CDCP Exam Torrent & CDCP Real Questions & CDCP Exam Cram
Posted at 2/14/2026 14:11:13      View:96 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TestBraindump CDCP dumps from Cloud Storage: https://drive.google.com/open?id=1AQHnbW51lltuBcPSgobRAHxkeTGOqvls
With the rapid development of IT technology, the questions in the IT certification exam are also changing. Therefore, TestBraindump also keeps updating test questions and answers. And if you purchase TestBraindump EXIN CDCP Practice Test materials, we will provide you with free updates for a year. As long as the questions updates, TestBraindump will immediately send the latest questions and answers to you which guarantees that you can get the latest materials at any time. TestBraindump can not only help you pass the test, but also help you learn the latest knowledge. Never pass up a good chance to have the substantial materials.
EXIN CDCP Exam Syllabus Topics:
  • Cooling Infrastructure: The topic focuses on liquid immersion cooling, supplemental cooling options, sensible and latent heat definitions, and temperature and humidity recommendations.
  • Power Infrastructure: It focuses ATS and STS systems, redundancy levels and techniques, static and dynamic UPS systems, battery types, thermo-graphics, and renewable energy factor (REF).
  • Designing a Scalable Network Infrastructure: It covers ANSI
  • TIA-942 cabling hierarchy, network redundancy, structured Cabling System, and planning considerations.
  • Physical Security and Safety: Sub-topics are about physical security considerations and physical safety considerations.
Topic 5
  • Raised Floor
  • Suspended Ceiling: The topic discusses applicable standards, signal reference grid, and disability act and regulations.
Topic 6
  • Data Centre Location, Building and Construction: It focuses on appropriate sites and components of an effective data centre and supporting facilities setup.
Topic 7
  • Auxiliary Systems: The topic covers water leak detection systems, data centre monitoring requirements, EMS, BMS and DCIM.
Topic 8
  • Light: This topic covers light fixture types and placement, emergency lighting, and emergency Power Supply (EPS).
Topic 9
  • Water Supply: This topic is all about water supply techniques and application areas.
Topic 10
  • Equipment Racks: It discusses power rail
  • strip options, security considerations, and rack standards, properties and selection criteria.
Topic 11
  • Electro Magnetic Fields: The topic deals with effects of EMF on human health and equipment (H)EMP, standards, and EMF shielding solutions.
CDCP PDF - CDCP Pdf BraindumpsAs long as you are willing to exercise on a regular basis, the CDCP exam will be a piece of cake, because what our CDCP practice materials include is quintessential points about the exam. And our high pass rate as 98% to 100% are all proved data form our customers who had attended the CDCP Exam and got their success with the help of our CDCP study dumps. So just come on and join our success!
EXIN Certified Data Centre Professional (CDCP) Sample Questions (Q55-Q60):NEW QUESTION # 55
What should be considered when using a direct air handler for a data centre?
  • A. Cost of operation as power consumption on these units tend to be higher compared to traditional air conditioning technology.
  • B. The availability of three-phase power due to the high power requirements of these air handler units.
  • C. Space available inside the computer rooms as the air handler space requirement for the inside the Computer room is quite large.
  • D. Temperature, humidity and contamination of the outdoor environment.
Direct air handlers are a type of cooling system that use outdoor air to cool the data centre. They draw in fresh air from outside, filter it, and supply it to the data centre at the desired temperature and humidity level. Direct air handlers can reduce the energy consumption and operating costs of data centres by eliminating the need for mechanical cooling or refrigeration. However, they also have some challenges and limitations that need to be considered. One of the main factors to consider when using direct air handlers for data centres is the temperature, humidity and contamination of the outdoor environment. Depending on the location and climate of the data centre, the outdoor air may not always be suitable for cooling the data centre. For example, if the outdoor air is too hot, too humid, or too polluted, it may not provide enough cooling capacity, or it may damage the IT equipment or cause corrosion. Therefore, direct air handlers need to have sensors and controls to monitor the outdoor air quality and adjust the airflow accordingly. They may also need to have backup cooling systems or supplementary cooling devices, such as evaporative coolers or heat exchangers, to cope with extreme weather conditions or peak loads.
References: Data Center Cooling: A Comprehensive Guide - Dgtl Infra, Carrier Data Center Cooling System
39DC, Dublin Data Center: Rooftop Air Handlers.
NEW QUESTION # 56
Which Class of Fire involves combustible metals or combustible metal alloys such as magnesium, sodium and potassium?
  • A. Class C
  • B. Class B
  • C. Class A
  • D. Class D
Class D fires involve combustible metals or combustible metal alloys such as magnesium, sodium and potassium. These metals can react violently with water, air, or other chemicals, and require special extinguishing agents1 References: 1: EPI Data Centre Professional (CDCP) Reference Materials, page 16.
NEW QUESTION # 57
is the degree to which a system or component is operational and accessibility when required for use.
  • A. Scalability
  • B. Agility
  • C. Reliability
  • D. Availability
Availability is the degree to which a system, product or component is operational and accessible when required for use. It is one of the attributes of reliability, which is the ability of a system or component to perform its required functions under stated conditions for a specified period of time. Availability can be calculated as the ratio of the expected value of the uptime (the time when the system is functional) to the total time (uptime plus downtime) of a system or component. Availability can also be influenced by factors such as maintainability, fault tolerance, redundancy, diagnostics, and logistics.
References: EPI Data Centre Professional (CDCP®) Preparation Guide, page 8; Availability - Wikipedia; Reliability - ISO 25000.
NEW QUESTION # 58
What should be considered when implementing hot- or cold-aisle containment in an existing computer room?
  • A. It will be more difficult to install power and network cabling in the contained area.
  • B. It creates potential issues with the existing fire suppression system(s).
  • C. Equipment will get too hot at the rear (back) of the rack potentially resulting in more ICT hardware failures.
  • D. The delta-T of the equipment will increase too much causing reliability issues.
Hot- or cold-aisle containment is a strategy to improve the cooling efficiency and reduce the energy consumption of data centers by isolating the hot exhaust air from the cold supply air. However, implementing this strategy in an existing computer room may create potential issues with the existing fire suppression system(s), such as:
*The containment barriers may interfere with the distribution and activation of the fire suppression agents, such as water, gas, or aerosol, and reduce their effectiveness in extinguishing a fire.
*The containment barriers may create pockets of high temperature and pressure that could damage the equipment or the containment structure itself in the event of a fire.
*The containment barriers may obstruct the access and visibility of the fire detection and alarm devices, such as smoke detectors, heat sensors, or manual call points, and delay the response time of the fire suppression system(s).
*The containment barriers may violate the local fire codes and regulations that specify the minimum clearance and ventilation requirements for the data center.
Therefore, when implementing hot- or cold-aisle containment in an existing computer room, it is important to consider the impact on the existing fire suppression system(s) and take appropriate measures to ensure the safety and compliance of the data center, such as:
*Consulting with the fire authorities and the fire suppression system vendor to assess the compatibility and suitability of the containment solution with the existing fire suppression system(s).
*Modifying or upgrading the existing fire suppression system(s) to accommodate the containment solution, such as relocating or adding fire suppression devices, adjusting the discharge rate and pressure, or installing a secondary fire suppression system within the contained area.
*Installing fire-rated containment barriers that can withstand high temperatures and resist the spread of fire and smoke, and that have self-closing or automatic release mechanisms in case of a fire.
*Installing fire detection and alarm devices within the contained area and ensuring their proper integration and communication with the existing fire suppression system(s).
*Conducting regular testing and maintenance of the fire suppression system(s) and the containment solution to ensure their functionality and reliability.
References: EPI Data Centre Framework, Module 4: Fire Protection, page 10-11. EPI Data Centre Professional (CDCP®) Reference Materials, page 66-67. 1, 2, 3.
NEW QUESTION # 59
What is the best practice for cutting holes in the raised floor tile?
  • A. Cut the tiles at the corner so the pedestals can be used as a vertical cable manager.
  • B. Anywhere as data centre tiles are designed to allow cut-outs anywhere.
  • C. Draw a line in the middle of the tile and never touch the line when making the cut.
  • D. Draw a cross on the tile and when making a cut-out do not touch a line and avoid the corners.
According to the Raised Floor Installation Manual, the best practice for cutting holes in the raised floor tile is to draw a cross on the tile and when making a cut-out do not touch a line and avoid the corners1. This ensures that the structural integrity and load-bearing capacity of the tile are not compromised. Cutting holes anywhere, touching the line, or cutting the corners can weaken the tile and cause it to crack or collapse1. Additionally, the manual recommends using a drill press or a reciprocating saw with a metal or bi-metal cutting blade, and deburring all sharp edges1.
References: 1: Raised Floor Installation Manual, E. Recommended Cutting Tools, Page 1
NEW QUESTION # 60
TestBraindump offers the CDCP exam questions in a convenient PDF format, allowing you to easily download them on your PC, laptop, Mac, tablet, or smartphone. With this accessibility, you can access the EXIN CDCP PDF questions anytime and from anywhere. Having all the information about the Certified Data Centre Professional (CDCP) (CDCP) Exam at your fingertips enhances your studying experience, making it easier and more effective, whether you're at home or on the go.
CDCP PDF: https://www.testbraindump.com/CDCP-exam-prep.html
BONUS!!! Download part of TestBraindump CDCP dumps for free: https://drive.google.com/open?id=1AQHnbW51lltuBcPSgobRAHxkeTGOqvls
Posted at 2/18/2026 02:59:13        Only Author  2#
Through reading this article, I gained a lot of professional knowledge. The free CT-UT Brain dumps content is exceptional, and it’s available at no cost.
Posted at 2/22/2026 10:33:20        Only Author  3#
Itexamdump에서는 가장 최신이자 최고인Salesforce인증 AP-215시험덤프를 제공해드려 여러분이 IT업계에서 더 순조롭게 나아가도록 최선을 다해드립니다. Salesforce인증 AP-215덤프는 최근 실제시험문제를 연구하여 제작한 제일 철저한 시험전 공부자료입니다. Salesforce인증 AP-215시험준비자료는 Itexamdump에서 마련하시면 기적같은 효과를 안겨드립니다.
