[General] 156-215.82 Latest Braindumps Sheet | 156-215.82 Certification Questions
97
General 156-215.82 Latest Braindumps Sheet | 156-215.82 Certification Questions
Posted at 2/14/2026 04:15:58      View186 | Replies1        Print      Only Author   [Copy Link] 1#
Our 156-215.82 guide questions have helped many people obtain an international certificate. In this industry, our products are in a leading position in all aspects. If you really want to get an international certificate, our 156-215.82 training quiz is really your best choice. Of course, you really must get international certification if you want to stand out in the job market and get better jobs and higher salaries. With the help of our 156-215.82 Exam Materials, you can reach your dream.
But there are question is that how you can pass the 156-215.82 exam and get a certificate. The best answer is to download and learn our 156-215.82 quiz torrent. Our products will help you get what you want in a short time. You just need little time to download and install it after you purchase, then you just need spend about 20~30 hours to learn it. We are glad that you are going to spare your precious time to have a look to our 156-215.82 Exam Guide.
156-215.82 Certification Questions, 156-215.82 Knowledge PointsAdditionally, students can take multiple CheckPoint 156-215.82 exam questions, helping them to check and improve their performance. Three formats are prepared in such a way that by using them, candidates will feel confident and crack the Check Point Certified Security Administrator - R82 (156-215.82) actual exam. These three formats suit different preparation styles of 156-215.82 test takers.
CheckPoint Check Point Certified Security Administrator - R82 Sample Questions (Q64-Q69):NEW QUESTION # 64
What protocol is specifically used for clustered environments?
  • A. Control Cluster Protocol
  • B. Cluster Control Protocol
  • C. Clustered Protocol
  • D. Synchronized Cluster Protocol
The protocol that is specifically used for clustered environments is Cluster Control Protocol (CCP). CCP is a proprietary Check Point protocol that is used for communication between cluster members and for cluster administration. CCP enables cluster members to exchange state information, synchronize connections, monitor interfaces, and perform failover operations. The other options are incorrect. Clustered Protocol, Synchronized Cluster Protocol, and Control Cluster Protocol are not valid terms in Check Point terminology. [Cluster Control Protocol (CCP) - Check Point Software]
NEW QUESTION # 65
After the initial installation on Check Point appliance, you notice that the Management interface and default gateway are incorrect. Which commands could you use to set the IP to 192.168.80.200/24 and default gateway to 192.168.80.1.
  • A. set interface Mgmt ipv4-address 192.168.80.200 255.255.255.0add static-route 0.0.0.0.0.0.0.0 gw 192.168.80.1 onsave config
  • B. add interface Mgmt ipv4-address 192.168.80.200 mask-length 24add static-route default nexthop gateway address 192.168.80.1 onsave config
  • C. set interface Mgmt ipv4-address 192.168.80.200 mask-length 24set static-route default nexthop gateway address 192.168.80.1 onsave config
  • D. add interface Mgmt ipv4-address 192.168.80.200 255.255.255.0add static-route 0.0.0.0.0.0.0.0 gw 192.168.80.1 onsave config
The commands you could use to set the IP to 192.168.80.200/24 and default gateway to 192.168.80.1 after the initial installation on Check Point appliance are:
set interface Mgmt ipv4-address 192.168.80.200 mask-length 24. This command sets the IPv4 address and subnet mask of the Management interface.
set static-route default nexthop gateway address 192.168.80.1 on. This command sets the default gateway for IPv4 routing.
save config. This command saves the configuration changes.
NEW QUESTION # 66
Which of the following is considered a "Subscription Blade", requiring renewal every 1-3 years?
  • A. Firewall Blade
  • B. IPSEC VPN Blade
  • C. Identity Awareness Blade
  • D. IPS blade
The following is considered a "Subscription Blade", requiring renewal every 1-3 years:IPS blade4. The IPS blade is a software blade that provides protection against network attacks and exploits by inspecting traffic and blocking malicious packets. The IPS blade requires a subscription license that includes updates for the IPS signatures and Geo Protection database. Other subscription blades include Anti-Bot, Anti-Virus, URL Filtering, Application Control, Threat Emulation, and Threat Extraction. Check Point Licensing and Contract Operations User Guide
NEW QUESTION # 67
An administrator is creating an IPsec site-to-site VPN between his corporate office and branch office. Both offices are protected by Check Point Security Gateway managed by the same Security Management Server (SMS). While configuring the VPN community to specify the pre-shared secret, the administrator did not find a box to input the pre-shared secret. Why does it not allow him to specify the pre-shared secret?
  • A. Pre-shared secret is already configured in Global Properties
  • B. The checkbox "Use only Shared Secret for all external members" is not checked
  • C. The Gateway is an SMB device
  • D. Certificate based Authentication is the only authentication method available between two Security Gateway managed by the same SMS
Certificate based Authentication is the only authentication method available between two Security Gateway managed by the same SMS. This is because certificate based authentication provides stronger security and easier management than pre-shared secret authentication. The other options are either incorrect or irrelevant for this scenario. [Check Point R80.10 - Part 6 - Certificate Based Authentication]
NEW QUESTION # 68
Which of the following is considered to be the more secure and preferred VPN authentication method?
  • B. Certificate
  • C. Password
  • D. MD5
NEW QUESTION # 69
We are proud that our CheckPoint 156-215.82 exam preparation material is one of the best in the market. You should buy our Check Point Certified Security Administrator - R82 (156-215.82) valid dumps and start preparation now because of some amazing offers. These offers are up to 1 year of Free 156-215.82 Dumps updates, free demos of our 156-215.82 exam product, and a full refund guarantee. What are you waiting for? Buy actual CheckPoint 156-215.82 now at discount and start your preparation.
156-215.82 Certification Questions: https://www.practicematerial.com/156-215.82-exam-materials.html
As everyone knows, 156-215.82 exams are difficult subjects which are hard to pass you may have too much worry for that, Here are several advantages about our 156-215.82 Certification Questions - Check Point Certified Security Administrator - R82 exam for your reference, CheckPoint 156-215.82 Latest Braindumps Sheet Some practice materials keep droning on the useless points of knowledge, Carefully written and constantly updated content of our 156-215.82 exam questions can make you keep up with the changing direction of the exam, without aimlessly learning and wasting energy.
Ubuntu Classic Desktop, Also if you need to be 156-215.82 Certification Questions retrained, you need to know if there are schools/training centers reasonably close by to getthe needed training, As everyone knows, 156-215.82 Exams are difficult subjects which are hard to pass you may have too much worry for that.
156-215.82 actual exam dumps, CheckPoint 156-215.82 practice testHere are several advantages about our Check Point Certified Security Administrator - R82 exam for 156-215.82 your reference, Some practice materials keep droning on the useless points of knowledge, Carefully written and constantly updated content of our 156-215.82 exam questions can make you keep up with the changing direction of the exam, without aimlessly learning and wasting energy.
Our website takes the lead in launching a set of test plan aiming at those office workers to get the 156-215.82 exam certification.
Posted at 3/9/2026 07:06:33        Only Author  2#
The points mentioned in the article are very useful and have helped me a lot. ISO-IEC-27001-Lead-Implementer reliable exam study guide has fantastic content, and its free to access.
