[General] CTS Exam Introduction | CTS Valid Test Pdf
108
【General】 CTS Exam Introduction | CTS Valid Test Pdf
Posted at 2/14/2026 05:26:07      View:121 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CTS dumps are available on Google Drive shared by Dumpexams: https://drive.google.com/open?id=19V1LGXaW2d2sb6d5pyyNou4bK97eAKkk
It is universally accepted that the exam is a tough nut to crack for the majority of candidates, but the related CTS certification is of great significance for workers in this field so that many workers have to meet the challenge. Fortunately, you need not to worry about this sort of question any more, since you can find the best solution in this website--our CTS Training Materials. With our continued investment in technology, people and facilities, the future of our company has never looked so bright. with our excellent CTS exam questions, you will pass the CTS exam successfully.
AVIXA CTS Exam Certification Details:
Exam NameAVIXA Certified Technology Specialist (CTS)
MemberExam Price$375(USD)
Number of Questions110
Passing Score350 / 500
Non-Member Exam Price$475(USD)
Exam CodeCTS
Duration150 mins
Books / TrainingCandidate Handbook
Sample QuestionsAVIXACTS Sample Questions
AVIXA CTS Valid Test Pdf, Exam CTS BlueprintWe can provide absolutely high quality guarantee for our CTS practice materials, for all of our AVIXA CTS learning materials are finalized after being approved by industry experts. Without doubt, you will get what you expect to achieve, no matter your satisfied scores or according CTScertification file. As long as you choose our Certified Technology Specialist exam questions, you will get the most awarded.
AVIXA CTS - General Exam Syllabus Topics:
TopicWeight
Duty A:Creating AV Solutions47%
Task 1:Gather Customer Information10%
Task 2:Conduct Initial Site Survey9%
Task 3: Evaluate Site Environment (acoustics, lighting, seating, finishing, etc.)9%
Task 4evelop an AV Project Scope9%
Task 5: Design AV Solutions10%
Domain 2:Implementing AV Solutions27%
Task 1:Integrate AV Solutions10%
AVIXA Certified Technology Specialist Sample Questions (Q57-Q62):NEW QUESTION # 57
The amount of light emitted through a projection system lens is TYPICALLY specified and measured
  • A. by its contrast ratio.
  • B. in footcandles.
  • C. in lux.
  • D. in lumens.
The light output of a projection system is typically measured in lumens, which quantify the total amount of visible light emitted by the projector. Lumens measure the projector's brightness, making it a standard metric for comparing different projectors' output capacities.
* Lux is used to measure illuminance or the amount of light falling on a surface.
* Footcandles is another unit of illuminance, similar to lux but based on the imperial system.
* Contrast ratio describes the difference in luminance between the brightest white and the darkest black a projector can produce, not the brightness itself.
CTS Technology Specialist ReferenceAccording to CTS training materials, projector brightness should be specified in lumens, which provides a clear indication of the projector's suitability for different environments and screen sizes.
NEW QUESTION # 58
When should preventive maintenance be undertaken?
  • A. after a customer has reported a system failure
  • B. when there is more than one failure in the system
  • C. at scheduled times independent of system failures
  • D. when a projector lamp has failed
Preventive maintenance is planned maintenance conducted at regular intervals to ensure system reliability and prevent issues before they occur, rather than in response to system failures.
CTS training on maintenance highlights the importance of scheduled preventive maintenance to keep systems operating smoothly and extend equipment lifespan.
NEW QUESTION # 59
In the initial stage of determining AV equipment for an installation, the AV team gathers information PRIMARILY to:
  • A. Produce schematic drawings of the proposed solution
  • B. Prepare a punch (snag or defect) list
  • C. Understand the application
  • D. Establish a baseline for system performance
Before selecting equipment, it's essential to understand how the system will be used. This includes the application (e.g., video conferencing, digital signage, education) and user requirements. This insight drives all design and equipment decisions.
"Understanding the application allows the integrator to tailor the system design to user needs, functionality, and budget."
- CTS Exam Guide, AV Needs Analysis Chapter
NEW QUESTION # 60
An integrator has to upgrade a camera system in an existing board room. What is the MOST IMPORTANT information to gather on the site visit?
  • A. ambient lighting placement
  • B. resolution of camera system
  • C. cable length
  • D. distance from the lens to first participant
The most important information to gather on a site visit when upgrading a camera system in an existing boardroom is the distance from the lens to the first participant. This measurement is crucial for determining the appropriate camera lens and its focal length to ensure all participants are clearly visible within the camera's field of view. It also affects the placement and angle of the camera to achieve the best possible coverage. Axis Technology Specialist documentation emphasizes the importance of precise measurements and placement to optimize camera performance and video quality in boardroom settings.
Top of Form
Bottom of Form
NEW QUESTION # 61
While conducting a site survey, it is discovered that a conference room has glass walls, high ceilings, and wooden floors. The BIGGEST challenge for this room would be handling of which of the following?
  • A. loudspeaker placement
  • B. reverberance
  • C. cable paths
  • D. feedback
NEW QUESTION # 62
CTS Valid Test Pdf: https://www.dumpexams.com/CTS-real-answers.html
What's more, part of that Dumpexams CTS dumps now are free: https://drive.google.com/open?id=19V1LGXaW2d2sb6d5pyyNou4bK97eAKkk
