[General] 1z0-1046-25 Free Pdf Guide - 1z0-1046-25 Test Sample Online
108
【General】 1z0-1046-25 Free Pdf Guide - 1z0-1046-25 Test Sample Online
Posted at 2/14/2026 18:21:48      View:101 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4suresVCE 1z0-1046-25 dumps from Cloud Storage: https://drive.google.com/open?id=166DSOQh9kb7Gpvm5-W04jJADAidcZVJj
Our 1z0-1046-25 learning materials will aim at helping every people fight for the 1z0-1046-25 certificate and help develop new skills. If we want to survive in this competitive world, we need a comprehensive development plan to adapt to the requirement of modern enterprises. We sincerely recommend our 1z0-1046-25 Preparation exam for our years' dedication and quality assurance will give you a helping hand. You can just free download the free demo of our 1z0-1046-25 study materials to know how excellent our 1z0-1046-25 exam questions are.
We will provide you with professional advice before you buy our 1z0-1046-25 guide materials. If you have problems in the process of using our 1z0-1046-25 study questions, as long as you contact us anytime and anywhere, we will provide you with remote assistance until that all the problems on our 1z0-1046-25 Exam Braindumps are solved. When you send us a message, we will reply immediately and we will never waste your precious time on studying our 1z0-1046-25 practice quiz.
1z0-1046-25 Test Sample Online & Latest 1z0-1046-25 Dumps EbookDo not miss the opportunity to buy the best 1z0-1046-25 preparation questions in the international market which will also help you to advance with the times. If you are still worrying about our 1z0-1046-25 exam questions, I would like to help you out with the free demos of our 1z0-1046-25 Training Materials compiled by our company. There are so many strong points of our 1z0-1046-25 training materials, such as wide applicability, sharpen the saw and responsible after sale service to name.
Oracle Global Human Resources Cloud 2025 Implementation Professional Sample Questions (Q89-Q94):NEW QUESTION # 89
As an implementation consultant, you have configured several rules in Transaction Design Studio within the test environment. How do you migrate these changes to your production environment?
  • A. Use the Configuration Package capabilities of Functional Setup Manager to export the configurations
  • B. Use the Configuration Package capabilities within the Configuration > Migration work area
  • C. Transaction Design Studio changes can't be migrated from one instance to another. You will need to reconfigure the transactions within your production environment
  • D. Use the Configuration Set Migration tool within the Configuration > Migration work area
Transaction Design Studio (TDS) customizations, such as rules for transactions, are migrated using the Configuration Set Migration tool, as per the "Implementing Global Human Resources" guide. Located in the Configuration > Migration work area, this tool allows export and import of TDS configurations between environments (e.g., test to production). Option A refers to a broader migration capability, not specific to TDS.
Option B (Functional Setup Manager) is for setup data, not TDS rules. Option C is incorrect, as migration is supported. Thus, Option D is correct.
Reference:Oracle Global Human Resources Cloud - Implementing Global Human Resources, "Migrating Transaction Design Studio Configurations" topic.
NEW QUESTION # 90
A consultant is trying to modify an existing lookup type to add a lookup code. But, they are not able to add lookup code.
What could be the possible reason?
  • A. The configuration level of lookup type is set as User.
  • B. The configuration level of lookup type is set as System.
  • C. The lookup type has been defined as Read Only.
In Oracle Global Human Resources Cloud, lookup types are used to define lists of values (lookup codes) for fields, such as drop-down menus or selection lists. The question indicates that a consultant cannot add a lookup code to an existing lookup type, and we need to identify the reason. Lookup types have a configuration level that determines their modifiability: System, Extensible, or User.
* Option A: The lookup type has been defined as Read Only.This option is incorrect because Oracle HCM Cloud does not use a Read Only designation for lookup types. Instead, modifiability is controlled by the Configuration Level (System, Extensible, or User). A System lookup type is non-editable, an Extensible lookup type allows adding new codes but not modifying predefined ones, and a User lookup type is fully editable. The term Read Only may be confused with System lookup types, but it is not a standard term in Oracle documentation for this context, making this option invalid.
* Option B: The configuration level of lookup type is set as System.This is the correct answer. Lookup types with a System configuration level are predefined by Oracle and cannot be modified by users, including adding, editing, or deleting lookup codes. For example, a lookup type like PER_PERSON_TYPE (for person types) is set as System, preventing consultants from adding new codes to maintain system integrity. If the consultant is trying to modify such a lookup type, they will be unable to add a lookup code, as the system restricts changes. Oracle documentation confirms that System lookup types are locked for modifications, making this the most likely reason.
* Option C: The configuration level of lookup type is set as User.This option is incorrect. A lookup type with a User configuration level is fully editable, allowing users to add, edit, or delete lookup codes as needed. For instance, a custom lookup type created for department categories would typically be User level, enabling the consultant to add new codes freely. Since the consultant cannot add a lookup code, a User configuration level does not explain the issue.
* Why this reason?The inability to add a lookup code points to a restriction on the lookup type's modifiability. The System configuration level explicitly prevents changes to ensure consistency across the application, aligning with Oracle's design for predefined lookup types. Neither Read Only nor User accurately describes the restriction, as Read Only is not a valid term, and User allows modifications.
References
* Oracle Global Human Resources Cloud: Implementing Global Human Resources, Document ID:
docs.oracle.com, Published: 2023-12-12
* Section: Lookups: "System lookup types are predefined and can't be modified. Extensible lookup types let you add new lookup codes, but you can't modify predefined codes. User lookup types are fully editable."
* Oracle Global Human Resources Cloud: Using Global Human Resources, Document ID: docs.
oracle.com, Published: 2024-07-02
* Section: Manage Lookups: "You manage lookups using the Manage Common Lookups task. The configuration level determines whether you can add or modify lookup codes."
* Oracle Fusion Cloud Human Resources 24C What's New, Document ID: docs.oracle.com, Published: 2024-08-27
* Section: Configuration Enhancements: "Clarifications on lookup type management and restrictions."
NEW QUESTION # 91
An organization is running a fitness program. They want to identify a Fitness Representative who will be responsible for a group of people in the organization. How should you set this up?
  • A. Define the person's area of responsibility to reflect Fitness Representative.
  • B. Deploy a Key Flexfield to capture the information.
  • C. Deploy a Descriptive Flexfield to capture the information.
  • D. Create a new job Fitness Representative and associate that to the person.
Full Detailed in Depth Explanation:
Oracle HCM Cloud allows assigning responsibilities to individuals for specific tasks or groups, such as a Fitness Representative for a fitness program. The setup should leverage existing functionality efficiently.
Option D ("Define the person's area of responsibility to reflect Fitness Representative") is correct. In Oracle HCM, "Areas of Responsibility" (AOR) can be defined via the "Manage Areas of Responsibility" task to assign specific duties (e.g., Fitness Representative) to a person for a group of workers. This is a standard feature for designating responsibilities without requiring new jobs or flexfields, as outlined in the
Option A ("Deploy a Key Flexfield to capture the information") is incorrect. Key Flexfields (KFFs) are used for structured data (e.g., job codes), not responsibilities.
Option B ("Deploy a Descriptive Flexfield to capture the information") could work for custom attributes but is overkill when AOR is available.
Option C ("Create a new job Fitness Representative and associate that to the person") is unnecessary; a job defines a role, not a specific responsibility for a program.
"Oracle Global Human Resources Cloud: Implementing Global Human Resources" - Section on Areas of Responsibility.
"Oracle Human Resources Cloud: Using Global Human Resources" - Managing responsibilities.
NEW QUESTION # 92
Which new feature has been added to the Redwood Grade Rates page to enhance the search and filtering capabilities?
  • A. Option to add custom columns to the grade rate table
  • B. Capability to search and filter grade rate values by name, code, and set
  • C. A function to compare grade rates across different locations
The Redwood Grade Rates page in Oracle Global Human Resources Cloud has been enhanced to improve usability, particularly in searching and filtering grade rate data. The question asks for the new feature added to enhance search and filtering capabilities. Oracle's 24C release notes highlight specific improvements to the Redwood interface for grade rates, focusing on streamlined data retrieval.
Option A: Capability to search and filter grade rate values by name, code, and set This is the correct answer. According to Oracle's 24C release notes, the Redwood Grade Rates page now includes advanced search and filtering capabilities, allowing users to search and filter grade rates by attributes such as name, code, and set. This enhancement enables HR specialists to quickly locate specific grade rates, for example, filtering by a grade rate name like "Salary Grade 1" or a set code tied to a legislative data group.
The feature improves efficiency in managing compensation data, especially in organizations with extensive grade structures, and is explicitly documented as a new Redwood functionality.
Option B: Option to add custom columns to the grade rate table
This option is incorrect. Oracle documentation, including 24C and 25A release notes, does not mention the ability to add custom columns to the grade rate table as a new feature on the Redwood Grade Rates page.
While Oracle supports flexfields for customization in other areas, there is no evidence that this specific capability was introduced for grade rates. The focus of Redwood enhancements is on search, filtering, and UI improvements, not custom column additions.
Option C: A function to compare grade rates across different locations
This option is incorrect. There is no documented feature in the 24C or 25A releases that enables comparing grade rates across different locations on the Redwood Grade Rates page. While Oracle HCM Cloud supports location-based configurations (e.g., for payroll or local regulations), the Redwood Grade Rates page enhancements center on search and filter improvements, not comparative analysis across locations. This functionality would require custom reporting or analytics, not a standard page feature.
Why this feature?
The capability to search and filter by name, code, and set directly addresses the need for enhanced search and filtering, making it easier to manage grade rates in a user-friendly Redwood interface. This aligns with Oracle' s focus on improving data accessibility and usability in the 24C release.
References
08-27
Section: Redwood Experience for Grade Rates Page: "You can now easily search and filter grade rate values by name, code, and set on the Grade Rates page." Oracle Global Human Resources Cloud: Using Global Human Resources, Document ID: docs.oracle.com, Published: 2024-07-02 Section: Grade Rates Management: "Describes how grade rates are managed, including searching and filtering capabilities." Oracle Global Human Resources Cloud: Implementing Global Human Resources, Document ID: docs.oracle.
Section: Grade Rates Configuration: "Details on configuring and accessing grade rates, including set-based assignments."
NEW QUESTION # 93
A Human Resource Representative is in the process of transferring an employee from France Subsidiary to US Subsidiary and exercises the option of Global Transfer. Identify the three options for the Global Transfer process. (Choose three.)
  • A. The existing set of employment terms and assignments in the source work relationship are terminated and their status is set to Inactive - Payroll Eligible by default.
  • B. The Human Resources Representative can override the default by deselecting the assignments that are not required to be terminated; these assignments retain their original status and the work relationship is not terminated.
  • C. A new work relationship in the destination legal employer is created automatically.
  • D. The Human Resources Representative cannot override the default changes.
  • E. A new work relationship in the destination legal employer is not created automatically.
Answer: A,B,C
The Global Transfer feature in Oracle HCM Cloud facilitates moving an employee between legal employers within the same enterprise, such as from France Subsidiary to US Subsidiary.
Option C ("The Human Resources Representative can override the default by deselecting the assignments that are not required to be terminated; these assignments retain their original status and the work relationship is not terminated"): True. During a Global Transfer, the HR representative can choose which assignments to terminate or retain, overriding defaults, as explained in the "Using Global Human Resources" guide.
Option D ("The existing set of employment terms and assignments in the source work relationship are terminated and their status is set to Inactive - Payroll Eligible by default"): True. By default, the source work relationship's assignments are terminated and marked Inactive - Payroll Eligible, preserving payroll history, per standard Oracle behavior.
Option E ("A new work relationship in the destination legal employer is created automatically"): True. A Global Transfer automatically creates a new work relationship in the destination legal employer, effective from the transfer date.
Option A ("A new work relationship in the destination legal employer is not created automatically"): False.
This contradicts the automated nature of Global Transfer.
Option B ("The Human Resources Representative cannot override the default changes"): False. Overrides are allowed, as noted in Option C.
"Oracle Human Resources Cloud: Using Global Human Resources" - Global Transfer process details.
"Oracle Global Human Resources Cloud: Implementing Global Human Resources" - Employment model changes.
NEW QUESTION # 94
Pass4suresVCE is unlike other exam materials that are available on the market, 1z0-1046-25 study torrent specially proposed different versions to allow you to learn not only on paper, but also to use mobile phones to learn. You can choose the version of 1z0-1046-25 training guide according to your interests and habits. And if you buy the value pack, you have all of the three versions, the price is quite preferential and you can enjoy all of the study experiences. This means you can study 1z0-1046-25 Exam Engine anytime and anyplace for the convenience these three versions bring.
1z0-1046-25 Test Sample Online: https://www.pass4suresvce.com/1z0-1046-25-pass4sure-vce-dumps.html
Our website offers you the latest preparation materials for the 1z0-1046-25 real exam and the study guide for your review, Our Pass4suresVCE can have a good and quick provide of professional study materials about Oracle certification 1z0-1046-25 exam, We have designed the perfect 1z0-1046-25 dumps PDF in a systematic and organized manner which help the candidate to utilize their time in the best possible way, Oracle 1z0-1046-25 Free Pdf Guide Thinking that if you got the certificate, you can get a higher salary, and you’re your position in the company will also in a higher level.
Kernel information, process control, Momentum takes time to build, Our website offers you the latest preparation materials for the 1z0-1046-25 Real Exam and the study guide for your review.
Our Pass4suresVCE can have a good and quick provide of professional study materials about Oracle certification 1z0-1046-25 exam, We have designed the perfect 1z0-1046-25 dumps PDF in a systematic and organized manner which help the candidate to utilize their time in the best possible way.
Hot 1z0-1046-25 Free Pdf Guide | High-quality Oracle 1z0-1046-25 Test Sample Online: Oracle Global Human Resources Cloud 2025 Implementation ProfessionalThinking that if you got the certificate, you 1z0-1046-25 can get a higher salary, and you’re your position in the company will also in a higher level, We strive to use the simplest language to make the learners understand our 1z0-1046-25 exam reference and passed the 1z0-1046-25 exam.
