[General] Useful NSE6_SDW_AD-7.6 Exam Revision Plan Help You to Get Acquainted with Real N
75
【General】 Useful NSE6_SDW_AD-7.6 Exam Revision Plan Help You to Get Acquainted with Real N
Posted at 2/14/2026 01:32:23      View:126 | Replies:0        Print      Only Author   [Copy Link] 1#
Our company has occupied large market shares because of our consistent renovating. We have built a powerful research center and owned a strong team. Up to now, we have got a lot of patents about our Fortinet study materials. On the one hand, our company has benefited a lot from renovation. Customers are more likely to choose our NSE6_SDW_AD-7.6 Materials. On the other hand, the money we have invested is meaningful, which helps to renovate new learning style of the exam. So it will be very convenient for you to buy our product and it will do a lot of good to you.
Our NSE6_SDW_AD-7.6 test materials boost three versions and they include the PDF version, PC version and the APP online version. The clients can use any electronic equipment on it. If only the users’ equipment can link with the internet they can use their equipment to learn our NSE6_SDW_AD-7.6 qualification test guide. They can use their cellphones, laptops and tablet computers to learn our NSE6_SDW_AD-7.6 Study Materials. The language is also refined to simplify the large amount of information. So the learners have no obstacles to learn our NSE6_SDW_AD-7.6 certification guide.
What is the importance of preparation-evaluation before the final certification Fortinet NSE6_SDW_AD-7.6 exam?Do some fresh things each day that moves you out of your comfort zone. If you stay cozy every day, you will gradually become lazy. Now, you have the opportunity to change your current conditions. Our NSE6_SDW_AD-7.6 real exam dumps are specially prepared for you. Try our NSE6_SDW_AD-7.6 study tool and absorb new knowledge. After a period of learning, you will find that you are making progress. The knowledge you have studied on our NSE6_SDW_AD-7.6 Exam Question will enrich your life and make you wise. Our NSE6_SDW_AD-7.6 real exam dumps are manufactured carefully, which could endure the test of practice. Stable and healthy development is our long lasting pursuit. In order to avoid fake products, we strongly advise you to purchase our NSE6_SDW_AD-7.6 exam question on our official website.
Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator Sample Questions (Q16-Q21):NEW QUESTION # 16
The SD-WAN overlay template helps to prepare SD-WAN deployments. To complete the tasks performed by the SD-WAN overlay template, the administrator must perform some post-run tasks. What are two mandatory post-run tasks that must be performed? (Choose two.)
  • A. Assign an sdwan_id metadata variable to each device (branch and hub)
  • B. Assign a hub id metadata variable to each hub device.
  • C. Create policy packages and assign them to the branch devices.
  • D. Configure SD-WAN rules
  • E. Configure routing through the overlay tunnels created by the SD-WAN overlay template.
After using the SD-WAN overlay template, two mandatory post-run tasks remain:
"First, administrators must create and assign policy packages to branch devices, as security and access policies are not included in overlay templates. Second, SD-WAN rules must be configured so that traffic can be matched and steered appropriately through the established overlays. Neglecting either task results in ungoverned traffic or inefficient routing, undermining the benefits of SD-WAN." Templates automate topology, but policy and rule definition are critical for operational effectiveness.
[FCSS_SDW_AR-7.4 1-0.docx Q25]
Fortinet SD-WAN Reference Architecture 7.4, "Post-Deployment Tasks for SD-WAN Overlay Templates"
NEW QUESTION # 17
Which statement best describe the role of the ADVPN device in handling traffic?
  • A. This is a spoke that has received a direct shortcut query from a remote spoke.
  • B. This is a hub, and two spokes, 192.2.0.1 and 10.0.3.101, establish a shortcut.
  • C. This is a spoke that has received a shortcut query from a remote hub.
  • D. This is a hub that has received a shortcut query from a spoke and has forwarded it to another spoke.
The log shows messages on HUB1-VPN1 where the device processes a SHORTCUT_QUERY and performs NAT hole punching (peer at 192.2.0.1:4500). This indicates that the device is acting as a hub, helping two spokes (192.2.0.1 and 10.0.3.101) establish a direct ADVPN shortcut tunnel between each other, instead of routing their traffic through the hub.
NEW QUESTION # 18
What are three key routing principles of SD-WAN? (Choose three.)
  • A. SD-WAN rules are skipped if the best route to the destination is not an SD-WAN member.
  • B. SD-WAN members are skipped if they do not have a valid route to the destination.
  • C. Directly connected routes have precedence over SD-WAN rules.
  • D. Policy routes have precedence over SD-WAN rules.
  • E. SD-WAN rules are skipped if the best route to the destination is a static route
Answer: A,B,D
Fortinet outlines key SD-WAN routing principles:
"Policy routes are always evaluated before SD-WAN rules, meaning if a policy route matches, SD-WAN steering is bypassed. If the best route for a destination is not via an SD-WAN member, SD-WAN rules do not apply, and members are ignored if they lack a valid route. This hierarchy ensures traffic always follows the most deterministic and valid path according to configuration." Understanding these principles is critical for correct SD-WAN and routing integration.
NEW QUESTION # 19
Within the context of SD-WAN, what does SIA correspond to?
  • A. Software Internet Access
  • B. Secure Internet Authorization
  • C. Local Breakout
  • D. Remote Breakout
NEW QUESTION # 20
SD-WAN interacts with many other FortiGate features. Some of them are required to allow SD-WAN to steer the traffic.
Which three configuration elements that you must configure before FortiGate can steer traffic according to SD-WAN rules? (Choose three.)
  • A. Interfaces
  • B. Routing
  • C. Traffic shaping
  • D. Security profiles
  • E. Firewall policies
Answer: A,B,E
Before FortiGate can steer traffic according to SD-WAN rules, certain configuration elements must be present. The guide states:
"SD-WAN is not a standalone feature and interacts with several fundamental FortiGate configurations.
Specifically, you must: (1) Define the interfaces (physical, VLAN, or IPsec) that will act as SD-WAN members, (2) Create firewall policies to allow traffic to be steered by SD-WAN, and (3) Set up routing so that traffic has valid routes via SD-WAN members. Without these, SD-WAN rules will not be able to match or steer any traffic." Security profiles and traffic shaping are not mandatory for basic SD-WAN steering but can be layered on for enhanced security and QoS once foundational elements are present.
[FCSS_SDW_AR-7.4 1-0.docx Q16]
FortiOS 7.4 SD-WAN Concept Guide, "Prerequisite Configuration Elements for SD-WAN Steering
NEW QUESTION # 21
In order to cater to different needs for customers, three versions for NSE6_SDW_AD-7.6 training materials are available, and you can choose the most suitable one according to your own needs. NSE6_SDW_AD-7.6 PDF version is printable, and if you prefer to practice on paper, you can choose this version and print it into hard one. NSE6_SDW_AD-7.6 Soft test engine can stimulate the real exam environment, so that you can know the process of the exam, you can choose this version. Besides, NSE6_SDW_AD-7.6 Soft test engine has two modes for practice, and it supports MS operating system. NSE6_SDW_AD-7.6 Online test engine is convenient and easy to learn, and it has testing history and performance review, if you like this mode, you can choose this version.
NSE6_SDW_AD-7.6 Latest Braindumps Questions: https://www.examslabs.com/Fortinet/Fortinet-NSE-6/best-NSE6_SDW_AD-7.6-exam-dumps.html
We assure you that if you have any question about the NSE6_SDW_AD-7.6 Latest Braindumps Questions - Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator practice test pdf, you will receive the fastest and precise reply from our staff.We will stand by your side with 24 hours online, Belive it or not, our efficient and authoritative NSE6_SDW_AD-7.6 exam materials are always here waiting for you to provide you with the best help of NSE6_SDW_AD-7.6 exam preparation, Unfortunately, if you got failed in NSE6_SDW_AD-7.6 exam claim your refund.
Git and GitHub LiveLesson Workshop View Larger NSE6_SDW_AD-7.6 Image, Assuring High Availability, We assure you that if you have any question about the Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator practice test pdf, you will receive the Test NSE6_SDW_AD-7.6 Dumps fastest and precise reply from our staff.We will stand by your side with 24 hours online.
Quiz High Hit-Rate Fortinet - NSE6_SDW_AD-7.6 - Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator Exam Revision PlanBelive it or not, our efficient and authoritative NSE6_SDW_AD-7.6 Exam Materials are always here waiting for you to provide you with the best help of NSE6_SDW_AD-7.6 exam preparation.
Unfortunately, if you got failed in NSE6_SDW_AD-7.6 exam claim your refund, The candidates taking the Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator exam can try a free demo and test features of Fortinet NSE6_SDW_AD-7.6 exam questions before purchasing it.
Our NSE6_SDW_AD-7.6 exam guide can stand the test of market as well as customers of various needs with passing rate up to 98 to 100 percent, which is a strong proof that attest to their efficacy.
