100% Pass Quiz ATLASSIAN Marvelous Latest ACP-120 Study Guide
Posted at 2/14/2026 01:06:02
DOWNLOAD the newest Prep4SureReview ACP-120 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Zi2aTgQ0Ru5SKaMAawbBko5BpDKubbZd
As the saying goes, opportunities for those who are prepared. If you have made up your mind to get respect and power, the first step you need to do is to get the ACP-120 certification, because the certification is a reflection of your ability. If you have the ACP-120 Certification, it will be easier for you to get respect and power. Our company happened to be designing the ACP-120 exam question.
The Jira Cloud Administrator certification exam is a valuable credential for individuals who want to demonstrate their expertise in Jira Cloud administration. Achieving the certification can help individuals advance their careers and stand out in a competitive job market. Additionally, organizations that employ certified Jira Cloud administrators can be confident that their teams are being managed by skilled professionals.
ATLASSIAN ACP-120 (Jira Cloud Administrator) Exam is designed to assess the skills and knowledge of professionals who are responsible for administering Jira Cloud. Jira Cloud is a powerful project management tool that is widely used by organizations to track issues, manage projects, and collaborate with team members. ACP-120 Exam is designed to test the candidate's ability to configure, manage, and troubleshoot Jira Cloud instances.
ATLASSIAN ACP-120 (Jira Cloud Administrator) Certification Exam is a rigorous exam that requires a solid understanding of Jira Cloud administration. ACP-120 exam consists of 68 multiple-choice questions that must be completed within 180 minutes. ACP-120 exam is designed to test an individual’s knowledge and skills across a range of Jira Cloud administration topics.
Passing ATLASSIAN ACP-120 Score Feedback & New ACP-120 Test TestThe ACP-120 exam bootcamp is quite necessary for the passing of the exam. Our ACP-120 exam bootcamp have the knowledge point as well as the answers. It will improve your sufficiency, and save your time. Besides, we have the top-ranking information safety protection system, and your information, such as name, email address will be very safe if you buy the ACP-120 bootcamp from us. Once you finished the trade our system will conceal your information, and if order is completely finished, we will clean away your information, so you can buy our ACP-120 with ease.
ATLASSIAN Jira Cloud Administrator Sample Questions (Q65-Q70):NEW QUESTION # 65
Some notification events are triggered only from a workflow post function. Identify one such event.
- A. Issue Closed
- B. Issue Moved
- C. Issue Assigned
- D. Issue Updated
- E. Issue Deleted
Certain notification events in Jira Software Cloud are triggered only when explicitly fired by aworkflow post functionin a workflow transition. The question asks for one such event, andIssue Closedis an example of an event that is typically triggered via a post function in the workflow.
* Explanation of the Correct Answer (Option B):
* TheIssue Closedevent is associated with the transition of an issue to a "Closed" status in a workflow. In Jira, this event is not automatically triggered by standard issue updates (like editing fields) but is instead fired by a post function in the workflow transition that moves the issue to the
"Closed" status.
* Exact Extract from Documentation:
Workflow post functions and events
Post functions in a workflow transition can fire specific events to trigger notifications. For example:
* TheIssue Closedevent is typically fired by a post function in the transition to a "Closed" status.
* To configure this, edit the workflow transition and add a post function like"Fire a Generic Event"or select theIssue Closedevent.These events are then mapped to recipients in the project's notification scheme.Note: Events like Issue Closed, Issue Resolved, or custom events require explicit configuration in the workflow to trigger notifications.(Source:
Atlassian Support Documentation, "Configure advanced work item workflows")
* Why This Fits: The Issue Closed event is specifically tied to a workflow transition (e.g., moving an issue to the "Closed" status), and it requires a post function to fire the event. This makes it a clear example of an event triggered only by a workflow post function.
* Why Other Options Are Incorrect:
* Issue Deleted (Option A):
* TheIssue Deletedevent is triggered when an issue is deleted from Jira (e.g., by an admin with appropriate permissions). This event is not tied to aworkflow transition or post function but is instead a system-level action.
* Extract from Documentation:
TheIssue Deletedevent is triggered when an issue is permanently removed from Jira. This is a system event and does not require a workflow post function.
(Source: Atlassian Support Documentation, "Configure notification schemes")
* Issue Updated (Option C):
* TheIssue Updatedevent is triggered by a wide range of actions, such as editing an issue's fields, adding comments, or changing the status. It is not exclusive to workflow post functions and can occur without any workflow transition.
TheIssue Updatedevent is a generic event triggered by most changes to an issue, including field updates, comments, or status changes. It does not require a post function.
* Issue Assigned (Option D):
* TheIssue Assignedevent is triggered when an issue's assignee is changed, either manually or through a workflow transition. This event is not exclusive to a post function, as it can occur outside of workflows (e.g., by editing the Assignee field).
TheIssue Assignedevent is triggered when the assignee of an issue changes, regardless of whether it occurs in a workflow or via direct editing.
* Issue Moved (Option E):
* TheIssue Movedevent is triggered when an issue is moved between projects or issue types.
This is a system-level action and does not require a workflow post function.
TheIssue Movedevent is triggered when an issue is relocated to a different project or issue type. This is not tied to workflow post functions.
* Additional Notes:
* Events likeIssue Closed,Issue Resolved, or custom events are typically fired by post functions because they are associated with specific workflow transitions. This distinguishes them from generic events like Issue Updated or Issue Assigned, which can be triggered by various actions.
* To configure the Issue Closed event, a Jira admin would edit the workflow, add a post function to the "Close Issue" transition, and ensure the notification scheme maps the event to the desired recipients.
Atlassian Support Documentation:Configure advanced work item workflows
Atlassian Support Documentation:Configure notification schemes
Atlassian Support Documentation:Manage events in Jira Cloud
NEW QUESTION # 66
Your company will migrate to Jira. You plan to import with a CSV file.
Which fields are required as CSV columns for your import?
- A. Project, Issue Type
- B. Summary
- C. Project, Summary
- D. Project
- E. Summary, Issue Type
Explanation: Each CSV file must possess a heading row with a Summary column Reference:
https://confluence.atlassian.com ... -csv-938847533.html
NEW QUESTION # 67
You are setting up Jira Software Cloud for an organization of 250 employees. Product access is already configured to grant new users access to Jira Software by default You now need to configure site access so that it meets these 3 conditions
1. Minimum administration overhead is required
2. Access is granted to the entire organization at the same time
3. Access is restricted only to your organization
Which solution meets these requirements? (Choose one)
- A. Add all your company's domains as approved domains
- B. Create an invite link and share it with all current and future employees
- C. Approve any domain in the site access settings
- D. Enable existing users to send invitations to all current and future employees
- E. Set the global mode to public and enable CAPTCHA on sign up
NEW QUESTION # 68
Gary complains that he is not getting any notifications when issues are updated.
According to the notification helper, he should receive notifications for all issues he is watching. His coworkers confirm they receive those notifications and they regularly update issues that he is watching.
Which update to Gary's personal settings must have occurred (Choose one)
- A. The setting You're watching the issue was disabled
- B. The setting Email notifications format was changed
- C. The setting Watch your issues was disabled
- D. The setting You make changes to the issue was disabled
NEW QUESTION # 69
A project lead wants to conduct historical trend analysis, but she is worried that older issues are being updated in a way that inhibits their comparison. She wants to take a snapshot of the data in her project at regular intervals so she can compare different periods.
Which tool will help meet this need?
- A. Backup Jira data
- B. Issue Filter Export to CSV
- C. Project Export
- D. JQL Results Snapshot
NEW QUESTION # 70
In real life, every great career must have the confidence to take the first step. When you suspect your level of knowledge, and cramming before the exam, do you think of how to pass the ATLASSIAN ACP-120 exam with confidence? Do not worry, Prep4SureReview is the only provider of training materials that can help you to pass the exam. Our training materials, including questions and answers, the pass rate can reach 100%. With Prep4SureReview ATLASSIAN ACP-120 Exam Training materials, you can begin your first step forward. When you get the certification of ATLASSIAN ACP-120 exam, the glorious period of your career will start.
Passing ACP-120 Score Feedback: https://www.prep4surereview.com/ACP-120-latest-braindumps.html
- ACP-120 Valid Dumps Files 🕰 New ACP-120 Braindumps Sheet 🧕 ACP-120 Valid Exam Review 👆 Download ▷ ACP-120 ◁ for free by simply searching on ☀ [url]www.prepawaypdf.com ️☀️ 🔰Latest Test ACP-120 Discount[/url]
- Training ACP-120 Kit 🥉 New ACP-120 Braindumps Sheet 🐺 ACP-120 Valid Braindumps Free 🍛 Copy URL ⮆ [url]www.pdfvce.com ⮄ open and search for ➤ ACP-120 ⮘ to download for free 🥟Free ACP-120 Practice Exams[/url]
- Top Latest ACP-120 Study Guide | Efficient ATLASSIAN Passing ACP-120 Score Feedback: Jira Cloud Administrator 🦍 Easily obtain free download of ( ACP-120 ) by searching on { [url]www.pass4test.com } 🍛Latest Test ACP-120 Discount[/url]
- Pass ACP-120 Exam 🔴 Valid ACP-120 Exam Sims 🛒 Valid ACP-120 Exam Sims 🎦 Open website ⏩ [url]www.pdfvce.com ⏪ and search for ▶ ACP-120 ◀ for free download 🥶Unlimited ACP-120 Exam Practice[/url]
- Quiz ATLASSIAN - ACP-120 –Valid Latest Study Guide 🗨 Download ➤ ACP-120 ⮘ for free by simply entering ( [url]www.examcollectionpass.com ) website 🏁Training ACP-120 Kit[/url]
- 100% Pass Quiz 2026 ATLASSIAN ACP-120: Newest Latest Jira Cloud Administrator Study Guide 🦨 Easily obtain free download of ▶ ACP-120 ◀ by searching on 【 [url]www.pdfvce.com 】 ☘ACP-120 Valid Dumps Files[/url]
- Get Special 25% EXTRA Discount on ACP-120 Dumps By [url]www.testkingpass.com 🤵 Open ☀ www.testkingpass.com ️☀️ and search for ➡ ACP-120 ️⬅️ to download exam materials for free 🤏ACP-120 Exam Brain Dumps[/url]
- Reliable ACP-120 Test Blueprint 🛤 Pass ACP-120 Exam 🥻 ACP-120 Lead2pass 🐳 Enter 「 [url]www.pdfvce.com 」 and search for 「 ACP-120 」 to download for free 🚰ACP-120 Valid Exam Review[/url]
- ACP-120 Troytec: Jira Cloud Administrator - ATLASSIAN ACP-120 dumps 😷 Download ▛ ACP-120 ▟ for free by simply entering 「 [url]www.troytecdumps.com 」 website 🟣ACP-120 Lead2pass[/url]
- Top Latest ACP-120 Study Guide | Efficient ATLASSIAN Passing ACP-120 Score Feedback: Jira Cloud Administrator 🔝 ➤ [url]www.pdfvce.com ⮘ is best website to obtain ⇛ ACP-120 ⇚ for free download 🥰ACP-120 Lead2pass[/url]
- 100% Pass Quiz 2026 Accurate ATLASSIAN Latest ACP-120 Study Guide 🚚 Go to website ➽ [url]www.torrentvce.com 🢪 open and search for ➽ ACP-120 🢪 to download for free 🔶Valid ACP-120 Exam Sims[/url]
- www.stes.tyc.edu.tw, kayaksekolah.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, schoolido.lu, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, divisionmidway.org, dl.instructure.com, Disposable vapes
What's more, part of that Prep4SureReview ACP-120 dumps now are free: https://drive.google.com/open?id=1Zi2aTgQ0Ru5SKaMAawbBko5BpDKubbZd
