[General] AZ-140 Learning Materials: Configuring and Operating Microsoft Azure Virtual Des
106
【General】 AZ-140 Learning Materials: Configuring and Operating Microsoft Azure Virtual Des
Posted at 2/13/2026 18:26:43      View:120 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest PracticeVCE AZ-140 PDF Dumps and AZ-140 Exam Engine Free Share: https://drive.google.com/open?id=1fBn10BTIsdusd0VA9tGv91c4gHNmeiNF
As to this fateful exam that can help you or break you in some circumstances, our company made these AZ-140 practice materials with accountability. We understand you can have more chances being accepted by other places and getting higher salary or acceptance. Our AZ-140training materials are made by our responsible company which means you can gain many other benefits as well. We offer free demos for your reference, and send you the new updates if our experts make them freely.
To pass the Microsoft AZ-140 Exam, candidates must demonstrate their ability to perform several tasks related to Azure Virtual Desktop. These include deploying and configuring virtual desktops and applications, creating and managing host pools and session hosts, implementing user profile management, and securing the Azure Virtual Desktop environment. Additionally, candidates must be knowledgeable in monitoring and troubleshooting issues related to Azure Virtual Desktop.
Pass Guaranteed Pass-Sure Microsoft - AZ-140 - Free Configuring and Operating Microsoft Azure Virtual Desktop Exam DumpsPassing a exam for most candidates may be not very easy, our AZ-140 Exam Materials are trying to make the make the difficult things become easier. With the experienced experts to revise the AZ-140 exam dump, and the professionals to check timely, the versions update is quietly fast. Thinking that if you got the certificate, you can get a higher salary, and you’re your position in the company will also in a higher level.
Microsoft Configuring and Operating Microsoft Azure Virtual Desktop Sample Questions (Q20-Q25):NEW QUESTION # 20
You have an Azure subscription that contains the virtual machines shown in the following table.
You create an Azure Compute Gallery as shown in the Azure compute gallery exhibit. (Click the Azure compute gallery tab.)
You create a virtual machine image definition as shown in the VM image definition exhibit. (Click the VM image definition tab.)
Text Description automatically generated with medium confidence
NEW QUESTION # 21
You have a Windows Virtual Desktop deployment.
You need to ensure that all the connections to the managed resources in the host pool require multi-factor authentication (MFA).
Which two settings should you modify in a conditional access policy? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... al-enable-azure-mfa
NEW QUESTION # 22
You have an Azure Virtual Desktop host pool. The pool contains session hosts that run Windows 10 Enterprise multi-session.
You connect to a Remote Desktop session on Pool1 and discover an issue with the frequency of screen updates.
You need to identify whether the issue related to insufficient server, network, or client resources. The solution must minimize how long it takes to identify the resource type.
What should you do?
  • A. From Azure Cloud Shell, run the
    Get-AzOperationalInsightsWorkspaceUsage cmdlet and specify the DefaultProfile parameter.
  • B. From Azure Cloud Shell, run the Get-AzWvdUserSession cmdlet and specify the UserSessionId parameter.
  • C. From within the current session, use the Azure Virtual Desktop Experience Estimator.
  • D. From within the current session, use Performance Monitor to display the values of all the RemoteFX Graphics(*)Frames Skipped/Second counters.
NEW QUESTION # 23
You have a Azure Virtual Desktop host pool named Pool1 that contains three session hosts. The session hosts are configured to use FSLogtx profile containers. You need to configure Cloud Cache on the session hosts.
What should you do?
  • A. Configure FSLogtx Office Container.
  • B. Add VHDlocations entries to the Windows registry.
  • C. Remove VHDlocations entries from the Windows registry.
  • D. Uninstall the FSLogix agent
NEW QUESTION # 24
You have two Azure subscriptions that are linked to an Azure Active Directory (Azure AD) tenant named contoso.com and contain an Azure Virtual Desktop deployment. The tenant contains a user named User1.
When User1 signs in to Azure Security Center, the user receives the message shown in the following exhibit.
You need to ensure that User1 can manage security information for the tenant. The solution must use the principle of least privilege.
Hot Area:
NEW QUESTION # 25
There is no such excellent exam material like our PracticeVCE AZ-140 exam materials. We not only provide all candidates with most reliable guarantee, but also have best customer support. Our AZ-140 exam material’s efficient staff is always prompt to respond you. If you have any doubts about our exam materials and need detailed answer, you can send emails to our customers’ care department. If you are in hurry, you can consult our AZ-140 exam material’s online customer service. We will solve your problem as soon as possible. Our customer support is available for you 24/7. 365 days a Year. Our PracticeVCE AZ-140 Exam Materials have managed to build an excellent relationship with our users through the mutual respect and attention we provide to everyone. We believed that you will pass the AZ-140 exam in the first attempt without any obstacles, and will get your ideal job.
AZ-140 Mock Test: https://www.practicevce.com/Microsoft/AZ-140-practice-exam-dumps.html
