[General] FSCP Valid Practice Questions | FSCP Reliable Exam Cram
106
【General】 FSCP Valid Practice Questions | FSCP Reliable Exam Cram
Posted at 2/14/2026 14:37:12      View:104 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Forescout FSCP dumps are available on Google Drive shared by TestKingIT: https://drive.google.com/open?id=1-NIj0lQ5Nt-ptsP-Fwc3johQH9Ws1rlS
If you want to own a better and bright development in the IT your IT career, it is the only way for you to pass FSCP exam. Don't complain how difficult the FSCP exam is. Because our TestKingIT experienced technicians have provided efficient way for you to easily get FSCP Exam Certification. We constantly update test simulation software in order to help you who are preparing for FSCP exam by efforts to get the satisfactory results.
If you buy TestKingIT Forescout FSCP Exam Training materials, you will solve the problem of your test preparation. You will get the training materials which have the highest quality. Buy our products today, and you will open a new door, and you will get a better future. We can make you pay a minimum of effort to get the greatest success.
100% Pass Trustable Forescout - FSCP Valid Practice QuestionsLife is beset with all different obstacles that are not easily overcome. For instance, FSCP exams may be insurmountable barriers for the majority of population. However, with the help of our FSCPexam questions, exams are no longer problems for you. The reason why our FSCP Training Materials outweigh other FSCP study prep can be attributed to three aspects, namely free renewal in one year, immediate download after payment and simulation for the software version.
Forescout Certified Professional Exam Sample Questions (Q32-Q37):NEW QUESTION # 32
Where are the plugin logs located in the CounterACT CLI?
  • A. /usr/local/forescout/log/plugin/<plugin ID>
  • B. /usr/local/forescout/plugin/<plugin ID>/log
  • C. /usr/local/forescout/plugin/log/<plugin ID>
  • D. /usr/local/forescout/log
  • E. /usr/local/log/plugin/<plugin ID>
Comprehensive and Detailed Explanation From Exact Extract of Forescout Platform Administration and Deployment:
According to the Forescout CLI Commands Reference Guide and official documentation, the plugin logs in the CounterACT CLI are located at the path /usr/local/forescout/log/plugin/<plugin ID>.
CLI Log File Structure:
The Forescout CLI organizes log files in a hierarchical directory structure. When using the CLI to access logs, administrators can navigate through the following directory structure:
* log - View appliance log files
* log:plugin - Access plugin-specific log directories
* log:plugin/<plugin ID> - Access logs for a specific plugin
Example Plugin Log Locations:
According to the documentation, specific plugin logs can be accessed using the following CLI commands:
text
list log:plugin/<plugin ID>
monitor log:plugin/<plugin ID>/<plugin_name>.log
For example, the Python server logs for the Connect Module are located at: /usr/local/forescout/plugin
/connect_module/python_logs
CLI Commands for Accessing Plugin Logs:
The correct CLI syntax for accessing plugin logs includes:
text
list log:plugin/<plugin ID> - Lists plugin log directory contents
monitor log:plugin/<plugin ID>/<plugin_name>.log - Monitors plugin log in real-time view log:plugin/<plugin ID>/<plugin_name>.log - Views plugin log file contents search <pattern> log:plugin/<plugin ID>/<plugin_name>.log - Searches within plugin logs Why Other Options Are Incorrect:
* A. /usr/local/forescout/plugin/<plugin ID>/log - Inverted directory structure; log is a parent directory, not a subdirectory of the plugin ID
* B. /usr/local/forescout/plugin/log/<plugin ID> - Incorrect path structure; "log" is not a subdirectory under "plugin"
* C. /usr/local/forescout/log - Too generic; this path refers to appliance-wide logs, not plugin-specific logs
* D. /usr/local/log/plugin/<plugin ID> - Incorrect root path; Forescout logs are stored under /usr/local
/forescout, not /usr/local
Referenced Documentation:
* Forescout CLI Commands Reference Guide - List Directories and Log Files section
* Python Log Location documentation
* FS-CLI Commands - File and Log Management section
* Examples showing log:plugin path structure in CLI reference guides
NEW QUESTION # 33
What best defines a 'Post-Connect Methodology'?
  • A. Innocent until proven guilty
  • B. Used subsequent to pre-connect
  • C. 802.1X is a flavor of Post-Connect
  • D. Guilty until proven innocent
  • E. Assessed for critical compliance before IP address is assigned
According to the Forescout Blog on Post-Connect Access Controls and the Comply-to-Connect framework documentation, a Post-Connect Methodology is best defined as treating endpoints as "Innocent until proven guilty".
Definition of Post-Connect Methodology:
According to the official documentation:
"Post-connect" is described as treating endpoints as innocent until they are proven guilty. They can connect to the network, during and after which they are assessed for acceptance criteria." How Post-Connect Works:
According to the Post-Connect Access Controls blog:
* Initial Connection - Endpoints are allowed to connect to the network immediately (innocent)
* Assessment During/After Connection - After connecting, endpoints are assessed for acceptance criteria
* Compliance Checking - Endpoints are checked for:
* Corporate asset status (must be company-owned)
* Security compliance (antivirus, patches, encryption, etc.)
* Remediation or Quarantine - Based on assessment results:
* Compliant endpoints: Full access
* Non-compliant endpoints: Placed in quarantine for remediation
Post-Connect vs. Pre-Connect:
According to the Comply-to-Connect documentation:
* Pre-Connect - "Guilty until proven innocent" - Endpoint must prove compliance BEFORE getting network access
* Post-Connect - "Innocent until proven guilty" - Endpoint connects first, then compliance is assessed Benefits of Post-Connect Methodology:
According to the documentation:
"The greatest benefit to the post-connect approach is a positive user experience. Unless a system is out of compliance and ends up in a quarantine, your company's users have no idea access controls are even taking place on the network." Acceptance Criteria in Post-Connect:
According to the framework:
* Corporate Asset Verification - Determines if the endpoint belongs to the organization
* Compliance Assessment - Checks for:
* Updated antivirus
* Patch levels
* Disk encryption status
* Security tool functionality
If an endpoint fails these criteria, it's placed in quarantine (controlled network access) rather than being completely blocked.
* A. 802.1X is a flavor of Post-Connect - 802.1X is a pre-connect access control method (requires authentication before network access)
* B. Guilty until proven innocent - This describes pre-connect methodology, not post-connect
* D. Used subsequent to pre-connect - While post-connect can follow pre-connect, this doesn't define what post-connect is
* E. Assessed for critical compliance before IP address is assigned - This describes pre-connect methodology Referenced Documentation:
* Forescout Blog - Post-Connect Access Controls
* Comply-to-Connect Brief - Pre-connect vs Post-connect comparison
* Achieving Comply-to-Connect Requirements with Forescout
NEW QUESTION # 34
Which of the following is true when setting up an Enterprise Manager as a High Availability Pair?
  • A. Connect devices to the network and to each other.
  • B. HA requires a license.
  • C. HA needs to be manually configured on the secondary appliance in order to sync correctly.
  • D. If HA reboots, this is an indication of a problem.
  • E. Set up HA on the Secondary node first.
According to the Forescout Resiliency Solutions User Guide and the Forescout Platform Installation Guide, High Availability (HA) requires a license. The documentation explicitly states:
"If your deployment is using Centralized Licensing Mode, you must acquire a valid ForeScout CounterACT Resiliency license. The Resiliency license supports: High Availability Pairing for Enterprise Manager is supported by the Forescout CounterACT See License." High Availability Licensing Requirements:
Per-Appliance Licensing Mode:
"The demo license for your High Availability system is valid for 30 days. You must install a permanent license before this period expires." Centralized Licensing Mode:
"If your deployment is using Centralized Licensing Mode, you must acquire a valid ForeScout CounterACT Resiliency license for Appliances, or a CounterACT See License for Enterprise Manager High Availability Pairing." License Usage Considerations:
* "You should use the IP address of the High Availability pair when requesting a High Availability license"
* "If a license is only issued to the Active node in a High Availability pair, the system may not operate after failover to the Standby node"
* "Both nodes must be up when requesting a license"
* A. If HA reboots, this is an indication of a problem - According to the documentation, reboots can occur during the setup process: "Following the second reboot in the high availability setup, allow time for data synchronization" - this is normal, not an indication of a problem
* B. Set up HA on the Secondary node first - Incorrect order. According to the documentation, "Before you begin setting up the Secondary node Forescout Platform device, verify that the Primary node Forescout Platform device is powered on" - the Primary node must be set up first
* C. Connect devices to the network and to each other - While devices must be connected, this is a general infrastructure requirement, not specific to HA setup. The more specific requirement is licensing
* D. HA needs to be manually configured on the secondary appliance in order to sync correctly - According to the documentation, the Secondary node configuration uses a setup process that is distinct from the Primary node: "When setting up the Secondary node device, use the same sync interfaces and netmask settings used in the Primary node device" - this is guided setup, not manual configuration for sync High Availability Setup Process:
* Set up Primary Node - "Select High Availability mode: 1) Standard Installation 2) High Availability - Primary Node"
* Set up Secondary Node - "Set up a device as the secondary node" (secondary node connects to primary automatically)
* Licensing - "You must install a permanent license before this period expires" Referenced Documentation:
* Forescout Resiliency Solutions User Guide (v8.0)
* Forescout Installation Guide v8.1.x
* Forescout Resiliency and Recovery Solutions User Guide v8.1
* Set up and configure a device as the primary node
* Set up a device as the secondary node
NEW QUESTION # 35
What is the best practice for order of sub rules?
  • A. First rule should capture the lowest number of endpoints
  • B. First rule should capture the highest number of endpoints
  • C. Second rule should capture the highest number of endpoints
  • D. Last rule should capture the highest number of endpoints
  • E. Last rule should not use a catch all
According to the Forescout Administration Guide and RADIUS Plugin Configuration Guide, the best practice for ordering sub-rules is that the first rule should capture the lowest number of endpoints.
Sub-Rule Evaluation Order:
"Endpoints are inspected against each sub-rule in the order listed. When an endpoint matches a sub-rule, subsequent sub-rules are not evaluated for that endpoint." This sequential evaluation means that sub-rule order is critical to policy behavior.
Best Practice - Specific to General:
According to the guidelines:
The correct approach is to order sub-rules from most specific to least specific:
* First Sub-Rules (Most Specific) - Should capture the lowest number of endpoints
* Very specific criteria
* Narrow scope
* Handles edge cases and special conditions
* Middle Sub-Rules - Broader criteria
* More endpoints matched
* General conditions
* Last Sub-Rule (Most General) - Catch-all sub-rule
* Lowest specificity
* Highest number of endpoints
* Handles remaining unmatched endpoints
Why Specific Rules First:
"When an endpoint is found to match a sub-rule, no subsequent rules are evaluated for the endpoint." This "first match wins" behavior requires:
* Most specific rules first - Ensure special cases are handled correctly
* General rules last - Catch remaining endpoints that don't match specific criteria
* Avoid premature matches - If a general rule appears first, specific rules never execute Example Sub-Rule Ordering:
According to the RADIUS documentation:
text
Sub-Rule 1 (Most Specific, Lowest Count):
Condition: Windows 7 AND Antivirus NOT Running AND Not Encrypted
Lowest number of endpoints - specific conditions
Sub-Rule 2 (More General, Moderate Count):
Condition: Windows Endpoint AND Missing Patches
More endpoints - broader criteria
Sub-Rule 3 (Least Specific, Highest Count - Catch-All):
Condition: Windows Endpoint (Any)
Highest number - captures all remaining Windows endpoints
* A. Last rule should capture the highest number - While the last rule may capture many endpoints, the key best practice is about the FIRST rule capturing the LOWEST
* C. Second rule should capture the highest number - Sub-rule order is specific to general, not based on position 2
* D. Last rule should not use a catch-all - Best practice is that the LAST rule should be the catch-all
* E. First rule should capture the highest number - This is the OPPOSITE of correct practice Referenced Documentation:
* Forescout RADIUS Plugin Configuration Guide v4.3 - Sub-Rules section
* Defining Forescout Platform Policy Sub-Rules
* Sub-Rule Advanced Options
NEW QUESTION # 36
What Protocol does CounterACT use to verify the revocation status of certificates?
  • A. Online Certificate Status Protocol (OCSP)
  • B. Certificate Revocation List Protocol (CRLP)
  • C. Online Revocation Status Protocol (ORSP)
  • D. Certificate Revocation Protocol (CRP)
  • E. PKI Certificate Revocation Protocol (PCRP)
According to the Forescout Platform Administration Guide and Certificate Configuration documentation, Forescout uses the Online Certificate Status Protocol (OCSP) to verify the revocation status of certificates.
OCSP in Forescout:
According to the official Forescout documentation:
"You can also configure the use of Online Certificate Status Protocol (OCSP) and set up validation method failover between CRL and OCSP." And further:
"The Forescout Platform supports certificate revocation lists (CRL) and Online Certificate Status Protocol (OCSP) for smart card authentication." What OCSP Does:
According to the Wikipedia and Fortinet OCSP documentation:
"The Online Certificate Status Protocol (OCSP) is an Internet protocol used for obtaining the revocation status of an X.509 digital certificate." OCSP provides:
* Real-Time Status Verification - Checks current certificate revocation status
* Request/Response Protocol - Sends a query to an OCSP responder
* Revocation Status Response - Returns "good," "revoked," or "unknown"
* Efficient Alternative to CRL - Smaller data payload than downloading full certificate revocation lists How OCSP Works:
According to the OCSP documentation:
* Request Sent - Client sends OCSP request to OCSP responder (server operated by CA)
* Status Verification - Responder checks revocation status with trusted CA
* Response Returned - Responder returns current status, revoked, or unknown
* Decision Made - Application (like Forescout) accepts or rejects the certificate based on response Forescout Smart Card Certificate Validation:
According to the Forescout documentation:
When using smart card authentication, Forescout:
* Supports OCSP - Sends OCSP requests for certificate revocation status
* Supports CRL - Also supports Certificate Revocation Lists as fallback
* Failover Configuration - Can be configured to use OCSP with CRL fallback OCSP vs. Certificate Revocation List (CRL):
Aspect
OCSP
CRL
Data Size
Smaller response
Larger list
Update Frequency
Real-time status
Periodic updates
Network Load
Lower burden
Higher burden
Timeliness
Current status
Potentially outdated
Processing
Less complex
More complex parsing
Forescout uses OCSP because it provides real-time, efficient certificate status verification.
* A. PKI Certificate Revocation Protocol (PCRP) - This is not a standard protocol; PCRP does not exist
* C. Online Revocation Status Protocol (ORSP) - This is not the correct name; the protocol is OCSP, not ORSP
* D. Certificate Revocation List Protocol (CRLP) - While Forescout supports CRL, the primary protocol for real-time status is OCSP
* E. Certificate Revocation Protocol (CRP) - This is not a standard protocol; the correct protocol is OCSP Referenced Documentation:
* Smart Card Certificate Configuration for Forescout Platform
* Using Forescout Platform Smart Card Authentication
* Client-Server Connection documentation
* Audit Actions - OCSP for Syslog validation
* Online Certificate Status Protocol (OCSP) - Wikipedia
* What Is Online Certificate Status Protocol (OCSP) - Fortinet
NEW QUESTION # 37
The Forescout FSCP exam practice questions are being offered in three different formats. These formats are Forescout FSCP web-based practice test software, desktop practice test software, and PDF dumps files. All these three Forescout FSCP exam questions format are important and play a crucial role in your Forescout Certified Professional Exam (FSCP) exam preparation. With the Forescout FSCP exam questions you will get updated and error-free Forescout Certified Professional Exam (FSCP) exam questions all the time. In this way, you cannot miss a single FSCP exam question without an answer.
FSCP Reliable Exam Cram: https://www.testkingit.com/Forescout/latest-FSCP-exam-dumps.html
Forescout FSCP Valid Practice Questions Money Back Guarantee and 24/7 Customer Care, Forescout FSCP Valid Practice Questions 100% efficient customer support, When you are not trust our FSCP Forescout Certified Professional Exam latest exam cram or have some doubts, you can try the Forescout Certified Professional Exam free download demo and assess whether our exam dumps deserve trust or not, We provide high quality and high reliable date for FSCP certification training.
EB: Like everyone else, I have an iPhone game FSCP in the works as a hobby project, Taylor holds a Master's degree in IndustrialTechnology with a concentration in Computer FSCP Reliable Exam Cram Network Management from East Carolina University in Greenville, North Carolina.
Avail Marvelous FSCP Valid Practice Questions to Pass FSCP on the First AttemptMoney Back Guarantee and 24/7 Customer Care, 100% efficient customer support, When you are not trust our FSCP Forescout Certified Professional Exam latestexam cram or have some doubts, you can try the FSCP Reliable Exam Cram Forescout Certified Professional Exam free download demo and assess whether our exam dumps deserve trust or not.
We provide high quality and high reliable date for FSCP certification training, How TestKingIT Saves Your Time.
DOWNLOAD the newest TestKingIT FSCP PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1-NIj0lQ5Nt-ptsP-Fwc3johQH9Ws1rlS
