[General] C_TS422_2023 Current Exam Content & Valid C_TS422_2023 Exam Camp
96
【General】 C_TS422_2023 Current Exam Content & Valid C_TS422_2023 Exam Camp
Posted at 2/13/2026 08:40:56      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest PrepAwayExam C_TS422_2023 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=17s28KwxXw0CC63Oq4CvrR3awhXvuJSAv
These mock tests are specially built for you to assess what you have studied. These C_TS422_2023 Practice Tests are customizable, which means you can change the time and questions according to your needs. You can even access your previously given tests from the history, which helps you to overcome mistakes while giving the actual test next time.
The C_TS422_2023 is an import way to improve our competitiveness, and our C_TS422_2023 exam dump will help you 100% pass your exam and get a certification. First of all, our C_TS422_2023 study materials are constantly being updated and impoved so that you can get the information you need and get a better experience. Our C_TS422_2023 test questions have been following the pace of digitalization, constantly refurbishing, and adding new things. I hope you can feel the C_TS422_2023 Exam Prep sincerely serve customers. We also attach great importance to the opinions of our customers. The duration of this benefit is one year, and C_TS422_2023 exam prep look forward to working with you.
Reliable C_TS422_2023 training materials bring you the best C_TS422_2023 guide exam: SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing - PrepAwayExamOur company has employed a lot of excellent experts and professors in the field in the past years, in order to design the best and most suitable C_TS422_2023 study materials for all customers. More importantly, it is evident to all that the C_TS422_2023 Study Materials from our company have a high quality, and we can make sure that the quality of our products will be higher than other study materials in the market.
SAP C_TS422_2023 Exam Syllabus Topics:
  • Capacity Planning in SAP S
  • 4HANA: This section covers a discussion of SAP S
  • 4HANA best practices, SAP HANA database concept, SAP Fiori user experience, and embedded analytics capabilities.
  • Master Data in SAP S
  • 4HANA: This section covers the exploration of crucial production-related master data elements, with emphasis on bill of material, routing, and production version.
  • Production Orders in SAP S
  • 4HANA: This section covers BOM item categorization, order status management, availability checks, routing selection, order type setup, and material handling processes.
  • Introduction to SAP S
  • 4HANA Production Planning: This section covers an overview of production planning components, functions, and planning approaches. Exploration of emerging trends.
Topic 5
  • Managing Clean Core: This section covers the application of clean core principles to enhance business process agility, reduce adaptation efforts, and drive innovation in ERP systems.
Topic 6
  • Process Orders in SAP S
  • 4HANA: This section covers an introduction to process order components, processing, and relevant master data objects. Overview of Good Manufacturing Practices (GMP) features.
Topic 7
  • Lean Manufacturing in SAP S
  • 4HANA: This section covers repetitive manufacturing master data, line load planning, and Kanban systems.
Topic 8
  • Advanced Planning in SAP S
  • 4HANA: This section includes an overview of advanced planning fundamentals and master data. Explanation of key tools and processes. Discussion of planning evaluation concepts.
Topic 9
  • 4HANA Supply Chain Planning: This part covers the background and motivation for SAP S
  • 4HANA, its main components, business applications, and user experience strategy.
SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing Sample Questions (Q58-Q63):NEW QUESTION # 58
Where do you maintain data to determine the duration of an operation for production? Note: There are
2 correct answers to this question.
  • A. Routing
  • B. Material master
  • C. Production version
  • D. Work center
NEW QUESTION # 59
How are dependent requirements for assemblies created?
  • A. They are created together with the independent requirement for the finished product.
  • B. They are created with exact times in Advanced Planning.
  • C. They are created on assembly level during the planning run.
  • D. They are only created for multilevel bill of material (BOM) structures.
NEW QUESTION # 60
Which standard item categories can you select inside a bill of material (BOM)? Note: There are 2 correct answers to this question.
  • A. WBS item
  • B. Preliminary item
  • C. Variable-size item
  • D. Work item
In SAP S/4HANA, the item category in a BOM (transaction CS01/CS02, field: Item Category) classifies components and determines their handling in production and procurement. Standard item categories include:
* Variable-size item(A): Item category "R" (Variable-Size Item) is used for components with dimensions (e.g., sheets, pipes) where quantity is calculated based on size data (entered in the Variable-Size Item Data tab). It's common in manufacturing for materials cut or sized during production.
* Preliminary item(C): Item category "V" (Preliminary Item) is a placeholder for components not yet fully specified (e.g., during design phase). It allows BOM creation to proceed, with details added later, and is valid for planning purposes.
Work item(B) is not a standard BOM item category-"L" (Stock Item) or "N" (Non-Stock Item) might apply to work-related components, but "Work Item" isn't a defined term.WBS item(D) (Work Breakdown Structure, category "W") relates to Project Systems (PS) BOMs, not standard production BOMs in PP, requiring PS integration. This is per SAP's BOM item category definitions.
NEW QUESTION # 61
Which options do you have to plan both quantities and capacities during line loading in repetitive manufacturing? Note: There are 2 correct answers to this question.
  • A. Run MRP with quota arrangement.
  • B. Run PP/DS heuristics for repetitive manufacturing.
  • C. Run MRP with automatic selection of production version.
  • D. Assign planned orders manually in the planning table.
In SAP S/4HANA repetitive manufacturing,line loadinginvolves planning production quantities and capacities across production lines. Options include:
* Run MRP with quota arrangement(B): MRP (MD01/MD02) with a quota arrangement (MEQ1, marked MRP-relevant) distributes production quantities across multiple production lines (production versions) based on predefined quotas (e.g., 60% Line A, 40% Line B). This plans quantities and implicitly considers capacity via the linked work centers, visible inMF50.
* Run PP/DS heuristics for repetitive manufacturing(D): PP/DS heuristics (e.g., SAP_PP_002 in
/SAPAPO/CDPSB0) plan both quantities (e.g., creating planned orders) and capacities (e.g., finite scheduling on production lines) for REM scenarios. This integrates detailed scheduling with line loading, optimizing resource use.
Assign planned orders manually in the planning table(A) (MF50) adjusts existing quantities but doesn't inherently plan capacities-it's a manual tweak.Run MRP with automatic selection of production version(C) selects one version (e.g., via alphanumeric order), planning quantities but not dynamically balancing capacities across lines. This is per SAP's REM planning options.
NEW QUESTION # 62
Which stard item categories can you select inside a bill of material (BOM)? Note: There are 2 correct answers to this question.
  • A. WBS item
  • B. Variablesize item
  • C. Preliminary item
  • D. Work item
NEW QUESTION # 63
The client only needs 20-30 hours to learn our C_TS422_2023 learning questions and then they can attend the exam. Most people may devote their main energy and time to their jobs, learning or other important things and can’t spare much time to prepare for the C_TS422_2023 Exam. But if clients buy our C_TS422_2023 training materials they can not only do their jobs or learning well but also pass the C_TS422_2023 exam smoothly and easily because they only need to spare little time to learn and prepare for the exam.
Valid C_TS422_2023 Exam Camp: https://www.prepawayexam.com/SAP/braindumps.C_TS422_2023.ete.file.html
2026 Latest PrepAwayExam C_TS422_2023 PDF Dumps and C_TS422_2023 Exam Engine Free Share: https://drive.google.com/open?id=17s28KwxXw0CC63Oq4CvrR3awhXvuJSAv
