[General] International Code Council Fire-Inspector-II Latest Braindumps Book & Latest
111
General International Code Council Fire-Inspector-II Latest Braindumps Book & Latest
Posted at 2/13/2026 21:26:06      View136 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that BraindumpsIT Fire-Inspector-II dumps now are free: https://drive.google.com/open?id=1XIFz_9ILNMGmUp76r0tgTl9F4Mvb8ov1
Test engine version is a simulation of real test; you can feel the atmosphere of formal test. You can well know your shortcoming and strength in the course of practicing International Code Council exam dumps. It adjusts you to do the Fire-Inspector-II Certification Dumps according to the time of formal test. Most IT workers like using it to test Fire-Inspector-II practice questions and their ability.
Top Rated Features of International Code Council Fire-Inspector-II Practice Test Questions. The BraindumpsIT is committed to making the International Code Council Fire-Inspector-II exam preparation journey simple, smart, and swift. To meet this objective the BraindumpsIT is offering Fire-Inspector-II practice test questions with top-rated features. These features are updated and real International Code Council Fire-Inspector-II Exam Questions, availability of 67 - Fire Inspector II Exam Fire-Inspector-II exam real questions in three easy-to-use and compatible formats, three months free updated International Code Council Fire-Inspector-II exam questions download facility, affordable price and 100 percent 67 - Fire Inspector II Exam Fire-Inspector-II exam passing money back guarantee.
100% Pass Quiz 2026 International Code Council Authoritative Fire-Inspector-II Latest Braindumps BookTo increase your chances of success, consider utilizing the BraindumpsIT Fire-Inspector-II Exam Questions, which are valid, updated, and reflective of the actual Fire-Inspector-II exam. Don't miss the opportunity to strengthen your International Code Council Fire-Inspector-II exam preparation with these valuable questions. The BraindumpsIT is a leading platform that has been assisting the International Code Council Fire-Inspector-II Exam candidates for many years. Over this long time period countless Fire-Inspector-II exam candidates have passed their International Code Council Fire-Inspector-II certification exam. They got success in 67 - Fire Inspector II Exam exam with flying colors and did a job in top world companies.
International Code Council 67 - Fire Inspector II Exam Sample Questions (Q39-Q44):NEW QUESTION # 39
A container in a clean-agent extinguishing system must be refilled or replaced when it shows a loss in original weight of more than five percent, or a loss in original pressure of more than ___ percent.
  • A. 0
  • B. 1
  • C. 2
  • D. 3
A container in a clean-agent extinguishing system must be refilled or replaced if it experiences a loss of more than 5% of its original weight or a loss in original pressure of more than 3%. This requirement ensures the system maintains sufficient agent concentration for fire suppression.
Reference to Fire Inspector Documentation:
1. NFPA 2001 - Standard on Clean Agent Fire Extinguishing Systems (2022 Edition) NFPA 2001, Section 7.3.2.1 states that a container must be refilled or replaced if the weight loss exceeds 5% or the pressure loss exceeds 3% from the original fill pressure.
These limits are set to maintain system effectiveness and ensure that a clean-agent system can properly discharge in case of a fire.
2. 2021 International Fire Code (IFC) - Chapter 9 (Fire Protection Systems) IFC 904.10 requires that clean-agent systems be maintained per NFPA 2001 to ensure reliability.
Detailed Explanation of Answer Choices:
Option A (Correct): 3% pressure loss is the correct threshold beyond which a container must be replaced or refilled.
Option B (Incorrect): While 5% is correct for weight loss, it is not the correct value for pressure loss.
Option C (Incorrect): A 10% pressure loss is too high and would compromise system performance before reaching the replacement threshold.
Option D (Incorrect): 12% is well beyond the acceptable loss limit and would pose a significant safety risk.
Thus, the correct and verified answer is: A. 3
NEW QUESTION # 40
What is the maximum travel distance to an exit from within a tent?
  • A. 150 ft.
  • B. Any distance approved by the chief
  • C. 75 ft.
  • D. 100 ft.
The maximum travel distance to an exit from within a tent is regulated under the 2021 International Fire Code (IFC), Section 3103.12.2 - Means of Egress (Tents and Membrane Structures).
IFC Section 3103.12.2 - Travel Distance:
"The maximum travel distance to an exit shall not exceed 150 feet (45,720 mm)." Why Other Options Are Incorrect?
A: 75 ft. - This limit does not apply to tents; the correct limit is 150 ft.
B: 100 ft. - Too restrictive; the IFC allows up to 150 ft.
D: Any distance approved by the chief. - The fire code does not allow unlimited travel distances; 150 feet is the maximum permitted by code.
NEW QUESTION # 41
The minimum fire-flow for a 3,700-sq. ft. two-family dwelling of Type VB construction with a sprinkler system is ___ GPM.
  • A. 1,000
  • B. 0
  • C. 1,313
  • D. 1,750
Fire flow for residential buildings is determined based on IFC Appendix B, Table B105.1(1) - Required Fire Flow for One- and Two-Family Dwellings, Group R-3, and R-4 Buildings.
For a 3,700 sq. ft. two-family dwelling of Type VB construction:
Per Table B105.1(1), the baseline fire flow is 1,750 gpm.
If an NFPA 13D-compliant automatic sprinkler system is installed, the fire flow is reduced by 50%.
1,750 gpm 0.50 = 875 gpm, but the minimum allowed for a sprinklered dwelling is 1,000 gpm.
NEW QUESTION # 42
The occupant load of an R-2 building's common patio area is to be calculated using the value:
  • A. assigned by the code official.
  • B. 50 net per person.
  • C. 15 gross per person.
  • D. 11 gross per person.
The occupant load for an R-2 building's common patio area must be calculated using an occupant load factor.
The correct factor is 15 gross sq. ft. per person.
1. 2021 International Building Code (IBC) - Table 1004.5 (Occupant Load Factor) For outdoor areas (such as patios and terraces), the applicable factor is 15 gross sq. ft. per person.
2. 2021 International Fire Code (IFC) - Section 1004.5 (Outdoor Occupant Loads) The 15 gross per person requirement is applied to common outdoor gathering areas in residential occupancies (R-2).
Option A (Incorrect): 50 net per person applies to storage areas, not patios.
Option B (Incorrect): 11 gross per person is used for business occupancies (B), not residential patios.
Option C (Correct): 15 gross per person is the correct calculation factor for common outdoor spaces in R-2 buildings.
Option D (Incorrect): The code official does not assign occupant load values arbitrarily-they follow IBC Table 1004.5.
Thus, the correct and verified answer is: C. 15 gross per person.
NEW QUESTION # 43
The minimum fire-flow for a 75,000-sq. ft. building of Type IIB construction without a sprinkler system is:
  • A. 5,750 gpm for 4 hours.
  • B. 3,000 gpm for 3 hours.
  • C. 5,500 gpm for 4 hours.
  • D. 4,000 gpm for 4 hours.
Reference to Fire-Flow Requirements for Type IIB Buildings:
The International Fire Code (IFC 2021), Appendix B, Table B105.1(2) establishes the minimum fire-flow requirements for buildings based on construction type, size, and the presence of sprinkler systems.
For a 75,000 sq. ft. Type IIB (non-combustible, unprotected) building without sprinklers, the required fire- flow is 5,500 gpm for 4 hours.
Why Fire-Flow Matters:
Fire-flow ensures that sufficient water is available to control and extinguish fires in large buildings.
Type IIB buildings lack built-in fire resistance enhancements, making adequate fire-flow crucial.
Clarification of Incorrect Answer Choices:
A). 3,000 gpm for 3 hours # Incorrect
Too low for a building of this size and construction type.
B). 4,000 gpm for 4 hours # Incorrect
Below the required 5,500 gpm per IFC Appendix B.
D). 5,750 gpm for 4 hours # Incorrect
Slightly above the requirement but not the exact minimum mandated by IFC Table B105.1(2).
Conclusion:
The correct and verified answer is C (5,500 gpm for 4 hours) as per IFC Appendix B, Table B105.1(2), ensuring compliance with fire-flow standards for Type IIB buildings without sprinklers.
NEW QUESTION # 44
All contents of Fire-Inspector-II training guide are being explicit to make you have explicit understanding of this exam. Their contribution is praised for their purview is unlimited. None cryptic contents in Fire-Inspector-II learning materials you may encounter. And our Fire-Inspector-II Exam Questions are easy to understand and they are popular to be sold to all over the world. Just look at the comments on the website, then you will know that we have a lot of loyal customers.
Latest Fire-Inspector-II Test Report: https://www.braindumpsit.com/Fire-Inspector-II_real-exam.html
The only goal of all experts and professors in our company is to design the best and suitable Fire-Inspector-II study materials for all people, International Code Council Fire-Inspector-II Latest Braindumps Book Therefore, we won't miss any key points for the IT exam, International Code Council Fire-Inspector-II Latest Braindumps Book As old saying goes, knowledge will change your life, International Code Council Fire-Inspector-II Latest Braindumps Book Actually, some meaningful certificates are of great importance, which is an obvious prove of your capacity.
The required number of hosts per subnet the design should create, In most Fire-Inspector-II cases, your cost includes these fees, but if you are buying direct from an overseas source, your quoted price may not include this additional cost.
True Fire-Inspector-II Exam Extraordinary Practice For the Fire-Inspector-II ExamThe only goal of all experts and professors in our company is to design the best and suitable Fire-Inspector-II Study Materials for all people, Therefore, we won't miss any key points for the IT exam.
As old saying goes, knowledge will change your Fire-Inspector-II Latest Braindumps Book life, Actually, some meaningful certificates are of great importance, which is an obvious prove of your capacity, With our latest Fire-Inspector-II training materials, you will pass the certification exam in your first try.
P.S. Free 2026 International Code Council Fire-Inspector-II dumps are available on Google Drive shared by BraindumpsIT: https://drive.google.com/open?id=1XIFz_9ILNMGmUp76r0tgTl9F4Mvb8ov1
Posted at 2/17/2026 10:50:36        Only Author  2#
Straight to the like button, this content is fantastic. Improve your IT skills and access free Agentforce-Specialist valid exam voucher. Wishing you the best of luck!
