[General] C_ACDET_2506 Dumps - Practice C_ACDET_2506 Exams Free
99
【General】 C_ACDET_2506 Dumps - Practice C_ACDET_2506 Exams Free
Posted at 2/13/2026 21:53:30      View:107 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of BraindumpsPrep C_ACDET_2506 dumps for free: https://drive.google.com/open?id=1CIVCb5mYYpe4UrNH_JICn4qYo-X_UEZ0
We provide SAP C_ACDET_2506 web-based self-assessment practice software that will help you to prepare for the SAP SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite exam. SAP C_ACDET_2506 Web-based software offers computer-based assessment solutions to help you automate the entire SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite exam testing procedure. The stylish and user-friendly interface works with all browsers, including Mozilla Firefox, Google Chrome, Opera, Safari, and Internet Explorer. It will make your SAP SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite exam preparation simple, quick, and smart. So, rest certain that you will discover all you need to study for and pass the SAP C_ACDET_2506 Exam on the first try.
SAP C_ACDET_2506 Exam Syllabus Topics:
  • Field Configuration: This domain evaluates the knowledge of an SAP Deployment Specialist and focuses on customizing and configuring business fields in the SAP system according to client-specific needs. This includes adjusting system settings for master data, transaction data, and other essential field-level controls to support business processes effectively. The section tests the candidate’s ability to use configuration tools, apply SAP standard templates, and ensure that the field configurations align with the desired operational workflows of the business. It also touches upon validation, testing, and documenting the configuration changes made during the implementation.
  • Project Overview, Roles and Responsibilities: This section of the exam measures the skills of an SAP Cloud Consultant and covers the fundamental understanding of SAP Activate methodology within the context of a cloud implementation project. Candidates are expected to be familiar with the project lifecycle, including phases such as Prepare, Explore, Realize, Deploy, and Run. This part also focuses on identifying key roles and responsibilities within a cloud project team, ensuring clarity in collaboration between consultants, clients, and SAP. It checks whether the consultant understands governance, stakeholder management, and the high-level structure of cloud deployment using SAP best practices.
  • Deploy and Migration: This part of the exam assesses the expertise of an SAP Deployment Specialist and focuses on the final deployment of the configured solution and the data migration process. Candidates should demonstrate a solid grasp of how to move configurations from a testing environment into production while minimizing disruption. It also includes knowledge of tools and strategies used for data extraction.
SAP C_ACDET_2506 Realistic Dumps Free PDF QuizThe C_ACDET_2506 dumps of BraindumpsPrep include valid C_ACDET_2506 questions PDF and customizable SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite (C_ACDET_2506) practice tests. Our 24/7 customer support provides assistance to help C_ACDET_2506 Dumps users solve their technical hitches during their test preparation. The C_ACDET_2506 exam questions of BraindumpsPrep come with up to 365 days of free updates and a free demo.
SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite Sample Questions (Q35-Q40):NEW QUESTION # 35
A standard field is not available in reporting. A Greenfield customer needs to be able to report on the data captured in that standard field. How can this be achieved?
  • A. The system makes all fields reportable after a system refresh.
  • B. All standard fields are reportable by default.
  • C. Under Field Configurations, search for the field in the appropriate class, mark the field reportable, save and publish.
  • D. Create a custom field that can be marked reportable, default the custom field to the standard field value, publish, and then pull the field into reporting.
Some standard fields in SAP Ariba are not reportable by design and cannot be made reportable through configuration changes. Therecommended workaround is to create a custom field that is marked as reportable, then set its default value to the standard field's value using an expression. Once published, this custom field can be included in reports, effectively surfacing the data previously inaccessible for reporting. System refreshes do not convert non-reportable standard fields to reportable. Marking the original standard field as reportable is not possible if the option is disabled by design.
NEW QUESTION # 36
What does ? represent in the ariba expression below? HierarchicalType=="SubAgreement" ? false: true
  • A. else
  • B. then
  • C. if
  • D. replace
NEW QUESTION # 37
While migrating form templates, you successfully exported all templates from the Test site.
However, when trying to import them into Production, you cannot find the correct folder.
What should you do to proceed without errors?
  • A. Manually create the required folder in the Production site before importing
  • B. Upload the templates to any existing folder regardless of its purpose.
  • C. Modify the form template files locally to bypass folder restrictions.
  • D. Skip the import and inform the team the templates cannot be migrated.
NEW QUESTION # 38
You have a custom string field with a list of values. The values are represented as an Enumeration.
Which of the following applies to this scenario?
  • A. In the enumeration file, the Value column must only contain whole numbers
  • B. The display order in the droop down matches the order defined in the enumeration file
  • C. The user can filter the values using the search box in the chooser
  • D. The display order of the values is alphabetical
NEW QUESTION # 39
Which of the following master data types requires manual migration from Test to Production in a Greenfield migration?
  • A. Translations
  • B. Enumerations
  • C. Relations and relation entries
  • D. Clause Library
In SAP Ariba Greenfield deployments,Enumerations (picklist value lists) require manual migration because they are not included in Intelligent Configuration Manager (ICM) bundles. Enumerations must be manually exported from Test and imported into Production to ensure correct picklist values for fields that depend on them.
Other master data types like Clause Library and Relations can be migrated using standard migration tools or processes. Translations are handled via AML & Translations Upload.
Ensuring enumerations are migrated correctly is critical because missing or inconsistent enumerations can cause field validation errors and disrupt system usage.
NEW QUESTION # 40
Our C_ACDET_2506 real exam helps you not only to avoid all the troubles of learning but also to provide you with higher learning quality than other students'. At the same time, our C_ACDET_2506 exam materials have been kind enough to prepare the App version for you, so that you can download our C_ACDET_2506 practice prep to any electronic device, and then you can take all the learning materials with you and review no matter where you are.
Practice C_ACDET_2506 Exams Free: https://www.briandumpsprep.com/C_ACDET_2506-prep-exam-braindumps.html
BTW, DOWNLOAD part of BraindumpsPrep C_ACDET_2506 dumps from Cloud Storage: https://drive.google.com/open?id=1CIVCb5mYYpe4UrNH_JICn4qYo-X_UEZ0
