PL-900 Valid Test Fee & Reliable PL-900 Exam Pattern
96
Posted at 2/14/2026 00:11:35      View:145 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TestPDF PL-900 dumps from Cloud Storage: https://drive.google.com/open?id=161OQV-PsQ0_LP0Hc2kQmdTrxqL228XMb
Our Microsoft training materials are famous at home and abroad, the main reason is because we have other companies that do not have core competitiveness, there are many complicated similar products on the market, if you want to stand out is the selling point of needs its own. Our PL-900 test question with other product of different thing is we have the most core expert team to update our PL-900 study materials, learning platform to changes with the change of the exam outline. If not timely updating PL-900 Training Materials will let users reduce the learning efficiency of even lags behind that of other competitors, the consequence is that users and we don't want to see the phenomenon of the worst, so in order to prevent the occurrence of this kind of risk, the PL-900 practice test dump give supervision and update the progress every day, it emphasized the key selling point of the product.
Microsoft PL-900 Exam is an entry-level certification exam that does not require any prerequisites. PL-900 exam is designed to test the foundational knowledge of individuals related to the Power Platform. PL-900 exam consists of multiple-choice questions that evaluate the knowledge of individuals related to Power Apps, Power BI, Power Automate, and the Common Data Service. PL-900 exam is also suitable for individuals who are interested in gaining an understanding of the Power Platform and its capabilities.
Identifying the Power Platform Key Components (15-20%)
  • Describing connectorsThis subtheme encompasses the individuals’ ability to explain triggers, including where triggers are utilized as well as trigger types; explain actions; explain licensing options for connectors such as standard/premium tier; define use cases for custom connectors.
  • Describing the General Data ServiceThis domain includes describing the Power Apps user experience; describing fields, entities, and relationships; explaining use cases for solutions; understanding limitations as well as use cases of business rules; describing the Common Data Model (CDM); explaining how to utilize general standard entities to describe places, people, and things.
  • Describing AI BuilderHere the test takers need to prove their expertise in defining the AI Builder business value; describing models, such as detection model, business card reader, prediction model, and form processing model; describing how Power Automate and Power Apps can utilize AI Builder data.
Reliable PL-900 Exam Pattern - Study PL-900 PlanThe learning material of TestPDF is in three different formats so the students can take full benefit from it and use it anywhere anytime while preparing for Microsoft Power Platform Fundamentals exam questions. The Microsoft Power Platform Fundamentals (PL-900) guarantees its customers that they will pass the Microsoft Power Platform Fundamentals (PL-900) certification exams in a single try if they prepare with our product and if they fail to do it so then they can reclaim their money back according to terms and conditions.
Microsoft PL-900 (Microsoft Power Platform Fundamentals) Exam is designed to test a candidate's knowledge of the Microsoft Power Platform. The Power Platform is a suite of products that allows businesses to automate processes, analyze data, and create custom solutions without extensive coding. PL-900 Exam is intended for individuals who have a basic understanding of the Power Platform and want to demonstrate their knowledge to potential employers or clients.
Microsoft Power Platform Fundamentals Sample Questions (Q355-Q360):NEW QUESTION # 355
You are creating a self-service solution to handle incoming sales support calls.
The solution must detect the caller's location and translate any information the caller provides from the caller's native language to English.
Which two components should you use? Each correct answer presents part of the solution.
  • A. Microsoft Azure Cognitive Services
  • B. AI Builder Language Detection Model
  • C. Power Virtual Agents
  • D. Microsoft Dynamics 365 Remote Assist for mobile
NEW QUESTION # 356
You need to explain the major components of the Common Data Model (CDM) and their functions.
Match each term to its definition.
Instructions: To answer, drag the appropriate term from the column on the left to its definition on the right.
Each term may be used once, more than once, or not at all. Each correct match is worth one point.
Box 1: Microsoft Power Platform
Power Platform combines the robust power of PowerApps, PowerBI, and Microsoft Flow into one powerful business application platform - providing quick and easy app building and data insights. Each component of the Microsoft Power Platform is built on the Common Data Service for Apps. Each component is dynamic by itself, but brilliant and masterful when combined.
The Microsoft Power platform brings all your data together into a common data model.
Box 2: Entities
An entity is a set of records used to store data, similar to how a table stores data within a database.
https://community.dynamics.com/3 ... -the-microsoft-powe
https://docs.microsoft.com/en-us ... data-platform-intro
NEW QUESTION # 357
You are designing Power BI dashboards and reports to analyze the financial data for a company.
You must analyze the past three years of data from the company's accounting system.
You need to ensure that dashboards only display required data.
What are two possible ways to achieve the goal? Each correct answer presents a complete solution.
  • A. Share dashboards.
  • B. Create calculated columns.
  • C. Import data into Microsoft Dataverse.
  • D. Create aggregations.
NEW QUESTION # 358
You are building Power Apps apps that use both Dynamics 365 Sales and Microsoft 365.
Box 1: No
When you offer your application for use by other companies through a purchase or subscription, you make your application available to customers within their own Azure tenants. This is known as creating a multi-tenant application.
Box 2: No
https://docs.microsoft.com/en-us ... pps/isv-sso-content
NEW QUESTION # 359
A company needs to create several workflows and applications to help streamline their sales operations.
You need to determine which applications are appropriate for given scenarios.
Which applications should you use? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us/power-automate/getting-started
https://docs.microsoft.com/en-us ... logic-apps-overview
https://powerapps.microsoft.com/pl-pl/blog/business-model-may/
NEW QUESTION # 360
Reliable PL-900 Exam Pattern: https://www.testpdf.com/PL-900-exam-braindumps.html
What's more, part of that TestPDF PL-900 dumps now are free: https://drive.google.com/open?id=161OQV-PsQ0_LP0Hc2kQmdTrxqL228XMb
Posted at 4/19/2026 13:19:36        Only Author  2#
The content is so good, I’m liking it immediately. Thanks to the C_BCFIN_2502 reliable test pattern, I earned a promotion and a pay raise. Now, I’m sharing it for free. Wishing you all success in your career paths!
