Testking Juniper JN0-351 Exam Questions & JN0-351 Exam Online
108
Posted at 2/14/2026 17:47:48      View:115 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New JN0-351 dumps are available on Google Drive shared by DumpsTorrent: https://drive.google.com/open?id=1vZ6SikkWN95y3Ka3togoVmjqbjLkGrkJ
If you buy our Software version of the JN0-351 study questions, you can enjoy the similar real exam environment for that this version has the advantage of simulating the real exam. In addition, the software version of our JN0-351 learning guide is not limited to the number of the computer. As long as you use it on the Windows system, then you can enjoy the convenience of this version brings. So do not hesitate and buy our Software version of JN0-351 Preparation exam, you will benefit a lot from it.
We all realize that how important an JNCIS-ENT certification is, also understand the importance of having a good knowledge of it. Passing the JN0-351 exam means you might get the chance of higher salary, greater social state and satisfying promotion chance. Once your professional ability is acknowledged by authority, you master the rapidly developing information technology. With so many advantages, why don’t you choose our reliable JN0-351 Actual Exam guide, for broader future and better life? Our JN0-351 exam questions won't let you down.
JN0-351 Exam Online - JN0-351 Reliable Exam AnswersTo get all these benefits you must have to pass the Enterprise Routing and Switching, Specialist (JNCIS-ENT) (JN0-351) certification exam which is not an easy task. It is a difficult task but you can make DumpsTorrent simple and quick. To do this you just visit Exams. Solutions provide updated, valid, and actual JN0-351 Exam Dumps that will assist you in Enterprise Routing and Switching, Specialist (JNCIS-ENT) (JN0-351) exam preparation and you can easily get success in this challenging Enterprise Routing and Switching, Specialist (JNCIS-ENT) exam with flying colors.
Juniper JN0-351 Exam Syllabus Topics:
  • IS-IS: Aspiring Juniper networking professionals enhance their understanding of IS-IS routing protocols. This topic equips candidates with the knowledge to configure and monitor IS-IS systems, addressing specific exam challenges and practical applications.
  • Tunnels: The fundamentals of IP tunneling are emphasized, highlighting their requirements and functionalities. Mastery in configuring, monitoring, and troubleshooting tunnels equips professionals to meet the demands of the JN0-351 exam.
  • BGP: This topic focuses on the operational and conceptual elements of BGP, a cornerstone in enterprise networks.
  • Protocol Independent Routing: An essential domain for understanding routing components outside protocol dependencies, this topic enhances expertise in configuring, monitoring, and troubleshooting critical elements.
Topic 5
  • High Availability: This topic covers the importance and application of high availability within Junos OS environments. Knowledge in configuring and managing these components is critical for ensuring robust and uninterrupted network operations, aligning with exam expectations.
Juniper Enterprise Routing and Switching, Specialist (JNCIS-ENT) Sample Questions (Q83-Q88):NEW QUESTION # 83
You have DHCP snooping enabled but no entries are automatically created in the snooping database for an interface on your EX Series switch. What are two reasons for the problem?
(Choose two.)
  • A. The device that is connected to the interface has performed a DHCPRELEASE.
  • B. Dynamic ARP inspection is enabled on the interface.
  • C. MAC limiting is enabled on the interface.
  • D. The device that is connected to the interface has a static IP address.
If the device connected to the interface has performed a DHCPRELEASE, it releases its IP address back to the DHCP server, resulting in the removal of the corresponding DHCP snooping entry.
If the device connected to the interface is using a static IP address, it will not send DHCP requests, and therefore no entries will be created in the DHCP snooping database for that device.
NEW QUESTION # 84
Which two elements are used to create the STP bridge ID? (Choose two.)
  • A. the root port number
  • B. the system MAC address
  • C. the bridge priority value
  • D. the port cost
NEW QUESTION # 85
You are asked to configure a redundant trunk group (RTG). Which two requirements would accomplish this task? (Choose two.)
  • A. Interfaces within an RTG must be configured as trunk ports.
  • B. Interfaces within an RTG can be configured as access ports.
  • C. Both interfaces of an RTG must be configured to service the same VLANS.
  • D. The RTG must be participating in a Spanning Tree topology.
NEW QUESTION # 86
You are a network operator troubleshooting BGP connectivity.
Which two statements are correct about the output shown in the exhibit? (Choose two.)
  • A. The BGP session is not established.
  • B. Peer 10.32.1.2 is configured for AS 63645.
  • C. The routers are exchanging IPv4 routes.
  • D. The R1 is configured for AS 65400.
The local AS is 65400, as indicated by "Local AS: 65400".
The output shows "NLRI for this session: inet-unicast", which indicates that the routers are exchanging IPv4 unicast routes.
NEW QUESTION # 87
You are attempting to configure the initial two aggregated Ethernet interfaces on a router but there are no aggregated Ethernet interfaces available.
In this scenario, which configuration will enable these interfaces on this router?
  • A.
  • B.
  • C.
  • D.
The correct answer to your question is
Option C shows the configuration of the   statement, which defines the properties of the router chassis, such as the number of aggregated Ethernet interfaces, the number of FPCs, and the number of PICs1.
To enable aggregated Ethernet interfaces on a router, you need to specify the aggregated-devices statement under the chassis   parameter to the desired number of interfaces2. For example, to enable two aggregated Ethernet interfaces, you can use the following configuration:
chassis { aggregated-devices { ethernet { device-count 2; } } }
Option C shows this configuration with the device-count set to 2, which will enable two aggregated Ethernet interfaces on the router. The other options do not show this configuration and will not enable any aggregated Ethernet interfaces on the router.
Therefore, option C is the correct answer to your question.
NEW QUESTION # 88
All the DumpsTorrent Juniper JN0-351 practice questions are real and based on actual Enterprise Routing and Switching, Specialist (JNCIS-ENT) (JN0-351) exam topics. The web-based Enterprise Routing and Switching, Specialist (JNCIS-ENT) (JN0-351) practice test is compatible with all operating systems like Mac, IOS, Android, and Windows. Because of its browser-based Juniper JN0-351 Practice Exam, it requires no installation to proceed further. Similarly, Chrome, IE, Firefox, Opera, Safari, and all the major browsers support the Enterprise Routing and Switching, Specialist (JNCIS-ENT) (JN0-351) practice test.
JN0-351 Exam Online: https://www.dumpstorrent.com/JN0-351-exam-dumps-torrent.html
Posted at 2/18/2026 06:58:01        Only Author  2#
Ob man in einem bestimmten Bereich den Erfolg macht, spiegelt an Ihren Zertifizierungen, sowie in IT-Industrie. Deshalb wollen viele Leute an Salesforce Mule-Arch-201 Zertifizierungsprüfungen teilnehmen, um Ihre selbe Fähigkeit zu beweisen. Und es ist nicht einfach, Salesforce Mule-Arch-201 Zertifizierung zu bekommen. Aber wenn sie den kürzeren Weg finden, können Sie die Mule-Arch-201 Prüfung leicht bestehen. So wollen Wir Ihnen ZertPruefung Dumps empfehlen. Es kann Ihnen helfen, weniger Zeit zu verwenden und die Mule-Arch-201 Prüfung zu bestehen.
Posted at 3/8/2026 10:29:58        Only Author  3#
This article is outstanding in every way, thank you for sharing. Free Valid study questions C-THR70-2505 free download to help you enhance your IT expertise. Best of luck on your exams!
