[General] Latest NCP-CN Training - Latest NCP-CN Test Answers
83
General Latest NCP-CN Training - Latest NCP-CN Test Answers
Posted at 2/14/2026 04:14:07      View113 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest Prep4sureGuide NCP-CN PDF Dumps and NCP-CN Exam Engine Free Share: https://drive.google.com/open?id=16hWe_ulKChbxN74rc7FtxOYSlHquBg_F
To want to pass Nutanix NCP-CN certification test can't be done just depend on the exam related books. Instead of blindly studying relevant knowledge the exam demands, you can do some valuable questions. The efficient exam dumps is essential tool to prepare for NCP-CN test. Come on and purchase Prep4sureGuide Nutanix NCP-CN Practice Test dumps. This braindump's hit accuracy is high and it works best the other way around. Prep4sureGuide Nutanix NCP-CN questions and answers are a rare material which can help you pass you exam first time.
Nutanix NCP-CN Exam Syllabus Topics:
  • Prepare the Environment for an NKP Deployment: This section of the exam measures the skills of infrastructure engineers and cloud administrators and covers the initial setup tasks needed for NKP deployment. Candidates must demonstrate the ability to seed a private container registry, create a bootstrap Kubernetes cluster, and determine license tiers suitable for clusters. They also need to prepare a bastion host for secure access, build machine images or prepare nodes for deployment, and gather all necessary information to build a cluster on the target cloud or on-premises provider.
  • Perform Day 2 Operations: This part assesses the expertise of site reliability engineers and cluster operators in ongoing cluster management tasks after deployment. It includes configuring authentication and authorization mechanisms, setting up logging systems, and implementing cluster backup and recovery procedures. Candidates also need to demonstrate skills in monitoring cluster performance and health, configuring autoscaling to handle workload changes, and performing lifecycle management functions such as upgrades and maintenance.
  • Manage Building an NKP Cluster: This section evaluates the skills of Kubernetes administrators and platform engineers in customizing and deploying NKP clusters. Candidates must show proficiency in tailoring cluster configurations to meet specific requirements and deploying Kommander, the management platform, while applying the appropriate licenses to enable cluster features and management capabilities.
  • Conduct NKP Fleet Management: This section tests the abilities of platform administrators and cloud operations engineers in managing multiple clusters as a fleet. It focuses on configuring workspaces to organize clusters, deploying workload clusters within these workspaces, and attaching or detaching clusters as needed. Additionally, candidates must be able to configure projects for workload segmentation and manage platform applications that support the overall NKP environment.
Pass Guaranteed Nutanix - Reliable NCP-CN - Latest Nutanix Certified Professional - Cloud Native v6.10 TrainingYou can easily use the PDF format on your tablets, laptops, and smartphones. It means you can save your free time and read Actual NCP-CN PDF Questions from any place. So, get PDF questions, study it properly and have faith in yourself. You can reach new heights and prove yourself to those who used to think that you are not worth competing with them.
Nutanix Certified Professional - Cloud Native v6.10 Sample Questions (Q13-Q18):NEW QUESTION # 13
Which procedure should a Platform Engineer follow for setting up user authentication into an NKP cluster?
  • A. Enable Gatekeeper and create a connector to the user base's identity provider.
  • B. Create a Dex connector to the user base's identity provider.
  • C. Disable native NKP authentication, enable Traefik, and create a connector to the user base's identity provider.
  • D. Create a MetalLB connector to the user base's identity provider.
The NKPA course covers user authentication for NKP clusters as part of Day 2 operations, emphasizing integration with external identity providers (IdPs) to manage user access securely. NKP uses Dex, an OpenID Connect (OIDC) identity provider, to facilitate authentication by acting as a connector between the Kubernetes cluster and external IdPs, such as LDAP, SAML, or OAuth-based systems.
The course explains that to set up user authentication, a Platform Engineer must configure a Dex connector to the user base's identity provider. Dex integrates with the Kubernetes API server to enable OIDC-based authentication, allowing users to log in using their IdP credentials. The Nutanix Cloud Native (NCP-CN) 6.10 Study Guide states: "NKP supports user authentication through Dex, which provides OIDC integration with external identity providers, enabling single sign-on (SSO) for cluster access." The process involves deploying Dex as a platform application, configuring the IdP connector (e.g., specifying client IDs, secrets, and endpoints), and updating the Kubernetes API server to use OIDC authentication.
Incorrect Options:
* A. Enable Gatekeeper and create a connector to the user base's identity provider: Gatekeeper is a Kubernetes policy engine used for enforcing admission control policies, not for authentication. The NKPA course does not associate Gatekeeper with user authentication.
* B. Disable native NKP authentication, enable Traefik, and create a connector to the user base's identity provider: Traefik is an ingress controller for managing external traffic, not authentication.
Disabling native authentication is unnecessary, as NKP supports OIDC alongside native methods. The NKPA course does not mention Traefik in the context of authentication.
* C. Create a MetalLB connector to the user base's identity provider: MetalLB is a load balancer for bare-metal Kubernetes clusters, not an authentication component. This option is irrelevant, as per the NKPA course.
Nutanix Kubernetes Platform Administration (NKPA) Course, Section on User Authentication and Authorization.
Nutanix Cloud Native (NCP-CN) 6.10 Study Guide, Chapter on NKP Day 2 Operations.
Nutanix Cloud Bible, NutanixKubernetesPlatform Section: https://www.nutanixbible.com Dex Documentation: https://dexidp.io
NEW QUESTION # 14
To keep an NKP cluster and applications healthy and drive productivity forward, a Platform Engineer needs to stay informed of all events occurring within the cluster. What component of kube-prometheus-stack will help the engineer to stay informed of these events in NKP?
  • A. node-exporter
  • B. alertmanager
  • C. service monitors
  • D. prometheus-operator
The kube-prometheus-stack is a key component of NKP's monitoring stack, providing tools for metrics collection, visualization, and alerting. The NKPA course explains that Alertmanager, a component of the kube-prometheus-stack, is responsible for handling alerts generated from Prometheus metrics. It aggregates, deduplicates, and routes notifications to the appropriate channels (e.g., email, Slack, PagerDuty), ensuring that the Platform Engineer stays informed of critical events and anomalies in the NKP cluster, such as node failures, resource exhaustion, or application errors.
The Nutanix Cloud Native (NCP-CN) 6.10 Study Guide states: "Alertmanager in the kube-prometheus-stack processes alerts from Prometheus, enabling administrators to stay informed of cluster events through configured notification channels." By configuring Alertmanager with appropriate routing rules and receivers, the engineer can receive real-time notifications about cluster events, driving proactive management and productivity.
Incorrect Options:
* A. prometheus-operator: The operator manages Prometheus and related resources but does not directly handle event notifications.
* B. service monitors: Service monitors define how Prometheus scrapes metrics, not how events are communicated.
* D. node-exporter: Node-exporter collects node-level metrics, not event notifications.
Nutanix Kubernetes Platform Administration (NKPA) Course, Section on Monitoring and Alerting.
Nutanix Cloud Native (NCP-CN) 6.10 Study Guide, Chapter on Day 2 Operations.
Nutanix Cloud Bible, NutanixKubernetesPlatform Section: https://www.nutanixbible.com Prometheus Documentation: https://prometheus.io/docs/alerting/alertmanager
NEW QUESTION # 15
A Platform Engineer has a requirement for backup and recovery and would like to leverage an Out-Of-The- Box solution distributed with NKP. What is the backup and recovery solution distributed for NKP?
  • A. Velero
  • B. Tar
  • C. Nutanix Snapshot
  • D. Kasten
The NKPA 6.10 documentation confirms that Velero is the built-in backup and recovery solution provided as part of the NKP platform. It provides cluster-level and namespace-level backup, restore, and migration capabilities.
Exact extract from the documentation:
"Velero is the integrated, out-of-the-box backup and restore solution in NKP. It supports scheduled backups, disaster recovery, and application migration workflows." Reference:
Nutanix Kubernetes Platform Administration (NKPA) 6.10 - "Velero Backup and Recovery Integration" NCP-CN 6.10 Study Guide - "Backup and Restore Solutions in NKP"
NEW QUESTION # 16
A company has standardized on NKP for their Kubernetes platform and needs to deploy their first cluster with the following requirements:
Dark site ready
Custom Service CIDR Block
Custom Pod CIDR Block
Hosted on Nutanix AHV ClusterWhich tool would the administrator use to perform the deployment?
  • A. kubectl CLI
  • B. OCP CLI
  • C. NKP CLI
  • D. NKP GUI
NEW QUESTION # 17
An administrator has experienced issues with an NKP-managed workload cluster and has been tasked with deploying NKP Insights in order to:
Resolve common anomalies
Check security issues
Verify whether workloads follow best practicesUpon trying to enable NKP Insights, the cluster that needs to be chosen is grayed out.Which missing prerequisite should be enabled?
  • A. Cert-manager
  • B. Nutanix Objects
  • C. Velero
  • D. Rook Ceph
NEW QUESTION # 18
Are you still distressed that you are young learner of NCP-CN exam prep? From now on, Prep4sureGuide will solve all your worries about the NCP-CN test. The textbooks of NCP-CN test questions contain different perspective materials. Even if you are young learners, you can master NCP-CN Test Questions easily. Having it, you will have the key to pass NCP-CN exam and will have unprecedented confidence. So what are you waiting for?
Latest NCP-CN Test Answers: https://www.prep4sureguide.com/NCP-CN-prep4sure-exam-guide.html
