[General] 300-425 Valid Test Format & Actual 300-425 Tests
99
General 300-425 Valid Test Format & Actual 300-425 Tests
Posted at 2/14/2026 16:32:59      View108 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Exams4sures 300-425 dumps for free: https://drive.google.com/open?id=1g2SLzWg46frzvfC86hzhbcrLpIe7lzRG
However, how can you get the 300-425 certification successfully in the shortest time? We also know you cant spend your all time on preparing for your exam, so it is very difficult for you to get the certification in a short time. Dont worry; 300-425 question torrent is willing to help you solve your problem. We have compiled such a 300-425 Guide torrents that can help you pass the exam easily, it has higher pass rate and higher quality than other study materials. So, are you ready? Buy our 300-425 guide questions; it will not let you down.
Cisco 300-425 Exam covers a variety of topics related to wireless network design and implementation, including site surveys, network topology, security, and troubleshooting. Successful candidates must demonstrate a deep understanding of wireless network technologies, such as 802.11 standards, RF technology, and antenna types. They must also have a strong grasp of network design principles, such as scalability, high availability, and redundancy.
Actual 300-425 Tests & 300-425 Latest Test QuestionsA good 300-425 certification must be supported by a good 300-425 exam practice, which will greatly improve your learning ability and effectiveness. Our study materials have the advantage of short time, high speed and high pass rate. You only take 20 to 30 hours to practice our 300-425 Guide materials and then you can take the exam. If you use our study materials, you can get the 300-425 certification by spending very little time and energy reviewing and preparing.
More Details for Exam 300-425Candidates looking forward to 300-425 have to hold skills which come by thoroughly exploring the aspect of developing wireless networks. Topics to venture into include site surveys, wireless in addition to wired architecture, high availability for wireless LAN, and mobility. Proving abilities in these areas is through a test lasting for 1.5 hours and presented in the English language and Japanese. Professional concentration tests like 300-425 go for $300. About the passing score, Cisco does not state the minimum points to get for one to be accredited. But it is always good to strive to get very high marks and promote your chances of passing. Revision guides and training serve the great purpose of assisting exam-takers to build appropriate knowledge around the stated topics.
Cisco Designing Cisco Enterprise Wireless Networks Sample Questions (Q110-Q115):NEW QUESTION # 110
An engineer working for an enterprise deployed multiple Cisco WLCs. A controller that sits in the R&D division is connected through a firewall and is part of the same mobility group. The engineer must ensure that the mobility tunneling is available through the firewall and test it as R&D engineers roam the production ..within their department. How is this requirement met?
  • A. mapping on UDP port 16666 and mapping on Protocol 96 between management ports
  • B. mapping on UDP port 16667 and mapping on Protocol 96 between management ports
  • C. mapping on UDP port 16666 and mapping on Protocol 97 between management ports
  • D. mapping on UDP port 16667 and mapping on Protocol 97 between management ports
For mobility tunneling through a firewall in a Cisco wireless network environment, UDP port 16666 must be open along with IP Protocol number '97', which is used for Encapsulating Security Payload (ESP) traffic typically found in IPsec tunnels. By ensuring these ports are mapped correctly through the firewall, R&D engineers can roam within their department while maintaining a secure mobility tunnel. Reference := (CCNP Enterprise Wireless Design ENWLSD 300-425 and Implementation ENWLSI 300-430 Official Cert Guide Premium Edition and Practice)
NEW QUESTION # 111
An engineer is working for an enterprise and deployed a Cisco 9800 Series Wireless Controller. The wireless infrastructure serves the employees and guest users across the company. The engineer must configure the controller to alleviate the sticky client issue in the deployment. Which action resolves the issue?
  • A. Enable 802.11k.
  • B. Enable data RSSI to -90db.
  • C. Enable CHDM.
  • D. Enable Optimize Roaming.
The sticky client issue occurs when a wireless client device clings to a suboptimal access point instead of roaming to a better one with a stronger signal. Enabling Optimize Roaming on the Cisco 9800 Series Wireless Controller can alleviate this issue. This feature prompts clients to roam by disassociating them when their signal strength drops below a threshold, encouraging them to seek a better connection.
NEW QUESTION # 112
A network engineer has identified that during a recent controller failure, several APs failed over to the tertiary controller instead of the secondary controller. The configuration from one of the APs is provided. Which design consideration led to the issue?
  • A. The tertiary controller is in the same subnet as the primary controller.
  • B. The secondary controller is an SSO configuration.
  • C. The tertiary controller is an HA-SKU controller, so it took priority.
  • D. The secondary controller was at capacity.
The issue where APs failed over to the tertiary controller instead of the secondary controller during a controller failure is likely due to the secondary controller being at capacity. When a controller reaches its maximum capacity, it cannot accept any additional APs, causing them to failover to the next available controller in the high availability configuration.
NEW QUESTION # 113
An engineer has been tasked with optimizing roaming for all the wireless networks used by shops located in a shopping center. A unique WLAN is assigned to each individual shop named ret470632970B55XX, where the last two digits indicate the shop's location. The wireless network consists of 9800 controllers and Cisco 9100 APs. What should the engineer configure on the controllers to optimize roaming?
  • A. enable AES encryption
  • B. create an interface per shop
  • C. disable the 802.11a/b network
  • D. assign access rules based on location
NEW QUESTION # 114
A school deploys a Cisco wireless infrastructure in its classrooms to support a high density of mobile devices. The network administrator wants to bond channels in groups of two and only allow APs to send 802.11 management frames at 24 MB. What should be included in the design to accomplish this objective?
  • A. Set the channel width for 802.11b to 40 MHz and set data rates to 24 MB and Mandatory.
  • B. Set the channel width for 802.11a to 40 MHz and set data rates to 24 MB and Supported.
  • C. Set the channel width for 802.11b to 40 MHz and set data rates to 24 MB and Supported.
  • D. Set the channel width for 802.11a to 40 MHz and set data rates to 24 MB and Mandatory.
To support a high density of mobile devices and bond channels in groups of two, the channel width for 802.11a should be set to 40 MHz. Setting the data rates to 24 MB and Mandatory ensures that only APs can send 802.11 management frames at this rate, which helps in managing the airtime fairness. Reference: CCNP Enterprise Wireless Design ENWLSD 300-425 and Implementation ENWLSI 300-430 Official Cert Guide.
NEW QUESTION # 115
Actual 300-425 Tests: https://www.exams4sures.com/Cisco/300-425-practice-exam-dumps.html
