover, the Oracle 1z0-071 Actual Questions PDF file will be available for immediate download right after your purchase, eliminating any waiting time.
Oracle Database SQL exam is a multiple-choice exam consisting of 73 questions that must be completed within 100 minutes. 1z0-071 exam is available in English and Japanese languages. 1z0-071 exam covers a wide range of topics, including data manipulation, database design, database objects, and more. 1z0-071 exam is designed to test your knowledge of SQL and your ability to apply it to real-world scenarios.
Oracle 1z1-071 is a certification exam that is designed for individuals seeking to validate their skills in Oracle Database SQL. 1z0-071 exam is intended for database administrators, developers, and IT professionals who want to enhance their knowledge and expertise in SQL database management using Oracle technologies. 1z0-071 Exam is a part of the Oracle Certified Associate (OCA) certification program, which is recognized globally and highly valued in the IT industry.
Oracle 1z0-071 exam is an intermediate-level certification exam that covers a broad range of SQL topics. 1z0-071 exam requires candidates to have a deep understanding of SQL concepts and experience with the Oracle SQL database management system. 1z0-071 exam is 90 minutes long, and candidates need to answer 73 questions correctly to pass the exam.
2026 Oracle 1z0-071 Authoritative Valid Exam SyllabusPassing Oracle actual test will make you stand out from other people and you will have access to the big companies. But it is not an easy thing for you to prepare 1z0-071 practice test. The best way for you is choosing a training tool to practice 1z0-071 Study Materials. If you have no idea about the training tools, VCETorrent will be your best partner in the way of passing the IT certification.
Oracle Database SQL Sample Questions (Q134-Q139):NEW QUESTION # 134
View the Exhibit and examine the description of the tables.
You execute this SQL statement:
Which three statements are true? (Choose three.)
- A. The statement will execute successfully and a new row will be inserted into the SALES table.
- B. The SALEStable has five foreign keys.
- C. The statement will fail because a subquery may not be contained in a VALUESclause.
- D. The statement will fail if a row already exists in the SALEStable for product 23.
- E. A product can have a different unit price at different times.
- F. A customer can exist in many countries.
Answer: A,B,E
NEW QUESTION # 135
Examine this description of the PRODUCTS table:
Rows exist in this table with data in all the columns. You put the PRODUCTS table in read-only mode. Which three commands execute successfully on PRODUCTS?
- A. CREATE INDEX price_idx on products (price);
- B. ALTER TABLE products SET UNUSED(expiry_date);
- C. DROP TABLE products
- D. ALTER TABLE products DROP UNUSED COLUMNS
- E. TRUNCATE TABLE products;
- F. ALTER TAELE products DROP COLUMN expiry_date;
Answer: A,C,D
B . CREATE INDEX price_idx on products (price); E. ALTER TABLE products DROP UNUSED COLUMNS; F . DROP TABLE products.
Comprehensive and Detailed Explanation WITH all Reference:
When a table is in read-only mode, most types of modifications are prohibited. However, certain operations can still be performed.
A . Incorrect. You cannot drop a column from a table that is in read-only mode, as it is a modifying operation. B. Correct. You can create an index on a read-only table. Creating an index does not modify the actual rows within the table; it builds a separate structure used for faster access. C. Incorrect. The SET UNUSED statement marks one or more columns as unused so they can be dropped when the database is not busy. This operation is considered a modifying operation and therefore is not allowed on a read-only table. D. Incorrect. Truncate is a DDL operation that would delete all rows from a table. This operation is not allowed on a read-only table. E. Correct. The ALTER TABLE ... DROP UNUSED COLUMNS statement is used to drop columns that have been previously marked as unused using the SET UNUSED statement. This operation is allowed because it only affects previously marked unused columns, not actively used data. F. Correct. Dropping a table is allowed even if it's in read-only mode because it is a DDL operation that does not operate on the rows of the table but rather on the object itself.
The behavior of read-only tables and the operations that can be performed on them are detailed in the Oracle Database SQL Language Reference and Oracle Database Administrator's Guide.
NEW QUESTION # 136
Examine the commands used to create DEPARTMENT_DETAILS and
COURSE_DETAILS tables:
You want to generate a list of all department IDs that do not exist in the COURSE_DETAILS table.
You execute the SQL statement:
What is the outcome?
- A. It executes successfully and displays the required list.
- B. It executes successfully but displays an incorrect list.
- C. It fails because the ON clause condition is not valid.
- D. It fails because the join type used is incorrect.
NEW QUESTION # 137
Examine the description of the CUSTOMERS table:
Which two SELECT statements will return these results:
CUSTOMER_ NAME
Mandy
Mary
- A. SELECT customer_ name FROM customers WHERE customer_ name='*Ma*';
- B. SELECT customer_ name FROM customers WHERE customer name LIKE 'Ma%' ;
- C. SELECT customer_ name FROM customers WHERE customer_ name KIKE .*Ma*';
- D. SELECT customer_ name FROM customers WHERE UPPER (customer_ name ) LIKE 'MA*. ;
- E. SELECT customer_ name FROM customers WHERE customer name LIKE 'Ma*';
- F. SELECT customer_ name FROM customers WHERE customer_ name LIKE ' % a % ' ;
- G. SELECT customer_ name FROM customers WHERE UPPER (customer name) LIKE 'MA&';
The SQL LIKE operator is used in a WHERE clause to search for a specified pattern in a column. Here are the evaluations of the options:
* A: The pattern ' % a % ' will match any customer names that contain the letter 'a' anywhere in the name, not necessarily those starting with 'Ma'.
* B: This is correct as 'Ma%' will match any customer names that start with 'Ma'.
* C: In SQL, the wildcard character is '%' not '*', therefore, the pattern 'Ma' is incorrect.
* D: This is the correct syntax. 'UPPER (customer_ name ) LIKE 'MA%'' will match customer names starting with 'Ma' in a case-insensitive manner.
* E: Again, '*' is not a valid wildcard character in SQL.
* F: The character '&' is not a wildcard in SQL.
* G: The operator 'KIKE' is a typo, and '.Ma' is not valid SQL pattern syntax.
NEW QUESTION # 138
You execute this query:
What is the result?
- A. It returns the date for the last Monday of the current month.
- B. It returns the date for the first Monday of the next month.
- C. It executes successfully but does not return any result.
- D. It generates an error.
Explanation/Reference:
NEW QUESTION # 139
Nowadays in this information-based world the definition of the talents mean that the personnel boost both the knowledge in 1z0-071 area and the practical abilities now. So if you want to be the talent the society actually needs you must apply your knowledge into the practical working and passing the test 1z0-071 Certification can make you become the talent the society needs. If you buy our 1z0-071 study materials you will pass the exam successfully and realize your goal to be the talent.
1z0-071 Reliable Mock Test: https://www.vcetorrent.com/1z0-071-valid-vce-torrent.html
- 1z0-071 Latest Exam Questions 🦑 1z0-071 Exam Objectives Pdf 🐂 1z0-071 Valid Test Preparation 🔸 Search for [ 1z0-071 ] on { [url]www.examcollectionpass.com } immediately to obtain a free download 🧔
ass4sure 1z0-071 Exam Prep[/url] - Pass4sure 1z0-071 Exam Prep 🤔 1z0-071 High Quality 🐥 New 1z0-071 Exam Questions 🌿 Immediately open ➽ [url]www.pdfvce.com 🢪 and search for 1z0-071 to obtain a free download 🕜1z0-071 Valid Exam Question[/url]
- 2026 1z0-071 Valid Exam Syllabus - Oracle Oracle Database SQL - Latest 1z0-071 Reliable Mock Test 😞 Easily obtain free download of ☀ 1z0-071 ️☀️ by searching on ➡ [url]www.prep4away.com ️⬅️ ⬇1z0-071 Valid Exam Question[/url]
- 1z0-071 Valid Exam Question 🪀 1z0-071 Exam Papers 🥔 Certification 1z0-071 Book Torrent 👩 Search for [ 1z0-071 ] on [url]www.pdfvce.com immediately to obtain a free download 👮1z0-071 Valid Exam Question[/url]
- Track Your Progress And Get Succeed With Oracle 1z0-071 Practice Test 🧀 Easily obtain free download of 1z0-071 by searching on ⇛ [url]www.easy4engine.com ⇚ 📁Certification 1z0-071 Book Torrent[/url]
- 1z0-071 Exam Papers 🟩 Reliable 1z0-071 Test Blueprint ▛ 1z0-071 Examinations Actual Questions ⬇ Search for 1z0-071 and download it for free immediately on ⇛ [url]www.pdfvce.com ⇚ 🦂Reliable 1z0-071 Study Notes[/url]
- 1z0-071 Test Torrent is Very Helpful for You to Learn 1z0-071 Exam - [url]www.examdiscuss.com 🚲 Easily obtain free download of [ 1z0-071 ] by searching on www.examdiscuss.com 🖕1z0-071 Valid Exam Question[/url]
- Pass Guaranteed 2026 1z0-071: Oracle Database SQL Perfect Valid Exam Syllabus 🚃 Search for 1z0-071 and obtain a free download on { [url]www.pdfvce.com } 🗜1z0-071 Pass Rate[/url]
- Pass4sure 1z0-071 Exam Prep 💚 1z0-071 Exam Topics Pdf 🦒 Reliable 1z0-071 Test Blueprint 🕠 Easily obtain free download of ➤ 1z0-071 ⮘ by searching on ➠ [url]www.exam4labs.com 🠰 🏂1z0-071 Exam Topics Pdf[/url]
- Practice 1z0-071 Online 🆎 Practice 1z0-071 Online 🚃 Practice 1z0-071 Online 🦆 Download 1z0-071 for free by simply searching on ▶ [url]www.pdfvce.com ◀ 🤧New 1z0-071 Exam Questions[/url]
- 1z0-071 High Quality 🌘 Pass4sure 1z0-071 Exam Prep 🎅 1z0-071 100% Accuracy 👶 Search for [ 1z0-071 ] on [url]www.validtorrent.com immediately to obtain a free download 🦥1z0-071 Pass Rate[/url]
- notefolio.net, learn.designoriel.com, www.stes.tyc.edu.tw, fatimahope.org, www.stes.tyc.edu.tw, kumu.io, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, edu.openu.in, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that VCETorrent 1z0-071 dumps now are free: https://drive.google.com/open?id=1LcQ9cHmdSDNrdX0SgSPodg5duU-PUFLN
