[General] NS0-185}ȽNS0-185gHԇY
94
General NS0-185}ȽNS0-185gHԇY
Posted at 2/12/2026 19:15:29      View167 | Replies1        Print      Only Author   [Copy Link] 1#
P.S.Tech4ExamGoogle DriveǹФƤoϤ2026 Network Appliance NS0-185ףhttps://drive.google.com/open?id=1UDt8xVJMkkN_BOYLwqamAS6yUk1bpSDJ
Tech4ExamNetwork ApplianceNS0-185ԇY}ȽϤʤYǰˤ٤ƤαҪȤʂYϤṩƤޤNetwork ApplianceNS0-185J^ԇYˤĤơʤϮʤ륵Ȥɫʆ}ҊĤ뤳ȤǤޤåӾAƤ뤫ɤϥ`ǤTech4ExamΆ}ȽϳԇYܤ뤢ʤݘS˳ɹ뤳ȤǤϤʤʤFؤʕrg򹝼s뤳ȤǤޤ
mФʥȥ`˥󥰤x֤Τϳɹα^ˤʤޤΤx֤ΤϷdzҪʤȤǤTech4ExamϤȤƤ˚ݤޤ顢xФʤɤϤʤǤ赤ʥȥ`˥YϤϤޤ⤷ʤ򤤤ƤʤΤʤoäˤʤޤ顢NS0-185}äǰˡһΆ}ȽoϤ˥`ɤƤߤ뤳ȤǤޤ顢ȫԇYʂ򤷤ơݘSԇYܤ뤳ȤǤ褦ˤʤޤǧYTech4ExamxҪɤǤTech4Examһ褤һgõĤʡһȫNS0-185ԇYȥ`˥YϤṩƤޤ顢YԇYʂ䤹뤳ȤҪˤʤޤ
NS0-185gHԇYNS0-185ϸMi줲NS0-185ȥ`˥YϤ^ȡä뤳ȤϡȻΤȤʤ顢¤_֪Rָ]⌟TĤʌTҤˤΤǤ줬NetApp Storage Installation Engineer, ONTAP Professional ExamԇYʂ䤬Јδ󲿷֤ռɤǤˡNS0-185̲ĤĤΤǤϤʤ֧B᤹˥`ɤǤΤǡ񤹤ɹؤäʼޤ礦
Network Appliance NetApp Storage Installation Engineer, ONTAP Professional Exam J NS0-185 ԇY} (Q18-Q23):| # 18
An iSCSI LIF fails to migrate during a storage failover test.
In this scenario, why did the LIF not migrate?
  • A. The failover policy was not configured
  • B. LIFs that serve block protocols do not failover
  • C. LIF failover was not enabled
  • D. A failover port was not defined
⣺B
h
SAN LIFs (iSCSI, FC, NVMe) donot use LIF migration. Instead, host multipathing handles path redundancy. Therefore, iSCSI LIFs do not migrate during storage failover.
| # 19
After the installation of a new 2-node cluster, you want to ensure AutoSupport is working as expected.
Which two ways can you trigger a new AutoSupport? (Choose two.)
  • A. Use the OnCommand Unified Manager GUI.
  • B. Use the ping command on the mailhost.
  • C. Use the OnCommand System Manager GUI.
  • D. Use the system node autosupport invoke -type test command.
⣺CD
h
AutoSupport can be manually triggered using the ONTAP CLI command or via System Manager. Ping tests and Unified Manager do not trigger AutoSupport generation.
| # 20
After updating BES-53248 cluster switches, which two commands verify a healthy cluster? (Choose two.)
  • A. network interface show -vserver Cluster
  • B. network device-discovery show -protocol cdp
  • C. network port show -ipspace Cluster
  • D. network interface show -vserver Cluster -fields auto-revert
⣺AC
| # 21
What are two functions of the four Ethernet switches in the supported configuration shown in the exhibit?
(Choose two.)
  • A. to provide a direct connection for SnapMirror Synchronous
  • B. to enable SyncMirror replication
  • C. to install cross-site cluster management switches
  • D. to provide connectivity for NVRAM over iWARP
⣺BD
h
The exhibit represents aMetroCluster IPconfiguration, which uses Ethernet switches to provide redundant connectivity between sites. In this architecture, the Ethernet switches are responsible for transportingNVRAM replication traffic using iWARP (RDMA over TCP/IP). This enables synchronous replication of write logs between HA partners across sites.
Additionally, the switches supportSyncMirror replication, which maintains mirrored aggregates across sites to provide continuous data availability in the event of a site failure.
SnapMirror Synchronous and cluster management traffic do not use these switches directly in this configuration. Therefore, the correct answers areC and D.
| # 22
A customer wants to replace their ONTAP cluster CN1610 switches with Cisco Nexus 3132Q-V switches.
They want to perform a non-disruptive upgrade.
Referring to the exhibit, which cable will be required to non-disruptively migrate to the new switches?
  • A. a 40GbE QSFP+ to QSFP+ cable
  • B. a 100GbE QSFP28+ to 4x25GbE SFP28+ cable
  • C. a 40GbE QSFP+ to 4x10GbE SFP+ cable
  • D. a 10GbE SFP+ to SFP+ cable
⣺A
h
The CN1610 uses 10GbE SFP+, while the Cisco Nexus 3132Q-V provides 40GbE QSFP+ cluster ports. For non-disruptive migration, the interconnect must operate at 40GbE without breakout. AQSFP+ to QSFP+
40GbE cablesupports this requirement and is validated for cluster interconnect traffic. Breakout cables would change port topology and are not used during NDU migration.
| # 23
󥿩`ͥåȤmǤԇY쥯YϤ˽ҊĤϡgHˤϡNS0-185JԇYmuƷҊĤޤ NS0-185ԇYκϸʤߤȤǤΤᡢयιŤ͘NS0-185ԇY˲μӤǰ˽mֱxkƤޤُ뤹ǰˡ`äΟoϤPDFǥṩơuƷƷ|֪뤳ȤǤˏꤨǤʤNS0-185ѧɤ_ُǤ褦ˤޤ
NS0-185gHԇY: https://www.tech4exam.com/NS0-185-pass-shiken.html
Network Appliance NS0-185}Ƚ ƥȤΥߥ`Network Appliance NS0-185}Ƚ ^֤ƤĤޤꡢҡ϶ڵĤNS0-185}θ°`ޤNS0-185ԇY˺ϸ񤹤ȡ߅¤ҊĤԤߤʤޤ⤷ʤNS0-185ԇY˺ϸ񤷤ǤNS0-185ԇY|ǡNS0-185ԇYDŽ٤Ťޤ˽Network Appliance NS0-185gHԇYޤͤȑBȤǃ줿ե``ӥṩޤNS0-185ԇYv򱣳֤ޤ
ǤHLɿ췫ϤʤӤƤˤv餺ʤ AƤͻȻֹޤäƥȤΥߥ`󡢱^֤ƤĤޤꡢҡ϶ڵĤNS0-185}θ°`ޤ
_ĤNS0-185}Ƚ & ϸ񥹥`NS0-185gHԇY | Ʒ|NS0-185ϸNS0-185ԇY˺ϸ񤹤ȡ߅¤ҊĤԤߤʤޤ⤷ʤNS0-185ԇY˺ϸ񤷤Ǥ
BONUS Tech4Exam NS0-185פһoϤǥ`ɣhttps://drive.google.com/open?id=1UDt8xVJMkkN_BOYLwqamAS6yUk1bpSDJ
Posted at 2/14/2026 05:25:40        Only Author  2#
Im absolutely amazed by your article, thank you for sharing it with me! Sharing NCM-MCI latest test cram review exam questions for freepromotions and salary growth await!
