[General] 1z0-1080-25 valid study questions & 1z0-1080-25 exam preparation & 1z0-1
94
【General】 1z0-1080-25 valid study questions & 1z0-1080-25 exam preparation & 1z0-1
Posted at 2/12/2026 18:56:10      View:123 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that ValidBraindumps 1z0-1080-25 dumps now are free: https://drive.google.com/open?id=1WC5KseAENyd5IIiIeHxP3Lkpsi_GoC-j
Along with 1z0-1080-25 self-evaluation exams, Oracle Planning 2025 Implementation Professional (1z0-1080-25) dumps PDF is also available at ValidBraindumps. These 1z0-1080-25 questions can be used for quick 1z0-1080-25 exam preparation. Our 1z0-1080-25 dumps PDF format works on a range of Smart devices, such as laptops, tablets, and smartphones. Since Oracle Planning 2025 Implementation Professional (1z0-1080-25) questions PDF are easily accessible, you can easily prepare for the test without time and place constraints. You can also print this format of ValidBraindumps's Oracle Planning 2025 Implementation Professional (1z0-1080-25) exam dumps to prepare off-screen and on the go.
Oracle 1z0-1080-25 Exam Syllabus Topics:
  • Report on Planning Data: This section of the exam measures the skills of a Planning Administrator and focuses on generating reports to analyze and present Planning data effectively.
  • Manage Metadata and Data: This section of the exam measures the skills of a Planning Administrator and covers methods for loading and maintaining metadata and data in Planning.
  • Design forms and dashboards: This section of the exam measures the skills of an EPM Consultant and covers designing planning input forms and visual dashboards to support decision-making.
  • Set up valid and invalid intersections and cell-level security: This section of the exam measures the skills of an EPM Consultant and focuses on defining valid data intersections and applying security controls to limit data access at the cell level.
Topic 5
  • Manage Dimensions: This section of the exam measures the skills of a Planning Administrator and covers how to manage essential dimensions and hierarchies that organize planning data.
Topic 6
  • Provision users and groups. This section of the exam measures the skills of a Planning Administrator and covers how to manage user access by assigning them to appropriate roles and groups.
Topic 7
  • Map data across applications: This section of the exam measures the skills of an EPM Consultant and includes how to map and align data structures between Planning and other connected applications.
Topic 8
  • This section of the exam measures the skills of a Planning Administrator and includes understanding how standard and custom dimensions are used, and how dimension hierarchies affect planning structure and outcomes.
Topic 9
  • Explain the benefits of using Groovy Rules: This section of the exam measures the skills of an EPM Consultant and explains how Groovy scripting enhances rule flexibility and performance.
Topic 10
  • Identify metadata and data load options: This section of the exam measures the skills of a Planning Administrator and introduces options available for importing and managing metadata and data within the system.
Topic 11
  • Manage Rules: This section of the exam measures the skills of an EPM Consultant and covers designing and managing business logic using rules and rulesets to automate calculations.
Topic 12
  • Set up Planning and FreeForm Applications: This section of the exam measures the skills of a Planning Administrator and involves setting up Planning applications, including FreeForm apps, to support flexible planning and modeling needs.
Topic 13
  • Explain required and user-defined dimensions; how dimension hierarchies impact Planning
Topic 14
  • Set up and run data maps: This section of the exam measures the skills of a Planning Administrator and focuses on configuring and executing data maps to move data across plan types or applications.
Topic 15
  • Import and export data into Planning: This section of the exam measures the skills of a Planning Administrator and covers the process of moving planning data into and out of the system.
1z0-1080-25 Valid Test Pass4sure & Best 1z0-1080-25 PracticeOur 1z0-1080-25 Test Braindumps are by no means limited to only one group of people. Whether you are trying this exam for the first time or have extensive experience in taking exams, our 1z0-1080-25 latest exam torrent can satisfy you. This is due to the fact that our 1z0-1080-25 test braindumps are humanized designed and express complex information in an easy-to-understand language. You will never have language barriers, and the learning process is very easy for you. What are you waiting for? If you are preparing to take the test, you can rely on our learning materials. You will also be the next beneficiary. After you get Oracle certification, you can get boosted and high salary to enjoy a good life.
Oracle Planning 2025 Implementation Professional Sample Questions (Q35-Q40):NEW QUESTION # 35
In which four ways can you create a FreeForm application?
  • A. Using a single cube, and then adding more cubes later.
  • B. With a maximum of 12 cubes.
  • C. Migrating an Essbase snapshot with Custom Defined Functions.
  • D. Importing a single Essbase outline, and then adding more cubes later.
  • E. With multiple cubes by using the Application Creation Wizard or Excel template in Smart View.
  • F. Importing multiple Essbase outlines - one for each cube.
Answer: A,B,D,E
NEW QUESTION # 36
You enabled Projects and within Projects you enabled the Program dimension so that you can group projects together into a program. Which is a post configuration task for Projects?
  • A. Review the assumptions under Investments and Intangibles at the No Entity level and members under the Total Entity level.
  • B. Synchronize defaults by pushing updated data to the input forms by running the Synchronize Default business rule.
  • C. Map projects to programs for analysis purposes.
  • D. Modify account type and variance reporting options for members in programs.
NEW QUESTION # 37
Which two statements are true regarding what you can do when configuring insights?
  • A. Create and edit data views to customize the display on the dashboard.
  • B. Use prediction results as input for generating insights.
  • C. Define insights for up to 1000 data intersections.
  • D. Select either a single type of insight or multiple types of insights.
NEW QUESTION # 38
In which three ways can you create data maps that copy data using Smart Push?
  • A. Between two Planning instances
  • B. From Financial Consolidation and Close to Planning
  • C. From Planning to Financial Consolidation and Close
  • D. From Planning to Tax Reporting Cloud
  • E. From Tax Reporting Cloud to Planning
Answer: A,B,C
In Oracle Planning 2024, Smart Push is a feature within data maps that enables efficient, real-time data movement between Oracle EPM Cloud applications or instances. It copies data dynamically when triggered (e.
g., via forms or rules). The three supported ways to create data maps with Smart Push are:
* A. From Planning to Tax Reporting Cloud: Incorrect. Smart Push does not support direct data movement from Planning to Tax Reporting Cloud, as these modules lack a predefined integration path for this feature.
* B. From Tax Reporting Cloud to Planning: Incorrect. Similarly, Smart Push does not facilitate data movement from Tax Reporting Cloud to Planning.
* C. From Financial Consolidation and Close to Planning: Correct. Smart Push supports moving consolidated data (e.g., actuals) from Financial Consolidation and Close (FCC) to Planning for planning purposes.
* D. From Planning to Financial Consolidation and Close: Correct. Smart Push allows pushing planned data from Planning to FCC for consolidation or reporting.
* E. Between two Planning instances: Correct. Smart Push can move data between two Planning instances (e.g., test and production environments) to synchronize data.
These three options-C, D, and E-are explicitly supported by Smart Push in Oracle EPM Cloud, as per the documentation, enabling seamless data integration across these applications.
Oracle Planning 2024 Implementation Study Guide: "Using Smart Push in Data Maps" (docs.oracle.com, Published 2024-09-30).
Oracle EPM Cloud Documentation: "Data Integration with Smart Push" (docs.oracle.com, Published 2023-12-
20, updated for 2024).
NEW QUESTION # 39
Which two statements are true about using anchor and nonanchor dimensions with cell-level security?
  • A. By default, nonanchor dimensions are required. You can change this setting later.
  • B. Anchor dimensions are never required in the cube that is used in the cell-level security definition.
  • C. Anchor dimensions are always required in the cube that is used in the cell-level security definition.
  • D. By default, nonanchor dimensions are not required.
In Oracle Planning 2024, cell-level security restricts access to specific data intersections using anchor and nonanchor dimensions. The two true statements are:
* A. Anchor dimensions are always required in the cube that is used in the cell-level security definition:
Correct. Anchor dimensions (e.g., Entity, Scenario) are mandatory in the security definition to specify the primary scope of access control within the cube.
* B. Anchor dimensions are never required in the cube that is used in the cell-level security definition:
Incorrect. Anchor dimensions are always required, contradicting this statement.
* C. By default, nonanchor dimensions are not required: Correct. Nonanchor dimensions (e.g., Account, Period) are optional by default in cell-level security definitions, allowing flexibility in granularity unless explicitly included.
* D. By default, nonanchor dimensions are required. You can change this setting later: Incorrect.
Nonanchor dimensions are not required by default, and there's no setting to make them mandatory-it's an optional inclusion.
The Oracle documentation specifies that A (anchor necessity) and C (nonanchor optional) align with cell-level security behavior, making them the correct answers.
Oracle Planning 2024 Implementation Study Guide: "Cell-Level Security Configuration" (docs.oracle.com, Published 2024-09-30).
Oracle EPM Cloud Documentation: "Anchor and Nonanchor Dimensions" (docs.oracle.com, Published 2023-
12-05, updated for 2024).
NEW QUESTION # 40
Our 1z0-1080-25 exam torrent will not only help you clear exam in your first try, but also enable you prepare exam with less time and effort. There are 1z0-1080-25 free download trials for your reference before you buy and you can check the accuracy of our questions and answers. Try to Practice 1z0-1080-25 Exam Pdf with our test engine and you will get used to the atmosphere of the formal test easily.
1z0-1080-25 Valid Test Pass4sure: https://www.validbraindumps.com/1z0-1080-25-exam-prep.html
Posted at 2/21/2026 13:24:21        Only Author  2#
This is brilliant—like clicked without hesitation. Sharing Actual C1000-173 Test exam questions for free—promotions and salary growth await!
