熱門的最新L4M4試題和資格考試領先提供者和實踐中的L4M4認證資料
Posted at 2/13/2026 09:27:28
用一下Fast2test的L4M4考古題怎麼樣?這個考古題可以說是與L4M4考試相關的所有參考資料中最優秀的資料。為什麼呢?有以下四個理由。第一,Fast2test的考古題是IT專家們運用他們多年的經驗研究出來的資料,可以準確地劃出考試出題的範圍。第二,Fast2test的考古題包含了可能出現在實際考試中的所有試題。第三,Fast2test的考古題保證考生一次就通過考試,如果考生考試失敗則全額退款。第四,Fast2test的考古題分為PDF版和軟體版兩個版本。利用這兩個版本的考古題,考生可以更輕鬆地準備考試。
CIPS L4M4 考試大綱:| 主題 | 簡介 | | 主題 1 | - This section examines analyzing market data, obtaining quotations
- tenders, and assessing responses. The sub-topics focus on key processes for evaluating potential suppliers.
| | 主題 2 | - Understand compliance issues when sourcing from suppliers: It explores legislative, regulatory, and organizational requirements for sourcing. It compares the use of audit and other mechanism of feedback.
| | 主題 3 | - Understand the key processes that can be applied to the analysis of potential external suppliers:
| | 主題 4 | - Understand options for sourcing requirements from suppliers: This section covers the sourcing process, approaches, options, and award criteria for obtaining requirements from suppliers. The sub-topics provide a foundation for strategic sourcing.
L4M4認證資料,L4M4證照考試Fast2test作為專門提供L4M4認證考試相關資料的提供者,一直以來都把為考生們提供最優秀的資料作為自己的目標。與其他網站相比,Fast2test更得大家的信任。這是為什麼呢?因為Fast2test有著多年的經驗,並且一直專心致力於L4M4認證考試的研究,總結出了很多關於考試的規律。這樣,Fast2test的資料就可以有很高的命中率。這也保證了大家的考試的合格率。所以Fast2test得到了大家的信任。
最新的 CIPS Level 4 Diploma in Procurement and Supply L4M4 免費考試真題 (Q115-Q120):問題 #115
Phishing is a type of fraud that is commonly associated with which industry?
- A. Construction
- B. Agriculture
- C. Mining
- D. IT
答案:D
解題說明:
Phishing is a type of fraud where IT users are sent a link (usually by email) which exposes them to activities of expert cybercriminals.
問題 #116
You have been asked to purchase 500 pens of a specific brand. You decided to use a weighted points system for assessment of proposals. Is this approach appropriate?
- A. No, you should only use a weighted points system for high-spend procurement
- B. Yes, a weighted points system is always the best way to evaluate suppliers' bids
- C. No, it is not necessary, as in this case, you are mainly concerned with price
- D. Yes, you should follow the same procurement process irrespective of the circumstances
答案:C
解題說明:
For low-value, routine purchases where price is the primary consideration, employing a weighted points system may not be necessary. Such systems are more suitable for complex procurements where multiple factors, such as quality, delivery, and sustainability, need to be evaluated alongside price. In the case of purchasing standard items like pens, a straightforward price comparison is typically sufficient.
CIPS Level 4 Diploma in Procurement and Supply, L4M4 Study Guide, Section 2.3.2: The use of weighted points systems for assessment
問題 #117
It is good practice for the procuring organisation's auditors to undertake the following upon completion of a supplier's audit. Select the TWO that apply.
- A. Call for a meeting with colleagues and share confidential details of the audit
- B. Inform the supplier of any non-conformances and improvement opportunities
- C. Prepare an audit report that may be shared with the supplier in advance
- D. Report non-compliance to police and have the supplier arrested for lapses
- E. Do nothing, after all, this is a known supplier incapable of serious breaches
答案:B,C
解題說明:
Informing suppliers of non-conformances and improvement opportunities supports responsible sourcing by promoting continuous improvement. Preparing a report for supplier review also aligns with transparency and collaborative improvement, integral to ethical sourcing standards.
問題 #118
Ivan is an investor who is looking to invest in new businesses. He is reviewing several companies and working out what his equity would be. Which of the following does Ivan need to know to calculate shareholder equity?
Select TWO.
- A. net profit
- B. net income
- C. total liabilities
- D. total assets
答案:C,D
解題說明:
Shareholder Equity = Total Assets - Total Liabilities
問題 #119
If a company is concerned with ethical sourcing and has concerns about issues such as corruption and modern day slavery within the supply chain, what course of action should they take?
- A. Complete Due-Diligence on all new suppliers
- B. Only work with known suppliers
- C. Complete formal tenders to find the best suppliers
- D. Only work with suppliers who have a published Anti-Slavery policy
答案:A
解題說明:
Completing Due Diligence checks will help guard against concerns about unethical business practices.
Not all companies will have a published Anti-Slavery policy- this is only required for large companies.
Known suppliers might have issues that you don't know about so you should always do due-diligence checks on everyone you work with Formal tenders won't sort out ethical issues unless specifically addressed within the tender and strong contract management is put in place afterwards.
問題 #120
如果你是一名IT職員,你想升職嗎?你想成為一名專業的IT技術專家嗎?那就趕緊報名參加CIPS的L4M4考試認證吧!你也知道這個認證對你們來說是多麼的重要,不要擔心考不過,不要懷疑自己的能力,只要參加了CIPS的L4M4考試認證。所有的備考問題都來找Fast2test,它是一家專業的IT認證培訓網站,有了它在,你考試難題將不攻而破,Fast2test CIPS的L4M4考試認證培訓資料可以幫助你輕鬆的應對考試,它幫助過的考生數不勝數,保證100%成功,還不趕緊行動,點擊Fast2test,早日實現你的IT夢吧。
L4M4認證資料: https://tw.fast2test.com/L4M4-premium-file.html
- L4M4參考資料 🐙 L4M4真題材料 🛥 L4M4權威考題 📝 在➤ [url]www.vcesoft.com ⮘網站下載免費▶ L4M4 ◀題庫收集L4M4考試重點[/url]
- 完美的最新L4M4試題&優秀的CIPS認證培訓 - 優秀的CIPS Ethical and Responsible Sourcing ☯ 立即到⏩ [url]www.newdumpspdf.com ⏪上搜索【 L4M4 】以獲取免費下載L4M4參考資料[/url]
- L4M4考題套裝 📁 L4M4題庫更新 🦆 L4M4软件版 🅿 來自網站▷ [url]www.newdumpspdf.com ◁打開並搜索▶ L4M4 ◀免費下載免費下載L4M4考題[/url]
- 選擇最新L4M4試題表示您已通過Ethical and Responsible Sourcing無憂 🎳 到“ [url]www.newdumpspdf.com ”搜尋⮆ L4M4 ⮄以獲取免費下載考試資料L4M4學習指南[/url]
- 使用最新L4M4試題,傳遞Ethical and Responsible Sourcing相關信息 👫 「 [url]www.pdfexamdumps.com 」上的➠ L4M4 🠰免費下載只需搜尋L4M4題庫更新資訊[/url]
- 100%保障最新L4M4試題,最有效的考試題庫幫助妳壹次性通過L4M4考試 🎧 立即到▶ [url]www.newdumpspdf.com ◀上搜索▶ L4M4 ◀以獲取免費下載L4M4考題免費下載[/url]
- L4M4考題 🌌 最新L4M4試題 😽 L4M4權威考題 🦳 立即打開⮆ tw.fast2test.com ⮄並搜索【 L4M4 】以獲取免費下載L4M4真題材料
- 最新L4M4試題 | Ethical and Responsible Sourcing的便捷資料 😍 進入⮆ [url]www.newdumpspdf.com ⮄搜尋▛ L4M4 ▟免費下載L4M4考題[/url]
- 最新L4M4試題 | Ethical and Responsible Sourcing的便捷資料 🧜 透過✔ tw.fast2test.com ️✔️輕鬆獲取⏩ L4M4 ⏪免費下載L4M4參考資料
- L4M4真題材料 🤛 L4M4软件版 🧒 免費下載L4M4考題 😬 到⇛ [url]www.newdumpspdf.com ⇚搜索{ L4M4 }輕鬆取得免費下載L4M4熱門認證[/url]
- L4M4熱門題庫 👷 L4M4題庫更新資訊 🍊 L4M4考試重點 🔸 打開▛ [url]www.pdfexamdumps.com ▟搜尋▶ L4M4 ◀以免費下載考試資料L4M4真題材料[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
