[Hardware] Salesforce Plat-Dev-210 Question Explanations | Sure Plat-Dev-210 Pass
103
Hardware Salesforce Plat-Dev-210 Question Explanations | Sure Plat-Dev-210 Pass
Posted at 2/14/2026 12:00:50      View126 | Replies0        Print      Only Author   [Copy Link] 1#
Our company guarantees this pass rate from various aspects such as content and service on our Plat-Dev-210 exam questions. We have hired the most authoritative professionals to compile the content Of the Plat-Dev-210 study materials. And we offer 24/7 service online to help you on all kinds of the problems about the Plat-Dev-210 learning guide. Of course, we also consider the needs of users, ourPlat-Dev-210 exam questions hope to help every user realize their dreams.
Salesforce Plat-Dev-210 Exam Syllabus Topics:
  • Omnistudio Data Mappers: This part of the exam measures the skills of a Data Engineer and focuses on the use of Omnistudio Data Mappers for extracting, transforming, and loading data. It includes identifying the appropriate Data Mapper for a given requirement, as well as determining the necessary Extract, Load, Transform, and Turbo Extract functionalities based on specific use cases. This section ensures the candidate can effectively map and manipulate data to support business processes.
  • Integration Procedures: This section measures the skills of an Integration Architect and involves designing and configuring Integration Procedures to automate processes and integrate systems. It requires comparing and contrasting different elements and configurations within Integration Procedures to meet specific use cases. Candidates are also tested on selecting the correct elements and properties to satisfy functional requirements, ensuring seamless data flow and process automation.
  • Flexcards: This section of the exam measures the skills of a Solution Architect and covers the ability to design and configure FlexCards based on specific business requirements. It evaluates the candidate's knowledge in selecting appropriate card styles, defining data sources and fields, and implementing user actions across different card states. Additionally, this domain tests the understanding of constructing the underlying JSON data structure that powers the FlexCards framework, ensuring that the configured cards meet both functional and technical specifications.
  • Integrated Troubleshooting and Deployment: This final section measures the skills of a Support Engineer and focuses on identifying and resolving issues within Omnistudio tools. It involves diagnosing errors based on given scenarios and determining where breakdowns occur in the data flow for specific customer issues. This ensures the candidate can effectively troubleshoot, debug, and maintain solutions to ensure optimal performance and reliability.
Sure Plat-Dev-210 Pass, Plat-Dev-210 PDF DownloadAll these three ITExamSimulator Salesforce Certified Omnistudio Developer (Plat-Dev-210) exam questions formats are easy to use and perfectly work with all devices, operating systems, and the latest web browsers. So rest assured that with the ITExamSimulator Plat-Dev-210 Exam Dumps you will get everything that you need to learn, prepare and pass the challenging Salesforce Certified Omnistudio Developer (Plat-Dev-210) exam with good scores.
Salesforce Certified Omnistudio Developer Sample Questions (Q76-Q81):NEW QUESTION # 76
A developer has an existing DataRaptorLoad that insert Contact records with inputs as LastName and firstName. The DataRaptor works as expected when previewed.
The developer creates an integration Procedure to test the DataRaptor and is using a SetValues element in the Integration Procedure toset the first name and last name for the contact record. The DataRaptor and Integration Procedure are set up as shown in the exhibit below.
When the developer executes the Integration procedure in preview, the following error message displays:
Required fields are missing: [last Name]'',
How should the developer address this issue?
  • A. The DataRaptor Post Action in the integration procedure should have been executed before the Set Values Action
  • B. SetValuesContactDetails should have been added to Additional input of DataRaptor Post Action in Integration Procedure
  • C. The Set values Action Keys should include the DataRaptor Post Action element name path, e,g LoadContactDetails, lastname
  • D. The valid field names should be added in the Domain object field in theDataRaptor
According to the Integration Procedure Actions page, "To pass data from a Set Values action to a DataRaptor action, add the Set Values action name to the Additional Input field of the DataRaptor action."
NEW QUESTION # 77
A developer examines data received from an external data source. The data is nested two levels down in the JSON structure.
Which OmniStudio tool could the developer use to simplify this data?
  • A. Data Mapper Transform
  • B. Guided Workflow
  • C. Integration Procedure
  • D. HTTP Action Element
According to Salesforce OmniStudio Integration Procedures documentation, when working with deeply nested JSON, Integration Procedures are ideal. They allow developers to flatten and manipulate JSON data, especially when handling external responses.
* C. Integration Procedure - This is correct. IPs provide Response Transformers, DataRaptor Transforms, and Response Actions to reshape and simplify nested data structures for consumption by front-end components.
Incorrect Options:
* A. DataRaptor Transform is used inside IPs but cannot directly handle external HTTP calls or manage complex orchestration.
* B. HTTP Action Element is used inside an Integration Procedure, but by itself, it does not process or simplify the data.
* D. Guided Workflow is not a recognized OmniStudio component for data transformation.
OmniStudio Integration Procedures Guide # Handling Nested JSON
NEW QUESTION # 78
A developer builds a new OmniScript. It contains aSet Values element with a ContextId key/value pair that was used during testing.
What should the developer do before moving the OmniScript to a production org?
  • A. Delete or Deactivate the Set Values element.
  • B. Deactivate the contextId key/value pair
  • C. Update the ContextId value to specify an id from the Production org.
  • D. Add a Show/Hide condition on the Set Values element.
The Set Values element with a ContextId key/value pair was used for testing purposes and is not needed for production. The developer should delete or deactivate the Set Values element before moving the OmniScript to a production org.
NEW QUESTION # 79
A developer has a requirement to create a child FlexCard that contains all of its parent FlexCard's records In a Datable How should the developer configure the parent FlexCard's Node?
  • A. {Records Plat-Dev-210}
  • B. {Params, records}
  • C. {Records}
  • D. {Recorded}
The Node field for the parent FlexCard should be set to {Records}, which is an array of all the records retrieved by the parent FlexCard data source. This will allow the child FlexCard to access the records and display them in a DataTable.
NEW QUESTION # 80
A developer creates an OmniScript display FirstName, LastName, and BirthDate of a contact using a Type Ahead Block. The DataRaptor used in the Type Ahead has been tested and fetches the correct data.
When previewing Omniscript, the developer enters a name in the Type Ahead and makes a selection of a contact from the list. However, the text fields FirstName. LastName, and BirthDate are not getting populated with the data.
What is the reason that the fields fail to display the fetched data?
  • A. FirstName, LastName, and Birthdate are not placed inside the Type ahead Block.
  • B. Lookup Mode is not selected in the properties of the Type A Head Block.
  • C. Use Data JSON is not selected in the properties of the Type Ahead Block.
  • D. The Typeghead ley is not in the correct format
The FirstName, LastName, and BirthDate fields should be placed inside the Type Ahead Block, so that they can receive the data from the selected record in the Type Ahead list. The Type Ahead Block has a Data JSON Path property that specifies the path to the data node that contains the record fields. For example, if the Data JSON Path is set to Contact, then the FirstName field should have a Value property set to {{Contact.
FirstName}}.
NEW QUESTION # 81
Our Plat-Dev-210 exam torrent is finalized after being approved by industry experts and Plat-Dev-210 Practice Materials are tested by professionals with a high pass rate as 99%. Besides, Plat-Dev-210 Learning Guide helps establish your confidence and avoid wasting time. That is because our Plat-Dev-210 Practice Test can serve as a conducive tool for you make up for those hot points you have ignored, you will have every needed Plat-Dev-210 exam questions and answers in the actual exam to pass it.
Sure Plat-Dev-210 Pass: https://www.itexamsimulator.com/Plat-Dev-210-brain-dumps.html
