Splendid Fortinet FCSS_SDW_AR-7.6 Exam Questions - Pass Exam Confidently [2026]
99
Posted at 2/13/2026 01:35:53      View100 | Replies0        Print      Only Author   [Copy Link] 1#
You can adjust the speed and keep vigilant by setting a timer for the simulation test. At the same time online version of FCSS_SDW_AR-7.6 test preps also provides online error correction through the statistical reporting function, it will help you find the weak links and deal with them. Of course, you can also choose two other versions. The contents of the three different versions of FCSS_SDW_AR-7.6 learn torrent is the same and all of them are not limited to the number of people/devices used at the same time.
To get all these benefits you must have to pass the FCSS - SD-WAN 7.6 Architect (FCSS_SDW_AR-7.6) certification exam which is not an easy task. It is a difficult task but you can make ExamcollectionPass simple and quick. To do this you just visit Exams. Solutions provide updated, valid, and actual FCSS_SDW_AR-7.6 Exam Dumps that will assist you in FCSS - SD-WAN 7.6 Architect (FCSS_SDW_AR-7.6) exam preparation and you can easily get success in this challenging FCSS - SD-WAN 7.6 Architect exam with flying colors.
FCSS_SDW_AR-7.6 Latest Exam Notes - FCSS_SDW_AR-7.6 Sample Questions PdfOur service and FCSS - SD-WAN 7.6 Architect exam questions are offered to exam candidates who are in demand of our products which are marvelous with the passing rate up to 98 percent and so on. So this result invariably makes our FCSS_SDW_AR-7.6 torrent prep the best in the market. We can assure you our FCSS_SDW_AR-7.6 test guide will relax the nerves of the exam without charging substantial fees. So we are always very helpful in arranging our FCSS - SD-WAN 7.6 Architect exam questions with both high quality and reasonable price. And you can choose them without hesitation. What is more, we give discounts upon occasions and send you the new version of our FCSS_SDW_AR-7.6 Test Guide according to the new requirements of the exam for one year from the time you place your order. One of our many privileges offering for exam candidates is the update. So we have received tremendous compliments which in return encourage us to do better. So please keep faithful to our FCSS_SDW_AR-7.6 torrent prep and you will prevail in the exam eventually.
Fortinet FCSS_SDW_AR-7.6 Exam Syllabus Topics:
  • SD-WAN Troubleshooting: This domain focuses on diagnosing SD-WAN rule behavior, routing issues, and ADVPN tunnel problems.
  • Centralized Management: This domain addresses FortiManager-based SD-WAN deployment, branch configuration implementation, and overlay orchestration using SD-WAN Manager.
  • SD-WAN Basic Setup: This domain covers initial SD-WAN configuration, member and zone setup, and Performance SLA creation for link monitoring.
  • Rules and Routing: This section focuses on configuring SD-WAN rules for traffic steering and routing policies for path selection and failover.
Topic 5
  • Advanced IPsec: This section covers hub-and-spoke topologies, ADVPN configuration, and scalable multihub and multiregion IPsec deployments.
Fortinet FCSS - SD-WAN 7.6 Architect Sample Questions (Q21-Q26):NEW QUESTION # 21
Exhibit.
Two hub-and-spoke groups are connected through redundant site-to-site IPsec VPNs between Hub 1 and Hub 2 Which two configuration settings are required for the spoke A1 to establish an ADVPN shortcut with the spoke B2? (Choose two.)
  • A. On hubs, auto-diacovery-sender must be enabled on the IPsec VPNs to spokes
  • B. On hubs, auto-discovery-receiver must be enabled on the IPsec VPNs to spokes.
  • C. On hubs, auto-discovery-forwarder must be enabled on the IPsec VPNs to spokes.
  • D. On hubs, auto-discovery-forwarder must be enabled on the IPsec VPNs to hubs.
To allow spokes in different hub-and-spoke groups to establish ADVPN shortcuts, the hubs must be configured to forward and send ADVPN shortcut offers. The key required settings on the hub are auto-discovery-forwarder (for VPNs to hubs) and auto-discovery-sender (for VPNs to spokes). This ensures the hub can facilitate and advertise ADVPN shortcut offers between spokes.
[FCSS_SDW_AR-7.4 1-0.docx Q1]
Fortinet SD-WAN 7.4 ADVPN Guide (Auto-discovery settings for hub-and-spoke topologies)
NEW QUESTION # 22
The exhibit shows the BGP configuration on the hub in a hub-and-spoke topology. The administrator wants BGP to advertise prefixes from spokes to other spokes over the IPsec overlays, including additional paths. However, when looking at the spoke routing table, the administrator does not see the prefixes from other spokes and the additional paths Which three settings must the administrator configure inside each BGP neighbor group so spokes can learn the prefixes of other spokes and their additional paths? (Choose three.)
  • A. Enable route-reflector-server
  • B. Enable route-reflector-client.
  • C. Set additional-path to send
  • D. Set adv-additional-path to the number of additional paths to advertise.
  • E. Set additional-path to forward
Answer: B,C,D
The hub must send additional paths to spokes (set additional-path send).
The hub must treat each spoke as a route-reflector client so spoke routes are reflected to other spokes.
The hub must specify how many additional paths to advertise (set adv-additional-path <n>).
NEW QUESTION # 23
Which three characteristics apply to provisioning templates available on FortiManager? (Choose three.)
  • A. CLI templates are applied in order, from top to bottom.
  • B. Each template group can contain up to three IPsec tunnel templates.
  • C. A template group can include a system template and an SD-WAN template.
  • D. A CLI template group can contain CLI templates of both types.
  • E. A CLI template can be of type CLI script or Perl script.
Answer: A,C,D
Template groups can include both system and SD-WAN templates to streamline configuration deployment.
A CLI template group can include both CLI Script and CLI Snippet types.
CLI templates are applied in top-to-bottom order, which affects configuration precedence.
NEW QUESTION # 24
In which SD-WAN template field can you use a metadata variable?
  • A. All SD-WAN template fields support metadata variables.
  • B. Any field identified with a dollar sign (S) in a magnifying glass.
  • C. You can use metadata variables only to define interface members and the gateway IP.
  • D. Any field identified with an "M" in a circle.
NEW QUESTION # 25
Which two statements correctly describe what happens when traffic matches the implicit SD-WAN rule? (Choose two.)
  • A. Traffic does not match any of the entries in the policy route table.
  • B. The traffic is distributed, regardless of weight, through all available static routes.
  • C. Traffic is load balanced using the algorithm set for the v4-ecmp-modesetting.
  • D. FortiGate flags the session with may_dirtyand vwl_default.
  • E. The session information output displays no SD-WAN service id.
Answer: A,E
When traffic matches the implicit SD-WAN rule, no specific SD-WAN service is applied, so the session information output does not show an SD-WAN service ID.
The implicit SD-WAN rule is considered only when no matching entry is found in the policy route table.
NEW QUESTION # 26
If you want to pass the FCSS - SD-WAN 7.6 Architect exam as shortly as possible, we will provide you the FCSS_SDW_AR-7.6 exam dumps to help you to pass it. You only need to practice the FCSS - SD-WAN 7.6 Architect exam dumps for adot 20 to 70 hours, you can pass it successfully. Our FCSS - SD-WAN 7.6 Architect exam braindumps will save your time as well as improve your efficiency. Since the skilled professionals will guide you through you practice FCSS_SDW_AR-7.6 the exam dumps.
FCSS_SDW_AR-7.6 Latest Exam Notes: https://www.examcollectionpass.com/Fortinet/FCSS_SDW_AR-7.6-practice-exam-dumps.html
