[General] 100% Pass Quiz Trustable SPLK-3002 - Valid Splunk IT Service Intelligence Certif
103
【General】 100% Pass Quiz Trustable SPLK-3002 - Valid Splunk IT Service Intelligence Certif
Posted at 2/13/2026 07:45:58      View:88 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that PDF4Test SPLK-3002 dumps now are free: https://drive.google.com/open?id=1XVPCfMJ2sii5bL9x2cOuYU-ieGhfsJJV
Research indicates that the success of our highly-praised SPLK-3002 test questions owes to our endless efforts for the easily operated practice system. Most feedback received from our candidates tell the truth that our SPLK-3002 guide torrent implement good practices, systems as well as strengthen our ability to launch newer and more competitive products. Accompanying with our SPLK-3002 exam dumps, we educate our candidates with less complicated Q&A but more essential information, which in a way makes you acquire more knowledge and enhance your self-cultivation. And our SPLK-3002 Exam Dumps also add vivid examples and accurate charts to stimulate those exceptional cases you may be confronted with. You can rely on our SPLK-3002 test questions, and we’ll do the utmost to help you succeed.
Splunk IT Service Intelligence Certified Admin exam consists of 60 multiple-choice questions and must be completed within 90 minutes. SPLK-3002 Exam can be taken online or at a Pearson VUE testing center. To prepare for the exam, Splunk recommends that candidates take the Splunk IT Service Intelligence Fundamentals course and have hands-on experience with ITSI.
Get Access To Splunk SPLK-3002 Questions Using Three Different FormatsThe Splunk SPLK-3002 certification exam is one of the hottest certifications in the market. This Splunk SPLK-3002 exam offers a great opportunity to learn new in-demand skills and upgrade your knowledge level. By doing this successful SPLK-3002 Splunk IT Service Intelligence Certified Admin exam candidates can gain several personal and professional benefits.
Splunk IT Service Intelligence Certified Admin Sample Questions (Q60-Q65):NEW QUESTION # 60
Which of the following are deployment recommendations for ITSI? (Choose all that apply.)
  • A. Deployments should use fastest possible disk arrays for indexers.
  • B. Deployments may increase the number of required indexers based on the number of KPI searches.
  • C. Deployments require a dedicated ITSI search head.
  • D. Deployments often require an increase of hardware resources above base Splunk requirements.
Answer: B,C,D
You might need to increase the hardware specifications of your own Enterprise Security deployment above the minimum hardware requirements depending on your environment.
Install Splunk Enterprise Security on a dedicated search head or search head cluster.
The Splunk platform uses indexers to scale horizontally. The number of indexers required in an Enterprise Security deployment varies based on the data volume, data type, retention requirements, search type, and search concurrency.
NEW QUESTION # 61
Which deep dive swim lane type does not require writing SPL?
  • A. Metric lane.
  • B. KPI lane.
  • C. Event lane.
  • D. Automatic lane.
A KPI lane is a type of deep dive swim lane that does not require writing SPL. You can simply select a service and a KPI from a drop-down list and ITSI will automatically populate the lane with the corresponding data. You can also adjust the threshold settings and time range for the KPI lane. References: [KPI Lanes]
NEW QUESTION # 62
Which of the following is a good use case for a Multi-KPI alert?
  • A. Alerting when the values of two or more KPIs go into maintenance mode.
  • B. Alerting when comparing the values of two or more KPIs indicates an unusual condition is occurring.
  • C. Alerting when two or more KPIs are deviating from their typical pattern.
  • D. Alerting when the trend of two or more KPIs indicates service failure is imminent.
A Multi-KPI alert in Splunk IT Service Intelligence (ITSI) is designed to trigger based on the conditions of multiple Key Performance Indicators (KPIs). This type of alert is particularly useful when a single KPI's state is not sufficient to indicate an issue, but the correlation between multiple KPIs can provide a clearer picture of an emerging problem. The best use case for a Multi-KPI alert is therefore when comparing the values of two or more KPIs indicates an unusual condition is occurring. This allows for more nuanced and context-rich alerting mechanisms that can identify complex issues not detectable by monitoring individual KPIs. This approach is beneficial in complex environments where the interplay between different performance metrics needs to be considered to accurately detect and diagnose issues.
NEW QUESTION # 63
Which capabilities are enabled through "teams"?
  • A. Teams restrict searches against the itsi_notable_audit index.
  • B. Teams allow searches against the itsi_summary index.
  • C. Teams restrict notable event alert actions.
  • D. Teams allow restrictions to service content in UI views.
D is the correct answer because teams allow you to restrict access to service content in UI views such as service analyzers, glass tables, deep dives, and episode review. Teams also control access to services and KPIs for editing and viewing purposes. Teams do not affect the ability to search against the itsi_summary index, restrict notable event alert actions, or restrict searches against the itsi_notable_audit index.
References: Overview of teams in ITSI
NEW QUESTION # 64
When installing ITSI to support a Distributed Search Architecture, which of the following items apply? (Choose all that apply.)
  • A. Extract ITSI app package into etc/apps directory of search head.
  • B. Extract installer package into etc/apps directory of the cluster deployer node.
  • C. Copy SA-IndexCreation to the etc/apps directory on the index cluster master node.
  • D. Copy SA-IndexCreation to all indexers.
Copy SA-IndexCreation to $SPLUNK_HOME/etc/apps/ on all individual indexers in your environment.
A is the correct answer because when installing ITSI to support a distributed search architecture, you need to copy SA-IndexCreation to all indexers. SA-IndexCreation is an app that contains the definitions of the ITSI indexes, such as itsi_summary, itsi_tracked_alerts, itsi_grouped_alerts, etc. You need to copy this app to all indexers to ensure that they can store and search the ITSI data. B is not a correct answer because you do not need to copy SA-IndexCreation to the etc/apps directory on the index cluster master node. The index cluster master node does not store or search data, it only manages the replication and availability of data across the index cluster peers. C is not a correct answer because you do not need to extract the installer package into etc/apps directory of the cluster deployer node. The cluster deployer node is used to distribute apps and configuration updates to the search head cluster members. You need to extract the installer package into etc/shcluster/apps directory of the cluster deployer node instead. D is not a correct answer because you do not need to extract the ITSI app package into etc/apps directory of search head. You need to extract the ITSI app package into etc/shcluster/apps directory of the cluster deployer node and use the deployer to push the app to all search head cluster members. Reference: [Install Splunk IT Service Intelligence on a search head cluster], [Install Splunk IT Service Intelligence on an indexer cluster]
NEW QUESTION # 65
The Splunk SPLK-3002 exam dumps are top-rated and real Splunk SPLK-3002 practice questions that will enable you to pass the final Splunk SPLK-3002 exam easily. PDF4Test is one of the best platforms that has been helping Splunk SPLK-3002 Exam candidates. You can also get help from actual Splunk SPLK-3002 exam questions and pass your dream Splunk SPLK-3002 certification exam.
SPLK-3002 Actual Exam: https://www.pdf4test.com/SPLK-3002-dump-torrent.html
BONUS!!! Download part of PDF4Test SPLK-3002 dumps for free: https://drive.google.com/open?id=1XVPCfMJ2sii5bL9x2cOuYU-ieGhfsJJV
