EDGE-Expert最新題庫資源,EDGE-Expert考題寶典
Posted at 2/13/2026 23:26:46
如果你選擇Fast2test,那麼成功就在不遠處。你很快就可以獲得EDGE EDGE-Expert 認證考試的證書。我們的Fast2test提供的產品可以100%保證你通過考試,而且還會為你提供一年的免費的更新服務。
Fast2test是一個可以成就很多IT人士的夢想的網站。Fast2test能為參加IT相關認證考試的考生提供他們想要的資料來助幫助他們通過考試。你還在為通過EDGE EDGE-Expert認證考試苦惱嗎?你有想過購買EDGE EDGE-Expert認證考試相關的課程來輔助你嗎?Fast2test可以為你提供這個便利,Fast2test提供的培訓資料可以有效地幫你通過認證考試。Fast2test提供的練習題幾乎真題是一樣的。有了Fast2test為你提供的精確的EDGE EDGE-Expert認證考試的練習題和答案,你可以以高分通過EDGE EDGE-Expert認證考試。
最好的EDGE-Expert最新題庫資源 & 可靠的EDGE-Expert考題寶典很多新人剛進入公司就聽說,每個月都會有 EDGE 證照考試,如果過了,年底有獎金的發放,根據你完成證照的情況,才完成獎金的分配。然而對於沒有參加過任何證照考試的新人來說,是一次不錯挑戰。Fast2test 剛剛更新的 EDGE EDGE-Expert 擬真試題剛好可以幫助很多新人,如果你正在準備 EDGE EDGE-Expert 考試的話,可以利用我們最新的擬真試題仔細地複習備考了。因為最新的 EDGE-Expert 擬真試題可以為你的複習和看書減輕很多的煩惱。
最新的 GBCI EDGE EDGE-Expert 免費考試真題 (Q66-Q71):問題 #66
Which of the following must be included in the EDGE Auditor submission for Preliminary Certification?
- A. All of the available design data.
- B. Compliance documents for selected measures.
- C. The Chapter 5 EDGE certification protocol.
- D. The design audit site visit results verified by the EDGE Auditor.
答案:B
解題說明:
The EDGE Auditor's submission for Preliminary Certification (design stage) must include specific elements to support the recommendation for certification. The EDGE Certification Protocol specifies: "For Preliminary Certification, the EDGE Auditor's submission must include compliance documents for the selected measures, such as drawings, specifications, and manufacturer's data sheets, which verify that the design aligns with the self-assessment in the EDGE software. These documents are reviewed by the Certification Provider to confirm eligibility" (EDGE Certification Protocol, Section 3.2: Audit Requirements). Option C, compliance documents for selected measures, directly matches this requirement. Option A (all available design data) is too broad and not required: "Only documents directly related to the selected measures are needed, not all design data" (EDGE Certification Protocol, Section 3.2: Audit Requirements). Option B (Chapter 5 EDGE certification protocol) is incorrect, as this refers to the protocol document itself, not a submission component:
"The certification protocol is a reference, not part of the Auditor's submission" (EDGE Certification Protocol, Section 1.1: Overview). Option D (design audit site visit results) is incorrect, as site visits are not required at the design stage: "Preliminary Certification is based on a desk audit, not a site visit, which occurs at the post- construction stage" (EDGE Certification Protocol, Section 3.3: Certification Decision). Thus, compliance documents (Option C) are required in the submission.
Reference:EDGE Certification Protocol, Section 3.2: Audit Requirements, Section 3.3: Certification Decision, Section 1.1: Overview.
問題 #67
Which of the following can deliver the highest efficiency in fans and pumps?
- A. Variable speed drive
- B. Single speed drive
- C. Constant speed drive
- D. Two speed drive
答案:A
解題說明:
Efficiency in fans and pumps is a critical aspect of green building design in EDGE, particularly for reducing energy consumption in HVAC systems. The EDGE User Guide provides detailed guidance on efficiency measures for mechanical systems: "Variable speed drives (VSDs) deliver the highest efficiency in fans and pumps by adjusting the motor speed to match the actual demand, significantly reducing energy consumption compared to fixed-speed systems. VSDs can achieve energy savings of up to 30-50% in HVAC applications by avoiding the constant operation at full speed typical of single or constant speed drives" (EDGE User Guide, Section 4.2: Energy Efficiency Measures). Option D, variable speed drive, aligns with this description as the most efficient option. Option A (two speed drive) offers some efficiency by allowing two operating speeds, but it is less flexible than VSDs: "Two speed drives provide limited efficiency gains, as they cannot continuously adjust to varying loads, unlike variable speed drives" (EDGE Methodology Report Version 2.0, Section 5.1: Energy Efficiency Metrics). Option B (single speed drive) and Option C (constant speed drive) are essentially the same in this context, operating at a fixed speed regardless of demand, leading to energy waste: "Single speed or constant speed drives run at a fixed rate, resulting in higher energy consumption compared to variable speed drives, which modulate speed based on need" (EDGE User Guide, Section 4.2:
Energy Efficiency Measures). The EDGE Methodology Report further elaborates: "Variable speed drives are the most efficient option for fans and pumps in EDGE, as they minimize energy use by matching output to demand, unlike two speed or constant speed drives, which operate inefficiently under partial loads" (EDGE Methodology Report Version 2.0, Section 5.1: Energy Efficiency Metrics). This makes variable speed drives (Option D) the clear choice for delivering the highest efficiency in fans and pumps.
Reference:EDGE User Guide Version 2.1, Section 4.2: Energy Efficiency Measures; EDGE Methodology Report Version 2.0, Section 5.1: Energy Efficiency Metrics.
問題 #68
A building achieved EDGE certification three years ago and obtained 30% energy savings. Solar panels have been added, which increased the energy savings to 60%. If carbon offsets are purchased for the remainder of the energy use, when should an EDGE Zero Carbon certification application be filed?
- A. At the same time as the EDGE Advanced certification and only after gathering two years of operational data
- B. No wait time required as the project is already EDGE certified
- C. As soon as one year of operational data can be provided
- D. After achieving EDGE Advanced certification and gathering one year of operational data
答案:D
解題說明:
EDGE Zero Carbon certification requires specific prerequisites and operational data to verify performance.
The EDGE Certification Protocol details the requirements: "To apply for EDGE Zero Carbon certification, a project must first achieve EDGE Advanced certification, which requires at least 40% energy savings.
Additionally, EDGE Zero Carbon certification mandates at least one year of operational data at 75% occupancy to confirm energy performance, after which carbon offsets can be purchased for the remaining energy use to achieve zero carbon status" (EDGE Certification Protocol, Section 2.3: Certification Levels). In this scenario, the building's energy savings have increased to 60% with solar panels, qualifying it for EDGE Advanced (40% minimum). The next step is to gather one year of operational data before applying for EDGE Zero Carbon, making Option C (after achieving EDGE Advanced certification and gathering one year of operational data) correct. Option A (as soon as one year of operational data) skips the EDGE Advanced requirement: "EDGE Advanced is a prerequisite for EDGE Zero Carbon" (EDGE Certification Protocol, Section 2.3: Certification Levels). Option B (no wait time) is incorrect, as operational data is mandatory:
"Operational data is required to verify performance for Zero Carbon certification" (EDGE User Guide, Section 6.3: Advanced Certifications). Option D (at the same time as EDGE Advanced and after two years) is wrong, as only one year of data is needed: "One year of operational data at 75% occupancy is sufficient for EDGE Zero Carbon" (EDGE Certification Protocol, Section 2.3: Certification Levels). Thus, Option C is the correct timeline.
Reference:EDGE Certification Protocol, Section 2.3: Certification Levels; EDGE User Guide Version 2.1, Section 6.3: Advanced Certifications.
問題 #69
Which of the following is NOT an option for insulation in materials efficiency measures?
- A. Polystyrene
- B. Polyurethane
- C. Mineral wool
- D. Polypropylene
答案:D
解題說明:
Insulation materials in EDGE are evaluated for their thermal performance and embodied energy as part of materials efficiency measures. The EDGE User Guide lists common insulation options: "In EDGE, insulation materials for walls, roofs, and floors include mineral wool, polyurethane,polystyrene, and fiberglass, which are selected for their low thermal conductivity and availability in most markets" (EDGE User Guide, Section
7.2: Materials Efficiency Measures). Options A (mineral wool), B (polyurethane), and D (polystyrene) are explicitly mentioned as insulation materials in EDGE. Option C, polypropylene, is not listed as an insulation material, as confirmed by the EDGE Methodology Report: "Polypropylene is a plastic material often used in packaging or pipes, but it is not recognized in EDGE as an insulation material due to its poor thermal resistance compared to standard insulation options like polystyrene or polyurethane" (EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials). The EDGE software's material database further excludes polypropylene from insulation options, focusing instead on materials with established thermal properties for building envelopes. Thus, polypropylene (Option C) is not an insulation option in EDGE.
Reference:EDGE User Guide Version 2.1, Section 7.2: Materials Efficiency Measures; EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials.
問題 #70
Which of the following measures will impact energy, water, and materials in an air-conditioned hospital with a water-cooled chiller?
- A. Insulation of the roof
- B. Water-efficient dishwashers
- C. Water-efficient urinals
- D. Variable speed drive pumps
答案:D
解題說明:
In EDGE, measures are evaluated for their impact on energy, water, and embodied energy in materials, the three core pillars of the standard. For an air-conditioned hospital with a water-cooled chiller, the measure must affect all three areas to be the correct answer. The EDGE User Guide provides detailed descriptions of each measure's impact: "Variable speed drive (VSD) pumps in HVAC systems, such as those used in water- cooled chillers, impact energy by reducing electricity consumption through load modulation, water by optimizing the chiller's cooling water circulation (reducing water use in the cooling tower), and materials because their installation may involve additional components with embodied energy, such as the VSD unit itself" (EDGE User Guide, Section 4.2: Energy Efficiency Measures). Option C, variable speed drive pumps, thus impacts all three areas: energy (reduced electricity use), water (less cooling tower water loss), and materials (embodied energy in the VSD equipment). Option A (insulation of the roof) affects energy (reduced cooling load) and materials (embodied energy in insulation), but not water: "Roof insulation reduces energy demand but does not directly impact water consumption" (EDGE User Guide, Section 4.1: Insulation Measures). Option B (water-efficient urinals) impacts water (reduced consumption) and potentially materials (embodied energy in fixtures), but not energy: "Water-efficient urinals save water but have no direct energy impact in EDGE calculations" (EDGE User Guide, Section 5.2: Water Efficiency Measures). Option D (water- efficient dishwashers) also affects water and materials, but not energy in this context: "Water-efficient dishwashers reduce water use, but their energy impact is minimal unless they include hot water savings, which is not specified for hospital dishwashers in EDGE" (EDGE Methodology Report Version 2.0, Section
4.2: Water Savings Calculations). The EDGE Methodology Report further confirms: "VSD pumps in water- cooled chillers are unique in affecting all three EDGE metrics-energy through efficiency, water through reduced cooling tower evaporation, and materials through the embodied energy of the equipment" (EDGE Methodology Report Version 2.0, Section 5.1: Energy Efficiency Metrics). Thus, variable speed drive pumps (Option C) is the measure impacting energy, water, and materials.
Reference:EDGE User Guide Version 2.1, Section 4.2: Energy Efficiency Measures, Section 4.1: Insulation Measures, Section 5.2: Water Efficiency Measures; EDGE Methodology Report Version 2.0, Section 5.1:
Energy Efficiency Metrics, Section 4.2: Water Savings Calculations.
問題 #71
Fast2test提供給你最權威全面的EDGE-Expert考試考古題,命中率極高,考試中會出現的問題可能都包含在這些考古題裏了,我們也會隨著大綱的變化隨時更新考古題。它可以避免你為考試浪費過多的時間和精力,助你輕鬆高效的通過考試。即便您沒有通過考試,我們也將承諾全額退款!所以你將沒有任何損失。機會是留給有準備的人的,希望你不要錯失良機。
EDGE-Expert考題寶典: https://tw.fast2test.com/EDGE-Expert-premium-file.html
EDGE EDGE-Expert最新題庫資源 那麼,難道沒有一個簡單的方法可以讓大家更容易地通過IT認證考試嗎,在這裏我想說的就是怎樣才能更有效率地準備EDGE-Expert考試,並且一次就通過考試拿到考試的認證資格,EDGE EDGE-Expert最新題庫資源 故意錯了幾道,91%通過,保證客戶在購買EDGE EDGE-Expert考題寶典考題學習資料後有足夠的時間學習並通過EDGE EDGE-Expert考題寶典認證考試,Fast2test的培訓資料包含EDGE EDGE-Expert考試的練習題和答案,能100%確保你通過EDGE EDGE-Expert考試,EDGE EDGE-Expert最新題庫資源 這意味著,考生應努力通過考試才能獲得認證。
曆史進程,一步步地不斷在變,太上令不僅在太上宗是地位的象征,其本身也是壹件攻防壹體的上品玄器,那麼,難道沒有一個簡單的方法可以讓大家更容易地通過IT認證考試嗎,在這裏我想說的就是怎樣才能更有效率地準備EDGE-Expert考試,並且一次就通過考試拿到考試的認證資格。
在資格考試中準確EDGE-Expert最新題庫資源和領先供應者並完成EDGE Excellence in Design for Greater Efficiencies (EDGE Expert) Exam故意錯了幾道,91%通過,保證客戶在購買EDGE考題學習資料後有足夠的時間學習並通過EDGE認證考試,Fast2test的培訓資料包含EDGE EDGE-Expert考試的練習題和答案,能100%確保你通過EDGE EDGE-Expert考試。
- 信任授權EDGE-Expert最新題庫資源是最快的通過途徑Excellence in Design for Greater Efficiencies (EDGE Expert) Exam 🩸 ▷ [url]www.testpdf.net ◁上搜索【 EDGE-Expert 】輕鬆獲取免費下載EDGE-Expert考題[/url]
- 最新的EDGE-Expert最新題庫資源,最有效的考試資料幫助妳快速通過EDGE-Expert考試 🆘 ⏩ [url]www.newdumpspdf.com ⏪上搜索⏩ EDGE-Expert ⏪輕鬆獲取免費下載EDGE-Expert指南[/url]
- 信任授權EDGE-Expert最新題庫資源是最快的通過途徑Excellence in Design for Greater Efficiencies (EDGE Expert) Exam 🏘 [ tw.fast2test.com ]上搜索▷ EDGE-Expert ◁輕鬆獲取免費下載EDGE-Expert試題
- 最實用的EDGE-Expert認證考試的題目與答案 🐵 免費下載▷ EDGE-Expert ◁只需在▷ [url]www.newdumpspdf.com ◁上搜索EDGE-Expert新版題庫上線[/url]
- 有效的考試資料EDGE-Expert最新題庫資源保證助您輕松通過EDGE EDGE-Expert考試無憂 🌞 立即在⏩ [url]www.kaoguti.com ⏪上搜尋✔ EDGE-Expert ️✔️並免費下載EDGE-Expert熱門證照[/url]
- 100%合格率EDGE-Expert最新題庫資源&資格考試領導者和精心準備的EDGE Excellence in Design for Greater Efficiencies (EDGE Expert) Exam ⭕ 立即到▷ [url]www.newdumpspdf.com ◁上搜索⮆ EDGE-Expert ⮄以獲取免費下載EDGE-Expert考證[/url]
- EDGE-Expert新版題庫上線 📑 EDGE-Expert考試證照 🧓 新版EDGE-Expert題庫上線 🍯 立即在【 [url]www.pdfexamdumps.com 】上搜尋➡ EDGE-Expert ️⬅️並免費下載EDGE-Expert考試重點[/url]
- EDGE-Expert最新題庫資源,通過Excellence in Design for Greater Efficiencies (EDGE Expert) Exam EDGE-Expert認證考試的不二選擇 ➖ 請在{ [url]www.newdumpspdf.com }網站上免費下載【 EDGE-Expert 】題庫EDGE-Expert題庫下載[/url]
- 最新的EDGE-Expert最新題庫資源,最有效的考試資料幫助妳快速通過EDGE-Expert考試 🍮 在[ [url]www.vcesoft.com ]網站上查找⇛ EDGE-Expert ⇚的最新題庫EDGE-Expert考證[/url]
- [url=https://www.brioengineering.com/?s=EDGE-Expert%e5%a5%97%e8%a3%9d%20%f0%9f%93%82%20EDGE-Expert%e8%aa%8d%e8%ad%89%20%f0%9f%9b%ab%20EDGE-Expert%e8%80%83%e9%a1%8c%e8%b3%87%e8%a8%8a%20%f0%9f%90%89%20[%20www.newdumpspdf.com%20]%e4%b8%8a%e7%9a%84%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89%ef%bc%88%20EDGE-Expert%20%ef%bc%89%e9%a0%81%e9%9d%a2%e7%ab%8b%e5%8d%b3%e6%89%93%e9%96%8bEDGE-Expert%e8%80%83%e8%ad%89]EDGE-Expert套裝 📂 EDGE-Expert認證 🛫 EDGE-Expert考題資訊 🐉 [ www.newdumpspdf.com ]上的免費下載( EDGE-Expert )頁面立即打開EDGE-Expert考證[/url]
- EDGE-Expert新版題庫上線 👤 EDGE-Expert熱門證照 🪑 EDGE-Expert考題資訊 🛤 打開➥ tw.fast2test.com 🡄搜尋➠ EDGE-Expert 🠰以免費下載考試資料EDGE-Expert認證
- pixabay.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, knowyourmeme.com, www.stes.tyc.edu.tw, www.4shared.com, leantheprocess.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
