NCP-MCA Exam Score & NCP-MCA Prep Guide
101
Posted at 2/14/2026 10:42:33      View88 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Nutanix NCP-MCA dumps are available on Google Drive shared by DumpsFree: https://drive.google.com/open?id=1ixI0Usr5g25hhVUfOwEgzQYtODmO5gLe
In compliance with syllabus of the exam, our NCP-MCA practice materials are determinant factors giving you assurance of smooth exam. Our NCP-MCA practice materials comprise of a number of academic questions for your practice, which are interlinked and helpful for your exam. So, they are specified as one of the most successful NCP-MCA practice materials in the line. They can renew your knowledge with high utility with Favorable prices. So, they are reliably rewarding NCP-MCA practice materials with high utility value.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA) exam is designed to test the skills and knowledge of IT professionals in automating and managing multicloud environments using Nutanix technologies. Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) certification is ideal for professionals who are responsible for managing and deploying applications across multiple cloud environments, including private, public, and hybrid clouds. With the growing adoption of multicloud strategies, the NCP-MCA certification has become increasingly valuable for IT professionals looking to advance their careers.
The NCP-MCA Certification Exam covers a range of topics, including the fundamentals of automation, the Nutanix Calm platform, and application lifecycle management. Candidates are expected to have a solid understanding of automation concepts and techniques, as well as experience working with the Nutanix Calm platform. NCP-MCA exam is designed to be challenging, and candidates must demonstrate their ability to solve complex problems and implement effective solutions in a multicloud environment.
NCP-MCA Prep Guide & Exam NCP-MCA Pass GuideWe should formulate a set of high efficient study plan to make the NCP-MCA exam dumps easier to operate. Here our products strive for providing you a comfortable study platform and continuously upgrade NCP-MCA test prep to meet every customers requirements. Under the guidance of our NCP-MCA Test Braindumps, 20-30 hours preparation is enough to help you obtain the Nutanix certification, which means you can have more time to do your own business as well as keep a balance between a rest and taking exams.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) Sample Questions (Q11-Q16):NEW QUESTION # 11
An administrator has run a multi-step Playbook. but sees the Failed status, as shown in the exhibit.
What could be causing the playbook to fail?
  • A. IP Address SSH action has a timeout of 5 minutes.
  • B. PowerShell action has a timeout of 5 minutes.
  • C. puppet action has a timeout of 5 minutes.
  • D. VM action has a timeout of 5 minutes.
The image shows a failed status for an SSH_VM_Task, which is manually triggered. Since the task involves SSH, it's likely that the IP Address SSH action has a timeout of 5 minutes, causing the playbook to fail if it cannot complete within this time frame. The IP Address SSH action is used to execute commands on a remote VM using SSH. It requires the IP address, username, password, and command to run as inputs. The timeout parameter specifies how long the action will wait for the command to finish before aborting. If the timeout is too short, the action may fail due to network latency, slow execution, or other factors. References:
* Nutanix Certified Professional - Multicloud Automation (NCP-MCA) 6.5 Exam, page 16, section
1.3.2.2: "Playbooks"
* [Nutanix University: NCP-MCA 6.5 Exam Prep - Playbooks], video 4: "Playbooks"
NEW QUESTION # 12
An administrator has an existing set of VMs that were deployed before the company started using Calm. The administrator would like to now use Calm to manage those existing VMs.
What should the administrator do to manage the existing VMs?
  • A. Create a Greenfield Application, select the VMs that are needed for each deployment from the drop down list.
  • B. Create a Greenfield Application, select the snapshots of the VMs to manage and redeploy the VMs from the latest snapshot.
  • C. Create a Brownfield Application, select the snapshots of the VMs to manage and redeploy the VMs from the latest snapshot.
  • D. Create a Brownfield Application, select the VMs that are needed for each deployment from the drop down list.
A Brownfield Application is a type of application that allows you to import and manage existing VMs that were not deployed by Calm. You can use a Brownfield Application to perform actions such as start, stop, restart, delete, or execute scripts on the imported VMs. You can also add services, credentials, variables, and policies to the Brownfield Application blueprint. To create a Brownfield Application, you need to select a multi-VM blueprint and then choose the VMs that you want to include in the application from the drop down list. You can also filter the VMs by name, cluster, or power state.
A Greenfield Application is a type of application that allows you to deploy new VMs from scratch using Calm. You can use a Greenfield Application to provision and configure VMs on different cloud platforms, such as Nutanix AHV, VMware ESXi, AWS, Azure, or GCP. You can also add services, credentials, variables, and policies to the Greenfield Application blueprint. To create a Greenfield Application, you need to select a single-VM or a multi-VM blueprint and then specify the VM properties, such as name, image, flavor, network, storage, etc.
Nutanix Calm DSL - Brownfield Apps the Easy Way
Nutanix Support & Insights
Getting started with Nutanix Calm
NEW QUESTION # 13
A Blueprint fails on executing a check-login task against a Windows 2016 VM and displays the error shown in the exhibit. The administrator is using a SSH key-based credential to authenticate the task.
What should the administrator change to resolve the issue?
  • A. Ensure the private key for the credential is correct.
  • B. Increase the retries to allow for the task to complete.
  • C. Modify the timeout to give the task longer to complete.
  • D. Change to password authentication credential.
The error message "Authentication by <Credential_type> failed" typically indicates an issue with the authentication credentials being used. Since the administrator is using SSH key-based credential to authenticate, it's essential to ensure that the private key associated with this credential is correct and accessible. If there's an issue with the private key, such as it being incorrect or inaccessible, authentication will fail. Increasing the retries or modifying the timeout will not help if the credential is invalid. Changing to password authentication credential may work, but it's not the best option as it may compromise security and require additional configuration. References:
* Nutanix Certified Professional - Multicloud Automation (NCP-MCA) v6.5, Section 3 - Validate Blueprints, Runbooks, Playbooks, and Automation Settings, page 2
* Nutanix Multicloud Automation Administration (NMCAA), Module 5 - X-Play, Lesson 5.2 - Credential Management, page 7
* Nutanix Calm User Guide, Credential Management, SSH Key-Based Authentication
NEW QUESTION # 14
An administrator is configuring a new Self-Service project. There is a Playbook targeting VMs with the respective CalmProject category that automates post-deployment tasks (such as tagging, monitoring and sending notifications).
After assigning the blueprint and users, the administrator wants to validate that the Project and Playbook configurations are functioning as created before user deployment begins.
Which two steps should the administrator take to complete this task? (Choose two.)
  • A. Deploy the blueprint associated with the Marketplace and verify that the Playbook executes as expected.
  • B. Run the Playbook manually using the "Execute on behalf of" option in Prism Central to test its logic.
  • C. Deploy the blueprint associated with the Project and verify that the Playbook executes as expected.
  • D. Run the Playbook manually using the "Execute" option in Prism Central to test its logic.
Nutanix Calm and Self-Service automation workflows require validation within the same execution context used by end users. Nutanix documentation specifies the following principles:
1. Playbook validation requires execution in the same user and project context Playbooks that target resources using aCalmProjectcategory must be tested in the exact context in which they will operate.
The"Execute on behalf of"option allows the administrator to run the Playbookas if a project user initiated it, ensuring validation of:
* Project-based scoping
* User permissions
* Category-based triggers
* Playbook logic and automation flow
This matches the documented requirement that Playbooks must be validated under theintended user execution model, makingOption B correct.
2. Deployment must occur inside the Project to activate category-driven Playbooks Blueprint deployments only trigger Playbooks when:
* The deployment occursinside the Project, and
* The VM receives metadata (such as CalmProject category) associated with that Project.
Nutanix Calm documentation highlights that Playbooks relying onProject categoriesonly activate when VMs are provisionedfrom that specific Project.
Deploying from the Marketplace does not guarantee that the correct project context or categories will be applied.
Thus, verifying Playbook execution requires deploying the blueprint assigned to the Project, makingOption D correct.
Why the other options are incorrect
#Option A - "Execute"
This executes Playbooks only in the admin context, not the Project context. It doesnotvalidate permissions, user behavior, or category-based triggers required for Self-Service operation.
#Option C - Marketplace deployment
Marketplace deployments do not necessarily apply Project-specific categories or metadata, so they cannot reliably test integration with Playbooks bound to a Project.
NEW QUESTION # 15
An administrator has been tasked with automating the optimization of plays with the autopilot feature.
What must the administrator be aware of before configuring autopilot?
  • A. Autopilot feature only applies to metric-based alerts as triggers.
  • B. Autopilot will only attempt to apply the playbook a single time
  • C. Autopilot only applies to new playbooks.
  • D. Autopilot never waits for approvals.
Autopilot is a feature of Nutanix Calm that allows the administrator to automate the execution of playbooks based on predefined conditions or triggers. Autopilot can optimizethe performance, availability, and cost of applications by applying the appropriate actions in response to events or metrics. Before configuring autopilot, the administrator must be aware of the following limitations12:
* Autopilot never waits for approvals. This means that the administrator must ensure that the playbooks
* are tested and verified before enabling autopilot. Autopilot will execute the playbooks without any human intervention or confirmation.
* Autopilot feature only applies to metric-based alerts as triggers. This means that the administrator can only use metrics from the Nutanix Prism Central or the Nutanix Karbon clusters as the conditions for triggering the playbooks. Autopilot does not support other types of triggers such as schedules, webhooks, or manual triggers. References: Nutanix Certified Professional - Multicloud Automation (NCP-MCA) Exam Blueprint Guide, page 10; Nutanix Calm SaaS User Guide, section 4.3.
NEW QUESTION # 16
As is known to us, a good product is not only reflected in the strict management system, complete quality guarantee system but also the fine pre-sale and after-sale service system. In order to provide the best NCP-MCA study materials for all people, our company already established the integrate quality manage system, before sell serve and promise after sale. If you buy the NCP-MCA Study Materials from our company, we can make sure that you will have the right to enjoy the 24 hours full-time online service.
NCP-MCA Prep Guide: https://www.dumpsfree.com/NCP-MCA-valid-exam.html
