Salesforce Platform-App-Builder Preparation - New Platform-App-Builder Test Boot
103
Posted at 2/14/2026 19:27:25      View134 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Pass4training Platform-App-Builder dumps for free: https://drive.google.com/open?id=1Yjb4X1VKQ67UgzWpxHJQhnzlmbriYtb7
You can invest safely spend your money to get Platform-App-Builder exam preparation products with as we provide money back guarantee. If you won't pass the actual Platform-App-Builder exam, after using the Pass4training practice test or PDF questions and answers booklet useful for preparing the Platform-App-Builder exam version, you can get the money back. We offer a free trial also, so that you can check the quality and working of Platform-App-Builder Exam Practice test software. In case, you have prepared the Platform-App-Builder exam with our products and did not pass the exam we will reimburse your money.
By overcoming your mistakes before the actual Salesforce Platform-App-Builder exam, you can avoid making those same errors during the Salesforce Certified Platform App Builder (Platform-App-Builder) real test. With customizable Platform-App-Builder practice tests, you can adjust the duration and quantity of Platform-App-Builder Practice Questions. This self-assessment Platform-App-Builder exam display your marks, helping you improve your performance while tracking your progress.
How do Pass4training Salesforce Platform-App-Builder Exam Questions Help You in Exam Preparation?Starting from our Platform-App-Builder practice materials will make a solid foundation for your exam definitively. Do not satisfied with using shortcuts during your process, regular practice with our Platform-App-Builder exam prep will be easy. Tens of thousands of people has achieved success with our Platform-App-Builderstudy questions, you can absolutely do it. And you will find that passing the Platform-App-Builder exam is as easy as pie.
Salesforce Certified Platform App Builder Sample Questions (Q102-Q107):NEW QUESTION # 102
What option is available to an App Builder when defining an object-specific Create Record custom action?
Choose 2 answers
  • A. Pre-Defining field values on the target object.
  • B. Redirecting the end user to the detail page of the target object
  • C. Allowing the end user to choose the record type
  • D. Specifying the fields and layout of the action.
NEW QUESTION # 103
Which two rules can be configured for the Opportunity object?
  • A. Escalation Rule
  • B. Validation Rule
  • C. Workflow Rule
  • D. Assignment Rule
NEW QUESTION # 104
Shipments at Cloud Kicks (CK) are created and updated by the warehouse staff in a shipping application. The Information needs to be pushed into Salesforce on a regular basis. CK's app builder creates a custom object called Delivery_c to track the information.
How can the app builder prevent creating duplicate delivery records and update the correct existing records when migrating data from the shipping application?
  • A. Use the Import Wizard and match on the tracking number.
  • B. Use the Import Wizard and match on the Salesforce ID.
  • C. Create a unique External ID field and use Dataloader.
  • D. Create a duplicate match rule and use Dataloader.
Creating a unique External ID field on the custom object and using Data Loader to upsert records prevents duplicates and ensures correct record updates by matching the unique ID. Reference:
Salesforce Help - External ID
NEW QUESTION # 105
Universal containers wants to ensure that they are accepting clean data from their users and verify that important fields are entered. What should an app builder recommend to meet this requirement?
  • A. Create a workflow rule to check the fields are formatted correctly
  • B. Make a formula field to check the format of the important fields
  • C. Configure a validation to require a field for a specific record type
  • D. Update the important fields to be required on the page layout
Configuring a validation rule to require a field for a specific record type is the best way to ensure that important fields are entered and formatted correctly. Updating the important fields to be required on the page layout will not prevent users from entering invalid data using other methods, such as data loader or quick actions. Making a formula field to check the format of the important fields will not prevent users from entering invalid data, but only display a message or an indicator. Creating a workflow rule to check the fields are formatted correctly will not prevent users from entering invalid data, but only trigger an action after the data is saved.
NEW QUESTION # 106
After universal containers converted qualified leads. Sales reps need to be able to report on converted leads.
How should an app builder support for this requirement?
  • A. Ensure the representative has read access to the original lead records
  • B. Create a custom report type with converted leads as the primary object
  • C. Assign the representative view and edit converted leads permission
  • D. Enable preserve lead status in the lead conversion settings
The solution that an app builder should use to meet this requirement is creating a custom report type with converted leads as the primary object. A custom report type is a template that defines the objects and fields that are available for a report. The app builder can create a custom report type that has converted leads as the primary object and includes fields from related objects, such as accounts, contacts, and opportunities. This way, sales reps can create reports on converted leads and see their related information. Option A is incorrect because enabling preserve lead status in the lead conversion settings does not affect the reporting on converted leads, but rather allows users to retain the original lead status after conversion. Option B is incorrect because assigning the representative view and edit converted leads permission does not affect the reporting on converted leads, but rather allows users to view and edit converted lead records. Option C is incorrect because ensuring the representative has read access to the original lead records does not affect the reporting on converted leads, but rather allows users to view the original lead records.
NEW QUESTION # 107
You only need 20-30 hours to learn Salesforce Certified Platform App Builder exam torrent and prepare the exam. Many people, especially the in-service staff, are busy in their jobs, learning, family lives and other important things and have little time and energy to learn and prepare the exam. But if you buy our Platform-App-Builder Test Torrent, you can invest your main energy on your most important thing and spare 1-2 hours each day to learn and prepare the exam. Our questions and answers are based on the real exam and conform to the popular trend in the industry.
New Platform-App-Builder Test Bootcamp: https://www.pass4training.com/Platform-App-Builder-pass-exam-training.html
Salesforce Platform-App-Builder Preparation We can make it with common effort, Platform-App-Builder examkiller valid study dumps will help you master all the topics on the Salesforce Platform-App-Builder actual test, In addition, you will easily pass the exam with the help of our Platform-App-Builder exam quiz material, Salesforce Platform-App-Builder Preparation In addition, the online mock test is supported by all browsers, In addition, as for the Platform-App-Builder PDF torrent you are able to print all the contents which are benefit for your notes.
The product of Pass4training is designed by professionals and is regularly Platform-App-Builder updated to reflect the latest changes in the content, Debt was incurred to deal with the pressure of keeping up with rising prices.
High Hit-Rate Salesforce - Platform-App-Builder PreparationWe can make it with common effort, Platform-App-Builder examkiller valid study dumps will help you master all the topics on the Salesforce Platform-App-Builder actual test, In addition, you will easily pass the exam with the help of our Platform-App-Builder exam quiz material.
P.S. Free & New Platform-App-Builder dumps are available on Google Drive shared by Pass4training: https://drive.google.com/open?id=1Yjb4X1VKQ67UgzWpxHJQhnzlmbriYtb7
Posted at 2/23/2026 00:12:41        Only Author  2#
This article is truly magnificent, thank you for sharing your knowledge. Wish me all the success I can get for the PRINCE2-Foundation accurate study material exam!
